/usr/share/ati/fglrx-install.logCode: Select all
Detected a previous installation, /usr/share/ati/amd-uninstall.sh
Dryrun uninstall succeeded continuing with installation.
Check if system has the tools required for installation.
Uninstalling any previously installed drivers.
Forcing uninstall of AMD Catalyst(TM) Proprietary Driver.
No integrity verification is done.
restore of system environment completed
Uninstall fglrx driver complete.
For detailed log of uninstall, please see /etc/ati/fglrx-uninstall.log
System must be rebooted to avoid system instability and potential data loss.
/usr/share/ati/amd-uninstall.sh completed with 0
[Message] Kernel Module : Trying to install a precompiled kernel module.
[Message] Kernel Module : Precompiled kernel module version mismatched.
[Message] Kernel Module : Found kernel module build environment, generating kernel module now.
AMD kernel module generator version 2.1
doing Makefile based build for kernel 2.6.x and higher
rm -rf *.c *.h *.o *.ko *.a .??* *.symvers
make -C /lib/modules/3.6.1/build SUBDIRS=/lib/modules/fglrx/build_mod/2.6.x modules
make[1]: Entering directory `/usr/src/linux-3.6.1'
CC [M] /lib/modules/fglrx/build_mod/2.6.x/firegl_public.o
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c: In function ‘KCL_MEM_AllocLinearAddrInterval’:
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2131:5: error: implicit declaration of function ‘do_mmap’ [-Werror=implicit-function-declaration]
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2131:13: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
cc1: some warnings being treated as errors
make[2]: *** [/lib/modules/fglrx/build_mod/2.6.x/firegl_public.o] Error 1
make[1]: *** [_module_/lib/modules/fglrx/build_mod/2.6.x] Error 2
make[1]: Leaving directory `/usr/src/linux-3.6.1'
make: *** [kmod_build] Error 2
build failed with return value 2
[Error] Kernel Module : Failed to compile kernel module - please consult readme.
[Reboot] Kernel Module : mkinitrd
Znam da sam negde zabrljao u kompajliranju kernela ali ne znam gde, jer mogu da uđem u prethodni kernel i da instaliram drajvere i oni rade. Ali to važi samo za prethodni kernel, za ovaj neće.
Nije mi problem ni da kompajliram kernel ponovo samo kad bi znao koju opciju da uključim.
P.S. Prilikom kompajliranja kernela 3.6.1 nisam pravio nikakve izmene u opcijama, čak ni debug nisam isključio
