Napisano: 03 Jan 2022, 11:06
Slackware 64-bit
Sun Jan 2 20:40:21 UTC 2022
d/doxygen-1.9.3-x86_64-1.txz: Upgraded.
n/network-scripts-15.0-noarch-18.txz: Rebuilt.
netconfig: when DHCP configuration is selected, also add hostname labeled
loopback entries to /etc/hosts. We don't want to have to rely on something
else providing correct name service in order to be able to reach our
machine through its own hostname. This was a regression since the netconfig
shipped with Slackware 14.2.
Thanks to Zexuo.
Sun Jan 2 01:25:29 UTC 2022
a/mdadm-4.2-x86_64-1.txz: Upgraded.
ap/usbmuxd-20210925_e3a3180-x86_64-1.txz: Upgraded.
Updated to fix mounting devices with iOS 15.1. Thanks to qunying.
l/libimobiledevice-20211124_2c6121d-x86_64-1.txz: Upgraded.
l/libimobiledevice-glue-20211125_3cb687b-x86_64-1.txz: Added.
l/xapian-core-1.4.19-x86_64-1.txz: Upgraded.
x/mesa-21.3.3-x86_64-1.txz: Upgraded.
Fri Dec 31 19:44:41 UTC 2021
a/e2fsprogs-1.46.5-x86_64-1.txz: Upgraded.
ap/sqlite-3.37.1-x86_64-1.txz: Upgraded.
n/mutt-2.1.5-x86_64-1.txz: Upgraded.
n/yptools-4.2.3-x86_64-4.txz: Rebuilt.
Added /usr/sbin/yp_dump_binding and /usr/sbin/yptest.
Add a hint about adding "nis" in /etc/pam.d/system-auth to /etc/default/yp.
Wed Dec 29 20:48:42 UTC 2021
a/kernel-firmware-20211229_57d6b95-noarch-1.txz: Upgraded.
a/kernel-generic-5.15.12-x86_64-1.txz: Upgraded.
a/kernel-huge-5.15.12-x86_64-1.txz: Upgraded.
a/kernel-modules-5.15.12-x86_64-1.txz: Upgraded.
d/kernel-headers-5.15.12-x86-1.txz: Upgraded.
k/kernel-source-5.15.12-noarch-1.txz: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Wed Dec 29 02:42:32 UTC 2021
l/libgsf-1.14.48-x86_64-1.txz: Upgraded.
l/netpbm-10.97.00-x86_64-1.txz: Upgraded.
n/wpa_supplicant-2.9-x86_64-8.txz: Rebuilt.
This update fixes the following security issues:
AP mode PMF disconnection protection bypass.
UPnP SUBSCRIBE misbehavior in hostapd WPS AP.
P2P group information processing vulnerability.
P2P provision discovery processing vulnerability.
ASN.1: Validate DigestAlgorithmIdentifier parameters.
Flush pending control interface message for an interface to be removed.
These issues could result in a denial-of-service, privilege escalation,
arbitrary code execution, or other unexpected behavior.
Thanks to nobodino for pointing out the patches.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-0326
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-0535
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-12695
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-16275
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-27803
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-30004
xap/seamonkey-2.53.10.2-x86_64-1.txz: Upgraded.
https://www.seamonkey-project.org/releases/seamonkey2.53.10.2
Mon Dec 27 23:06:00 UTC 2021
The --enable-systemd-logind change to xorg-server that caused resume from
suspend regressions (and others) has been reverted, and in retrospect it was
a bad idea to take it at that point, but it had appeared as if it wouldn't
cause problems in the case where Xorg was running as root. Oh well, lesson
learned. But the build script has been enhanced to make it easy to build
rootless versions of the xorg-server packages. Just do this:
ROOTLESSX=YES ./x11.SlackBuild xserver xorg-server
Depending on your GPU, this could work for your use case with no problems.
Also, I've gone ahead and taken a couple of shared library version bumps since
the projects (opencv and poppler) have decent track records as far as not
introducing regressions, and if there are any, we've got time to test and fix.
I'm still avoiding some things that aren't as trusted in that regard, and will
likely continue to do so. :-)
ap/cups-filters-1.28.10-x86_64-2.txz: Rebuilt.
Recompiled against poppler-21.12.0.
kde/ark-21.12.0-x86_64-2.txz: Rebuilt.
Applied upstream patches:
[PATCH] Fix extraction "Dolphin Actions" not abiding "Open destination
folder after extracting" setting.
[PATCH] Do not highlight file after compression.
Thanks to ctrlaltca.
kde/calligra-3.2.1-x86_64-15.txz: Rebuilt.
kde/cantor-21.12.0-x86_64-2.txz: Rebuilt.
kde/digikam-7.4.0-x86_64-2.txz: Rebuilt.
Recompiled against opencv-4.5.5.
kde/kfilemetadata-5.89.0-x86_64-2.txz: Rebuilt.
kde/kile-2.9.93-x86_64-15.txz: Rebuilt.
kde/kitinerary-21.12.0-x86_64-2.txz: Rebuilt.
kde/krita-5.0.0-x86_64-2.txz: Rebuilt.
kde/okular-21.12.0-x86_64-2.txz: Rebuilt.
l/gegl-0.4.34-x86_64-2.txz: Rebuilt.
l/gst-plugins-bad-free-1.18.5-x86_64-3.txz: Rebuilt.
l/imagemagick-7.1.0_19-x86_64-1.txz: Upgraded.
l/mlt-7.4.0-x86_64-1.txz: Upgraded.
l/opencv-4.5.5-x86_64-1.txz: Upgraded.
l/poppler-21.12.0-x86_64-1.txz: Upgraded.
n/fetchmail-6.4.26-x86_64-1.txz: Upgraded.
n/tin-2.6.1-x86_64-1.txz: Upgraded.
x/ibus-anthy-1.5.14-x86_64-1.txz: Upgraded.
x/xorg-server-1.20.14-x86_64-2.txz: Rebuilt.
Recompiled using these options:
--enable-suid-wrapper --enable-install-setuid --disable-systemd-logind.
x/xorg-server-xephyr-1.20.14-x86_64-2.txz: Rebuilt.
x/xorg-server-xnest-1.20.14-x86_64-2.txz: Rebuilt.
x/xorg-server-xvfb-1.20.14-x86_64-2.txz: Rebuilt.
xap/geeqie-1.6-x86_64-4.txz: Rebuilt.
xap/gimp-2.10.30-x86_64-2.txz: Rebuilt.
xfce/tumbler-4.16.0-x86_64-4.txz: Rebuilt.
extra/rust-for-mozilla/rust-1.54.0-x86_64-3.txz: Added.
This is an alternate version of Rust that may be useful for compiling
software from Mozilla since using the very latest Rust often won't
compile, or produces an unstable build.
Slackware 32-bit
d/doxygen-1.9.3-i586-1.txz: Upgraded.
Thanks to Zexuo.
a/mdadm-4.2-i586-1.txz: Upgraded.
ap/usbmuxd-20210925_e3a3180-i586-1.txz: Upgraded.
l/libimobiledevice-20211124_2c6121d-i586-1.txz: Upgraded.
l/libimobiledevice-glue-20211125_3cb687b-i586-1.txz: Added.
l/xapian-core-1.4.19-i586-1.txz: Upgraded.
x/mesa-21.3.3-i586-1.txz: Upgraded.
a/e2fsprogs-1.46.5-i586-1.txz: Upgraded.
ap/sqlite-3.37.1-i586-1.txz: Upgraded.
n/mutt-2.1.5-i586-1.txz: Upgraded.
n/yptools-4.2.3-i586-4.txz: Rebuilt.
a/kernel-generic-5.15.12-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.15.12_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.15.12-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.15.12_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.15.12-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.15.12_smp-i686-1.txz: Upgraded.
d/kernel-headers-5.15.12_smp-x86-1.txz: Upgraded.
k/kernel-source-5.15.12_smp-noarch-1.txz: Upgraded.
extra/linux-5.15.12-nosmp-sdk/*: Upgraded.
l/libgsf-1.14.48-i586-1.txz: Upgraded.
l/netpbm-10.97.00-i586-1.txz: Upgraded.
n/wpa_supplicant-2.9-i586-8.txz: Rebuilt.
xap/seamonkey-2.53.10.2-i686-1.txz: Upgraded.
ap/cups-filters-1.28.10-i586-2.txz: Rebuilt.
kde/ark-21.12.0-i586-2.txz: Rebuilt.
kde/calligra-3.2.1-i586-15.txz: Rebuilt.
kde/cantor-21.12.0-i586-2.txz: Rebuilt.
kde/digikam-7.4.0-i586-2.txz: Rebuilt.
kde/kfilemetadata-5.89.0-i586-2.txz: Rebuilt.
kde/kile-2.9.93-i586-15.txz: Rebuilt.
kde/kitinerary-21.12.0-i586-2.txz: Rebuilt.
kde/krita-5.0.0-i586-2.txz: Rebuilt.
kde/okular-21.12.0-i586-2.txz: Rebuilt.
l/gegl-0.4.34-i586-2.txz: Rebuilt.
l/gst-plugins-bad-free-1.18.5-i586-3.txz: Rebuilt.
l/imagemagick-7.1.0_19-i586-1.txz: Upgraded.
l/mlt-7.4.0-i586-1.txz: Upgraded.
l/opencv-4.5.5-i586-1.txz: Upgraded.
l/poppler-21.12.0-i586-1.txz: Upgraded.
n/fetchmail-6.4.26-i586-1.txz: Upgraded.
n/tin-2.6.1-i586-1.txz: Upgraded.
x/ibus-anthy-1.5.14-i586-1.txz: Upgraded.
x/xorg-server-1.20.14-i586-2.txz: Rebuilt.
x/xorg-server-xephyr-1.20.14-i586-2.txz: Rebuilt.
x/xorg-server-xnest-1.20.14-i586-2.txz: Rebuilt.
x/xorg-server-xvfb-1.20.14-i586-2.txz: Rebuilt.
xap/geeqie-1.6-i586-4.txz: Rebuilt.
xap/gimp-2.10.30-i586-2.txz: Rebuilt.
xfce/tumbler-4.16.0-i586-4.txz: Rebuilt.
extra/rust-for-mozilla/rust-1.54.0-i686-3.txz: Added.
Napisano: 05 Jan 2022, 15:33
Slackware 64-bit
Tue Jan 4 22:51:41 UTC 2022
a/bash-5.1.016-x86_64-1.txz: Upgraded.
a/haveged-1.9.16-x86_64-1.txz: Upgraded.
a/hwdata-0.355-noarch-1.txz: Upgraded.
ap/gphoto2-2.5.28-x86_64-1.txz: Upgraded.
kde/bluedevil-5.23.5-x86_64-1.txz: Upgraded.
kde/breeze-5.23.5-x86_64-1.txz: Upgraded.
kde/breeze-grub-5.23.5-x86_64-1.txz: Upgraded.
kde/breeze-gtk-5.23.5-x86_64-1.txz: Upgraded.
kde/drkonqi-5.23.5-x86_64-1.txz: Upgraded.
kde/kactivitymanagerd-5.23.5-x86_64-1.txz: Upgraded.
kde/kde-cli-tools-5.23.5-x86_64-1.txz: Upgraded.
kde/kde-gtk-config-5.23.5-x86_64-1.txz: Upgraded.
kde/kdecoration-5.23.5-x86_64-1.txz: Upgraded.
kde/kdeplasma-addons-5.23.5-x86_64-1.txz: Upgraded.
kde/kgamma5-5.23.5-x86_64-1.txz: Upgraded.
kde/khotkeys-5.23.5-x86_64-1.txz: Upgraded.
kde/kinfocenter-5.23.5-x86_64-1.txz: Upgraded.
kde/kmenuedit-5.23.5-x86_64-1.txz: Upgraded.
kde/konsole-21.12.0-x86_64-2.txz: Rebuilt.
Applied upstream patch:
[PATCH] Use tighter matching when finding the default profile file name.
Thanks to alienBOB.
kde/kscreen-5.23.5-x86_64-1.txz: Upgraded.
kde/kscreenlocker-5.23.5-x86_64-1.txz: Upgraded.
kde/ksshaskpass-5.23.5-x86_64-1.txz: Upgraded.
kde/ksystemstats-5.23.5-x86_64-1.txz: Upgraded.
kde/kwallet-pam-5.23.5-x86_64-1.txz: Upgraded.
kde/kwayland-integration-5.23.5-x86_64-1.txz: Upgraded.
kde/kwayland-server-5.23.5-x86_64-1.txz: Upgraded.
kde/kwin-5.23.5-x86_64-1.txz: Upgraded.
kde/kwrited-5.23.5-x86_64-1.txz: Upgraded.
kde/layer-shell-qt-5.23.5-x86_64-1.txz: Upgraded.
kde/libkscreen-5.23.5-x86_64-1.txz: Upgraded.
kde/libksysguard-5.23.5-x86_64-1.txz: Upgraded.
kde/milou-5.23.5-x86_64-1.txz: Upgraded.
kde/oxygen-5.23.5-x86_64-1.txz: Upgraded.
kde/plasma-browser-integration-5.23.5-x86_64-1.txz: Upgraded.
kde/plasma-desktop-5.23.5-x86_64-1.txz: Upgraded.
kde/plasma-disks-5.23.5-x86_64-1.txz: Upgraded.
kde/plasma-firewall-5.23.5-x86_64-1.txz: Upgraded.
kde/plasma-integration-5.23.5-x86_64-1.txz: Upgraded.
kde/plasma-nm-5.23.5-x86_64-1.txz: Upgraded.
kde/plasma-pa-5.23.5-x86_64-1.txz: Upgraded.
kde/plasma-sdk-5.23.5-x86_64-1.txz: Upgraded.
kde/plasma-systemmonitor-5.23.5-x86_64-1.txz: Upgraded.
kde/plasma-vault-5.23.5-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.23.5-x86_64-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.23.5-x86_64-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.23.5-x86_64-1.txz: Upgraded.
kde/powerdevil-5.23.5-x86_64-1.txz: Upgraded.
kde/qqc2-breeze-style-5.23.5-x86_64-1.txz: Upgraded.
kde/sddm-kcm-5.23.5-x86_64-1.txz: Upgraded.
kde/systemsettings-5.23.5-x86_64-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.23.5-x86_64-1.txz: Upgraded.
l/imagemagick-7.1.0_19-x86_64-2.txz: Rebuilt.
It seems that even with --enable-opencl, ImageMagick has disabled OpenCL
support by default unless the environment variable MAGICK_OCL_DEVICE=true
is set, so there should be no harm enabling this feature again.
Thanks to denydias.
l/iso-codes-4.9.0-noarch-1.txz: Upgraded.
l/libgphoto2-2.5.28-x86_64-1.txz: Upgraded.
l/pipewire-0.3.42-x86_64-2.txz: Rebuilt.
Added sample startup files in /etc/xdg/autostart. Thanks to stormtracknole.
Added scripts (pipewire-enable.sh, pipewire-disable.sh) to setup pipewire as
the default multimedia server, or to disable it and return to pulseaudio as
the default. Thanks to stormtracknole and LuckyCyborg for many useful tips.
l/pulseaudio-15.0-x86_64-4.txz: Rebuilt.
Install pulseaudio.desktop as a .new file so that future package updates
won't overwrite custom content.
n/whois-5.5.11-x86_64-1.txz: Upgraded.
n/yptools-4.2.3-x86_64-5.txz: Rebuilt.
Fixed ypcat installation. Thanks to Stuart Winter.
x/libdrm-2.4.109-x86_64-1.txz: Upgraded.
x/xdg-desktop-portal-1.12.1-x86_64-1.txz: Upgraded.
x/xf86-video-vmware-13.3.0-x86_64-6.txz: Rebuilt.
Patched to build against libdrm-2.4.109. Thanks to gmgf.
Slackware 32-bit
a/bash-5.1.016-i586-1.txz: Upgraded.
a/haveged-1.9.16-i586-1.txz: Upgraded.
ap/gphoto2-2.5.28-i586-1.txz: Upgraded.
kde/bluedevil-5.23.5-i586-1.txz: Upgraded.
kde/breeze-5.23.5-i586-1.txz: Upgraded.
kde/breeze-grub-5.23.5-i586-1.txz: Upgraded.
kde/breeze-gtk-5.23.5-i586-1.txz: Upgraded.
kde/drkonqi-5.23.5-i586-1.txz: Upgraded.
kde/kactivitymanagerd-5.23.5-i586-1.txz: Upgraded.
kde/kde-cli-tools-5.23.5-i586-1.txz: Upgraded.
kde/kde-gtk-config-5.23.5-i586-1.txz: Upgraded.
kde/kdecoration-5.23.5-i586-1.txz: Upgraded.
kde/kdeplasma-addons-5.23.5-i586-1.txz: Upgraded.
kde/kgamma5-5.23.5-i586-1.txz: Upgraded.
kde/khotkeys-5.23.5-i586-1.txz: Upgraded.
kde/kinfocenter-5.23.5-i586-1.txz: Upgraded.
kde/kmenuedit-5.23.5-i586-1.txz: Upgraded.
kde/konsole-21.12.0-i586-2.txz: Rebuilt.
Thanks to alienBOB.
kde/kscreen-5.23.5-i586-1.txz: Upgraded.
kde/kscreenlocker-5.23.5-i586-1.txz: Upgraded.
kde/ksshaskpass-5.23.5-i586-1.txz: Upgraded.
kde/ksystemstats-5.23.5-i586-1.txz: Upgraded.
kde/kwallet-pam-5.23.5-i586-1.txz: Upgraded.
kde/kwayland-integration-5.23.5-i586-1.txz: Upgraded.
kde/kwayland-server-5.23.5-i586-1.txz: Upgraded.
kde/kwin-5.23.5-i586-1.txz: Upgraded.
kde/kwrited-5.23.5-i586-1.txz: Upgraded.
kde/layer-shell-qt-5.23.5-i586-1.txz: Upgraded.
kde/libkscreen-5.23.5-i586-1.txz: Upgraded.
kde/libksysguard-5.23.5-i586-1.txz: Upgraded.
kde/milou-5.23.5-i586-1.txz: Upgraded.
kde/oxygen-5.23.5-i586-1.txz: Upgraded.
kde/plasma-browser-integration-5.23.5-i586-1.txz: Upgraded.
kde/plasma-desktop-5.23.5-i586-1.txz: Upgraded.
kde/plasma-disks-5.23.5-i586-1.txz: Upgraded.
kde/plasma-firewall-5.23.5-i586-1.txz: Upgraded.
kde/plasma-integration-5.23.5-i586-1.txz: Upgraded.
kde/plasma-nm-5.23.5-i586-1.txz: Upgraded.
kde/plasma-pa-5.23.5-i586-1.txz: Upgraded.
kde/plasma-sdk-5.23.5-i586-1.txz: Upgraded.
kde/plasma-systemmonitor-5.23.5-i586-1.txz: Upgraded.
kde/plasma-vault-5.23.5-i586-1.txz: Upgraded.
kde/plasma-workspace-5.23.5-i586-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.23.5-i586-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.23.5-i586-1.txz: Upgraded.
kde/powerdevil-5.23.5-i586-1.txz: Upgraded.
kde/qqc2-breeze-style-5.23.5-i586-1.txz: Upgraded.
kde/sddm-kcm-5.23.5-i586-1.txz: Upgraded.
kde/systemsettings-5.23.5-i586-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.23.5-i586-1.txz: Upgraded.
l/imagemagick-7.1.0_19-i586-2.txz: Rebuilt.
Thanks to denydias.
l/libgphoto2-2.5.28-i586-1.txz: Upgraded.
l/pipewire-0.3.42-i586-2.txz: Rebuilt.
l/pulseaudio-15.0-i586-4.txz: Rebuilt.
n/whois-5.5.11-i586-1.txz: Upgraded.
n/yptools-4.2.3-i586-5.txz: Rebuilt.
x/libdrm-2.4.109-i586-1.txz: Upgraded.
x/xdg-desktop-portal-1.12.1-i586-1.txz: Upgraded.
x/xf86-video-vmware-13.3.0-i586-6.txz: Rebuilt.
