Wifi radar
Post Napisano: 08 Jan 2012, 01:01
Wifi radar je aplikacija za otkrivanje dostupnih wireless mreža. Napisana je u Python-u i koristi Gtk2 interfejs.
WiFi Radar is a Python/PyGTK2 utility for managing WiFi profiles on GNU/Linux.
It enables you to scan for available networks and create profiles for your
preferred networks. You can drag and drop your preferred networks to arrange
the profile priority.
SlackBuild je dostupan sa:
http://slackbuilds.org/repository/13.37 ... ifi-radar/
Pre instalacije, obratite pažnju na dodatne napomene:
WiFi Radar is tested to work with an Intel iwlagn 6300 on Slackware but
should work just the same for any iwconfig interface.
NOTE: wifi-radar needs to run as root. You may need to issue:
xhost +local:root
which you can put in your ~/.bashrc or ~/.zshrc etc.
I've installed the program into /opt/radar-wifi and created a
/usr/bin/wifi-radar script that sets $DISPLAY which defaults to :0.0
For other $DISPLAY's you can edit the script in the slackbuild
directory, or pass DISPLAY=:N.n to wifi-radar on the command line
http://wifi-radar.berlios.de/
