Cool...That's right -- KDE version 4.1 is now part of Slackware -current (in the /testing directory), so for everyone who can't wait to try it out, have a look at it! We're all (very happily) using it here now, and it has come a long way since the first 4.x release. Congratulations to the KDE team for the fine work (and many thanks to Robby Workman and Heinz Wiesinger for all the help with build scripts and testing for the initial Slackware packaging of KDE4). Have fun! :-)
KDE 4.x u narednom Slackware-u mozda kao i default
Poznata ličnostoffline
Sa zvanicnog sajta na kome stoji vec neko vreme
Prijatelj forumaoffline
Dobro, jeste testing directory, ali opet - cool, što ti reče
Elitni članoffline
Ako se dobro secam, vec kod 12.0 verzije je rekao da ceka da se pojavi KDE 4.1 da bi ga ukljucio u narednu verziju. Lepo od njega sto je ispunio obecanje.
Pre nekoliko dana sam se iznenadio kad sam video da je vratio XMMS, ali i to je bilo prijatno iznenadjenje.
Mada koliko sam video u changelog-u vec je ubacen KDE 3.5.10 u current pa ce verovatno KDE 4 biti u extra ili testing folderu za buduce izdanje Slackware-a
Najnovije informacije - KDE4 i zavisnosti nece biti isporucene na Slack-u 12.2, cak ni u /testing grani.
Edit:
Odlomak iz mail-a koji je Robby Workman poslao na SlackBuilds mailing listu:
Edit:
I've just been informed that 12.2 will *not* ship with a /testing tree
(or at least, not with the kde4 stuff, including deps). Those packages
and sources will carry over to the next -current cycle instead where
development will continue with the intent of including them in next
Slackware release.
Dobro uvek je moguce poskidati pakete sa neta, i probati ili koristiti.
Ali ipak je ovo jedna losa vest, da slack ne zasija u punom sjaju, jer ja koliko sam probao/video da kde 4.1.2 jako dobro i stabilno radi, sigurno da ima poneka bubica, mada sve se da ispraviti.
Stalni članoffline - Posts: 45
KDE 4.2.1 je kod current grane od 09.03.2009 prebačen iz /testing foldera u /slackware/kde... eto nama Slackware-a 13.0 uskoro...
One OS to rule them all, one OS to find them...
One OS to call them all, and in salvation bind them...
In the bright land of Linux, where the hackers play...
Heh-sta ga znam koliko je to pametno
Po meni je novi KDE jos uvek nedovrsen-radi sve to fino i stabilno ali pojedini delovi izgledaju jos uvek "neutegnuto"
Ja se drzim stare,dobre 3-ice koliko god bude trebalo
Ja se nadam da ce imat opciju da se iskljuci sve te fensi stvari. Kao sto ima sad na kde3 taj wizard kad se pokrene prvi put posle instalacije tj za to ima mogucnost i kasnije.
Pošto sam danas na testing particiji laptopa instalirao najnoviji current mogu reći da ni ja nisam preterano zadovoljan novinama koje donosi KDE 4.x.x (osim što stvarno izgleda fancy...) Ako ga Pat stvarno odluči da ga ubaci u novu verziju Slackware-a (a svi su izgledi da će tako biti
) mislim da ću nevoljno morati da Slackware zamenim nekom drugom distribucijom ili možda predjem na xfce...
P.S. Za one koje to zanima, evo šta Alen Bob kaže o novostima na current-u... http://alien.slackbook.org/blog/massive ... e-current/
Users browsing this forum: Claude User [Bot], Meta [Bot] and 2 guests