Napisano: 08 Jan 2022, 20:59
Slackware 64-bit
Fri Jan 7 06:03:52 UTC 2022
a/kernel-firmware-20220106_4aa2c65-noarch-1.txz: Upgraded.
a/tcsh-6.23.02-x86_64-1.txz: Upgraded.
ap/sqlite-3.37.2-x86_64-1.txz: Upgraded.
ap/vim-8.2.4018-x86_64-1.txz: Upgraded.
d/mercurial-6.0.1-x86_64-1.txz: Upgraded.
kde/akonadi-21.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-21.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-tools-21.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-contacts-21.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-import-wizard-21.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-mime-21.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-notes-21.12.1-x86_64-1.txz: Upgraded.
kde/akonadi-search-21.12.1-x86_64-1.txz: Upgraded.
kde/akonadiconsole-21.12.1-x86_64-1.txz: Upgraded.
kde/akregator-21.12.1-x86_64-1.txz: Upgraded.
kde/analitza-21.12.1-x86_64-1.txz: Upgraded.
kde/ark-21.12.1-x86_64-1.txz: Upgraded.
kde/artikulate-21.12.1-x86_64-1.txz: Upgraded.
kde/audiocd-kio-21.12.1-x86_64-1.txz: Upgraded.
kde/baloo-widgets-21.12.1-x86_64-1.txz: Upgraded.
kde/blinken-21.12.1-x86_64-1.txz: Upgraded.
kde/bomber-21.12.1-x86_64-1.txz: Upgraded.
kde/bovo-21.12.1-x86_64-1.txz: Upgraded.
kde/calendarsupport-21.12.1-x86_64-1.txz: Upgraded.
kde/cantor-21.12.1-x86_64-1.txz: Upgraded.
kde/cervisia-21.12.1-x86_64-1.txz: Upgraded.
kde/dolphin-21.12.1-x86_64-1.txz: Upgraded.
kde/dolphin-plugins-21.12.1-x86_64-1.txz: Upgraded.
kde/dragon-21.12.1-x86_64-1.txz: Upgraded.
kde/elisa-21.12.1-x86_64-1.txz: Upgraded.
kde/eventviews-21.12.1-x86_64-1.txz: Upgraded.
kde/ffmpegthumbs-21.12.1-x86_64-1.txz: Upgraded.
kde/filelight-21.12.1-x86_64-1.txz: Upgraded.
kde/granatier-21.12.1-x86_64-1.txz: Upgraded.
kde/grantlee-editor-21.12.1-x86_64-1.txz: Upgraded.
kde/grantleetheme-21.12.1-x86_64-1.txz: Upgraded.
kde/gwenview-21.12.1-x86_64-1.txz: Upgraded.
kde/incidenceeditor-21.12.1-x86_64-1.txz: Upgraded.
kde/itinerary-21.12.1-x86_64-1.txz: Upgraded.
kde/juk-21.12.1-x86_64-1.txz: Upgraded.
kde/k3b-21.12.1-x86_64-1.txz: Upgraded.
kde/kaddressbook-21.12.1-x86_64-1.txz: Upgraded.
kde/kalarm-21.12.1-x86_64-1.txz: Upgraded.
kde/kalarmcal-21.12.1-x86_64-1.txz: Upgraded.
kde/kalgebra-21.12.1-x86_64-1.txz: Upgraded.
kde/kalzium-21.12.1-x86_64-1.txz: Upgraded.
kde/kamera-21.12.1-x86_64-1.txz: Upgraded.
kde/kamoso-21.12.1-x86_64-1.txz: Upgraded.
kde/kanagram-21.12.1-x86_64-1.txz: Upgraded.
kde/kapman-21.12.1-x86_64-1.txz: Upgraded.
kde/kapptemplate-21.12.1-x86_64-1.txz: Upgraded.
kde/kate-21.12.1-x86_64-1.txz: Upgraded.
kde/katomic-21.12.1-x86_64-1.txz: Upgraded.
kde/kbackup-21.12.1-x86_64-1.txz: Upgraded.
kde/kblackbox-21.12.1-x86_64-1.txz: Upgraded.
kde/kblocks-21.12.1-x86_64-1.txz: Upgraded.
kde/kbounce-21.12.1-x86_64-1.txz: Upgraded.
kde/kbreakout-21.12.1-x86_64-1.txz: Upgraded.
kde/kbruch-21.12.1-x86_64-1.txz: Upgraded.
kde/kcachegrind-21.12.1-x86_64-1.txz: Upgraded.
kde/kcalc-21.12.1-x86_64-1.txz: Upgraded.
kde/kcalutils-21.12.1-x86_64-1.txz: Upgraded.
kde/kcharselect-21.12.1-x86_64-1.txz: Upgraded.
kde/kcolorchooser-21.12.1-x86_64-1.txz: Upgraded.
kde/kcron-21.12.1-x86_64-1.txz: Upgraded.
kde/kde-dev-scripts-21.12.1-x86_64-1.txz: Upgraded.
kde/kde-dev-utils-21.12.1-x86_64-1.txz: Upgraded.
kde/kdebugsettings-21.12.1-x86_64-1.txz: Upgraded.
kde/kdeconnect-kde-21.12.1-x86_64-1.txz: Upgraded.
kde/kdeedu-data-21.12.1-x86_64-1.txz: Upgraded.
kde/kdegraphics-mobipocket-21.12.1-x86_64-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-21.12.1-x86_64-1.txz: Upgraded.
kde/kdenetwork-filesharing-21.12.1-x86_64-1.txz: Upgraded.
kde/kdenlive-21.12.1-x86_64-1.txz: Upgraded.
kde/kdepim-addons-21.12.1-x86_64-1.txz: Upgraded.
kde/kdepim-runtime-21.12.1-x86_64-1.txz: Upgraded.
kde/kdesdk-kioslaves-21.12.1-x86_64-1.txz: Upgraded.
kde/kdesdk-thumbnailers-21.12.1-x86_64-1.txz: Upgraded.
kde/kdev-php-21.12.1-x86_64-1.txz: Upgraded.
kde/kdev-python-21.12.1-x86_64-1.txz: Upgraded.
kde/kdevelop-21.12.1-x86_64-1.txz: Upgraded.
kde/kdf-21.12.1-x86_64-1.txz: Upgraded.
kde/kdialog-21.12.1-x86_64-1.txz: Upgraded.
kde/kdiamond-21.12.1-x86_64-1.txz: Upgraded.
kde/keditbookmarks-21.12.1-x86_64-1.txz: Upgraded.
kde/kfind-21.12.1-x86_64-1.txz: Upgraded.
kde/kfloppy-21.12.1-x86_64-1.txz: Upgraded.
kde/kfourinline-21.12.1-x86_64-1.txz: Upgraded.
kde/kgeography-21.12.1-x86_64-1.txz: Upgraded.
kde/kget-21.12.1-x86_64-1.txz: Upgraded.
kde/kgoldrunner-21.12.1-x86_64-1.txz: Upgraded.
kde/kgpg-21.12.1-x86_64-1.txz: Upgraded.
kde/khangman-21.12.1-x86_64-1.txz: Upgraded.
kde/khelpcenter-21.12.1-x86_64-1.txz: Upgraded.
kde/kidentitymanagement-21.12.1-x86_64-1.txz: Upgraded.
kde/kig-21.12.1-x86_64-1.txz: Upgraded.
kde/kigo-21.12.1-x86_64-1.txz: Upgraded.
kde/killbots-21.12.1-x86_64-1.txz: Upgraded.
kde/kimagemapeditor-21.12.1-x86_64-1.txz: Upgraded.
kde/kimap-21.12.1-x86_64-1.txz: Upgraded.
kde/kio-extras-21.12.1-x86_64-1.txz: Upgraded.
kde/kio-gdrive-21.12.1-x86_64-1.txz: Upgraded.
kde/kipi-plugins-21.12.1-x86_64-1.txz: Upgraded.
kde/kirigami-gallery-21.12.1-x86_64-1.txz: Upgraded.
kde/kiriki-21.12.1-x86_64-1.txz: Upgraded.
kde/kiten-21.12.1-x86_64-1.txz: Upgraded.
kde/kitinerary-21.12.1-x86_64-1.txz: Upgraded.
kde/kjumpingcube-21.12.1-x86_64-1.txz: Upgraded.
kde/kldap-21.12.1-x86_64-1.txz: Upgraded.
kde/kleopatra-21.12.1-x86_64-1.txz: Upgraded.
kde/klickety-21.12.1-x86_64-1.txz: Upgraded.
kde/klines-21.12.1-x86_64-1.txz: Upgraded.
kde/kmag-21.12.1-x86_64-1.txz: Upgraded.
kde/kmahjongg-21.12.1-x86_64-1.txz: Upgraded.
kde/kmail-21.12.1-x86_64-1.txz: Upgraded.
kde/kmail-account-wizard-21.12.1-x86_64-1.txz: Upgraded.
kde/kmailtransport-21.12.1-x86_64-1.txz: Upgraded.
kde/kmbox-21.12.1-x86_64-1.txz: Upgraded.
kde/kmime-21.12.1-x86_64-1.txz: Upgraded.
kde/kmines-21.12.1-x86_64-1.txz: Upgraded.
kde/kmix-21.12.1-x86_64-1.txz: Upgraded.
kde/kmousetool-21.12.1-x86_64-1.txz: Upgraded.
kde/kmouth-21.12.1-x86_64-1.txz: Upgraded.
kde/kmplot-21.12.1-x86_64-1.txz: Upgraded.
kde/knavalbattle-21.12.1-x86_64-1.txz: Upgraded.
kde/knetwalk-21.12.1-x86_64-1.txz: Upgraded.
kde/knights-21.12.1-x86_64-1.txz: Upgraded.
kde/knotes-21.12.1-x86_64-1.txz: Upgraded.
kde/kolf-21.12.1-x86_64-1.txz: Upgraded.
kde/kollision-21.12.1-x86_64-1.txz: Upgraded.
kde/kolourpaint-21.12.1-x86_64-1.txz: Upgraded.
kde/kompare-21.12.1-x86_64-1.txz: Upgraded.
kde/konqueror-21.12.1-x86_64-1.txz: Upgraded.
kde/konquest-21.12.1-x86_64-1.txz: Upgraded.
kde/konsole-21.12.1-x86_64-1.txz: Upgraded.
kde/kontact-21.12.1-x86_64-1.txz: Upgraded.
kde/kontactinterface-21.12.1-x86_64-1.txz: Upgraded.
kde/kontrast-21.12.1-x86_64-1.txz: Upgraded.
kde/konversation-21.12.1-x86_64-1.txz: Upgraded.
kde/kopeninghours-21.12.1-x86_64-1.txz: Upgraded.
kde/kopete-21.12.1-x86_64-1.txz: Upgraded.
kde/korganizer-21.12.1-x86_64-1.txz: Upgraded.
kde/kosmindoormap-21.12.1-x86_64-1.txz: Upgraded.
kde/kpat-21.12.1-x86_64-1.txz: Upgraded.
kde/kpimtextedit-21.12.1-x86_64-1.txz: Upgraded.
kde/kpkpass-21.12.1-x86_64-1.txz: Upgraded.
kde/kpmcore-21.12.1-x86_64-1.txz: Upgraded.
kde/kpublictransport-21.12.1-x86_64-1.txz: Upgraded.
kde/kqtquickcharts-21.12.1-x86_64-1.txz: Upgraded.
kde/krdc-21.12.1-x86_64-1.txz: Upgraded.
kde/kreversi-21.12.1-x86_64-1.txz: Upgraded.
kde/krfb-21.12.1-x86_64-1.txz: Upgraded.
kde/krita-5.0.2-x86_64-1.txz: Upgraded.
kde/kross-interpreters-21.12.1-x86_64-1.txz: Upgraded.
kde/kruler-21.12.1-x86_64-1.txz: Upgraded.
kde/kshisen-21.12.1-x86_64-1.txz: Upgraded.
kde/ksirk-21.12.1-x86_64-1.txz: Upgraded.
kde/ksmtp-21.12.1-x86_64-1.txz: Upgraded.
kde/ksnakeduel-21.12.1-x86_64-1.txz: Upgraded.
kde/kspaceduel-21.12.1-x86_64-1.txz: Upgraded.
kde/ksquares-21.12.1-x86_64-1.txz: Upgraded.
kde/ksudoku-21.12.1-x86_64-1.txz: Upgraded.
kde/ksystemlog-21.12.1-x86_64-1.txz: Upgraded.
kde/kteatime-21.12.1-x86_64-1.txz: Upgraded.
kde/ktimer-21.12.1-x86_64-1.txz: Upgraded.
kde/ktnef-21.12.1-x86_64-1.txz: Upgraded.
kde/ktorrent-21.12.1-x86_64-1.txz: Upgraded.
kde/ktouch-21.12.1-x86_64-1.txz: Upgraded.
kde/kturtle-21.12.1-x86_64-1.txz: Upgraded.
kde/kubrick-21.12.1-x86_64-1.txz: Upgraded.
kde/kwalletmanager-21.12.1-x86_64-1.txz: Upgraded.
kde/kwave-21.12.1-x86_64-1.txz: Upgraded.
kde/kwordquiz-21.12.1-x86_64-1.txz: Upgraded.
kde/libgravatar-21.12.1-x86_64-1.txz: Upgraded.
kde/libkcddb-21.12.1-x86_64-1.txz: Upgraded.
kde/libkcompactdisc-21.12.1-x86_64-1.txz: Upgraded.
kde/libkdcraw-21.12.1-x86_64-1.txz: Upgraded.
kde/libkdegames-21.12.1-x86_64-1.txz: Upgraded.
kde/libkdepim-21.12.1-x86_64-1.txz: Upgraded.
kde/libkeduvocdocument-21.12.1-x86_64-1.txz: Upgraded.
kde/libkexiv2-21.12.1-x86_64-1.txz: Upgraded.
kde/libkgapi-21.12.1-x86_64-1.txz: Upgraded.
kde/libkipi-21.12.1-x86_64-1.txz: Upgraded.
kde/libkleo-21.12.1-x86_64-1.txz: Upgraded.
kde/libkmahjongg-21.12.1-x86_64-1.txz: Upgraded.
kde/libkomparediff2-21.12.1-x86_64-1.txz: Upgraded.
kde/libksane-21.12.1-x86_64-1.txz: Upgraded.
kde/libksieve-21.12.1-x86_64-1.txz: Upgraded.
kde/libktorrent-21.12.1-x86_64-1.txz: Upgraded.
kde/lokalize-21.12.1-x86_64-1.txz: Upgraded.
kde/lskat-21.12.1-x86_64-1.txz: Upgraded.
kde/mailcommon-21.12.1-x86_64-1.txz: Upgraded.
kde/mailimporter-21.12.1-x86_64-1.txz: Upgraded.
kde/marble-21.12.1-x86_64-1.txz: Upgraded.
kde/markdownpart-21.12.1-x86_64-1.txz: Upgraded.
kde/mbox-importer-21.12.1-x86_64-1.txz: Upgraded.
kde/messagelib-21.12.1-x86_64-1.txz: Upgraded.
kde/minuet-21.12.1-x86_64-1.txz: Upgraded.
kde/okular-21.12.1-x86_64-1.txz: Upgraded.
kde/palapeli-21.12.1-x86_64-1.txz: Upgraded.
kde/parley-21.12.1-x86_64-1.txz: Upgraded.
kde/partitionmanager-21.12.1-x86_64-1.txz: Upgraded.
kde/picmi-21.12.1-x86_64-1.txz: Upgraded.
kde/pim-data-exporter-21.12.1-x86_64-1.txz: Upgraded.
kde/pim-sieve-editor-21.12.1-x86_64-1.txz: Upgraded.
kde/pimcommon-21.12.1-x86_64-1.txz: Upgraded.
kde/poxml-21.12.1-x86_64-1.txz: Upgraded.
kde/print-manager-21.12.1-x86_64-1.txz: Upgraded.
kde/rocs-21.12.1-x86_64-1.txz: Upgraded.
kde/skanlite-21.12.1-x86_64-1.txz: Upgraded.
kde/spectacle-21.12.1-x86_64-1.txz: Upgraded.
kde/step-21.12.1-x86_64-1.txz: Upgraded.
kde/svgpart-21.12.1-x86_64-1.txz: Upgraded.
kde/sweeper-21.12.1-x86_64-1.txz: Upgraded.
kde/umbrello-21.12.1-x86_64-1.txz: Upgraded.
kde/yakuake-21.12.1-x86_64-1.txz: Upgraded.
kde/zanshin-21.12.1-x86_64-1.txz: Upgraded.
kde/zeroconf-ioslave-21.12.1-x86_64-1.txz: Upgraded.
l/mozilla-nss-3.74-x86_64-1.txz: Upgraded.
l/readline-8.1.002-x86_64-1.txz: Upgraded.
n/bluez-5.63-x86_64-1.txz: Upgraded.
xap/vim-gvim-8.2.4018-x86_64-1.txz: Upgraded.
Wed Jan 5 20:09:37 UTC 2022
a/aaa_libraries-15.0-x86_64-12.txz: Rebuilt.
Upgraded: libcap.so.2.62, libelf-0.186.so, libzstd.so.1.5.1,
libcares.so.2.5.1, libexpat.so.1.8.2, libglib-2.0.so.0.7000.2,
libgmodule-2.0.so.0.7000.2, libgobject-2.0.so.0.7000.2,
libgthread-2.0.so.0.7000.2, libpcre2-8.so.0.10.4.
Added: libunwind.so.8.0.1 (thanks to Jeebizz).
a/kernel-generic-5.15.13-x86_64-1.txz: Upgraded.
a/kernel-huge-5.15.13-x86_64-1.txz: Upgraded.
a/kernel-modules-5.15.13-x86_64-1.txz: Upgraded.
d/doxygen-1.9.3-x86_64-2.txz: Rebuilt.
Fix manpage versions, build and install docs. Thanks to duncan_roe.
d/kernel-headers-5.15.13-x86-1.txz: Upgraded.
k/kernel-source-5.15.13-noarch-1.txz: Upgraded.
l/libuv-1.43.0-x86_64-1.txz: Upgraded.
l/pipewire-0.3.43-x86_64-1.txz: Upgraded.
Remove redundant .sample files on package upgrade.
When disabling pipewire, toss the .desktop files and keep the .sample files
if both exist.
Added missing X-KDE-autostart-phase=1 to pipewire-pulse.desktop.sample.
Thanks to ZhaoLin1457.
n/curl-7.81.0-x86_64-1.txz: Upgraded.
x/fcitx-qt5-1.2.7-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/tcsh-6.23.02-i586-1.txz: Upgraded.
ap/sqlite-3.37.2-i586-1.txz: Upgraded.
ap/vim-8.2.4018-i586-1.txz: Upgraded.
d/mercurial-6.0.1-i586-1.txz: Upgraded.
kde/akonadi-21.12.1-i586-1.txz: Upgraded.
kde/akonadi-calendar-21.12.1-i586-1.txz: Upgraded.
kde/akonadi-calendar-tools-21.12.1-i586-1.txz: Upgraded.
kde/akonadi-contacts-21.12.1-i586-1.txz: Upgraded.
kde/akonadi-import-wizard-21.12.1-i586-1.txz: Upgraded.
kde/akonadi-mime-21.12.1-i586-1.txz: Upgraded.
kde/akonadi-notes-21.12.1-i586-1.txz: Upgraded.
kde/akonadi-search-21.12.1-i586-1.txz: Upgraded.
kde/akonadiconsole-21.12.1-i586-1.txz: Upgraded.
kde/akregator-21.12.1-i586-1.txz: Upgraded.
kde/analitza-21.12.1-i586-1.txz: Upgraded.
kde/ark-21.12.1-i586-1.txz: Upgraded.
kde/artikulate-21.12.1-i586-1.txz: Upgraded.
kde/audiocd-kio-21.12.1-i586-1.txz: Upgraded.
kde/baloo-widgets-21.12.1-i586-1.txz: Upgraded.
kde/blinken-21.12.1-i586-1.txz: Upgraded.
kde/bomber-21.12.1-i586-1.txz: Upgraded.
kde/bovo-21.12.1-i586-1.txz: Upgraded.
kde/calendarsupport-21.12.1-i586-1.txz: Upgraded.
kde/cantor-21.12.1-i586-1.txz: Upgraded.
kde/cervisia-21.12.1-i586-1.txz: Upgraded.
kde/dolphin-21.12.1-i586-1.txz: Upgraded.
kde/dolphin-plugins-21.12.1-i586-1.txz: Upgraded.
kde/dragon-21.12.1-i586-1.txz: Upgraded.
kde/elisa-21.12.1-i586-1.txz: Upgraded.
kde/eventviews-21.12.1-i586-1.txz: Upgraded.
kde/ffmpegthumbs-21.12.1-i586-1.txz: Upgraded.
kde/filelight-21.12.1-i586-1.txz: Upgraded.
kde/granatier-21.12.1-i586-1.txz: Upgraded.
kde/grantlee-editor-21.12.1-i586-1.txz: Upgraded.
kde/grantleetheme-21.12.1-i586-1.txz: Upgraded.
kde/gwenview-21.12.1-i586-1.txz: Upgraded.
kde/incidenceeditor-21.12.1-i586-1.txz: Upgraded.
kde/itinerary-21.12.1-i586-1.txz: Upgraded.
kde/juk-21.12.1-i586-1.txz: Upgraded.
kde/k3b-21.12.1-i586-1.txz: Upgraded.
kde/kaddressbook-21.12.1-i586-1.txz: Upgraded.
kde/kalarm-21.12.1-i586-1.txz: Upgraded.
kde/kalarmcal-21.12.1-i586-1.txz: Upgraded.
kde/kalgebra-21.12.1-i586-1.txz: Upgraded.
kde/kalzium-21.12.1-i586-1.txz: Upgraded.
kde/kamera-21.12.1-i586-1.txz: Upgraded.
kde/kamoso-21.12.1-i586-1.txz: Upgraded.
kde/kanagram-21.12.1-i586-1.txz: Upgraded.
kde/kapman-21.12.1-i586-1.txz: Upgraded.
kde/kapptemplate-21.12.1-i586-1.txz: Upgraded.
kde/kate-21.12.1-i586-1.txz: Upgraded.
kde/katomic-21.12.1-i586-1.txz: Upgraded.
kde/kbackup-21.12.1-i586-1.txz: Upgraded.
kde/kblackbox-21.12.1-i586-1.txz: Upgraded.
kde/kblocks-21.12.1-i586-1.txz: Upgraded.
kde/kbounce-21.12.1-i586-1.txz: Upgraded.
kde/kbreakout-21.12.1-i586-1.txz: Upgraded.
kde/kbruch-21.12.1-i586-1.txz: Upgraded.
kde/kcachegrind-21.12.1-i586-1.txz: Upgraded.
kde/kcalc-21.12.1-i586-1.txz: Upgraded.
kde/kcalutils-21.12.1-i586-1.txz: Upgraded.
kde/kcharselect-21.12.1-i586-1.txz: Upgraded.
kde/kcolorchooser-21.12.1-i586-1.txz: Upgraded.
kde/kcron-21.12.1-i586-1.txz: Upgraded.
kde/kde-dev-scripts-21.12.1-i586-1.txz: Upgraded.
kde/kde-dev-utils-21.12.1-i586-1.txz: Upgraded.
kde/kdebugsettings-21.12.1-i586-1.txz: Upgraded.
kde/kdeconnect-kde-21.12.1-i586-1.txz: Upgraded.
kde/kdeedu-data-21.12.1-i586-1.txz: Upgraded.
