[REŠENO] Sbopkg problem
Post Napisano: 19 Mar 2014, 13:47
Narode, išao danas syncati svoj sbopkg sa repozitorijem i javlja mi sljedeću grešku:
rsync: failed to connect to slackbuilds.org (208.94.238.115): Connection timed out (110)
rsync error: error in socket IO (code 10) at clientserver.c(128) [Receiver=3.1.0]
Rsync reported a socket error which may be due to a problem with the LINK value in sbopkg.conf.
(The repo's LINK is currently set to: slackbuilds.org::slackbuilds/14.1)
Please check your settings and try again later.
I sad sam ja, pun sebe misleći "šta će on meni majku mu.." i pogledam /etc/sbopkg/sbopkg.conf i on veli:
bash-4.2# cat /etc/sbopkg/sbopkg.conf
# $Id: sbopkg.conf 922 2013-12-09 02:11:01Z chess.griffin@gmail.com $
# Please read the sbopkg.conf(5) man page for information about this
# configuration file, including an explanation of how to set these
# variables.
# The following variables are used by sbopkg and by the SlackBuild
# scripts themselves.  They must be exported for this reason.
export TMP=${TMP:-/tmp/SBo}
export OUTPUT=${OUTPUT:-/tmp}
# The following are variables used by sbopkg.  Any of these variables
# could be exported, if desired.
# Path variables
LOGFILE=${LOGFILE:-/var/log/sbopkg/sbopkg-build-log}
QUEUEDIR=${QUEUEDIR:-/var/lib/sbopkg/queues}
REPO_ROOT=${REPO_ROOT:-/var/lib/sbopkg}
SRCDIR=${SRCDIR:-/var/cache/sbopkg}
# sbopkg's temporary directory (where its internal temporary files are
# kept and where packages are made prior to being moved to OUTPUT)
# defaults to /tmp/sbopkg.XXXXXX where 'XXXXXX' is a random string. If
# /tmp is not a suitable containing directory, pass in an alternate
# TMPDIR or modify the following variable. This is actually a mktemp(1)
# variable.
export TMPDIR=${TMPDIR:-/tmp}
# Other variables:
CLEANUP=${CLEANUP:-NO}
DEBUG_UPDATES=${DEBUG_UPDATES:-0}
KEEPLOG=${KEEPLOG:-YES}
MKDIR_PROMPT=${MKDIR_PROMPT:-YES}
NICE=${NICE:-10}
REPO_BRANCH=${REPO_BRANCH:-14.1}
REPO_NAME=${REPO_NAME:-SBo}
# The following variable determines if multiple instances of sbopkg can
# be run simultaneously. It is *strongly* recommended that this value be
# set to NO. Do not set it to YES without first reading the
# sbopkg.conf(5) man page.
ALLOW_MULTI=${ALLOW_MULTI:-NO}
# The following variables are required and can be tweaked if desired,
# although this is not recommended.  Note:  rsync already uses
# --archive, --delete, --no-owner, and --exclude in the main sbopkg
# script so there is no need to add those flags here.
DIFF=${DIFF:-diff}
DIFFOPTS=${DIFFOPTS:--u}
RSYNCFLAGS="${RSYNCFLAGS:---verbose --timeout=30}"
WGETFLAGS="${WGETFLAGS:--c --progress=bar:force --timeout=30 --tries=5}"
E sad, ja nigdje ne vidim onu varijablu LINK u ovom konf. fajlu i trenutno sam malo zbunjen... Zna li netko u čemu je problem jer ja ne vidim ništa sumnjivo :-/
Post Napisano: 19 Mar 2014, 13:55
Slackbuilds.org trenutno nije aktivan, na irc kanalu nema nikakvih informacija još uvek. Neki problem do njih, ništa ne brini.
Post Napisano: 19 Mar 2014, 13:56
ok, hvala ;)
ja se uplašio da nisam prilikom nekog updatea prepisao neko konf. fajl :D
Post Napisano: 19 Mar 2014, 13:59
Nisi nisi :)
Malopre sam probao da pristupim slackbuilds.org da proverim ima li neki update kad ono neće. http://www.downforeveryoneorjustme.com/" onclick="window.open(this.href);return false; kaže da je sajt down za sve.
Da je neki veći problem bila bi neka informacija valjda...
Post Napisano: 19 Mar 2014, 16:35
Nisam video od kad ali slackbuilds.org je opet operativan.
EDIT: Willy je javio da je negde od 16h sve nazad u normali.
