Jeste li videli? Na SlackBuilds.org je postavjlen repozitorijum za Slackware 14. Sada i zvanično.
Ipak, sbopkg aplikacija nije doživela update još od 28.04.2011. godine tako da je još uvek aktuelna verzija 0.35.0.
Ja se nadam da je sbopkg projekat još uvek aktivan i da će uskoro neki svež update.
I Slacky je sredio repo za Slackware 14
SlackBuilds.org!
Administratoroffline
Sa SBo mailing liste:
Tue Oct 2 18:25:39 UTC 2012
We're running a bit later than usual on getting ready for the new release
this time, but we think you'll agree that it was worth the wait for us
to get all (or at least) most of the kinks worked out. One of the most
user-visible changes is the new REQUIRES variable in the .info files.
For a description, see this git commit in our templates repo:
http://slackbuilds.org/cgit/templates/c ... 15779cbbfb" onclick="window.open(this.href);return false;
Also note that the various template files can be viewed and/or downloaded
via http here: http://slackbuilds.org/templates/" onclick="window.open(this.href);return false;
I'd like to take this time to welcome our newest admin, Matteo Bernardini
(ponce) to the team and thank him for the huge amount of testing and
updating of various scripts that he did. On that note, I should thank
David Somero (XGizzmo) for once again doing the automated build testing
(and providing error logs) for this release, and of course all of his
fixes and updates along the way. Then there's Heinz Wiesinger (pprkut) for
the usual fixes and updates, but he's also done a lot of work behind the
scenes with database updates and our custom admin tools. I'd be remiss if
I didn't point out the never-ending job of server maintenance and upkeep
done by the SBo co-founder, Erik Hanson (erik), and that's on top of the
usual fixes and updates all over the SBo tree. Michiel van Wessem (BP{k})
and Niels Horn (niels_horn) get the same kudos for helping out with all
of the testing and fixing in the tree, and as much as I hate to talk nicely
about rob0 (/dev/rob0), he actually deserves some kind words for his work
on keeping our mail and dns working properly.
All of our users and maintainers deserve proper thanks for our existence, but
Binh Nguyen and Willy Sudiarto Raharjo really stepped up and helped out with
lots of testing and fixing and updating needed to get the 14.0 repo ready.
I'm sure I've left someone out, but please understand that my bad memory is
in no way a reflection on your contributions. Thanks to everyone for your
contributions, regardless of how small or large they may have been.
See the git log <http://slackbuilds.org/cgit/slackbuilds/log/?h=14.0> for
detail changes since 13.37. Now go forth and Slack!
--rworkman (on behalf of the entire SBo team)
Malo su poranili sa objavljivanjem. Nisu još ispeglane sve nekompatibilnost/ slomljeni download linkovi.
Nisam još probao da skidam jer mi je ova mašina podešena prilično dobro a za malu mašinu još nemam vremena da sređujem. Sa ovom verzijom Sleka ću raditi isključivo kombinaciju slackpkg i sbopkg. Ovog puta mala mašina neće videti slapt-get
Prijatelj forumaoffline
Instalirah sa SlekBuildsa.org pakete za compiz, fusion-icon... ima jedno 15-ak paketa sve skupa, FileZillu, jedna zavisnost wxPython (samo malo duže traje kompajliranje, nekih 15-ak minuta) i imao sam izgleda sreće da nisam naišao na probleme.bocke wrote:Malo su poranili sa objavljivanjem. Nisu još ispeglane sve nekompatibilnost/ slomljeni download linkovi.
Gledao sam famozni Shutter
Nešto se ne sećam da su ranije zavisnosti kod paketa koji ih ima puno, kao Shutter-a recimo, bili direktno linkovani.
Možda je tako bilo i ranije ali se nešto ne sećam.
I nisu bili linkovani, bio je samo spisak neophodnih paketa ali ništa nije bilo linkovano.
Čini ti se brok. Nije ništa manji. Na SBo se ne listaju rekurzivne zavisnosti. Tj listaju se samo neposredne, a one dalje imaju svoje zavisnosti. A Shutter nikad i nije zavisio od Gtk+ 3.
Inače upravo se na #slackbuilds kanalu priča baš o tim linkovanjima. Ako naiđete na pakete koji nisu linkovani to je zato što su opcione zavisnosti. Ako bude još nekih zanimljivosti objavljivaću ih ovde
To je onda odlična novina Stereo. Nešto je lakši posao kada su linkovane zavisnosti.
Stereo Slekverski insajder.
Dobro Bocke, imaćemo sa čime da se zanimamo, nama nikada ne može da bude dosadno.
Šta ću Brok kad mi se sviđa ovaj Slackware, mogu da se igram sa njim do iznemoglosti. A on, baraba jedna, izdržava sve moje napade
Users browsing this forum: Claude User [Bot] and 18 guests
