Thunar Archive Plugin 0.4.0 (29.09.2018.)
Kreiranje Slackware paketa
Post Napisano: 29 Sep 2018, 15:12
Look below for english text.
Ažuriranje Robby Workman-ovog SlackBuilda sa SBo na Thunar Archive Plugin 0.4.0. Testirano na Currentu (poslednje ažuriranje: 28.09.2018).
INSTALACIJA UZ POMOĆ SBOPKG
Korak 0 - Preuzmite thunar-plugin.tar.gz u vaš Downloads direktorijum.
thunar-archive-plugin.tar.gz
Korak 1 - kopiranje i priprema skripti za sbopkg.
[ ! -d /var/lib/sbopkg/local/network ] && mkdir -p /var/lib/sbopkg/local/network
cd
cp ~/Downloads/thunar-archive-plugin.tar.gz /var/lib/sbopkg/local/network
pushd  /var/lib/sbopkg/local/network
tar xvf thunar-archive-plugin.tar.gz
&& rm thunar-archive-plugin.tar.gz
popd
Korak 2 - Instalacija pomoću sbopkg:
sbopkg -V local -i thunar-archive-plugin
Napomena: Ako kačite ovaj tekst ili modifikovanu SlackBuild skriptu negde drugde, budite fer i navedite izvor.
An update of Robby Workman's SlackBuild from SBo for Thunar Archive Plugin 0.4.0. Tested on Slackware Current (last update: 28. sept. of 2018).
INSTALLATION WITH SBOPKG
Step 0 - Make sure to download thunar-archive-plugin.tar.gz to your Downloads directory.
Step 1 - copying and preparation of scripts for sbopkg.
cd
popd
Step 2 - Installation with sbopkg's help:
Note: If you upload or share the modified SlackBuild script or this text somewhere else, be fair and credit us.
Post Napisano: 29 Sep 2018, 15:16
Korisno za one kojima je Thunar Archive Plugin ovih dana prestao da radi u Currentu. ;)
Post Napisano: 29 Sep 2018, 15:24
Paket za 64-bitni Slackware Current sa Thunar-om 1.8.1:
thunar-archive-plugin-0.4.0-x86_64-1bocke.tgz
Slackware package for 64-bit Slackware Current with Thunar 1.8.1:
Users browsing this forum: Claude User [Bot] and 4 guests