kde/kdegraphics-mobipocket-21.12.1-i586-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-21.12.1-i586-1.txz: Upgraded.
kde/kdenetwork-filesharing-21.12.1-i586-1.txz: Upgraded.
kde/kdenlive-21.12.1-i586-1.txz: Upgraded.
kde/kdepim-addons-21.12.1-i586-1.txz: Upgraded.
kde/kdepim-runtime-21.12.1-i586-1.txz: Upgraded.
kde/kdesdk-kioslaves-21.12.1-i586-1.txz: Upgraded.
kde/kdesdk-thumbnailers-21.12.1-i586-1.txz: Upgraded.
kde/kdev-php-21.12.1-i586-1.txz: Upgraded.
kde/kdev-python-21.12.1-i586-1.txz: Upgraded.
kde/kdevelop-21.12.1-i586-1.txz: Upgraded.
kde/kdf-21.12.1-i586-1.txz: Upgraded.
kde/kdialog-21.12.1-i586-1.txz: Upgraded.
kde/kdiamond-21.12.1-i586-1.txz: Upgraded.
kde/keditbookmarks-21.12.1-i586-1.txz: Upgraded.
kde/kfind-21.12.1-i586-1.txz: Upgraded.
kde/kfloppy-21.12.1-i586-1.txz: Upgraded.
kde/kfourinline-21.12.1-i586-1.txz: Upgraded.
kde/kgeography-21.12.1-i586-1.txz: Upgraded.
kde/kget-21.12.1-i586-1.txz: Upgraded.
kde/kgoldrunner-21.12.1-i586-1.txz: Upgraded.
kde/kgpg-21.12.1-i586-1.txz: Upgraded.
kde/khangman-21.12.1-i586-1.txz: Upgraded.
kde/khelpcenter-21.12.1-i586-1.txz: Upgraded.
kde/kidentitymanagement-21.12.1-i586-1.txz: Upgraded.
kde/kig-21.12.1-i586-1.txz: Upgraded.
kde/kigo-21.12.1-i586-1.txz: Upgraded.
kde/killbots-21.12.1-i586-1.txz: Upgraded.
kde/kimagemapeditor-21.12.1-i586-1.txz: Upgraded.
kde/kimap-21.12.1-i586-1.txz: Upgraded.
kde/kio-extras-21.12.1-i586-1.txz: Upgraded.
kde/kio-gdrive-21.12.1-i586-1.txz: Upgraded.
kde/kipi-plugins-21.12.1-i586-1.txz: Upgraded.
kde/kirigami-gallery-21.12.1-i586-1.txz: Upgraded.
kde/kiriki-21.12.1-i586-1.txz: Upgraded.
kde/kiten-21.12.1-i586-1.txz: Upgraded.
kde/kitinerary-21.12.1-i586-1.txz: Upgraded.
kde/kjumpingcube-21.12.1-i586-1.txz: Upgraded.
kde/kldap-21.12.1-i586-1.txz: Upgraded.
kde/kleopatra-21.12.1-i586-1.txz: Upgraded.
kde/klickety-21.12.1-i586-1.txz: Upgraded.
kde/klines-21.12.1-i586-1.txz: Upgraded.
kde/kmag-21.12.1-i586-1.txz: Upgraded.
kde/kmahjongg-21.12.1-i586-1.txz: Upgraded.
kde/kmail-21.12.1-i586-1.txz: Upgraded.
kde/kmail-account-wizard-21.12.1-i586-1.txz: Upgraded.
kde/kmailtransport-21.12.1-i586-1.txz: Upgraded.
kde/kmbox-21.12.1-i586-1.txz: Upgraded.
kde/kmime-21.12.1-i586-1.txz: Upgraded.
kde/kmines-21.12.1-i586-1.txz: Upgraded.
kde/kmix-21.12.1-i586-1.txz: Upgraded.
kde/kmousetool-21.12.1-i586-1.txz: Upgraded.
kde/kmouth-21.12.1-i586-1.txz: Upgraded.
kde/kmplot-21.12.1-i586-1.txz: Upgraded.
kde/knavalbattle-21.12.1-i586-1.txz: Upgraded.
kde/knetwalk-21.12.1-i586-1.txz: Upgraded.
kde/knights-21.12.1-i586-1.txz: Upgraded.
kde/knotes-21.12.1-i586-1.txz: Upgraded.
kde/kolf-21.12.1-i586-1.txz: Upgraded.
kde/kollision-21.12.1-i586-1.txz: Upgraded.
kde/kolourpaint-21.12.1-i586-1.txz: Upgraded.
kde/kompare-21.12.1-i586-1.txz: Upgraded.
kde/konqueror-21.12.1-i586-1.txz: Upgraded.
kde/konquest-21.12.1-i586-1.txz: Upgraded.
kde/konsole-21.12.1-i586-1.txz: Upgraded.
kde/kontact-21.12.1-i586-1.txz: Upgraded.
kde/kontactinterface-21.12.1-i586-1.txz: Upgraded.
kde/kontrast-21.12.1-i586-1.txz: Upgraded.
kde/konversation-21.12.1-i586-1.txz: Upgraded.
kde/kopeninghours-21.12.1-i586-1.txz: Upgraded.
kde/kopete-21.12.1-i586-1.txz: Upgraded.
kde/korganizer-21.12.1-i586-1.txz: Upgraded.
kde/kosmindoormap-21.12.1-i586-1.txz: Upgraded.
kde/kpat-21.12.1-i586-1.txz: Upgraded.
kde/kpimtextedit-21.12.1-i586-1.txz: Upgraded.
kde/kpkpass-21.12.1-i586-1.txz: Upgraded.
kde/kpmcore-21.12.1-i586-1.txz: Upgraded.
kde/kpublictransport-21.12.1-i586-1.txz: Upgraded.
kde/kqtquickcharts-21.12.1-i586-1.txz: Upgraded.
kde/krdc-21.12.1-i586-1.txz: Upgraded.
kde/kreversi-21.12.1-i586-1.txz: Upgraded.
kde/krfb-21.12.1-i586-1.txz: Upgraded.
kde/krita-5.0.2-i586-1.txz: Upgraded.
kde/kross-interpreters-21.12.1-i586-1.txz: Upgraded.
kde/kruler-21.12.1-i586-1.txz: Upgraded.
kde/kshisen-21.12.1-i586-1.txz: Upgraded.
kde/ksirk-21.12.1-i586-1.txz: Upgraded.
kde/ksmtp-21.12.1-i586-1.txz: Upgraded.
kde/ksnakeduel-21.12.1-i586-1.txz: Upgraded.
kde/kspaceduel-21.12.1-i586-1.txz: Upgraded.
kde/ksquares-21.12.1-i586-1.txz: Upgraded.
kde/ksudoku-21.12.1-i586-1.txz: Upgraded.
kde/ksystemlog-21.12.1-i586-1.txz: Upgraded.
kde/kteatime-21.12.1-i586-1.txz: Upgraded.
kde/ktimer-21.12.1-i586-1.txz: Upgraded.
kde/ktnef-21.12.1-i586-1.txz: Upgraded.
kde/ktorrent-21.12.1-i586-1.txz: Upgraded.
kde/ktouch-21.12.1-i586-1.txz: Upgraded.
kde/kturtle-21.12.1-i586-1.txz: Upgraded.
kde/kubrick-21.12.1-i586-1.txz: Upgraded.
kde/kwalletmanager-21.12.1-i586-1.txz: Upgraded.
kde/kwave-21.12.1-i586-1.txz: Upgraded.
kde/kwordquiz-21.12.1-i586-1.txz: Upgraded.
kde/libgravatar-21.12.1-i586-1.txz: Upgraded.
kde/libkcddb-21.12.1-i586-1.txz: Upgraded.
kde/libkcompactdisc-21.12.1-i586-1.txz: Upgraded.
kde/libkdcraw-21.12.1-i586-1.txz: Upgraded.
kde/libkdegames-21.12.1-i586-1.txz: Upgraded.
kde/libkdepim-21.12.1-i586-1.txz: Upgraded.
kde/libkeduvocdocument-21.12.1-i586-1.txz: Upgraded.
kde/libkexiv2-21.12.1-i586-1.txz: Upgraded.
kde/libkgapi-21.12.1-i586-1.txz: Upgraded.
kde/libkipi-21.12.1-i586-1.txz: Upgraded.
kde/libkleo-21.12.1-i586-1.txz: Upgraded.
kde/libkmahjongg-21.12.1-i586-1.txz: Upgraded.
kde/libkomparediff2-21.12.1-i586-1.txz: Upgraded.
kde/libksane-21.12.1-i586-1.txz: Upgraded.
kde/libksieve-21.12.1-i586-1.txz: Upgraded.
kde/libktorrent-21.12.1-i586-1.txz: Upgraded.
kde/lokalize-21.12.1-i586-1.txz: Upgraded.
kde/lskat-21.12.1-i586-1.txz: Upgraded.
kde/mailcommon-21.12.1-i586-1.txz: Upgraded.
kde/mailimporter-21.12.1-i586-1.txz: Upgraded.
kde/marble-21.12.1-i586-1.txz: Upgraded.
kde/markdownpart-21.12.1-i586-1.txz: Upgraded.
kde/mbox-importer-21.12.1-i586-1.txz: Upgraded.
kde/messagelib-21.12.1-i586-1.txz: Upgraded.
kde/minuet-21.12.1-i586-1.txz: Upgraded.
kde/okular-21.12.1-i586-1.txz: Upgraded.
kde/palapeli-21.12.1-i586-1.txz: Upgraded.
kde/parley-21.12.1-i586-1.txz: Upgraded.
kde/partitionmanager-21.12.1-i586-1.txz: Upgraded.
kde/picmi-21.12.1-i586-1.txz: Upgraded.
kde/pim-data-exporter-21.12.1-i586-1.txz: Upgraded.
kde/pim-sieve-editor-21.12.1-i586-1.txz: Upgraded.
kde/pimcommon-21.12.1-i586-1.txz: Upgraded.
kde/poxml-21.12.1-i586-1.txz: Upgraded.
kde/print-manager-21.12.1-i586-1.txz: Upgraded.
kde/rocs-21.12.1-i586-1.txz: Upgraded.
kde/skanlite-21.12.1-i586-1.txz: Upgraded.
kde/spectacle-21.12.1-i586-1.txz: Upgraded.
kde/step-21.12.1-i586-1.txz: Upgraded.
kde/svgpart-21.12.1-i586-1.txz: Upgraded.
kde/sweeper-21.12.1-i586-1.txz: Upgraded.
kde/umbrello-21.12.1-i586-1.txz: Upgraded.
kde/yakuake-21.12.1-i586-1.txz: Upgraded.
kde/zanshin-21.12.1-i586-1.txz: Upgraded.
kde/zeroconf-ioslave-21.12.1-i586-1.txz: Upgraded.
l/mozilla-nss-3.74-i586-1.txz: Upgraded.
l/readline-8.1.002-i586-1.txz: Upgraded.
n/bluez-5.63-i586-1.txz: Upgraded.
xap/vim-gvim-8.2.4018-i586-1.txz: Upgraded.
a/aaa_libraries-15.0-i586-12.txz: Rebuilt.
a/kernel-generic-5.15.13-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.15.13_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.15.13-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.15.13_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.15.13-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.15.13_smp-i686-1.txz: Upgraded.
d/doxygen-1.9.3-i586-2.txz: Rebuilt.
d/kernel-headers-5.15.13_smp-x86-1.txz: Upgraded.
k/kernel-source-5.15.13_smp-noarch-1.txz: Upgraded.
l/libuv-1.43.0-i586-1.txz: Upgraded.
l/pipewire-0.3.43-i586-1.txz: Upgraded.
if both exist.
n/curl-7.81.0-i586-1.txz: Upgraded.
x/fcitx-qt5-1.2.7-i586-1.txz: Upgraded.
extra/linux-5.15.13-nosmp-sdk/*: Upgraded.
Napisano: 14 Jan 2022, 19:50
Slackware 64-bit
Fri Jan 14 05:24:07 UTC 2022
a/cryptsetup-2.4.3-x86_64-1.txz: Upgraded.
This update addresses a multi-step attack on LUKS2 format by orchestrating
LUKS2 reencryption metadata in existing LUKS2 header. An attacker is able to
trigger permanent data decryption (ciphertext->plaintext transformation) on
part of data device on next LUKS2 device activation. Attacker does _not_
have to know passphrase or decrypted volume encryption key.
cryptsetup versions older than 2.2.0 are not affected by this, because they
do not support online LUKS2 reencryption.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-4122
Wed Jan 12 22:04:33 UTC 2022
Good hello, and welcome to the third and final release candidate for Slackware
15.0. We're 99% frozen at this point and are mostly looking for regression or
other bug reports that might be able to be addressed before this goes stable.
Of course, the management here reserves the right to make exceptions... that
5.15.15 kernel version has a nice ring to it. If your requests didn't make it
into this iteration, perhaps we will revisit them for the next -current cycle.
Some were just a little too late but will more than likely be needed next time
(I'm looking at Didier's grubconfig), while others are just out of scope for
the main tree where I like to abide by YAGNI as much as possible.
Anyway, let's get some testing done and we'll be there soon. Enjoy! :-)
a/aaa_base-15.0-x86_64-2.txz: Rebuilt.
The Linux Counter has shut down, so remove the registration email.
Update the welcome email for Slackware 15.0.
a/aaa_libraries-15.0-x86_64-13.txz: Rebuilt.
Upgraded: libsigsegv.so.2.0.7.
a/eudev-3.2.11-x86_64-1.txz: Upgraded.
a/haveged-1.9.17-x86_64-1.txz: Upgraded.
a/hdparm-9.63-x86_64-1.txz: Upgraded.
a/kernel-firmware-20220111_13dca28-noarch-1.txz: Upgraded.
a/kernel-generic-5.15.14-x86_64-1.txz: Upgraded.
a/kernel-huge-5.15.14-x86_64-1.txz: Upgraded.
a/kernel-modules-5.15.14-x86_64-1.txz: Upgraded.
ap/vim-8.2.4065-x86_64-1.txz: Upgraded.
d/kernel-headers-5.15.14-x86-1.txz: Upgraded.
d/strace-5.16-x86_64-1.txz: Upgraded.
d/vala-0.54.6-x86_64-1.txz: Upgraded.
k/kernel-source-5.15.14-noarch-1.txz: Upgraded.
VMD m -> y
Thanks to dr.s.
kde/attica-5.90.0-x86_64-1.txz: Upgraded.
kde/baloo-5.90.0-x86_64-1.txz: Upgraded.
kde/bluez-qt-5.90.0-x86_64-1.txz: Upgraded.
kde/breeze-icons-5.90.0-noarch-1.txz: Upgraded.
kde/extra-cmake-modules-5.90.0-x86_64-1.txz: Upgraded.
kde/frameworkintegration-5.90.0-x86_64-1.txz: Upgraded.
kde/kactivities-5.90.0-x86_64-1.txz: Upgraded.
kde/kactivities-stats-5.90.0-x86_64-1.txz: Upgraded.
kde/kapidox-5.90.0-x86_64-1.txz: Upgraded.
kde/karchive-5.90.0-x86_64-1.txz: Upgraded.
kde/kauth-5.90.0-x86_64-1.txz: Upgraded.
kde/kbookmarks-5.90.0-x86_64-1.txz: Upgraded.
kde/kcalendarcore-5.90.0-x86_64-1.txz: Upgraded.
kde/kcmutils-5.90.0-x86_64-1.txz: Upgraded.
kde/kcodecs-5.90.0-x86_64-1.txz: Upgraded.
kde/kcompletion-5.90.0-x86_64-1.txz: Upgraded.
kde/kconfig-5.90.0-x86_64-1.txz: Upgraded.
kde/kconfigwidgets-5.90.0-x86_64-1.txz: Upgraded.
kde/kcontacts-5.90.0-x86_64-1.txz: Upgraded.
kde/kcoreaddons-5.90.0-x86_64-1.txz: Upgraded.
kde/kcrash-5.90.0-x86_64-1.txz: Upgraded.
kde/kdav-5.90.0-x86_64-1.txz: Upgraded.
kde/kdbusaddons-5.90.0-x86_64-1.txz: Upgraded.
kde/kdeclarative-5.90.0-x86_64-1.txz: Upgraded.
kde/kded-5.90.0-x86_64-1.txz: Upgraded.
kde/kdelibs4support-5.90.0-x86_64-1.txz: Upgraded.
kde/kdesignerplugin-5.90.0-x86_64-1.txz: Upgraded.
kde/kdesu-5.90.0-x86_64-1.txz: Upgraded.
kde/kdewebkit-5.90.0-x86_64-1.txz: Upgraded.
kde/kdnssd-5.90.0-x86_64-1.txz: Upgraded.
kde/kdoctools-5.90.0-x86_64-1.txz: Upgraded.
kde/kemoticons-5.90.0-x86_64-1.txz: Upgraded.
kde/kfilemetadata-5.90.0-x86_64-1.txz: Upgraded.
kde/kglobalaccel-5.90.0-x86_64-1.txz: Upgraded.
kde/kguiaddons-5.90.0-x86_64-1.txz: Upgraded.
kde/kholidays-5.90.0-x86_64-1.txz: Upgraded.
kde/khtml-5.90.0-x86_64-1.txz: Upgraded.
kde/ki18n-5.90.0-x86_64-1.txz: Upgraded.
kde/kiconthemes-5.90.0-x86_64-1.txz: Upgraded.
kde/kidletime-5.90.0-x86_64-1.txz: Upgraded.
kde/kimageformats-5.90.0-x86_64-1.txz: Upgraded.
kde/kinit-5.90.0-x86_64-1.txz: Upgraded.
kde/kio-5.90.0-x86_64-1.txz: Upgraded.
kde/kirigami2-5.90.0-x86_64-1.txz: Upgraded.
kde/kitemmodels-5.90.0-x86_64-1.txz: Upgraded.
kde/kitemviews-5.90.0-x86_64-1.txz: Upgraded.
kde/kjobwidgets-5.90.0-x86_64-1.txz: Upgraded.
kde/kjs-5.90.0-x86_64-1.txz: Upgraded.
kde/kjsembed-5.90.0-x86_64-1.txz: Upgraded.
kde/kmediaplayer-5.90.0-x86_64-1.txz: Upgraded.
kde/knewstuff-5.90.0-x86_64-1.txz: Upgraded.
kde/knotifications-5.90.0-x86_64-1.txz: Upgraded.
kde/knotifyconfig-5.90.0-x86_64-1.txz: Upgraded.
kde/kpackage-5.90.0-x86_64-1.txz: Upgraded.
kde/kparts-5.90.0-x86_64-1.txz: Upgraded.
kde/kpeople-5.90.0-x86_64-1.txz: Upgraded.
kde/kplotting-5.90.0-x86_64-1.txz: Upgraded.
kde/kpty-5.90.0-x86_64-1.txz: Upgraded.
kde/kquickcharts-5.90.0-x86_64-1.txz: Upgraded.
kde/kross-5.90.0-x86_64-1.txz: Upgraded.
kde/krunner-5.90.0-x86_64-1.txz: Upgraded.
kde/kservice-5.90.0-x86_64-1.txz: Upgraded.
kde/ktexteditor-5.90.0-x86_64-1.txz: Upgraded.
kde/ktextwidgets-5.90.0-x86_64-1.txz: Upgraded.
kde/kunitconversion-5.90.0-x86_64-1.txz: Upgraded.
kde/kwallet-5.90.0-x86_64-1.txz: Upgraded.
kde/kwayland-5.90.0-x86_64-1.txz: Upgraded.
kde/kwidgetsaddons-5.90.0-x86_64-1.txz: Upgraded.
kde/kwindowsystem-5.90.0-x86_64-1.txz: Upgraded.
kde/kxmlgui-5.90.0-x86_64-1.txz: Upgraded.
kde/kxmlrpcclient-5.90.0-x86_64-1.txz: Upgraded.
kde/latte-dock-0.10.7-x86_64-1.txz: Upgraded.
kde/modemmanager-qt-5.90.0-x86_64-1.txz: Upgraded.
kde/networkmanager-qt-5.90.0-x86_64-1.txz: Upgraded.
kde/oxygen-icons5-5.90.0-noarch-1.txz: Upgraded.
kde/plasma-framework-5.90.0-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.23.5-x86_64-2.txz: Rebuilt.
[PATCH] [libtaskmanager] Increase buffer for pipewire format negotiation.
[PATCH] runners/shell: Port from KToolInvocation::invokeTerminal
to KTerminalLauncherJob.
Thanks to gmgf.
kde/prison-5.90.0-x86_64-1.txz: Upgraded.
kde/purpose-5.90.0-x86_64-1.txz: Upgraded.
kde/qqc2-desktop-style-5.90.0-x86_64-1.txz: Upgraded.
kde/solid-5.90.0-x86_64-1.txz: Upgraded.
kde/sonnet-5.90.0-x86_64-1.txz: Upgraded.
kde/syndication-5.90.0-x86_64-1.txz: Upgraded.
kde/syntax-highlighting-5.90.0-x86_64-1.txz: Upgraded.
kde/threadweaver-5.90.0-x86_64-1.txz: Upgraded.
l/SDL2-2.0.20-x86_64-1.txz: Upgraded.
l/SDL2_ttf-2.0.18-x86_64-1.txz: Upgraded.
l/libsigsegv-2.14-x86_64-1.txz: Upgraded.
l/pango-1.48.11-x86_64-1.txz: Upgraded.
l/python-urllib3-1.26.8-x86_64-1.txz: Upgraded.
n/getmail-6.18.6-x86_64-1.txz: Upgraded.
n/iproute2-5.16.0-x86_64-1.txz: Upgraded.
n/metamail-2.7-x86_64-10.txz: Rebuilt.
