Audacious 3.4
Kreiranje Slackware paketa
Post Napisano: 07 Jul 2013, 08:35
28.06.2013. se pojavila novija verzija Audacious plejera 3.4. Jedina stvar što buni je što je na sajtu objavljeno da je izašla verzija 3.4 a source je za 3.4-beta 2 :question:
Ja sam skinuo source i za Audacious i za audacious-plugins (oba za 3.4-beta2 - source). Slackbuildove sam preuzeo sa sledećih lokacija i malo prepravio:
http://mirrors.slackware.com/slackware/ ... SlackBuild" onclick="window.open(this.href);return false;
Source:
http://distfiles.audacious-media-player ... .4.tar.bz2" onclick="window.open(this.href);return false;
Izmene u slackbuildovima su sledeće:
  • raniji source je imao tar.xz extenziju, slackbuild je prepravljen da extraktuje tar.?z*
  • dodat je -_stereo tag
Razlike u odnosu na verziju 3.3.1 (stiže uz Slackware 14) su:
Changes in Audacious 3.4 since 3.3:
  • Added a new scrobbler plugin which uses the Last.fm Scrobbling API 2.0;
  • Added a new 3D frequency spectrum visualizer, ported from XMMS;
  • Album art fetching is now done in the background so that it will not make the UI unresponsive;
  • Added a new command-line option (--quit-after-play) has been added to allow the player to exit automatically when finished playing;
  • A global hotkey can be configured to enable/disable the "stop after current song" option;
  • The ModPlug plugin has a new preferences window;
  • An alternative sample rate converter plugin, using libsoxr, has been added;
  • When search terms are too generic, the search tool now shows the first 100 results instead of showing no results as in previous versions.
GTK interface changes in Audacious 3.4:
  • Playlist columns can now be resized, however, according to the changelog, this requires GTK 3.8 to work properly;
  • New option to automatically remove duplicate entries from a playlist;
  • New option to repeat only a portion of a song ("A-to-B repeat");
  • New option to show remaining instead of elapsed time;
  • Playlist entries can now be sorted by song length;
  • New option to sort, randomize, and reverse the order of selected playlist entries only
A evo i paketa za testiranje i korišćenje :)
Za Slackware 64bit:
audacious-3.4-x86_64-2_stereo.txz
audacious-plugins-3.4-x86_64-1_stereo.txz
Za Slackware 32bit:
audacious-3.4-i486-2_stereo.txz
audacious-plugins-3.4-i486-1_stereo.txz
EDIT Postavljene i 32bit verzije :)
Post Napisano: 07 Jul 2013, 13:58
Odličan posao, hvala Stereo. :beer:
Prikaz verzije 64-bit
Post Napisano: 07 Jul 2013, 21:19
Uh da ne zaboravim. Ovaj paket nećete moći koristiti na 13.37 zbog nedostatka gtk+ 3 za ovu verziju Slackware-a. Bar ja nisam našao neko provereno rešenje.
Post Napisano: 08 Jul 2013, 00:58
Odrađen brzi test na sveže instaliranom Slackware64. Testirani su samo 64-bitni paketi. Kompajlirani paket radi pri pokretanju, ali pluginovi zahtevaju nekoliko paketa koji nisu dostupni u zvaničnim repoima. Moguće ih je instalirati sa SlackBuilds.org ili iz alienbobovog repoa.
To su:
ffmpeg (libavcodec, libavformat, libavutil), lame, faad
Post Napisano: 08 Jul 2013, 01:52
Testirani i 32-bitni paketi. Za razliku od 64-bitnih, nemaju dodatnih zavisnosti. Čini se da šljaka ok.
Post Napisano: 08 Jul 2013, 09:34
Evo i linka do ffmpeg od čika Erika ako nekome zatreba http://www.slackware.com/~alien/slackbuilds/ffmpeg/" onclick="window.open(this.href);return false;
Ja taj paket imam odavno, zato kod mene nije pravio problema. Hvala za testiranje.
Post Napisano: 18 Aug 2013, 19:08
Korišćena slackbuild skripta:
