QTGZManager
Post Napisano: 10 Dec 2012, 04:21
QTGZManager je Qt GUI frontend za pkgtools.
About QTGZManager
QTGZManager is a powerfull tool to manage Slackware Linux TGZ/TXZ packages. It resembles a file manager and consists basicly of 4 (configurable) panels:
Directories;
Packages found in selected directory;
List of installed packages;
Actions, a tabbed panel where we have access to various actions executed over packages.
Some of the features:
Supports KDE 3.x, KDE 4.x, XFCE, LXDE, MATE and Trinity Desktop Environments;
Install/Re install/Upgrade/Downgrade/Remove packages – watching the output of these commands on demand;
View the content of packages (including opening files from non-installed packages);
View the description of packages in colored tooltips;
Find out which package a certain file belongs to;
Search for files inside an installed/not installed package;
Search for packages in directories;
View differences between different package versions;
Freeze/Unfreeze a package so it cannot be accidentally removed/upgraded/downgraded;
Download official OS patches from your nearest Slackware mirror 2.
Written in Qt4 C++ and compatible with stock Slackware 13.0 and beyound, QTGZManager is a very fast solution to deal with every package collection.
Matična strana
https://qtgzmanager.wordpress.com/" onclick="window.open(this.href);return false;
Download (izvorni kod i SlackBuild skripta)
http://sourceforge.net/projects/jtgzman ... gzmanager/" onclick="window.open(this.href);return false;
Post Napisano: 26 Feb 2013, 20:10
Izašao QTGZManager 1.0.1. Od pre koji dan je dostupan i na SlackBuilds.org: http://www.slackbuilds.org/repository/1 ... gzmanager/" onclick="window.open(this.href);return false;.