Fixed misnamed mimencode man page. Thanks to mbeninca.
n/mtr-0.95-x86_64-1.txz: Upgraded.
n/socat-1.7.4.3-x86_64-1.txz: Upgraded.
xap/freerdp-2.5.0-x86_64-1.txz: Upgraded.
xap/gnuplot-5.4.3-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-91.5.0esr-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/91.5.0/releasenotes/
https://www.mozilla.org/security/advisories/mfsa2022-02/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22746
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22743
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22742
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22741
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22740
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22738
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22737
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-4140
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22748
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22745
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22744
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22747
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22739
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22751
xap/mozilla-thunderbird-91.5.0-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/91.5.0/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2022-03/
xap/vim-gvim-8.2.4065-x86_64-1.txz: Upgraded.
Slackware 43-bit
a/cryptsetup-2.4.3-i586-1.txz: Upgraded.
a/aaa_base-15.0-i586-2.txz: Rebuilt.
a/aaa_libraries-15.0-i586-13.txz: Rebuilt.
a/eudev-3.2.11-i586-1.txz: Upgraded.
a/haveged-1.9.17-i586-1.txz: Upgraded.
a/hdparm-9.63-i586-1.txz: Upgraded.
a/kernel-generic-5.15.14-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.15.14_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.15.14-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.15.14_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.15.14-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.15.14_smp-i686-1.txz: Upgraded.
ap/vim-8.2.4065-i586-1.txz: Upgraded.
d/kernel-headers-5.15.14_smp-x86-1.txz: Upgraded.
d/strace-5.16-i586-1.txz: Upgraded.
d/vala-0.54.6-i586-1.txz: Upgraded.
k/kernel-source-5.15.14_smp-noarch-1.txz: Upgraded.
kde/attica-5.90.0-i586-1.txz: Upgraded.
kde/baloo-5.90.0-i586-1.txz: Upgraded.
kde/bluez-qt-5.90.0-i586-1.txz: Upgraded.
kde/extra-cmake-modules-5.90.0-i586-1.txz: Upgraded.
kde/frameworkintegration-5.90.0-i586-1.txz: Upgraded.
kde/kactivities-5.90.0-i586-1.txz: Upgraded.
kde/kactivities-stats-5.90.0-i586-1.txz: Upgraded.
kde/kapidox-5.90.0-i586-1.txz: Upgraded.
kde/karchive-5.90.0-i586-1.txz: Upgraded.
kde/kauth-5.90.0-i586-1.txz: Upgraded.
kde/kbookmarks-5.90.0-i586-1.txz: Upgraded.
kde/kcalendarcore-5.90.0-i586-1.txz: Upgraded.
kde/kcmutils-5.90.0-i586-1.txz: Upgraded.
kde/kcodecs-5.90.0-i586-1.txz: Upgraded.
kde/kcompletion-5.90.0-i586-1.txz: Upgraded.
kde/kconfig-5.90.0-i586-1.txz: Upgraded.
kde/kconfigwidgets-5.90.0-i586-1.txz: Upgraded.
kde/kcontacts-5.90.0-i586-1.txz: Upgraded.
kde/kcoreaddons-5.90.0-i586-1.txz: Upgraded.
kde/kcrash-5.90.0-i586-1.txz: Upgraded.
kde/kdav-5.90.0-i586-1.txz: Upgraded.
kde/kdbusaddons-5.90.0-i586-1.txz: Upgraded.
kde/kdeclarative-5.90.0-i586-1.txz: Upgraded.
kde/kded-5.90.0-i586-1.txz: Upgraded.
kde/kdelibs4support-5.90.0-i586-1.txz: Upgraded.
kde/kdesignerplugin-5.90.0-i586-1.txz: Upgraded.
kde/kdesu-5.90.0-i586-1.txz: Upgraded.
kde/kdewebkit-5.90.0-i586-1.txz: Upgraded.
kde/kdnssd-5.90.0-i586-1.txz: Upgraded.
kde/kdoctools-5.90.0-i586-1.txz: Upgraded.
kde/kemoticons-5.90.0-i586-1.txz: Upgraded.
kde/kfilemetadata-5.90.0-i586-1.txz: Upgraded.
kde/kglobalaccel-5.90.0-i586-1.txz: Upgraded.
kde/kguiaddons-5.90.0-i586-1.txz: Upgraded.
kde/kholidays-5.90.0-i586-1.txz: Upgraded.
kde/khtml-5.90.0-i586-1.txz: Upgraded.
kde/ki18n-5.90.0-i586-1.txz: Upgraded.
kde/kiconthemes-5.90.0-i586-1.txz: Upgraded.
kde/kidletime-5.90.0-i586-1.txz: Upgraded.
kde/kimageformats-5.90.0-i586-1.txz: Upgraded.
kde/kinit-5.90.0-i586-1.txz: Upgraded.
kde/kio-5.90.0-i586-1.txz: Upgraded.
kde/kirigami2-5.90.0-i586-1.txz: Upgraded.
kde/kitemmodels-5.90.0-i586-1.txz: Upgraded.
kde/kitemviews-5.90.0-i586-1.txz: Upgraded.
kde/kjobwidgets-5.90.0-i586-1.txz: Upgraded.
kde/kjs-5.90.0-i586-1.txz: Upgraded.
kde/kjsembed-5.90.0-i586-1.txz: Upgraded.
kde/kmediaplayer-5.90.0-i586-1.txz: Upgraded.
kde/knewstuff-5.90.0-i586-1.txz: Upgraded.
kde/knotifications-5.90.0-i586-1.txz: Upgraded.
kde/knotifyconfig-5.90.0-i586-1.txz: Upgraded.
kde/kpackage-5.90.0-i586-1.txz: Upgraded.
kde/kparts-5.90.0-i586-1.txz: Upgraded.
kde/kpeople-5.90.0-i586-1.txz: Upgraded.
kde/kplotting-5.90.0-i586-1.txz: Upgraded.
kde/kpty-5.90.0-i586-1.txz: Upgraded.
kde/kquickcharts-5.90.0-i586-1.txz: Upgraded.
kde/kross-5.90.0-i586-1.txz: Upgraded.
kde/krunner-5.90.0-i586-1.txz: Upgraded.
kde/kservice-5.90.0-i586-1.txz: Upgraded.
kde/ktexteditor-5.90.0-i586-1.txz: Upgraded.
kde/ktextwidgets-5.90.0-i586-1.txz: Upgraded.
kde/kunitconversion-5.90.0-i586-1.txz: Upgraded.
kde/kwallet-5.90.0-i586-1.txz: Upgraded.
kde/kwayland-5.90.0-i586-1.txz: Upgraded.
kde/kwidgetsaddons-5.90.0-i586-1.txz: Upgraded.
kde/kwindowsystem-5.90.0-i586-1.txz: Upgraded.
kde/kxmlgui-5.90.0-i586-1.txz: Upgraded.
kde/kxmlrpcclient-5.90.0-i586-1.txz: Upgraded.
kde/latte-dock-0.10.7-i586-1.txz: Upgraded.
kde/modemmanager-qt-5.90.0-i586-1.txz: Upgraded.
kde/networkmanager-qt-5.90.0-i586-1.txz: Upgraded.
kde/plasma-framework-5.90.0-i586-1.txz: Upgraded.
kde/plasma-workspace-5.23.5-i586-2.txz: Rebuilt.
Thanks to gmgf.
kde/prison-5.90.0-i586-1.txz: Upgraded.
kde/purpose-5.90.0-i586-1.txz: Upgraded.
kde/qqc2-desktop-style-5.90.0-i586-1.txz: Upgraded.
kde/solid-5.90.0-i586-1.txz: Upgraded.
kde/sonnet-5.90.0-i586-1.txz: Upgraded.
kde/syndication-5.90.0-i586-1.txz: Upgraded.
kde/syntax-highlighting-5.90.0-i586-1.txz: Upgraded.
kde/threadweaver-5.90.0-i586-1.txz: Upgraded.
l/SDL2-2.0.20-i586-1.txz: Upgraded.
l/SDL2_ttf-2.0.18-i586-1.txz: Upgraded.
l/libsigsegv-2.14-i586-1.txz: Upgraded.
l/pango-1.48.11-i586-1.txz: Upgraded.
l/python-urllib3-1.26.8-i586-1.txz: Upgraded.
n/getmail-6.18.6-i586-1.txz: Upgraded.
n/iproute2-5.16.0-i586-1.txz: Upgraded.
n/metamail-2.7-i586-10.txz: Rebuilt.
n/mtr-0.95-i586-1.txz: Upgraded.
n/socat-1.7.4.3-i586-1.txz: Upgraded.
xap/freerdp-2.5.0-i586-1.txz: Upgraded.
xap/gnuplot-5.4.3-i586-1.txz: Upgraded.
xap/mozilla-firefox-91.5.0esr-i686-1.txz: Upgraded.
xap/mozilla-thunderbird-91.5.0-i686-1.txz: Upgraded.
xap/vim-gvim-8.2.4065-i586-1.txz: Upgraded.
extra/linux-5.15.14-nosmp-sdk/*: Upgraded.
Napisano: 19 Jan 2022, 22:36
Slackware 64-bit
Wed Jan 19 18:18:02 UTC 2022
ap/inxi-3.3.12_1-noarch-1.txz: Upgraded.
ap/man-db-2.9.4-x86_64-3.txz: Rebuilt.
Don't use --no-purge in the daily cron job to update the databases.
l/gst-plugins-bad-free-1.18.5-x86_64-4.txz: Rebuilt.
Link against neon-0.32.2. Thanks to marav.
n/bind-9.16.25-x86_64-1.txz: Upgraded.
n/ethtool-5.16-x86_64-1.txz: Upgraded.
n/samba-4.15.4-x86_64-1.txz: Upgraded.
n/wpa_supplicant-2.10-x86_64-1.txz: Upgraded.
The implementations of EAP-pwd in hostapd before 2.10 and wpa_supplicant
before 2.10 are vulnerable to side-channel attacks as a result of cache
access patterns.
NOTE: this issue exists because of an incomplete fix for CVE-2019-9495.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23303
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23304
x/xterm-370-x86_64-6.txz: Rebuilt.
XTerm-console: improve the font settings. Thanks to GazL.
Tue Jan 18 20:39:39 UTC 2022
l/rpcsvc-proto-1.4.3-x86_64-1.txz: Upgraded.
x/xterm-370-x86_64-5.txz: Rebuilt.
XTerm-console: don't include locale options by default. Fix typo in comment.
Thanks to GazL.
Mon Jan 17 22:44:42 UTC 2022
Things haven't quite settled down yet with more bugfixes and a couple of safe
upgrades, so not today folks. But enjoy Slackware's half-birthday anyway! ;-)
ap/slackpkg-15.0.10-noarch-1.txz: Upgraded.
Fix mirrors.ucr.ac.cr link address (Emmet Ford)
Remove wroc.pl mirrors (Emmet Ford)
Remove kddilabs.jp from mirrors (Emmet Ford)
Unattended usage improvements (PiterPUNK)
Create file to flag if the system needs restart (PiterPUNK)
Thanks to Robby Workman.
kde/kstars-3.5.7-x86_64-1.txz: Upgraded.
kde/kwin-5.23.5-x86_64-2.txz: Rebuilt.
[PATCH] Bypass wayland interface blacklisting.
Thanks to LuckyCyborg.
kde/plasma-workspace-5.23.5-x86_64-3.txz: Rebuilt.
[PATCH 1/2] Revert "Drop setupX11 from startplasma-waylandsession."
[PATCH 2/2] Revert "Drop X11 root properties for KDE full session."
l/libical-3.0.13-x86_64-1.txz: Upgraded.
n/p11-kit-0.24.1-x86_64-1.txz: Upgraded.
n/stunnel-5.62-x86_64-1.txz: Upgraded.
x/xterm-370-x86_64-4.txz: Rebuilt.
Fixed XTerm-console (previously XTerm.linux.console).
Renamed XTerm.upstream.default to XTerm-upstream.
Thanks to GazL.
xap/fluxbox-1.3.7-x86_64-6.txz: Rebuilt.
[PATCH] replace FbRootWindow::depth with maxDepth.
Thanks to OldHolborn.
xap/geeqie-1.7.1-x86_64-1.txz: Upgraded.
Sun Jan 16 21:33:27 UTC 2022
a/aaa_libraries-15.0-x86_64-14.txz: Rebuilt.
Upgraded: libexpat.so.1.8.3.
a/kernel-generic-5.15.15-x86_64-1.txz: Upgraded.
a/kernel-huge-5.15.15-x86_64-1.txz: Upgraded.
a/kernel-modules-5.15.15-x86_64-1.txz: Upgraded.
ap/cups-filters-1.28.11-x86_64-1.txz: Upgraded.
ap/ksh93-1.0_20220114_e569f23e-x86_64-1.txz: Upgraded.
ap/vim-8.2.4115-x86_64-1.txz: Upgraded.
d/gdb-11.2-x86_64-1.txz: Upgraded.
d/kernel-headers-5.15.15-x86-1.txz: Upgraded.
k/kernel-source-5.15.15-noarch-1.txz: Upgraded.
kde/kwayland-server-5.23.5-x86_64-2.txz: Rebuilt.
[PATCH] Store surface object in tablet cursor using QPointer.
l/expat-2.4.3-x86_64-1.txz: Upgraded.
Fix issues with left shifts by >=29 places resulting in:
a) realloc acting as free
b) realloc allocating too few bytes
c) undefined behavior
Fix integer overflow on variable m_groupSize in function doProlog leading
to realloc acting as free. Impact is denial of service or other undefined
behavior.
Prevent integer overflows near memory allocation at multiple places.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-45960
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-46143
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22822
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22823
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22824
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22825
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22826
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22827
l/libunwind-1.6.2-x86_64-1.txz: Upgraded.
x/xterm-370-x86_64-3.txz: Rebuilt.
Ship a sample XTerm.linux.console app-defaults file. Thanks to GazL.
xap/vim-gvim-8.2.4115-x86_64-1.txz: Upgraded.
xap/xsnow-3.4.3-x86_64-1.txz: Upgraded.
Sun Jan 16 07:23:29 UTC 2022
a/aaa_base-15.0-x86_64-3.txz: Rebuilt.
In initial email to root, use the new /var/lib/pkgtools/ paths to the files
for packages and scripts. Thanks to franzen.
a/btrfs-progs-5.16-x86_64-1.txz: Upgraded.
d/python3-3.9.10-x86_64-1.txz: Upgraded.
d/rust-1.58.0-x86_64-1.txz: Upgraded.
kde/digikam-7.5.0-x86_64-1.txz: Upgraded.
kde/kglobalaccel-5.90.0-x86_64-2.txz: Rebuilt.
Applied patch:
[PATCH] Prevent kglobalaccel5 getting activated on non-Plasma systems.
Although this patch was later reverted, I'm on board with the need for it.
If it causes any problems, please let me know soon.
Thanks to Lockywolf.
kde/kid3-3.9.1-x86_64-1.txz: Upgraded.
kde/plasma-wayland-protocols-1.6.0-x86_64-1.txz: Upgraded.
kde/sddm-0.19.0-x86_64-10.txz: Rebuilt.
Allow the init program to properly supervise sddm when entering runlevel 4.
Thanks to mumahendras3.
l/neon-0.32.2-x86_64-1.txz: Upgraded.
l/netpbm-10.97.02-x86_64-1.txz: Upgraded.
n/postfix-3.6.4-x86_64-1.txz: Upgraded.
x/mesa-21.3.4-x86_64-1.txz: Upgraded.
x/xterm-370-x86_64-2.txz: Rebuilt.
Use upstream app-defaults again. Thanks to OldHolborn.
Slackware 32-bit
ap/man-db-2.9.4-i586-3.txz: Rebuilt.
l/gst-plugins-bad-free-1.18.5-i586-4.txz: Rebuilt.
n/bind-9.16.25-i586-1.txz: Upgraded.
n/ethtool-5.16-i586-1.txz: Upgraded.
n/samba-4.15.4-i586-1.txz: Upgraded.
n/wpa_supplicant-2.10-i586-1.txz: Upgraded.
access patterns.
x/xterm-370-i586-6.txz: Rebuilt.
l/rpcsvc-proto-1.4.3-i586-1.txz: Upgraded.
x/xterm-370-i586-5.txz: Rebuilt.
Thanks to GazL.
kde/kstars-3.5.7-i586-1.txz: Upgraded.
kde/kwin-5.23.5-i586-2.txz: Rebuilt.
kde/plasma-workspace-5.23.5-i586-3.txz: Rebuilt.
l/libical-3.0.13-i586-1.txz: Upgraded.
n/p11-kit-0.24.1-i586-1.txz: Upgraded.
n/stunnel-5.62-i586-1.txz: Upgraded.
x/xterm-370-i586-4.txz: Rebuilt.
Thanks to GazL.
xap/fluxbox-1.3.7-i586-6.txz: Rebuilt.
xap/geeqie-1.7.1-i586-1.txz: Upgraded.
a/aaa_libraries-15.0-i586-14.txz: Rebuilt.
a/kernel-generic-5.15.15-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.15.15_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.15.15-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.15.15_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.15.15-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.15.15_smp-i686-1.txz: Upgraded.
ap/cups-filters-1.28.11-i586-1.txz: Upgraded.
ap/ksh93-1.0_20220114_e569f23e-i586-1.txz: Upgraded.
ap/vim-8.2.4115-i586-1.txz: Upgraded.
d/gdb-11.2-i586-1.txz: Upgraded.
d/kernel-headers-5.15.15_smp-x86-1.txz: Upgraded.
k/kernel-source-5.15.15_smp-noarch-1.txz: Upgraded.
kde/kwayland-server-5.23.5-i586-2.txz: Rebuilt.
l/expat-2.4.3-i586-1.txz: Upgraded.
behavior.
l/libunwind-1.6.2-i586-1.txz: Upgraded.
x/xterm-370-i586-3.txz: Rebuilt.
xap/vim-gvim-8.2.4115-i586-1.txz: Upgraded.
xap/xsnow-3.4.3-i586-1.txz: Upgraded.
extra/linux-5.15.15-nosmp-sdk/*: Upgraded.
a/aaa_base-15.0-i586-3.txz: Rebuilt.
a/btrfs-progs-5.16-i586-1.txz: Upgraded.
d/python3-3.9.10-i586-1.txz: Upgraded.
d/rust-1.58.0-i686-1.txz: Upgraded.
kde/digikam-7.5.0-i586-1.txz: Upgraded.
kde/kglobalaccel-5.90.0-i586-2.txz: Rebuilt.
Applied patch:
kde/kid3-3.9.1-i586-1.txz: Upgraded.
kde/plasma-wayland-protocols-1.6.0-i586-1.txz: Upgraded.
kde/sddm-0.19.0-i586-10.txz: Rebuilt.
l/neon-0.32.2-i586-1.txz: Upgraded.
l/netpbm-10.97.02-i586-1.txz: Upgraded.
n/postfix-3.6.4-i586-1.txz: Upgraded.
x/mesa-21.3.4-i586-1.txz: Upgraded.
x/xterm-370-i586-2.txz: Rebuilt.
Napisano: 25 Jan 2022, 23:15
Slackware 64-bit
Tue Jan 25 20:10:35 UTC 2022
d/icecream-1.3.1-x86_64-4.txz: Rebuilt.
rc.icecream.conf: generate an error message and avoid a hang when
"hostname -d" doesn't work, usually because the hostname in /etc/HOSTNAME
can't be resolved. Thanks to franzen.
kde/latte-dock-0.10.8-x86_64-1.txz: Upgraded.
xap/geeqie-1.7.2-x86_64-1.txz: Upgraded.
Tue Jan 25 06:16:36 UTC 2022
It may look like we're currently experiencing more stuckness, but this will
lead us to Quality. We'll have this release in the can before you know it.
a/aaa_glibc-solibs-2.33-x86_64-5.txz: Rebuilt.
a/aaa_libraries-15.0-x86_64-16.txz: Rebuilt.
Rebuilt to pick up the patched libexpat.so.1.8.3.
a/kernel-firmware-20220124_eb8ea1b-noarch-1.txz: Upgraded.
a/kernel-generic-5.15.16-x86_64-2.txz: Upgraded.
a/kernel-huge-5.15.16-x86_64-2.txz: Upgraded.
-9P_FSCACHE n
9P_FS m -> y
Thanks to peake.
a/kernel-modules-5.15.16-x86_64-2.txz: Upgraded.
a/mkinitrd-1.4.11-x86_64-27.txz: Rebuilt.
mkinitrd_command_generator.sh: properly detect partitions of a RAID device.
Thanks to perrin4869.
a/util-linux-2.37.3-x86_64-1.txz: Upgraded.
This release fixes two security mount(8) and umount(8) issues:
An issue related to parsing the /proc/self/mountinfo file allows an
unprivileged user to unmount other user's filesystems that are either
world-writable themselves or mounted in a world-writable directory.
Improper UID check in libmount allows an unprivileged user to unmount
FUSE filesystems of users with similar UID.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3995
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3996
ap/vim-8.2.4212-x86_64-1.txz: Upgraded.
d/git-2.35.0-x86_64-1.txz: Upgraded.
d/kernel-headers-5.15.16-x86-2.txz: Upgraded.
k/kernel-source-5.15.16-noarch-2.txz: Upgraded.
l/expat-2.4.3-x86_64-2.txz: Rebuilt.
Fix signed integer overflow in function XML_GetBuffer for when
XML_CONTEXT_BYTES is defined to >0 (which is both common and
default). Impact is denial of service or other undefined behavior.
While we're here, also patch a memory leak on output file opening error.
Thanks to marav.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23852
l/fluidsynth-2.2.5-x86_64-1.txz: Upgraded.
l/glibc-2.33-x86_64-5.txz: Rebuilt.
This update patches two security issues:
Unexpected return value from glibc's realpath().
Off-by-one buffer overflow/underflow in glibc's getcwd().
