http://eagle-usb.org/ueagle-atm/non-fre ... 1.1.tar.gz
na osnovu postova sa neta ovo uopšte skoro nije teško da se postavi
firmer bi trebao da se iskopira u
/lib/firmware/ueagle-atm
od kernela 2.6.24.1 podržan je i eagle 4 (još od prošle godine)
libatm1 : pošto je na netu pominjana 2.4.1 međutim
na novim slackwareima koji imaju promenjen gcc mora sa libatm 2.5.x da se ide
(u verziji 2.5.x je već uključen program br2364ctl ,konačno se setili :huh: )
http://linux-atm.sourceforge.net/
ovako se reinicijalizuje naživo bez restarta (rmmod)
rmmod ueagle-atm
modprobe ueagle-atm
modprobe br2684
br2684ctl -c 0 -b -a 8.35
ifconfig nas0 up
pppoe-setup
prilikom podešavanja :
ime@provider u tom obliku da se unese ime
(na primer marko@eunet pera@sezampro isto da izgleda kao na windousu ?
pera@verat.net zika@neobee.net )
umesto eth0 koristi se nas0 interfejs ,pa to i da se ukuca ?
i firewall : standalone
a startuje se veza
pppoe-start
ovako izgleda pppoe setup
u prilogu tgz za firmware i libatm 2.50 nekako ukompiliran sa slaxbuild skriptom :afro:root@slax:~# pppoe-setup
Welcome to the Roaring Penguin PPPoE client setup. First, I will run
some checks on your system to make sure the PPPoE client is installed
properly...
Looks good! Now, please enter some information:
USER NAME
>>> Enter your PPPoE user name (default bxxxnxnx@sympatico.ca): pera@neobee.net
INTERFACE
>>> Enter the Ethernet interface connected to the DSL modem
For Solaris, this is likely to be something like /dev/hme0.
For Linux, it will be ethn, where 'n' is a number.
(default eth0): nas0
Do you want the link to come up on demand, or stay up continuously?
If you want it to come up on demand, enter the idle time in seconds
after which the link should be dropped. If you want the link to
stay up permanently, enter 'no' (two letters, lower-case.)
NOTE: Demand-activated links do not interact well with dynamic IP
addresses. You may have some problems with demand-activated links.
>>> Enter the demand value (default no): no
DNS
Please enter the IP address of your ISP's primary DNS server.
If your ISP claims that 'the server will provide DNS addresses',
enter 'server' (all lower-case) here.
If you just press enter, I will assume you know what you are
doing and not modify your DNS setup.
>>> Enter the DNS information here: server
PASSWORD
>>> Please enter your PPPoE password:
>>> Please re-enter your PPPoE password:
FIREWALLING
Please choose the firewall rules to use. Note that these rules are
very basic. You are strongly encouraged to use a more sophisticated
firewall setup; however, these will provide basic security. If you
are running any servers on your machine, you must choose 'NONE' and
set up firewalling yourself. Otherwise, the firewall rules will deny
access to all standard servers like Web, e-mail, ftp, etc. If you
are using SSH, the rules will block outgoing SSH connections which
allocate a privileged source port.
The firewall choices are:
0 - NONE: This script will not set any firewall rules. You are responsible
for ensuring the security of your machine. You are STRONGLY
recommended to use some kind of firewall rules.
1 - STANDALONE: Appropriate for a basic stand-alone web-surfing workstation
2 - MASQUERADE: Appropriate for a machine acting as an Internet gateway
for a LAN
>>> Choose a type of firewall (0-2): 1
** Summary of what you entered **
Ethernet Interface: nas0
User name: pera@neobee.net
Activate-on-demand: No
DNS addresses: Supplied by ISP's server
Firewalling: STANDALONE
>>> Accept these settings and adjust configuration files (y/n)? y
valjda je dobro :huh:
ako ste sami ukompilirali kernel ,proverite da nije zaboravljen u .config
CONFIG_USB_ATM=m
CONFIG_USB_SPEEDTOUCH=m
CONFIG_USB_CXACRU=m
CONFIG_USB_UEAGLEATM=m
CONFIG_USB_XUSBATM=m
modinfo ueagle-atm
radi olakšavanja konekcija može da se doda jednostavno ,što bi rekli ,u Knemo na desni klik
ovo je deo iz ~/.kde/share/config/knemorc
ovo podvučeno se u stvari dopiše iz menija
[Interface_ppp0]
ActivateStatistics=false
Command1=konsole -T SetupPPPoverEthernetConnection -e pppoe-setup --noclose
Command2=pppoe-start
Command3=pppoe-stop
Command4=pppoe-stop
CustomCommands=true
HideWhenNotAvailable=false
HideWhenNotExisting=false
IconSet=0
MenuText1=Setup
MenuText2=Reconnect
MenuText3=Disconnect
MenuText4=Disconnect
NumCommands=3
RunAsRoot1=false
RunAsRoot2=false
RunAsRoot3=false
RunAsRoot4=false
TrafficThreshold=0