Audacious
#!/bin/sh
# Copyright 2006-2012  Patrick J. Volkerding, Sebeka, MN, USA
# All rights reserved.
# Redistribution and use of this script, with or without modification, is
# permitted provided that the following conditions are met:
# 1. Redistributions of this script must retain the above copyright
#    notice, this list of conditions and the following disclaimer.
#  THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR IMPLIED
#  WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
#  MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.  IN NO
#  EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
#  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
#  PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
#  OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
#  WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
#  OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
#  ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
PKGNAM=audacious
VERSION=${VERSION:-$(echo $PKGNAM-*.tar.?z* | rev | cut -f 3- -d . | cut -f 1 -d - | rev)}
BUILD=${BUILD:-2}
TAG=${TAG:-_stereo}
NUMJOBS=${NUMJOBS:-" -j7 "}
# Automatically determine the architecture we're building on:
if [ -z "$ARCH" ]; then
  case "$( uname -m )" in
    i?86) export ARCH=i486 ;;
    arm*) export ARCH=arm ;;
    # Unless $ARCH is already set, use uname -m for all other archs:
       *) export ARCH=$( uname -m ) ;;
  esac
fi
CWD=$(pwd)
TMP=${TMP:-/tmp}
PKG=$TMP/package-${PKGNAM}
if [ "$ARCH" = "i486" ]; then
  LIBDIRSUFFIX=""
  ARCHOPTS="--disable-sse2"
elif [ "$ARCH" = "s390" ]; then
  SLKCFLAGS="-O2"
  LIBDIRSUFFIX=""
  SLKCFLAGS="-O2 -fPIC"
  LIBDIRSUFFIX="64"
  ARCHOPTS=""
elif [ "$ARCH" = "arm" ]; then
  SLKCFLAGS="-O2 -march=armv4 -mtune=xscale"
  LIBDIRSUFFIX=""
elif [ "$ARCH" = "armel" ]; then
  SLKCFLAGS="-O2 -march=armv4t"
  LIBDIRSUFFIX=""
else
  SLKCFLAGS="-O2"
  LIBDIRSUFFIX=""
fi
rm -rf $PKG
mkdir -p $TMP $PKG
cd $TMP
rm -rf ${PKGNAM}-${VERSION}
tar xvf $CWD/${PKGNAM}-$VERSION.tar.?z* || exit 1
cd ${PKGNAM}-$VERSION || exit 1
# Make sure ownerships and permissions are sane:
chown -R root:root .
find . \
  \( -perm 777 -o -perm 775 -o -perm 711 -o -perm 555 -o -perm 511 \) \
  -exec chmod 755 {} \; -o \
  \( -perm 666 -o -perm 664 -o -perm 600 -o -perm 444 -o -perm 440 -o -perm 400 \) \
  -exec chmod 644 {} \;
# Configure:
CFLAGS="$SLKCFLAGS" \
./configure \
  --prefix=/usr \
  --libdir=/usr/lib${LIBDIRSUFFIX} \
  --sysconfdir=/etc \
  --mandir=/usr/man \
  --docdir=/usr/doc/${PKGNAM}-$VERSION \
  --program-prefix= \
  --program-suffix= \
  ${ARCHOPTS} \
  --with-buildstamp=$ARCH-slackware-linux \
  --build=$ARCH-slackware-linux || exit 1
# Build and install:
make $NUMJOBS || make || exit 1
make install DESTDIR=$PKG || exit 1
# Fix broken symlinks pointing into the build directory
#( cd $PKG/usr/bin
#  rm -f audacious audtool
#  ln -s audacious2 audacious
#  ln -s audtool2 audtool
# Strip binaries:
find $PKG | xargs file | grep -e "executable" -e "shared object" \
  | grep ELF | cut -f 1 -d : | xargs strip --strip-unneeded 2> /dev/null
# Compress and link manpages, if any:
if [ -d $PKG/usr/man ]; then
  ( cd $PKG/usr/man
    for manpagedir in $(find . -type d -name "man*") ; do
      ( cd $manpagedir
        for eachpage in $( find . -type l -maxdepth 1) ; do
          ln -s $( readlink $eachpage ).gz $eachpage.gz
          rm $eachpage
        done
        gzip -9 *.*
    done
fi
# Compress info files, if any:
if [ -d $PKG/usr/info ]; then
  ( cd $PKG/usr/info
    rm -f dir
    gzip -9 *
fi
# Add a documentation directory:
mkdir -p $PKG/usr/doc/${PKGNAM}-$VERSION
cp -a \
  AUTHORS COPYING INSTALL Mercurial-Access NEWS README doc/* \
# If there's a ChangeLog, installing at least part of the recent history
# is useful, but don't let it get totally out of control:
if [ -r ChangeLog ]; then
  DOCSDIR=$(echo $PKG/usr/doc/*-$VERSION)
  cat ChangeLog | head -n 1000 > $DOCSDIR/ChangeLog
  touch -r ChangeLog $DOCSDIR/ChangeLog
fi
mkdir -p $PKG/install
zcat $CWD/doinst.sh.gz > $PKG/install/doinst.sh
cd $PKG
/sbin/makepkg -l y -c n $TMP/${PKGNAM}-$VERSION-$ARCH-$BUILD$TAG.txz
Audacious-plugins
#!/bin/sh
# Copyright 2006, 2007, 2008, 2009, 2010, 2011, 2012  Patrick J. Volkerding, Sebeka, MN, USA
PKGNAM=audacious-plugins
BUILD=${BUILD:-1}
TAG=${TAG:-_stereo}
  esac
fi
CWD=$(pwd)
TMP=${TMP:-/tmp}
  LIBDIRSUFFIX=""
  SLKCFLAGS="-O2"
  LIBDIRSUFFIX=""
  SLKCFLAGS="-O2"
  LIBDIRSUFFIX="64"
  ARCHOPTS=""
else
  SLKCFLAGS="-O2"
  LIBDIRSUFFIX=""
  ARCHOPTS=""
fi
rm -rf $PKG
mkdir -p $TMP $PKG
cd $TMP
find . \
# Configure:
CXXFLAGS="$SLKCFLAGS" \
./configure \
  --prefix=/usr \
  --sysconfdir=/etc \
  --mandir=/usr/man \
  --enable-amidiplug \
  --program-prefix= \
  --program-suffix= \
  ${ARCHOPTS} \
# Strip binaries:
  ( cd $PKG/usr/man
      ( cd $manpagedir
          rm $eachpage
        done
        gzip -9 *.*
    done
fi
  ( cd $PKG/usr/info
    rm -f dir
    gzip -9 *
fi
cp -a \
  AUTHORS COPYING INSTALL Mercurial-Access README* \
fi
cd $PKG