Thanks to Qualys Research Labs for reporting these issues.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3998
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-3999
l/glibc-i18n-2.33-x86_64-5.txz: Rebuilt.
l/glibc-profile-2.33-x86_64-5.txz: Rebuilt.
l/tdb-1.4.6-x86_64-1.txz: Upgraded.
x/xf86-input-libinput-1.2.1-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-91.5.1-x86_64-1.txz: Upgraded.
This is a bugfix release.
https://www.mozilla.org/en-US/thunderbird/91.5.1/releasenotes/
xap/vim-gvim-8.2.4212-x86_64-1.txz: Upgraded.
Sun Jan 23 19:36:54 UTC 2022
l/imagemagick-7.1.0_20-x86_64-1.txz: Upgraded.
Built using --with-fftw. Thanks to stormbr.
Sun Jan 23 01:17:39 UTC 2022
ap/ddrescue-1.26-x86_64-1.txz: Upgraded.
d/parallel-20220122-noarch-1.txz: Upgraded.
l/libimobiledevice-20211124_2c6121d-x86_64-2.txz: Rebuilt.
Don't include compatibility pkgconfig symlink. It's unlikely that
anything requires it.
l/libimobiledevice-glue-20211125_3cb687b-x86_64-2.txz: Rebuilt.
Removed broken pkgconfig symlink. Thanks to marav.
Fri Jan 21 19:58:34 UTC 2022
kde/kconfigwidgets-5.90.1-x86_64-1.txz: Upgraded.
l/libwebp-1.2.2-x86_64-1.txz: Upgraded.
Fri Jan 21 05:47:49 UTC 2022
a/aaa_libraries-15.0-x86_64-15.txz: Rebuilt.
Upgraded: libzstd.so.1.5.2.
a/kernel-firmware-20220119_0c6a7b3-noarch-1.txz: Upgraded.
a/kernel-generic-5.15.16-x86_64-1.txz: Upgraded.
a/kernel-huge-5.15.16-x86_64-1.txz: Upgraded.
a/kernel-modules-5.15.16-x86_64-1.txz: Upgraded.
ap/vim-8.2.4166-x86_64-1.txz: Upgraded.
d/kernel-headers-5.15.16-x86-1.txz: Upgraded.
d/rust-1.58.1-x86_64-1.txz: Upgraded.
k/kernel-source-5.15.16-noarch-1.txz: Upgraded.
l/qt5-5.15.3_20211130_014c375b-x86_64-2.txz: Rebuilt.
[PATCH] Move the wayland socket polling to a separate event thread.
l/svgalib-1.9.25-x86_64-7.txz: Rebuilt.
Don't try to use the (broken) assembly. Thanks to nobodino.
l/zstd-1.5.2-x86_64-1.txz: Upgraded.
x/ibus-m17n-1.4.9-x86_64-1.txz: Upgraded.
xap/vim-gvim-8.2.4166-x86_64-1.txz: Upgraded.
extra/php80/php80-8.0.15-x86_64-1.txz: Upgraded.
extra/php81/php81-8.1.2-x86_64-1.txz: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Slackware 32-bit
d/icecream-1.3.1-i586-4.txz: Rebuilt.
kde/latte-dock-0.10.8-i586-1.txz: Upgraded.
xap/geeqie-1.7.2-i586-1.txz: Upgraded.
a/aaa_glibc-solibs-2.33-i586-5.txz: Rebuilt.
a/aaa_libraries-15.0-i586-16.txz: Rebuilt.
a/kernel-generic-5.15.16-i586-2.txz: Upgraded.
a/kernel-generic-smp-5.15.16_smp-i686-2.txz: Upgraded.
a/kernel-huge-5.15.16-i586-2.txz: Upgraded.
-9P_FSCACHE n
9P_FS m -> y
Thanks to peake.
a/kernel-huge-smp-5.15.16_smp-i686-2.txz: Upgraded.
-9P_FSCACHE n
9P_FS m -> y
Thanks to peake.
a/kernel-modules-5.15.16-i586-2.txz: Upgraded.
a/kernel-modules-smp-5.15.16_smp-i686-2.txz: Upgraded.
a/mkinitrd-1.4.11-i586-27.txz: Rebuilt.
a/util-linux-2.37.3-i586-1.txz: Upgraded.
ap/vim-8.2.4212-i586-1.txz: Upgraded.
d/git-2.35.0-i586-1.txz: Upgraded.
d/kernel-headers-5.15.16_smp-x86-2.txz: Upgraded.
k/kernel-source-5.15.16_smp-noarch-2.txz: Upgraded.
l/expat-2.4.3-i586-2.txz: Rebuilt.
Thanks to marav.
l/fluidsynth-2.2.5-i586-1.txz: Upgraded.
l/glibc-2.33-i586-5.txz: Rebuilt.
l/glibc-i18n-2.33-i586-5.txz: Rebuilt.
l/glibc-profile-2.33-i586-5.txz: Rebuilt.
l/tdb-1.4.6-i586-1.txz: Upgraded.
x/xf86-input-libinput-1.2.1-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-91.5.1-i686-1.txz: Upgraded.
xap/vim-gvim-8.2.4212-i586-1.txz: Upgraded.
extra/linux-5.15.16-nosmp-sdk/*: Upgraded.
l/imagemagick-7.1.0_20-i586-1.txz: Upgraded.
ap/ddrescue-1.26-i586-1.txz: Upgraded.
l/libimobiledevice-20211124_2c6121d-i586-2.txz: Rebuilt.
l/libimobiledevice-glue-20211125_3cb687b-i586-2.txz: Rebuilt.
kde/kconfigwidgets-5.90.1-i586-1.txz: Upgraded.
l/libwebp-1.2.2-i586-1.txz: Upgraded.
a/aaa_libraries-15.0-i586-15.txz: Rebuilt.
a/kernel-generic-5.15.16-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.15.16_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.15.16-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.15.16_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.15.16-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.15.16_smp-i686-1.txz: Upgraded.
ap/vim-8.2.4166-i586-1.txz: Upgraded.
d/kernel-headers-5.15.16_smp-x86-1.txz: Upgraded.
d/rust-1.58.1-i686-1.txz: Upgraded.
k/kernel-source-5.15.16_smp-noarch-1.txz: Upgraded.
l/qt5-5.15.3_20211130_014c375b-i586-2.txz: Rebuilt.
l/svgalib-1.9.25-i586-7.txz: Rebuilt.
l/zstd-1.5.2-i586-1.txz: Upgraded.
x/ibus-m17n-1.4.9-i586-1.txz: Upgraded.
xap/vim-gvim-8.2.4166-i586-1.txz: Upgraded.
extra/php80/php80-8.0.15-i586-1.txz: Upgraded.
extra/php81/php81-8.1.2-i586-1.txz: Upgraded.
Napisano: 29 Jan 2022, 23:33
Slackware 64-bit
Sat Jan 29 19:23:50 UTC 2022
a/kernel-generic-5.15.18-x86_64-1.txz: Upgraded.
a/kernel-huge-5.15.18-x86_64-1.txz: Upgraded.
a/kernel-modules-5.15.18-x86_64-1.txz: Upgraded.
ap/vim-8.2.4256-x86_64-1.txz: Upgraded.
d/kernel-headers-5.15.18-x86-1.txz: Upgraded.
k/kernel-source-5.15.18-noarch-1.txz: Upgraded.
xap/vim-gvim-8.2.4256-x86_64-1.txz: Upgraded.
Sat Jan 29 06:17:05 UTC 2022
a/rpm2tgz-1.2.2-x86_64-5.txz: Rebuilt.
rpm2targz: when extracting the cpio archive from inside the RPM, use
--no-absolute-filenames to protect against a poorly made RPM scribbling all
over system files/directories. Thanks to Sl4ck3ver.
Support -i option to ignore non-zero exit value from rpm2cpio.
This allows repackaging some malformed RPMs.
Thanks to ricky_cardo for the sample malformed RPM.
Fri Jan 28 21:01:03 UTC 2022
a/plzip-1.10-x86_64-1.txz: Upgraded.
ap/sudo-1.9.9-x86_64-1.txz: Upgraded.
d/Cython-0.29.27-x86_64-1.txz: Upgraded.
d/poke-2.0-x86_64-1.txz: Upgraded.
l/python-charset-normalizer-2.0.10-x86_64-1.txz: Upgraded.
x/mesa-21.3.5-x86_64-2.txz: Rebuilt.
Include eglinfo utility. Thanks to LuckyCyborg.
x/wayland-protocols-1.25-noarch-1.txz: Upgraded.
Thu Jan 27 22:43:13 UTC 2022
a/aaa_libraries-15.0-x86_64-18.txz: Rebuilt.
a/kernel-generic-5.15.17-x86_64-1.txz: Upgraded.
a/kernel-huge-5.15.17-x86_64-1.txz: Upgraded.
a/kernel-modules-5.15.17-x86_64-1.txz: Upgraded.
a/lzlib-1.13-x86_64-1.txz: Upgraded.
a/sysvinit-scripts-15.0-noarch-8.txz: Rebuilt.
rc.S: clear /var/lock/subsys before starting libcgroup services.
Thanks to pyllyukko.
ap/pamixer-1.5-x86_64-2.txz: Rebuilt.
Recompiled against boost-1.78.0.
d/kernel-headers-5.15.17-x86-1.txz: Upgraded.
k/kernel-source-5.15.17-noarch-1.txz: Upgraded.
kde/kig-21.12.1-x86_64-2.txz: Rebuilt.
kde/kopeninghours-21.12.1-x86_64-2.txz: Rebuilt.
kde/krita-5.0.2-x86_64-2.txz: Rebuilt.
l/boost-1.78.0-x86_64-1.txz: Upgraded.
I hadn't planned to update this at such a late stage, but POV-Ray needs it
and everything we ship builds fine against it. Thanks to bender647.
l/cryfs-0.10.3-x86_64-4.txz: Rebuilt.
l/expat-2.4.3-x86_64-3.txz: Rebuilt.
Prevent integer overflow in doProlog.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23990
l/netpbm-10.97.03-x86_64-1.txz: Upgraded.
l/openexr-2.5.7-x86_64-5.txz: Rebuilt.
l/pipewire-0.3.44-x86_64-1.txz: Upgraded.
n/fetchmail-6.4.27-x86_64-1.txz: Upgraded.
n/libgpg-error-1.44-x86_64-1.txz: Upgraded.
x/mesa-21.3.5-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-91.5.1esr-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/91.5.1/releasenotes/
extra/rust-for-mozilla/rust-1.54.0-x86_64-4.txz: Rebuilt.
Removed duplicated libLLVM shared library.
Wed Jan 26 20:46:44 UTC 2022
a/aaa_libraries-15.0-x86_64-17.txz: Rebuilt.
Upgraded: libcap.so.2.63, libglib-2.0.so.0.7000.3,
libgmodule-2.0.so.0.7000.3, libgobject-2.0.so.0.7000.3,
libgthread-2.0.so.0.7000.3, libtdb.so.1.4.6.
a/mkinitrd-1.4.11-x86_64-28.txz: Rebuilt.
Support kernel modules compressed with xz. Thanks to baldzhang.
l/glib2-2.70.3-x86_64-1.txz: Upgraded.
l/libcap-2.63-x86_64-1.txz: Upgraded.
n/bluez-5.63-x86_64-2.txz: Rebuilt.
rc.bluetooth: use #!/bin/bash shebang.
Filter commented and empty lines when parsing uart.conf.
Thanks to atelszewski.
Wed Jan 26 04:37:35 UTC 2022
l/polkit-0.120-x86_64-2.txz: Rebuilt.
[PATCH] pkexec: local privilege escalation.
Thanks to Qualys Research Labs for reporting this issue.
https://blog.qualys.com/vulnerabilities-threat-research/2022/01/25/pwnkit-local-privilege-escalation-vulnerability-discovered-in-polkits-pkexec-cve-2021-4034
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-4034
Slackware 32-bit
a/kernel-generic-5.15.18-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.15.18_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.15.18-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.15.18_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.15.18-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.15.18_smp-i686-1.txz: Upgraded.
ap/vim-8.2.4256-i586-1.txz: Upgraded.
d/kernel-headers-5.15.18_smp-x86-1.txz: Upgraded.
k/kernel-source-5.15.18_smp-noarch-1.txz: Upgraded.
xap/vim-gvim-8.2.4256-i586-1.txz: Upgraded.
extra/linux-5.15.18-nosmp-sdk/*: Upgraded.
a/rpm2tgz-1.2.2-i586-5.txz: Rebuilt.
a/plzip-1.10-i586-1.txz: Upgraded.
ap/sudo-1.9.9-i586-1.txz: Upgraded.
d/Cython-0.29.27-i586-1.txz: Upgraded.
d/poke-2.0-i586-1.txz: Upgraded.
l/python-charset-normalizer-2.0.10-i586-1.txz: Upgraded.
x/mesa-21.3.5-i586-2.txz: Rebuilt.
a/aaa_libraries-15.0-i586-18.txz: Rebuilt.
a/kernel-generic-5.15.17-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.15.17_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.15.17-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.15.17_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.15.17-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.15.17_smp-i686-1.txz: Upgraded.
a/lzlib-1.13-i586-1.txz: Upgraded.
ap/pamixer-1.5-i586-2.txz: Rebuilt.
d/kernel-headers-5.15.17_smp-x86-1.txz: Upgraded.
k/kernel-source-5.15.17_smp-noarch-1.txz: Upgraded.
kde/kig-21.12.1-i586-2.txz: Rebuilt.
kde/kopeninghours-21.12.1-i586-2.txz: Rebuilt.
kde/krita-5.0.2-i586-2.txz: Rebuilt.
l/boost-1.78.0-i586-1.txz: Upgraded.
l/cryfs-0.10.3-i586-4.txz: Rebuilt.
l/expat-2.4.3-i586-3.txz: Rebuilt.
l/netpbm-10.97.03-i586-1.txz: Upgraded.
l/openexr-2.5.7-i586-5.txz: Rebuilt.
l/pipewire-0.3.44-i586-1.txz: Upgraded.
n/fetchmail-6.4.27-i586-1.txz: Upgraded.
n/libgpg-error-1.44-i586-1.txz: Upgraded.
x/mesa-21.3.5-i586-1.txz: Upgraded.
xap/mozilla-firefox-91.5.1esr-i686-1.txz: Upgraded.
extra/linux-5.15.17-nosmp-sdk/*: Upgraded.
extra/rust-for-mozilla/rust-1.54.0-i686-4.txz: Rebuilt.
a/aaa_libraries-15.0-i586-17.txz: Rebuilt.
a/mkinitrd-1.4.11-i586-28.txz: Rebuilt.
l/glib2-2.70.3-i586-1.txz: Upgraded.
l/libcap-2.63-i586-1.txz: Upgraded.
n/bluez-5.63-i586-2.txz: Rebuilt.
l/polkit-0.120-i586-2.txz: Rebuilt.
Napisano: 06 Feb 2022, 19:26
Slackware 64-bit
Wed Feb 2 22:22:22 UTC 2022
Slackware 15.0 x86_64 stable is released!
Another too-long development cycle is behind us after we bit off more than
we could chew and then had to shine it up to a high-gloss finish. Hopefully
we've managed to get the tricky parts out of the way so that we'll be able
to see a 15.1 incremental update after a far shorter development cycle.
Certainly the development infrastructure has been streamlined here and things
should be easier moving forward. My thanks to the rest of the Slackware team,
all the upstream developers who have given us such great building materials,
the folks on LinuxQuestions.org and elsewhere for all the help with testing,
great suggestions, and countless bug fixes, and to everyone who helped
support this project so that the release could finally see the light of day.
I couldn't have done any of this without your help, and I'm grateful to all
of you. Thanks!
For more information, check out the RELEASE_NOTES, CHANGES_AND_HINTS.TXT,
and ANNOUNCE.15.0.
Have fun! :-)
Wed Feb 2 08:21:48 UTC 2022
a/kernel-generic-5.15.19-x86_64-2.txz: Upgraded.
a/kernel-huge-5.15.19-x86_64-2.txz: Upgraded.
a/kernel-modules-5.15.19-x86_64-2.txz: Upgraded.
d/kernel-headers-5.15.19-x86-2.txz: Upgraded.
k/kernel-source-5.15.19-noarch-2.txz: Upgraded.
-RTC_SYSTOHC_DEVICE "rtc0"
RTC_SYSTOHC y -> n
testing/source/linux-5.16.5-configs/*: Rebuilt.
RTC_SYSTOHC y -> n
Wed Feb 2 04:17:39 UTC 2022
fortune -m "I will be finished tomorrow" fortunes2
a/kernel-generic-5.15.19-x86_64-1.txz: Upgraded.
a/kernel-huge-5.15.19-x86_64-1.txz: Upgraded.
a/kernel-modules-5.15.19-x86_64-1.txz: Upgraded.
ap/screen-4.9.0-x86_64-1.txz: Upgraded.
Patched possible denial of service via a crafted UTF-8 character sequence.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-26937
d/kernel-headers-5.15.19-x86-1.txz: Upgraded.
k/kernel-source-5.15.19-noarch-1.txz: Upgraded.
RTC_INTF_DEV_UIE_EMUL y -> n
RTC_SYSTOHC n -> y
+RTC_SYSTOHC_DEVICE "rtc0"
l/lcms2-2.13-x86_64-2.txz: Rebuilt.
[PATCH] Fix for optimization error on grayscale.
Thanks to Aaron Boxer for reporting this issue.
Thanks to gmgf.
testing/source/linux-5.16.5-configs/*: Upgraded.
Tue Feb 1 08:27:47 UTC 2022
kde/kate-21.12.1-x86_64-2.txz: Rebuilt.
Fix missing validation of binaries executed via QProcess.
Thanks to Heinz Wiesinger.
https://kde.org/info/security/advisory-20220131-1.txt
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23853
Tue Feb 1 05:35:21 UTC 2022
Hey, my shiny brass lamp is almost out of fuel!
a/rpm2tgz-1.2.2-x86_64-6.txz: Rebuilt.
Don't use --no-absolute-filenames, because inexplicably it also strips the
leading '/' from symlink targets, generally creating a broken symlink.
The problem we were attempting to fix is far less common than symlinks to
absolute filenames, so we'll revert this for further consideration.
Thanks to pghvlaans.
Tue Feb 1 04:37:04 UTC 2022
The sepulchral voice intones, "The cave is now closed."
kde/falkon-3.2.0-x86_64-1.txz: Upgraded.
kde/ktexteditor-5.90.0-x86_64-2.txz: Rebuilt.
[PATCH] only start programs in user's path.
[PATCH] only execute diff in path.
Thanks to gmgf.
l/libcanberra-0.30-x86_64-9.txz: Rebuilt.
Fix a bug crashing some applications in Wayland desktops.
Thanks to 01micko.
n/samba-4.15.5-x86_64-1.txz: Upgraded.
This is a security release in order to address the following defects:
UNIX extensions in SMB1 disclose whether the outside target of a symlink
exists.
Out-of-Bound Read/Write on Samba vfs_fruit module. This vulnerability
allows remote attackers to execute arbitrary code as root on affected Samba
installations that use the VFS module vfs_fruit.
Re-adding an SPN skips subsequent SPN conflict checks. An attacker who has
the ability to write to an account can exploit this to perform a
denial-of-service attack by adding an SPN that matches an existing service.
Additionally, an attacker who can intercept traffic can impersonate existing
services, resulting in a loss of confidentiality and integrity.
https://www.samba.org/samba/security/CVE-2021-44141.html
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-44141
https://www.samba.org/samba/security/CVE-2021-44142.html
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-44142
https://www.samba.org/samba/security/CVE-2022-0336.html
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0336
x/xterm-370-x86_64-7.txz: Rebuilt.
Rebuilt with --disable-sixel-graphics to fix a buffer overflow.
Thanks to gmgf.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-24130
testing/source/linux-5.16.4-configs/*: Added.
Sample config files to build 5.16.4 Linux kernels.
Sun Jan 30 20:48:46 UTC 2022
a/aaa_libraries-15.0-x86_64-19.txz: Rebuilt.
Upgraded: libexpat.so.1.8.4, libjson-c.so.5.1.0 (thanks to peake).
ap/at-3.2.4-x86_64-1.txz: Upgraded.
d/git-2.35.1-x86_64-1.txz: Upgraded.
l/expat-2.4.4-x86_64-1.txz: Upgraded.
This update merges the patches we previously applied to expat-2.4.3.
l/imagemagick-7.1.0_22-x86_64-1.txz: Upgraded.
l/lcms2-2.13-x86_64-1.txz: Upgraded.
Slackware 32-bit
Slackware 15.0 x86 stable is released!
of you. Thanks!
and ANNOUNCE.15.0.
Have fun! :-)
a/kernel-generic-5.15.19-i586-2.txz: Upgraded.
a/kernel-generic-smp-5.15.19_smp-i686-2.txz: Upgraded.
a/kernel-huge-5.15.19-i586-2.txz: Upgraded.
a/kernel-huge-smp-5.15.19_smp-i686-2.txz: Upgraded.
a/kernel-modules-5.15.19-i586-2.txz: Upgraded.
a/kernel-modules-smp-5.15.19_smp-i686-2.txz: Upgraded.
d/kernel-headers-5.15.19_smp-x86-2.txz: Upgraded.
k/kernel-source-5.15.19_smp-noarch-2.txz: Upgraded.
RTC_SYSTOHC y -> n
extra/linux-5.15.19-nosmp-sdk/*: Upgraded.
RTC_SYSTOHC y -> n
a/kernel-generic-5.15.19-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.15.19_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.15.19-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.15.19_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.15.19-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.15.19_smp-i686-1.txz: Upgraded.
ap/screen-4.9.0-i586-1.txz: Upgraded.
d/kernel-headers-5.15.19_smp-x86-1.txz: Upgraded.
k/kernel-source-5.15.19_smp-noarch-1.txz: Upgraded.
