/etc/hosts koji blokira štetne sajtove i reklame
Post Napisano: 16 Feb 2018, 19:08
Upravo naiđoh na nešto vrlo interesantno. Dan Pollock održava hosts fajl za blokiranje "štetočina" sa listom različitih domena sa reklamama, praćenjem i malverom. Opis i uputstva su u komentarima hosts datoteke. Na primer, kratak opis:
# Use this file to prevent your computer from connecting to selected
# internet hosts. This is an easy and effective way to protect you from
# many types of spyware, reduces bandwidth use, blocks certain pop-up
# traps, prevents user tracking by way of "web bugs" embedded in spam,
# provides partial protection to IE from certain web-based exploits and
# blocks most advertising you would otherwise be subjected to on the
# internet.
I kratak opis za upotrebu:
# For Linux, Unix, or OS X place this file at "/etc/hosts" or on some
#    systems at "/private/etc/hosts". You will require root access to do
#    this. Saving this file to "~/hosts" will allow you to run something
#    like "sudo cp ~/hosts /etc/hosts".
Adresa za preuzimanje i ostatak informacija:
http://someonewhocares.org/hosts/
Post Napisano: 16 Feb 2018, 19:11
Još jedan sličan link koji ima jedno 20-ak puta više unosa:
https://hosts-file.net/?s=Download