RTC_SYSTOHC n -> y
l/lcms2-2.13-i586-2.txz: Rebuilt.
Thanks to gmgf.
kde/kate-21.12.1-i586-2.txz: Rebuilt.
a/rpm2tgz-1.2.2-i586-6.txz: Rebuilt.
kde/falkon-3.2.0-i586-1.txz: Upgraded.
kde/ktexteditor-5.90.0-i586-2.txz: Rebuilt.
Thanks to gmgf.
l/libcanberra-0.30-i586-9.txz: Rebuilt.
Thanks to 01micko.
n/samba-4.15.5-i586-1.txz: Upgraded.
exists.
x/xterm-370-i586-7.txz: Rebuilt.
Thanks to gmgf.
a/aaa_libraries-15.0-i586-19.txz: Rebuilt.
ap/at-3.2.4-i586-1.txz: Upgraded.
d/git-2.35.1-i586-1.txz: Upgraded.
l/expat-2.4.4-i586-1.txz: Upgraded.
l/imagemagick-7.1.0_22-i586-1.txz: Upgraded.
l/lcms2-2.13-i586-1.txz: Upgraded.
Napisano: 20 Feb 2022, 22:24
Slackware 64-bit
Sun Feb 20 05:13:20 UTC 2022
ap/nano-6.2-x86_64-1.txz: Upgraded.
d/mercurial-6.0.3-x86_64-1.txz: Upgraded.
l/expat-2.4.5-x86_64-1.txz: Upgraded.
Fixed security issues that could lead to denial of service or potentially
arbitrary code execution.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-25235
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-25236
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-25313
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-25314
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-25315
l/pipewire-0.3.47-x86_64-1.txz: Upgraded.
n/libnetfilter_conntrack-1.0.9-x86_64-1.txz: Upgraded.
n/mutt-2.2.1-x86_64-1.txz: Upgraded.
Fri Feb 18 05:29:00 UTC 2022
a/btrfs-progs-5.16.2-x86_64-1.txz: Upgraded.
a/kernel-generic-5.16.10-x86_64-1.txz: Upgraded.
a/kernel-huge-5.16.10-x86_64-1.txz: Upgraded.
a/kernel-modules-5.16.10-x86_64-1.txz: Upgraded.
ap/cups-filters-1.28.12-x86_64-1.txz: Upgraded.
ap/qpdf-10.6.2-x86_64-1.txz: Upgraded.
d/kernel-headers-5.16.10-x86-1.txz: Upgraded.
k/kernel-source-5.16.10-noarch-1.txz: Upgraded.
AMD_PTDMA n -> m
Thanks to walecha.
l/imagemagick-7.1.0_25-x86_64-1.txz: Upgraded.
l/librsvg-2.52.6-x86_64-1.txz: Upgraded.
l/pipewire-0.3.46-x86_64-1.txz: Upgraded.
n/php-7.4.28-x86_64-1.txz: Upgraded.
This update fixes bugs and a security issue:
UAF due to php_filter_float() failing for ints.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-21708
x/libdrm-2.4.110-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-97.0.1-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/97.0.1/releasenotes/
xap/mozilla-thunderbird-91.6.1-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/91.6.1/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2022-07/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0566
extra/php80/php80-8.0.16-x86_64-1.txz: Upgraded.
extra/php81/php81-8.1.3-x86_64-1.txz: Upgraded.
Tue Feb 15 20:00:48 UTC 2022
a/aaa_base-15.1-x86_64-2.txz: Rebuilt.
If root's mailbox did not already exist, it would be created with insecure
permissions leading to possible local information disclosure. This update
ensures that a new mailbox will be created with proper permissions and
ownership, and corrects the permissions on an existing mailbox if they are
found to be incorrect. Thanks to Martin for the bug report.
d/help2man-1.49.1-x86_64-1.txz: Upgraded.
kde/bluedevil-5.24.1-x86_64-1.txz: Upgraded.
kde/breeze-5.24.1-x86_64-1.txz: Upgraded.
kde/breeze-grub-5.24.1-x86_64-1.txz: Upgraded.
kde/breeze-gtk-5.24.1-x86_64-1.txz: Upgraded.
kde/drkonqi-5.24.1-x86_64-1.txz: Upgraded.
kde/kactivitymanagerd-5.24.1-x86_64-1.txz: Upgraded.
kde/kde-cli-tools-5.24.1-x86_64-1.txz: Upgraded.
kde/kde-gtk-config-5.24.1-x86_64-1.txz: Upgraded.
kde/kdecoration-5.24.1-x86_64-1.txz: Upgraded.
kde/kdeplasma-addons-5.24.1-x86_64-1.txz: Upgraded.
kde/kgamma5-5.24.1-x86_64-1.txz: Upgraded.
kde/khotkeys-5.24.1-x86_64-1.txz: Upgraded.
kde/kinfocenter-5.24.1-x86_64-1.txz: Upgraded.
kde/kmenuedit-5.24.1-x86_64-1.txz: Upgraded.
kde/kscreen-5.24.1-x86_64-1.txz: Upgraded.
kde/kscreenlocker-5.24.1-x86_64-1.txz: Upgraded.
kde/ksshaskpass-5.24.1-x86_64-1.txz: Upgraded.
kde/ksystemstats-5.24.1-x86_64-1.txz: Upgraded.
kde/kwallet-pam-5.24.1-x86_64-1.txz: Upgraded.
kde/kwayland-integration-5.24.1-x86_64-1.txz: Upgraded.
kde/kwayland-server-5.24.1-x86_64-1.txz: Upgraded.
kde/kwin-5.24.1-x86_64-1.txz: Upgraded.
kde/kwrited-5.24.1-x86_64-1.txz: Upgraded.
kde/layer-shell-qt-5.24.1-x86_64-1.txz: Upgraded.
kde/libkscreen-5.24.1-x86_64-1.txz: Upgraded.
kde/libksysguard-5.24.1-x86_64-1.txz: Upgraded.
kde/milou-5.24.1-x86_64-1.txz: Upgraded.
kde/oxygen-5.24.1-x86_64-1.txz: Upgraded.
kde/plasma-browser-integration-5.24.1-x86_64-1.txz: Upgraded.
kde/plasma-desktop-5.24.1-x86_64-1.txz: Upgraded.
kde/plasma-disks-5.24.1-x86_64-1.txz: Upgraded.
kde/plasma-firewall-5.24.1-x86_64-1.txz: Upgraded.
kde/plasma-integration-5.24.1-x86_64-1.txz: Upgraded.
kde/plasma-nm-5.24.1-x86_64-1.txz: Upgraded.
kde/plasma-pa-5.24.1-x86_64-1.txz: Upgraded.
kde/plasma-sdk-5.24.1-x86_64-1.txz: Upgraded.
kde/plasma-systemmonitor-5.24.1-x86_64-1.txz: Upgraded.
kde/plasma-vault-5.24.1-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.24.1-x86_64-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.24.1-x86_64-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.24.1-x86_64-1.txz: Upgraded.
kde/powerdevil-5.24.1-x86_64-1.txz: Upgraded.
kde/qqc2-breeze-style-5.24.1-x86_64-1.txz: Upgraded.
kde/sddm-kcm-5.24.1-x86_64-1.txz: Upgraded.
kde/systemsettings-5.24.1-x86_64-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.24.1-x86_64-1.txz: Upgraded.
Tue Feb 15 02:14:30 UTC 2022
a/util-linux-2.37.4-x86_64-1.txz: Upgraded.
d/rcs-5.10.1-x86_64-1.txz: Upgraded.
d/vala-0.54.7-x86_64-1.txz: Upgraded.
l/libqalculate-4.0.0-x86_64-1.txz: Upgraded.
Mon Feb 14 00:10:38 UTC 2022
ap/mariadb-10.6.7-x86_64-1.txz: Upgraded.
This update fixes potential denial-of-service vulnerabilities.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-46665
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-46664
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-46661
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-46668
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-46663
ap/zsh-5.8.1-x86_64-1.txz: Upgraded.
d/autoconf-archive-2022.02.11-noarch-1.txz: Upgraded.
d/guile-3.0.8-x86_64-1.txz: Upgraded.
kde/attica-5.91.0-x86_64-1.txz: Upgraded.
kde/baloo-5.91.0-x86_64-1.txz: Upgraded.
kde/bluez-qt-5.91.0-x86_64-1.txz: Upgraded.
kde/breeze-icons-5.91.0-noarch-1.txz: Upgraded.
kde/extra-cmake-modules-5.91.0-x86_64-1.txz: Upgraded.
kde/frameworkintegration-5.91.0-x86_64-1.txz: Upgraded.
kde/kactivities-5.91.0-x86_64-1.txz: Upgraded.
kde/kactivities-stats-5.91.0-x86_64-1.txz: Upgraded.
kde/kapidox-5.91.0-x86_64-1.txz: Upgraded.
kde/karchive-5.91.0-x86_64-1.txz: Upgraded.
kde/kauth-5.91.0-x86_64-1.txz: Upgraded.
kde/kbookmarks-5.91.0-x86_64-1.txz: Upgraded.
kde/kcalendarcore-5.91.0-x86_64-1.txz: Upgraded.
kde/kcmutils-5.91.0-x86_64-1.txz: Upgraded.
kde/kcodecs-5.91.0-x86_64-1.txz: Upgraded.
kde/kcompletion-5.91.0-x86_64-1.txz: Upgraded.
kde/kconfig-5.91.0-x86_64-1.txz: Upgraded.
kde/kconfigwidgets-5.91.0-x86_64-1.txz: Upgraded.
kde/kcontacts-5.91.0-x86_64-1.txz: Upgraded.
kde/kcoreaddons-5.91.0-x86_64-1.txz: Upgraded.
kde/kcrash-5.91.0-x86_64-1.txz: Upgraded.
kde/kdav-5.91.0-x86_64-1.txz: Upgraded.
kde/kdbusaddons-5.91.0-x86_64-1.txz: Upgraded.
kde/kdeclarative-5.91.0-x86_64-1.txz: Upgraded.
kde/kded-5.91.0-x86_64-1.txz: Upgraded.
kde/kdelibs4support-5.91.0-x86_64-1.txz: Upgraded.
kde/kdesignerplugin-5.91.0-x86_64-1.txz: Upgraded.
kde/kdesu-5.91.0-x86_64-1.txz: Upgraded.
kde/kdewebkit-5.91.0-x86_64-1.txz: Upgraded.
kde/kdnssd-5.91.0-x86_64-1.txz: Upgraded.
kde/kdoctools-5.91.0-x86_64-1.txz: Upgraded.
kde/kemoticons-5.91.0-x86_64-1.txz: Upgraded.
kde/kfilemetadata-5.91.0-x86_64-1.txz: Upgraded.
kde/kglobalaccel-5.91.0-x86_64-1.txz: Upgraded.
kde/kguiaddons-5.91.0-x86_64-1.txz: Upgraded.
kde/kholidays-5.91.0-x86_64-1.txz: Upgraded.
kde/khtml-5.91.0-x86_64-1.txz: Upgraded.
kde/ki18n-5.91.0-x86_64-1.txz: Upgraded.
kde/kiconthemes-5.91.0-x86_64-1.txz: Upgraded.
kde/kidletime-5.91.0-x86_64-1.txz: Upgraded.
kde/kimageformats-5.91.0-x86_64-1.txz: Upgraded.
kde/kinit-5.91.0-x86_64-1.txz: Upgraded.
kde/kio-5.91.0-x86_64-1.txz: Upgraded.
kde/kirigami2-5.91.0-x86_64-1.txz: Upgraded.
kde/kitemmodels-5.91.0-x86_64-1.txz: Upgraded.
kde/kitemviews-5.91.0-x86_64-1.txz: Upgraded.
kde/kjobwidgets-5.91.0-x86_64-1.txz: Upgraded.
kde/kjs-5.91.0-x86_64-1.txz: Upgraded.
kde/kjsembed-5.91.0-x86_64-1.txz: Upgraded.
kde/kmediaplayer-5.91.0-x86_64-1.txz: Upgraded.
kde/knewstuff-5.91.0-x86_64-1.txz: Upgraded.
kde/knotifications-5.91.0-x86_64-1.txz: Upgraded.
kde/knotifyconfig-5.91.0-x86_64-1.txz: Upgraded.
kde/kpackage-5.91.0-x86_64-1.txz: Upgraded.
kde/kparts-5.91.0-x86_64-1.txz: Upgraded.
kde/kpeople-5.91.0-x86_64-1.txz: Upgraded.
kde/kplotting-5.91.0-x86_64-1.txz: Upgraded.
kde/kpty-5.91.0-x86_64-1.txz: Upgraded.
kde/kquickcharts-5.91.0-x86_64-1.txz: Upgraded.
kde/kross-5.91.0-x86_64-1.txz: Upgraded.
kde/krunner-5.91.0-x86_64-1.txz: Upgraded.
kde/kservice-5.91.0-x86_64-1.txz: Upgraded.
kde/ktexteditor-5.91.0-x86_64-1.txz: Upgraded.
kde/ktextwidgets-5.91.0-x86_64-1.txz: Upgraded.
kde/kunitconversion-5.91.0-x86_64-1.txz: Upgraded.
kde/kwallet-5.91.0-x86_64-1.txz: Upgraded.
kde/kwayland-5.91.0-x86_64-1.txz: Upgraded.
kde/kwidgetsaddons-5.91.0-x86_64-1.txz: Upgraded.
kde/kwindowsystem-5.91.0-x86_64-1.txz: Upgraded.
kde/kxmlgui-5.91.0-x86_64-1.txz: Upgraded.
kde/kxmlrpcclient-5.91.0-x86_64-1.txz: Upgraded.
kde/modemmanager-qt-5.91.0-x86_64-1.txz: Upgraded.
kde/networkmanager-qt-5.91.0-x86_64-1.txz: Upgraded.
kde/oxygen-icons5-5.91.0-noarch-1.txz: Upgraded.
kde/plasma-framework-5.91.0-x86_64-1.txz: Upgraded.
kde/prison-5.91.0-x86_64-1.txz: Upgraded.
kde/purpose-5.91.0-x86_64-1.txz: Upgraded.
kde/qqc2-desktop-style-5.91.0-x86_64-1.txz: Upgraded.
kde/solid-5.91.0-x86_64-1.txz: Upgraded.
kde/sonnet-5.91.0-x86_64-1.txz: Upgraded.
kde/syndication-5.91.0-x86_64-1.txz: Upgraded.
kde/syntax-highlighting-5.91.0-x86_64-1.txz: Upgraded.
kde/threadweaver-5.91.0-x86_64-1.txz: Upgraded.
l/harfbuzz-3.4.0-x86_64-1.txz: Upgraded.
l/imagemagick-7.1.0_24-x86_64-1.txz: Upgraded.
l/libspectre-0.2.10-x86_64-1.txz: Upgraded.
l/libxkbcommon-1.4.0-x86_64-1.txz: Upgraded.
n/mutt-2.2.0-x86_64-1.txz: Upgraded.
xap/hexchat-2.16.1-x86_64-1.txz: Upgraded.
xfce/xfce4-notifyd-0.6.3-x86_64-1.txz: Upgraded.
Fri Feb 11 20:36:58 UTC 2022
a/kernel-firmware-20220209_6342082-noarch-1.txz: Upgraded.
a/kernel-generic-5.16.9-x86_64-1.txz: Upgraded.
a/kernel-huge-5.16.9-x86_64-1.txz: Upgraded.
a/kernel-modules-5.16.9-x86_64-1.txz: Upgraded.
ap/qpdf-10.6.1-x86_64-1.txz: Upgraded.
d/binutils-2.38-x86_64-1.txz: Upgraded.
d/kernel-headers-5.16.9-x86-1.txz: Upgraded.
d/oprofile-1.4.0-x86_64-9.txz: Rebuilt.
Recompiled against binutils-2.38.
k/kernel-source-5.16.9-noarch-1.txz: Upgraded.
l/glib2-2.70.4-x86_64-1.txz: Upgraded.
n/ModemManager-1.18.6-x86_64-1.txz: Upgraded.
n/NetworkManager-1.34.0-x86_64-1.txz: Upgraded.
n/libqmi-1.30.4-x86_64-1.txz: Upgraded.
x/ibus-table-1.16.7-x86_64-1.txz: Upgraded.
x/xorg-server-1.20.14-x86_64-3.txz: Rebuilt.
Rebuilt using --with-xkb-path=/usr/share/X11/xkb. Thanks to TheRealGrogan.
Bump OS name: --with-os-name="Slackware 15.1".
x/xorg-server-xephyr-1.20.14-x86_64-3.txz: Rebuilt.
x/xorg-server-xnest-1.20.14-x86_64-3.txz: Rebuilt.
x/xorg-server-xvfb-1.20.14-x86_64-3.txz: Rebuilt.
x/xorg-server-xwayland-21.1.4-x86_64-2.txz: Rebuilt.
Rebuilt using -Dxkb_dir=/usr/share/X11/xkb.
xap/libnma-1.8.34-x86_64-1.txz: Upgraded.
Fri Feb 11 01:09:45 UTC 2022
x/xkeyboard-config-2.35.1-noarch-2.txz: Rebuilt.
Perhaps upstream didn't mean to move these files (or perhaps we should have
recompiled everything that looks for these), but they did switch to meson,
and the 'xkb-base' option to set the data directory doesn't work. Anyway,
I've placed a symlink at /etc/X11/xkb and that fixes the problem.
Thanks to Petri Kaukasoina and LuckyCyborg.
Thu Feb 10 19:30:37 UTC 2022
ap/lxc-4.0.12-x86_64-1.txz: Upgraded.
ap/man-db-2.10.1-x86_64-1.txz: Upgraded.
ap/qpdf-10.6.0-x86_64-1.txz: Upgraded.
l/libarchive-3.6.0-x86_64-1.txz: Upgraded.
x/libgee-0.20.5-x86_64-1.txz: Upgraded.
x/mesa-21.3.6-x86_64-1.txz: Upgraded.
x/xkeyboard-config-2.35.1-noarch-1.txz: Upgraded.
This package moves the data files out of /etc.
xap/blueman-2.2.4-x86_64-1.txz: Upgraded.
xap/gftp-2.9.0b-x86_64-1.txz: Upgraded.
Thu Feb 10 01:46:55 UTC 2022
Well here we are a week later... welcome back to -current with a bunch of new
updates. Had to give marav's script something to kick out. If it were April 1st
maybe I would have put a fake 15.1 release announcement here. ;-)
I'll probably take some time off eventually but there were too many updates
that I skipped during late RC, and I love doing this, so... enjoy!
a/aaa_base-15.1-x86_64-1.txz: Upgraded.
a/btrfs-progs-5.16.1-x86_64-1.txz: Upgraded.
a/dialog-1.3_20220117-x86_64-1.txz: Upgraded.
a/ed-1.18-x86_64-1.txz: Upgraded.
a/findutils-4.9.0-x86_64-1.txz: Upgraded.
a/hwdata-0.356-noarch-1.txz: Upgraded.
a/kernel-generic-5.16.8-x86_64-1.txz: Upgraded.
a/kernel-huge-5.16.8-x86_64-1.txz: Upgraded.
a/kernel-modules-5.16.8-x86_64-1.txz: Upgraded.
a/lzip-1.23-x86_64-1.txz: Upgraded.
a/tcsh-6.24.00-x86_64-1.txz: Upgraded.
ap/alsa-utils-1.2.6-x86_64-1.txz: Upgraded.
ap/at-3.2.3-x86_64-1.txz: Upgraded.
Switched to at-3.2.3 since version 3.2.4 has a regression that causes
queued jobs to not always run on time when atd is run as a standalone
daemon. Thanks to Cesare.
ap/cups-2.4.1-x86_64-1.txz: Upgraded.
ap/man-db-2.10.0-x86_64-1.txz: Upgraded.
ap/mariadb-10.6.5-x86_64-1.txz: Upgraded.
ap/nano-6.1-x86_64-1.txz: Upgraded.
d/kernel-headers-5.16.8-x86-1.txz: Upgraded.
d/llvm-13.0.1-x86_64-1.txz: Upgraded.
d/mercurial-6.0.2-x86_64-1.txz: Upgraded.
d/poke-2.1-x86_64-1.txz: Upgraded.
d/re2c-3.0-x86_64-1.txz: Upgraded.
k/kernel-source-5.16.8-noarch-1.txz: Upgraded.
+FRAMEBUFFER_CONSOLE_LEGACY_ACCELERATION y
kde/akonadi-21.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-21.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-tools-21.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-contacts-21.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-import-wizard-21.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-mime-21.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-notes-21.12.2-x86_64-1.txz: Upgraded.
kde/akonadi-search-21.12.2-x86_64-1.txz: Upgraded.
kde/akonadiconsole-21.12.2-x86_64-1.txz: Upgraded.
kde/akregator-21.12.2-x86_64-1.txz: Upgraded.
kde/analitza-21.12.2-x86_64-1.txz: Upgraded.
kde/ark-21.12.2-x86_64-1.txz: Upgraded.
kde/artikulate-21.12.2-x86_64-1.txz: Upgraded.
kde/audiocd-kio-21.12.2-x86_64-1.txz: Upgraded.
kde/baloo-widgets-21.12.2-x86_64-1.txz: Upgraded.
kde/blinken-21.12.2-x86_64-1.txz: Upgraded.
kde/bluedevil-5.24.0-x86_64-1.txz: Upgraded.
kde/bomber-21.12.2-x86_64-1.txz: Upgraded.
kde/bovo-21.12.2-x86_64-1.txz: Upgraded.
kde/breeze-5.24.0-x86_64-1.txz: Upgraded.
kde/breeze-grub-5.24.0-x86_64-1.txz: Upgraded.
kde/breeze-gtk-5.24.0-x86_64-1.txz: Upgraded.
kde/calendarsupport-21.12.2-x86_64-1.txz: Upgraded.
kde/cantor-21.12.2-x86_64-1.txz: Upgraded.
kde/cervisia-21.12.2-x86_64-1.txz: Upgraded.
kde/dolphin-21.12.2.1-x86_64-1.txz: Upgraded.
kde/dolphin-plugins-21.12.2-x86_64-1.txz: Upgraded.
kde/dragon-21.12.2-x86_64-1.txz: Upgraded.
kde/drkonqi-5.24.0-x86_64-1.txz: Upgraded.
kde/elisa-21.12.2-x86_64-1.txz: Upgraded.
kde/eventviews-21.12.2-x86_64-1.txz: Upgraded.
kde/ffmpegthumbs-21.12.2-x86_64-1.txz: Upgraded.
kde/filelight-21.12.2-x86_64-1.txz: Upgraded.
kde/granatier-21.12.2-x86_64-1.txz: Upgraded.
kde/grantlee-editor-21.12.2-x86_64-1.txz: Upgraded.
kde/grantleetheme-21.12.2-x86_64-1.txz: Upgraded.
kde/gwenview-21.12.2-x86_64-1.txz: Upgraded.
kde/incidenceeditor-21.12.2-x86_64-1.txz: Upgraded.
kde/itinerary-21.12.2-x86_64-1.txz: Upgraded.
kde/juk-21.12.2-x86_64-1.txz: Upgraded.
kde/k3b-21.12.2-x86_64-1.txz: Upgraded.
kde/kactivitymanagerd-5.24.0-x86_64-1.txz: Upgraded.
kde/kaddressbook-21.12.2-x86_64-1.txz: Upgraded.
kde/kalarm-21.12.2-x86_64-1.txz: Upgraded.
kde/kalarmcal-21.12.2-x86_64-1.txz: Upgraded.
kde/kalgebra-21.12.2-x86_64-1.txz: Upgraded.
kde/kalzium-21.12.2-x86_64-1.txz: Upgraded.
kde/kamera-21.12.2-x86_64-1.txz: Upgraded.
kde/kamoso-21.12.2-x86_64-1.txz: Upgraded.
kde/kanagram-21.12.2-x86_64-1.txz: Upgraded.
kde/kapman-21.12.2-x86_64-1.txz: Upgraded.
kde/kapptemplate-21.12.2-x86_64-1.txz: Upgraded.
kde/kate-21.12.2-x86_64-1.txz: Upgraded.
kde/katomic-21.12.2-x86_64-1.txz: Upgraded.
kde/kbackup-21.12.2-x86_64-1.txz: Upgraded.
kde/kblackbox-21.12.2-x86_64-1.txz: Upgraded.
kde/kblocks-21.12.2-x86_64-1.txz: Upgraded.
kde/kbounce-21.12.2-x86_64-1.txz: Upgraded.
kde/kbreakout-21.12.2-x86_64-1.txz: Upgraded.
kde/kbruch-21.12.2-x86_64-1.txz: Upgraded.
kde/kcachegrind-21.12.2-x86_64-1.txz: Upgraded.
kde/kcalc-21.12.2-x86_64-1.txz: Upgraded.
kde/kcalutils-21.12.2-x86_64-1.txz: Upgraded.
kde/kcharselect-21.12.2-x86_64-1.txz: Upgraded.
kde/kcolorchooser-21.12.2-x86_64-1.txz: Upgraded.
kde/kcron-21.12.2-x86_64-1.txz: Upgraded.
kde/kde-cli-tools-5.24.0-x86_64-1.txz: Upgraded.
kde/kde-dev-scripts-21.12.2-x86_64-1.txz: Upgraded.
kde/kde-dev-utils-21.12.2-x86_64-1.txz: Upgraded.
kde/kde-gtk-config-5.24.0-x86_64-1.txz: Upgraded.
kde/kdebugsettings-21.12.2-x86_64-1.txz: Upgraded.
kde/kdeconnect-kde-21.12.2-x86_64-1.txz: Upgraded.
kde/kdecoration-5.24.0-x86_64-1.txz: Upgraded.
kde/kdeedu-data-21.12.2-x86_64-1.txz: Upgraded.
kde/kdegraphics-mobipocket-21.12.2-x86_64-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-21.12.2-x86_64-1.txz: Upgraded.
kde/kdenetwork-filesharing-21.12.2-x86_64-1.txz: Upgraded.
kde/kdenlive-21.12.2-x86_64-1.txz: Upgraded.
kde/kdepim-addons-21.12.2-x86_64-1.txz: Upgraded.
kde/kdepim-runtime-21.12.2-x86_64-1.txz: Upgraded.
kde/kdeplasma-addons-5.24.0-x86_64-1.txz: Upgraded.
kde/kdesdk-kioslaves-21.12.2-x86_64-1.txz: Upgraded.
kde/kdesdk-thumbnailers-21.12.2-x86_64-1.txz: Upgraded.
kde/kdev-php-21.12.2-x86_64-1.txz: Upgraded.
kde/kdev-python-21.12.2-x86_64-1.txz: Upgraded.
kde/kdevelop-21.12.2-x86_64-1.txz: Upgraded.
kde/kdf-21.12.2-x86_64-1.txz: Upgraded.
kde/kdialog-21.12.2-x86_64-1.txz: Upgraded.
kde/kdiamond-21.12.2-x86_64-1.txz: Upgraded.
kde/keditbookmarks-21.12.2-x86_64-1.txz: Upgraded.
kde/kfind-21.12.2-x86_64-1.txz: Upgraded.
kde/kfloppy-21.12.2-x86_64-1.txz: Upgraded.
kde/kfourinline-21.12.2-x86_64-1.txz: Upgraded.
kde/kgamma5-5.24.0-x86_64-1.txz: Upgraded.
kde/kgeography-21.12.2-x86_64-1.txz: Upgraded.
kde/kget-21.12.2-x86_64-1.txz: Upgraded.
kde/kgoldrunner-21.12.2-x86_64-1.txz: Upgraded.
kde/kgpg-21.12.2-x86_64-1.txz: Upgraded.
kde/khangman-21.12.2-x86_64-1.txz: Upgraded.
kde/khelpcenter-21.12.2-x86_64-1.txz: Upgraded.
kde/khotkeys-5.24.0-x86_64-1.txz: Upgraded.
kde/kidentitymanagement-21.12.2-x86_64-1.txz: Upgraded.
kde/kig-21.12.2-x86_64-1.txz: Upgraded.
kde/kigo-21.12.2-x86_64-1.txz: Upgraded.
kde/killbots-21.12.2-x86_64-1.txz: Upgraded.
kde/kimagemapeditor-21.12.2-x86_64-1.txz: Upgraded.
kde/kimap-21.12.2-x86_64-1.txz: Upgraded.
kde/kinfocenter-5.24.0-x86_64-1.txz: Upgraded.
kde/kio-extras-21.12.2-x86_64-1.txz: Upgraded.
kde/kio-gdrive-21.12.2-x86_64-1.txz: Upgraded.
kde/kipi-plugins-21.12.2-x86_64-1.txz: Upgraded.
kde/kirigami-gallery-21.12.2-x86_64-1.txz: Upgraded.
kde/kiriki-21.12.2-x86_64-1.txz: Upgraded.
kde/kiten-21.12.2-x86_64-1.txz: Upgraded.
kde/kitinerary-21.12.2-x86_64-1.txz: Upgraded.
kde/kjumpingcube-21.12.2-x86_64-1.txz: Upgraded.
kde/kldap-21.12.2-x86_64-1.txz: Upgraded.
kde/kleopatra-21.12.2-x86_64-1.txz: Upgraded.
kde/klickety-21.12.2-x86_64-1.txz: Upgraded.
kde/klines-21.12.2-x86_64-1.txz: Upgraded.
kde/kmag-21.12.2-x86_64-1.txz: Upgraded.
kde/kmahjongg-21.12.2-x86_64-1.txz: Upgraded.
kde/kmail-21.12.2-x86_64-1.txz: Upgraded.
kde/kmail-account-wizard-21.12.2-x86_64-1.txz: Upgraded.
kde/kmailtransport-21.12.2-x86_64-1.txz: Upgraded.
kde/kmbox-21.12.2-x86_64-1.txz: Upgraded.
kde/kmenuedit-5.24.0-x86_64-1.txz: Upgraded.
kde/kmime-21.12.2-x86_64-1.txz: Upgraded.
kde/kmines-21.12.2-x86_64-1.txz: Upgraded.
kde/kmix-21.12.2-x86_64-1.txz: Upgraded.
kde/kmousetool-21.12.2-x86_64-1.txz: Upgraded.
kde/kmouth-21.12.2-x86_64-1.txz: Upgraded.
kde/kmplot-21.12.2-x86_64-1.txz: Upgraded.
kde/knavalbattle-21.12.2-x86_64-1.txz: Upgraded.
kde/knetwalk-21.12.2-x86_64-1.txz: Upgraded.
kde/knights-21.12.2-x86_64-1.txz: Upgraded.
kde/knotes-21.12.2-x86_64-1.txz: Upgraded.
kde/kolf-21.12.2-x86_64-1.txz: Upgraded.
kde/kollision-21.12.2-x86_64-1.txz: Upgraded.
kde/kolourpaint-21.12.2-x86_64-1.txz: Upgraded.
kde/kompare-21.12.2-x86_64-1.txz: Upgraded.
kde/konqueror-21.12.2-x86_64-1.txz: Upgraded.
kde/konquest-21.12.2-x86_64-1.txz: Upgraded.
kde/konsole-21.12.2-x86_64-1.txz: Upgraded.
kde/kontact-21.12.2-x86_64-1.txz: Upgraded.
kde/kontactinterface-21.12.2-x86_64-1.txz: Upgraded.
kde/kontrast-21.12.2-x86_64-1.txz: Upgraded.
kde/konversation-21.12.2-x86_64-1.txz: Upgraded.
kde/kopeninghours-21.12.2-x86_64-1.txz: Upgraded.
kde/kopete-21.12.2-x86_64-1.txz: Upgraded.
kde/korganizer-21.12.2-x86_64-1.txz: Upgraded.
kde/kosmindoormap-21.12.2-x86_64-1.txz: Upgraded.
kde/kpat-21.12.2-x86_64-1.txz: Upgraded.
kde/kpimtextedit-21.12.2-x86_64-1.txz: Upgraded.
kde/kpkpass-21.12.2-x86_64-1.txz: Upgraded.
kde/kpmcore-21.12.2-x86_64-1.txz: Upgraded.
kde/kpublictransport-21.12.2-x86_64-1.txz: Upgraded.
kde/kqtquickcharts-21.12.2-x86_64-1.txz: Upgraded.
kde/krdc-21.12.2-x86_64-1.txz: Upgraded.
kde/kreversi-21.12.2-x86_64-1.txz: Upgraded.
kde/krfb-21.12.2-x86_64-1.txz: Upgraded.
kde/kross-interpreters-21.12.2-x86_64-1.txz: Upgraded.
kde/kruler-21.12.2-x86_64-1.txz: Upgraded.
kde/kscreen-5.24.0-x86_64-1.txz: Upgraded.
kde/kscreenlocker-5.24.0-x86_64-1.txz: Upgraded.
kde/kshisen-21.12.2-x86_64-1.txz: Upgraded.
kde/ksirk-21.12.2-x86_64-1.txz: Upgraded.
kde/ksmtp-21.12.2-x86_64-1.txz: Upgraded.
kde/ksnakeduel-21.12.2-x86_64-1.txz: Upgraded.
kde/kspaceduel-21.12.2-x86_64-1.txz: Upgraded.
kde/ksquares-21.12.2-x86_64-1.txz: Upgraded.
kde/ksshaskpass-5.24.0-x86_64-1.txz: Upgraded.
kde/ksudoku-21.12.2-x86_64-1.txz: Upgraded.
kde/ksystemlog-21.12.2-x86_64-1.txz: Upgraded.
kde/ksystemstats-5.24.0-x86_64-1.txz: Upgraded.
kde/kteatime-21.12.2-x86_64-1.txz: Upgraded.
kde/ktimer-21.12.2-x86_64-1.txz: Upgraded.
kde/ktnef-21.12.2-x86_64-1.txz: Upgraded.
kde/ktorrent-21.12.2-x86_64-1.txz: Upgraded.
kde/ktouch-21.12.2-x86_64-1.txz: Upgraded.
kde/kturtle-21.12.2-x86_64-1.txz: Upgraded.
kde/kubrick-21.12.2-x86_64-1.txz: Upgraded.
kde/kwallet-pam-5.24.0-x86_64-1.txz: Upgraded.
kde/kwalletmanager-21.12.2-x86_64-1.txz: Upgraded.
kde/kwave-21.12.2-x86_64-1.txz: Upgraded.
kde/kwayland-integration-5.24.0-x86_64-1.txz: Upgraded.
kde/kwayland-server-5.24.0-x86_64-1.txz: Upgraded.
kde/kwin-5.24.0-x86_64-1.txz: Upgraded.
kde/kwordquiz-21.12.2-x86_64-1.txz: Upgraded.
kde/kwrited-5.24.0-x86_64-1.txz: Upgraded.
kde/layer-shell-qt-5.24.0-x86_64-1.txz: Upgraded.
kde/libgravatar-21.12.2-x86_64-1.txz: Upgraded.
kde/libkcddb-21.12.2-x86_64-1.txz: Upgraded.
kde/libkcompactdisc-21.12.2-x86_64-1.txz: Upgraded.
kde/libkdcraw-21.12.2-x86_64-1.txz: Upgraded.
kde/libkdegames-21.12.2-x86_64-1.txz: Upgraded.
kde/libkdepim-21.12.2-x86_64-1.txz: Upgraded.
kde/libkeduvocdocument-21.12.2-x86_64-1.txz: Upgraded.
kde/libkexiv2-21.12.2-x86_64-1.txz: Upgraded.
kde/libkgapi-21.12.2-x86_64-1.txz: Upgraded.
kde/libkipi-21.12.2-x86_64-1.txz: Upgraded.
kde/libkleo-21.12.2-x86_64-1.txz: Upgraded.
kde/libkmahjongg-21.12.2-x86_64-1.txz: Upgraded.
kde/libkomparediff2-21.12.2-x86_64-1.txz: Upgraded.
kde/libksane-21.12.2-x86_64-1.txz: Upgraded.
kde/libkscreen-5.24.0-x86_64-1.txz: Upgraded.
kde/libksieve-21.12.2-x86_64-1.txz: Upgraded.
kde/libksysguard-5.24.0-x86_64-1.txz: Upgraded.
kde/libktorrent-21.12.2-x86_64-1.txz: Upgraded.
kde/lokalize-21.12.2-x86_64-1.txz: Upgraded.
kde/lskat-21.12.2-x86_64-1.txz: Upgraded.
kde/mailcommon-21.12.2-x86_64-1.txz: Upgraded.
kde/mailimporter-21.12.2-x86_64-1.txz: Upgraded.
kde/marble-21.12.2-x86_64-1.txz: Upgraded.
kde/markdownpart-21.12.2-x86_64-1.txz: Upgraded.
kde/mbox-importer-21.12.2-x86_64-1.txz: Upgraded.
kde/messagelib-21.12.2-x86_64-1.txz: Upgraded.
kde/milou-5.24.0-x86_64-1.txz: Upgraded.
kde/minuet-21.12.2-x86_64-1.txz: Upgraded.
kde/okular-21.12.2-x86_64-1.txz: Upgraded.
kde/oxygen-5.24.0-x86_64-1.txz: Upgraded.
kde/palapeli-21.12.2-x86_64-1.txz: Upgraded.
kde/parley-21.12.2-x86_64-1.txz: Upgraded.
kde/partitionmanager-21.12.2-x86_64-1.txz: Upgraded.
kde/picmi-21.12.2-x86_64-1.txz: Upgraded.
kde/pim-data-exporter-21.12.2-x86_64-1.txz: Upgraded.
kde/pim-sieve-editor-21.12.2-x86_64-1.txz: Upgraded.
kde/pimcommon-21.12.2-x86_64-1.txz: Upgraded.
kde/plasma-browser-integration-5.24.0-x86_64-1.txz: Upgraded.
kde/plasma-desktop-5.24.0-x86_64-1.txz: Upgraded.
kde/plasma-disks-5.24.0-x86_64-1.txz: Upgraded.
kde/plasma-firewall-5.24.0-x86_64-1.txz: Upgraded.
kde/plasma-integration-5.24.0-x86_64-1.txz: Upgraded.
kde/plasma-nm-5.24.0-x86_64-1.txz: Upgraded.
kde/plasma-pa-5.24.0-x86_64-1.txz: Upgraded.
kde/plasma-sdk-5.24.0-x86_64-1.txz: Upgraded.
kde/plasma-systemmonitor-5.24.0-x86_64-1.txz: Upgraded.
kde/plasma-vault-5.24.0-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.24.0-x86_64-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.24.0-x86_64-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.24.0-x86_64-1.txz: Upgraded.
kde/powerdevil-5.24.0-x86_64-1.txz: Upgraded.
kde/poxml-21.12.2-x86_64-1.txz: Upgraded.
kde/print-manager-21.12.2-x86_64-1.txz: Upgraded.
kde/qqc2-breeze-style-5.24.0-x86_64-1.txz: Upgraded.
kde/rocs-21.12.2-x86_64-1.txz: Upgraded.
kde/sddm-kcm-5.24.0-x86_64-1.txz: Upgraded.
kde/skanlite-21.12.2-x86_64-1.txz: Upgraded.
kde/spectacle-21.12.2-x86_64-1.txz: Upgraded.
kde/step-21.12.2-x86_64-1.txz: Upgraded.
kde/svgpart-21.12.2-x86_64-1.txz: Upgraded.
kde/sweeper-21.12.2-x86_64-1.txz: Upgraded.
kde/systemsettings-5.24.0-x86_64-1.txz: Upgraded.
kde/umbrello-21.12.2-x86_64-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.24.0-x86_64-1.txz: Upgraded.
kde/yakuake-21.12.2-x86_64-1.txz: Upgraded.
kde/zanshin-21.12.2-x86_64-1.txz: Upgraded.
kde/zeroconf-ioslave-21.12.2-x86_64-1.txz: Upgraded.
l/alsa-lib-1.2.6.1-x86_64-1.txz: Upgraded.
l/alsa-plugins-1.2.6-x86_64-1.txz: Upgraded.
l/gdbm-1.23-x86_64-1.txz: Upgraded.
l/gjs-1.70.1-x86_64-1.txz: Upgraded.
l/gst-plugins-bad-free-1.20.0-x86_64-1.txz: Upgraded.
l/gst-plugins-base-1.20.0-x86_64-1.txz: Upgraded.
l/gst-plugins-good-1.20.0-x86_64-1.txz: Upgraded.
l/gst-plugins-libav-1.20.0-x86_64-1.txz: Upgraded.
l/gstreamer-1.20.0-x86_64-1.txz: Upgraded.
l/harfbuzz-3.3.2-x86_64-1.txz: Upgraded.
l/imagemagick-7.1.0_23-x86_64-1.txz: Upgraded.
l/lcms2-2.13.1-x86_64-1.txz: Upgraded.
l/libical-3.0.14-x86_64-1.txz: Upgraded.
l/mozilla-nss-3.75-x86_64-1.txz: Upgraded.
l/pipewire-0.3.45-x86_64-1.txz: Upgraded.
l/quazip-1.2-x86_64-1.txz: Upgraded.
n/bind-9.18.0-x86_64-1.txz: Upgraded.
n/dovecot-2.3.18-x86_64-1.txz: Upgraded.
n/gnupg2-2.2.34-x86_64-1.txz: Upgraded.
n/gnutls-3.7.3-x86_64-1.txz: Upgraded.
n/libgcrypt-1.10.0-x86_64-1.txz: Upgraded.
n/postfix-3.7.0-x86_64-1.txz: Upgraded.
x/freeglut-3.2.2-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-97.0-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/97.0/releasenotes/
https://www.mozilla.org/security/advisories/mfsa2022-04/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22753
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22754
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22755
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22756
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22757
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22758
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22759
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22760
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22761
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22762
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-22764
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0511
xap/mozilla-thunderbird-91.6.0-x86_64-1.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/91.6.0/releasenotes/
https://www.mozilla.org/en-US/security/known-vulnerabilities/thunderbird/#thunderbird91.6
extra/rust-for-mozilla/rust-1.57.0-x86_64-1.txz: Upgraded.
Slackware 32-bit
ap/nano-6.2-i586-1.txz: Upgraded.
d/mercurial-6.0.3-i586-1.txz: Upgraded.
l/expat-2.4.5-i586-1.txz: Upgraded.
l/pipewire-0.3.47-i586-1.txz: Upgraded.
n/libnetfilter_conntrack-1.0.9-i586-1.txz: Upgraded.
n/mutt-2.2.1-i586-1.txz: Upgraded.
a/btrfs-progs-5.16.2-i586-1.txz: Upgraded.
a/kernel-generic-5.16.10-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.16.10_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.16.10-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.16.10_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.16.10-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.16.10_smp-i686-1.txz: Upgraded.
ap/cups-filters-1.28.12-i586-1.txz: Upgraded.
ap/qpdf-10.6.2-i586-1.txz: Upgraded.
d/kernel-headers-5.16.10_smp-x86-1.txz: Upgraded.
k/kernel-source-5.16.10_smp-noarch-1.txz: Upgraded.
l/imagemagick-7.1.0_25-i586-1.txz: Upgraded.
l/librsvg-2.52.6-i586-1.txz: Upgraded.
l/pipewire-0.3.46-i586-1.txz: Upgraded.
n/php-7.4.28-i586-1.txz: Upgraded.
x/libdrm-2.4.110-i586-1.txz: Upgraded.
xap/mozilla-firefox-97.0.1-i686-1.txz: Upgraded.
xap/mozilla-thunderbird-91.6.1-i686-1.txz: Upgraded.
extra/linux-5.16.10-nosmp-sdk/*: Upgraded.
extra/php80/php80-8.0.16-i586-1.txz: Upgraded.
extra/php81/php81-8.1.3-i586-1.txz: Upgraded.
a/aaa_base-15.1-i586-2.txz: Rebuilt.
d/help2man-1.49.1-i586-1.txz: Upgraded.
kde/bluedevil-5.24.1-i586-1.txz: Upgraded.
kde/breeze-5.24.1-i586-1.txz: Upgraded.
kde/breeze-grub-5.24.1-i586-1.txz: Upgraded.
kde/breeze-gtk-5.24.1-i586-1.txz: Upgraded.
kde/drkonqi-5.24.1-i586-1.txz: Upgraded.
kde/kactivitymanagerd-5.24.1-i586-1.txz: Upgraded.
kde/kde-cli-tools-5.24.1-i586-1.txz: Upgraded.
kde/kde-gtk-config-5.24.1-i586-1.txz: Upgraded.
kde/kdecoration-5.24.1-i586-1.txz: Upgraded.
kde/kdeplasma-addons-5.24.1-i586-1.txz: Upgraded.
kde/kgamma5-5.24.1-i586-1.txz: Upgraded.
kde/khotkeys-5.24.1-i586-1.txz: Upgraded.
kde/kinfocenter-5.24.1-i586-1.txz: Upgraded.
kde/kmenuedit-5.24.1-i586-1.txz: Upgraded.
kde/kscreen-5.24.1-i586-1.txz: Upgraded.
kde/kscreenlocker-5.24.1-i586-1.txz: Upgraded.
kde/ksshaskpass-5.24.1-i586-1.txz: Upgraded.
kde/ksystemstats-5.24.1-i586-1.txz: Upgraded.
kde/kwallet-pam-5.24.1-i586-1.txz: Upgraded.
kde/kwayland-integration-5.24.1-i586-1.txz: Upgraded.
kde/kwayland-server-5.24.1-i586-1.txz: Upgraded.
kde/kwin-5.24.1-i586-1.txz: Upgraded.
kde/kwrited-5.24.1-i586-1.txz: Upgraded.
kde/layer-shell-qt-5.24.1-i586-1.txz: Upgraded.
kde/libkscreen-5.24.1-i586-1.txz: Upgraded.
kde/libksysguard-5.24.1-i586-1.txz: Upgraded.
kde/milou-5.24.1-i586-1.txz: Upgraded.
kde/oxygen-5.24.1-i586-1.txz: Upgraded.
kde/plasma-browser-integration-5.24.1-i586-1.txz: Upgraded.
kde/plasma-desktop-5.24.1-i586-1.txz: Upgraded.
kde/plasma-disks-5.24.1-i586-1.txz: Upgraded.
kde/plasma-firewall-5.24.1-i586-1.txz: Upgraded.
kde/plasma-integration-5.24.1-i586-1.txz: Upgraded.
kde/plasma-nm-5.24.1-i586-1.txz: Upgraded.
kde/plasma-pa-5.24.1-i586-1.txz: Upgraded.
kde/plasma-sdk-5.24.1-i586-1.txz: Upgraded.
kde/plasma-systemmonitor-5.24.1-i586-1.txz: Upgraded.
kde/plasma-vault-5.24.1-i586-1.txz: Upgraded.
kde/plasma-workspace-5.24.1-i586-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.24.1-i586-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.24.1-i586-1.txz: Upgraded.
kde/powerdevil-5.24.1-i586-1.txz: Upgraded.
kde/qqc2-breeze-style-5.24.1-i586-1.txz: Upgraded.
kde/sddm-kcm-5.24.1-i586-1.txz: Upgraded.
kde/systemsettings-5.24.1-i586-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.24.1-i586-1.txz: Upgraded.
a/util-linux-2.37.4-i586-1.txz: Upgraded.
d/rcs-5.10.1-i586-1.txz: Upgraded.
d/vala-0.54.7-i586-1.txz: Upgraded.
l/libqalculate-4.0.0-i586-1.txz: Upgraded.
ap/mariadb-10.6.7-i586-1.txz: Upgraded.
ap/zsh-5.8.1-i586-1.txz: Upgraded.
d/guile-3.0.8-i586-1.txz: Upgraded.
kde/attica-5.91.0-i586-1.txz: Upgraded.
kde/baloo-5.91.0-i586-1.txz: Upgraded.
kde/bluez-qt-5.91.0-i586-1.txz: Upgraded.
kde/extra-cmake-modules-5.91.0-i586-1.txz: Upgraded.
kde/frameworkintegration-5.91.0-i586-1.txz: Upgraded.
kde/kactivities-5.91.0-i586-1.txz: Upgraded.
kde/kactivities-stats-5.91.0-i586-1.txz: Upgraded.
kde/kapidox-5.91.0-i586-1.txz: Upgraded.
kde/karchive-5.91.0-i586-1.txz: Upgraded.
kde/kauth-5.91.0-i586-1.txz: Upgraded.
kde/kbookmarks-5.91.0-i586-1.txz: Upgraded.
kde/kcalendarcore-5.91.0-i586-1.txz: Upgraded.
kde/kcmutils-5.91.0-i586-1.txz: Upgraded.
kde/kcodecs-5.91.0-i586-1.txz: Upgraded.
kde/kcompletion-5.91.0-i586-1.txz: Upgraded.
kde/kconfig-5.91.0-i586-1.txz: Upgraded.
kde/kconfigwidgets-5.91.0-i586-1.txz: Upgraded.
kde/kcontacts-5.91.0-i586-1.txz: Upgraded.
kde/kcoreaddons-5.91.0-i586-1.txz: Upgraded.
kde/kcrash-5.91.0-i586-1.txz: Upgraded.
kde/kdav-5.91.0-i586-1.txz: Upgraded.
kde/kdbusaddons-5.91.0-i586-1.txz: Upgraded.
kde/kdeclarative-5.91.0-i586-1.txz: Upgraded.
kde/kded-5.91.0-i586-1.txz: Upgraded.
kde/kdelibs4support-5.91.0-i586-1.txz: Upgraded.
kde/kdesignerplugin-5.91.0-i586-1.txz: Upgraded.
kde/kdesu-5.91.0-i586-1.txz: Upgraded.
kde/kdewebkit-5.91.0-i586-1.txz: Upgraded.
kde/kdnssd-5.91.0-i586-1.txz: Upgraded.
kde/kdoctools-5.91.0-i586-1.txz: Upgraded.
kde/kemoticons-5.91.0-i586-1.txz: Upgraded.
kde/kfilemetadata-5.91.0-i586-1.txz: Upgraded.
kde/kglobalaccel-5.91.0-i586-1.txz: Upgraded.
kde/kguiaddons-5.91.0-i586-1.txz: Upgraded.
kde/kholidays-5.91.0-i586-1.txz: Upgraded.
kde/khtml-5.91.0-i586-1.txz: Upgraded.
kde/ki18n-5.91.0-i586-1.txz: Upgraded.
kde/kiconthemes-5.91.0-i586-1.txz: Upgraded.
kde/kidletime-5.91.0-i586-1.txz: Upgraded.
kde/kimageformats-5.91.0-i586-1.txz: Upgraded.
kde/kinit-5.91.0-i586-1.txz: Upgraded.
kde/kio-5.91.0-i586-1.txz: Upgraded.
kde/kirigami2-5.91.0-i586-1.txz: Upgraded.
kde/kitemmodels-5.91.0-i586-1.txz: Upgraded.
kde/kitemviews-5.91.0-i586-1.txz: Upgraded.
kde/kjobwidgets-5.91.0-i586-1.txz: Upgraded.
kde/kjs-5.91.0-i586-1.txz: Upgraded.
kde/kjsembed-5.91.0-i586-1.txz: Upgraded.
kde/kmediaplayer-5.91.0-i586-1.txz: Upgraded.
kde/knewstuff-5.91.0-i586-1.txz: Upgraded.
kde/knotifications-5.91.0-i586-1.txz: Upgraded.
kde/knotifyconfig-5.91.0-i586-1.txz: Upgraded.
kde/kpackage-5.91.0-i586-1.txz: Upgraded.
kde/kparts-5.91.0-i586-1.txz: Upgraded.
kde/kpeople-5.91.0-i586-1.txz: Upgraded.
kde/kplotting-5.91.0-i586-1.txz: Upgraded.
kde/kpty-5.91.0-i586-1.txz: Upgraded.
kde/kquickcharts-5.91.0-i586-1.txz: Upgraded.
kde/kross-5.91.0-i586-1.txz: Upgraded.
kde/krunner-5.91.0-i586-1.txz: Upgraded.
kde/kservice-5.91.0-i586-1.txz: Upgraded.
kde/ktexteditor-5.91.0-i586-1.txz: Upgraded.
kde/ktextwidgets-5.91.0-i586-1.txz: Upgraded.
kde/kunitconversion-5.91.0-i586-1.txz: Upgraded.
kde/kwallet-5.91.0-i586-1.txz: Upgraded.
kde/kwayland-5.91.0-i586-1.txz: Upgraded.
kde/kwidgetsaddons-5.91.0-i586-1.txz: Upgraded.
kde/kwindowsystem-5.91.0-i586-1.txz: Upgraded.
kde/kxmlgui-5.91.0-i586-1.txz: Upgraded.
kde/kxmlrpcclient-5.91.0-i586-1.txz: Upgraded.
kde/modemmanager-qt-5.91.0-i586-1.txz: Upgraded.
kde/networkmanager-qt-5.91.0-i586-1.txz: Upgraded.
kde/plasma-framework-5.91.0-i586-1.txz: Upgraded.
kde/prison-5.91.0-i586-1.txz: Upgraded.
kde/purpose-5.91.0-i586-1.txz: Upgraded.
kde/qqc2-desktop-style-5.91.0-i586-1.txz: Upgraded.
kde/solid-5.91.0-i586-1.txz: Upgraded.
kde/sonnet-5.91.0-i586-1.txz: Upgraded.
kde/syndication-5.91.0-i586-1.txz: Upgraded.
kde/syntax-highlighting-5.91.0-i586-1.txz: Upgraded.
kde/threadweaver-5.91.0-i586-1.txz: Upgraded.
l/harfbuzz-3.4.0-i586-1.txz: Upgraded.
l/imagemagick-7.1.0_24-i586-1.txz: Upgraded.
l/libspectre-0.2.10-i586-1.txz: Upgraded.
l/libxkbcommon-1.4.0-i586-1.txz: Upgraded.
n/mutt-2.2.0-i586-1.txz: Upgraded.
xap/hexchat-2.16.1-i586-1.txz: Upgraded.
xfce/xfce4-notifyd-0.6.3-i586-1.txz: Upgraded.
a/kernel-generic-5.16.9-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.16.9_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.16.9-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.16.9_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.16.9-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.16.9_smp-i686-1.txz: Upgraded.
ap/qpdf-10.6.1-i586-1.txz: Upgraded.
d/binutils-2.38-i586-1.txz: Upgraded.
d/kernel-headers-5.16.9_smp-x86-1.txz: Upgraded.
d/oprofile-1.4.0-i586-9.txz: Rebuilt.
k/kernel-source-5.16.9_smp-noarch-1.txz: Upgraded.
l/glib2-2.70.4-i586-1.txz: Upgraded.
n/ModemManager-1.18.6-i586-1.txz: Upgraded.
n/NetworkManager-1.34.0-i586-1.txz: Upgraded.
n/libqmi-1.30.4-i586-1.txz: Upgraded.
x/ibus-table-1.16.7-i586-1.txz: Upgraded.
x/xorg-server-1.20.14-i586-3.txz: Rebuilt.
x/xorg-server-xephyr-1.20.14-i586-3.txz: Rebuilt.
x/xorg-server-xnest-1.20.14-i586-3.txz: Rebuilt.
x/xorg-server-xvfb-1.20.14-i586-3.txz: Rebuilt.
x/xorg-server-xwayland-21.1.4-i586-2.txz: Rebuilt.
xap/libnma-1.8.34-i586-1.txz: Upgraded.
extra/linux-5.16.9-nosmp-sdk/*: Upgraded.
ap/lxc-4.0.12-i586-1.txz: Upgraded.
ap/man-db-2.10.1-i586-1.txz: Upgraded.
ap/qpdf-10.6.0-i586-1.txz: Upgraded.
l/libarchive-3.6.0-i586-1.txz: Upgraded.
x/libgee-0.20.5-i586-1.txz: Upgraded.
x/mesa-21.3.6-i586-1.txz: Upgraded.
xap/blueman-2.2.4-i586-1.txz: Upgraded.
xap/gftp-2.9.0b-i586-1.txz: Upgraded.
a/aaa_base-15.1-i586-1.txz: Upgraded.
a/btrfs-progs-5.16.1-i586-1.txz: Upgraded.
a/dialog-1.3_20220117-i586-1.txz: Upgraded.
a/ed-1.18-i586-1.txz: Upgraded.
a/findutils-4.9.0-i586-1.txz: Upgraded.
a/kernel-generic-5.16.8-i586-1.txz: Upgraded.
a/kernel-generic-smp-5.16.8_smp-i686-1.txz: Upgraded.
a/kernel-huge-5.16.8-i586-1.txz: Upgraded.
a/kernel-huge-smp-5.16.8_smp-i686-1.txz: Upgraded.
a/kernel-modules-5.16.8-i586-1.txz: Upgraded.
a/kernel-modules-smp-5.16.8_smp-i686-1.txz: Upgraded.
a/lzip-1.23-i586-1.txz: Upgraded.
a/tcsh-6.24.00-i586-1.txz: Upgraded.
ap/alsa-utils-1.2.6-i586-1.txz: Upgraded.
ap/at-3.2.3-i586-1.txz: Upgraded.
ap/cups-2.4.1-i586-1.txz: Upgraded.
ap/man-db-2.10.0-i586-1.txz: Upgraded.
ap/mariadb-10.6.5-i586-1.txz: Upgraded.
ap/nano-6.1-i586-1.txz: Upgraded.
d/kernel-headers-5.16.8_smp-x86-1.txz: Upgraded.
d/llvm-13.0.1-i586-1.txz: Upgraded.
d/mercurial-6.0.2-i586-1.txz: Upgraded.
d/poke-2.1-i586-1.txz: Upgraded.
d/re2c-3.0-i586-1.txz: Upgraded.
k/kernel-source-5.16.8_smp-noarch-1.txz: Upgraded.
kde/akonadi-21.12.2-i586-1.txz: Upgraded.
kde/akonadi-calendar-21.12.2-i586-1.txz: Upgraded.
kde/akonadi-calendar-tools-21.12.2-i586-1.txz: Upgraded.
kde/akonadi-contacts-21.12.2-i586-1.txz: Upgraded.
kde/akonadi-import-wizard-21.12.2-i586-1.txz: Upgraded.
kde/akonadi-mime-21.12.2-i586-1.txz: Upgraded.
kde/akonadi-notes-21.12.2-i586-1.txz: Upgraded.
kde/akonadi-search-21.12.2-i586-1.txz: Upgraded.
kde/akonadiconsole-21.12.2-i586-1.txz: Upgraded.
kde/akregator-21.12.2-i586-1.txz: Upgraded.
kde/analitza-21.12.2-i586-1.txz: Upgraded.
kde/ark-21.12.2-i586-1.txz: Upgraded.
kde/artikulate-21.12.2-i586-1.txz: Upgraded.
kde/audiocd-kio-21.12.2-i586-1.txz: Upgraded.
kde/baloo-widgets-21.12.2-i586-1.txz: Upgraded.
kde/blinken-21.12.2-i586-1.txz: Upgraded.
kde/bluedevil-5.24.0-i586-1.txz: Upgraded.
kde/bomber-21.12.2-i586-1.txz: Upgraded.
kde/bovo-21.12.2-i586-1.txz: Upgraded.
kde/breeze-5.24.0-i586-1.txz: Upgraded.
kde/breeze-grub-5.24.0-i586-1.txz: Upgraded.
kde/breeze-gtk-5.24.0-i586-1.txz: Upgraded.
kde/calendarsupport-21.12.2-i586-1.txz: Upgraded.
kde/cantor-21.12.2-i586-1.txz: Upgraded.
kde/cervisia-21.12.2-i586-1.txz: Upgraded.
kde/dolphin-21.12.2.1-i586-1.txz: Upgraded.
kde/dolphin-plugins-21.12.2-i586-1.txz: Upgraded.
kde/dragon-21.12.2-i586-1.txz: Upgraded.
kde/drkonqi-5.24.0-i586-1.txz: Upgraded.
kde/elisa-21.12.2-i586-1.txz: Upgraded.
kde/eventviews-21.12.2-i586-1.txz: Upgraded.
kde/ffmpegthumbs-21.12.2-i586-1.txz: Upgraded.
kde/filelight-21.12.2-i586-1.txz: Upgraded.
kde/granatier-21.12.2-i586-1.txz: Upgraded.
kde/grantlee-editor-21.12.2-i586-1.txz: Upgraded.
kde/grantleetheme-21.12.2-i586-1.txz: Upgraded.
kde/gwenview-21.12.2-i586-1.txz: Upgraded.
kde/incidenceeditor-21.12.2-i586-1.txz: Upgraded.
kde/itinerary-21.12.2-i586-1.txz: Upgraded.
kde/juk-21.12.2-i586-1.txz: Upgraded.
kde/k3b-21.12.2-i586-1.txz: Upgraded.
kde/kactivitymanagerd-5.24.0-i586-1.txz: Upgraded.
kde/kaddressbook-21.12.2-i586-1.txz: Upgraded.
kde/kalarm-21.12.2-i586-1.txz: Upgraded.
kde/kalarmcal-21.12.2-i586-1.txz: Upgraded.
kde/kalgebra-21.12.2-i586-1.txz: Upgraded.
kde/kalzium-21.12.2-i586-1.txz: Upgraded.
kde/kamera-21.12.2-i586-1.txz: Upgraded.
kde/kamoso-21.12.2-i586-1.txz: Upgraded.
kde/kanagram-21.12.2-i586-1.txz: Upgraded.
kde/kapman-21.12.2-i586-1.txz: Upgraded.
kde/kapptemplate-21.12.2-i586-1.txz: Upgraded.
kde/kate-21.12.2-i586-1.txz: Upgraded.
kde/katomic-21.12.2-i586-1.txz: Upgraded.
kde/kbackup-21.12.2-i586-1.txz: Upgraded.
kde/kblackbox-21.12.2-i586-1.txz: Upgraded.
kde/kblocks-21.12.2-i586-1.txz: Upgraded.
kde/kbounce-21.12.2-i586-1.txz: Upgraded.
kde/kbreakout-21.12.2-i586-1.txz: Upgraded.
kde/kbruch-21.12.2-i586-1.txz: Upgraded.
kde/kcachegrind-21.12.2-i586-1.txz: Upgraded.
kde/kcalc-21.12.2-i586-1.txz: Upgraded.
kde/kcalutils-21.12.2-i586-1.txz: Upgraded.
kde/kcharselect-21.12.2-i586-1.txz: Upgraded.
kde/kcolorchooser-21.12.2-i586-1.txz: Upgraded.
kde/kcron-21.12.2-i586-1.txz: Upgraded.
kde/kde-cli-tools-5.24.0-i586-1.txz: Upgraded.
kde/kde-dev-scripts-21.12.2-i586-1.txz: Upgraded.
kde/kde-dev-utils-21.12.2-i586-1.txz: Upgraded.
kde/kde-gtk-config-5.24.0-i586-1.txz: Upgraded.
kde/kdebugsettings-21.12.2-i586-1.txz: Upgraded.
kde/kdeconnect-kde-21.12.2-i586-1.txz: Upgraded.
kde/kdecoration-5.24.0-i586-1.txz: Upgraded.
kde/kdeedu-data-21.12.2-i586-1.txz: Upgraded.
kde/kdegraphics-mobipocket-21.12.2-i586-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-21.12.2-i586-1.txz: Upgraded.
kde/kdenetwork-filesharing-21.12.2-i586-1.txz: Upgraded.
kde/kdenlive-21.12.2-i586-1.txz: Upgraded.
kde/kdepim-addons-21.12.2-i586-1.txz: Upgraded.
kde/kdepim-runtime-21.12.2-i586-1.txz: Upgraded.
kde/kdeplasma-addons-5.24.0-i586-1.txz: Upgraded.
kde/kdesdk-kioslaves-21.12.2-i586-1.txz: Upgraded.
kde/kdesdk-thumbnailers-21.12.2-i586-1.txz: Upgraded.
kde/kdev-php-21.12.2-i586-1.txz: Upgraded.
kde/kdev-python-21.12.2-i586-1.txz: Upgraded.
kde/kdevelop-21.12.2-i586-1.txz: Upgraded.
kde/kdf-21.12.2-i586-1.txz: Upgraded.
kde/kdialog-21.12.2-i586-1.txz: Upgraded.
kde/kdiamond-21.12.2-i586-1.txz: Upgraded.
kde/keditbookmarks-21.12.2-i586-1.txz: Upgraded.
kde/kfind-21.12.2-i586-1.txz: Upgraded.
kde/kfloppy-21.12.2-i586-1.txz: Upgraded.
kde/kfourinline-21.12.2-i586-1.txz: Upgraded.
kde/kgamma5-5.24.0-i586-1.txz: Upgraded.
kde/kgeography-21.12.2-i586-1.txz: Upgraded.
kde/kget-21.12.2-i586-1.txz: Upgraded.
kde/kgoldrunner-21.12.2-i586-1.txz: Upgraded.
kde/kgpg-21.12.2-i586-1.txz: Upgraded.
kde/khangman-21.12.2-i586-1.txz: Upgraded.
kde/khelpcenter-21.12.2-i586-1.txz: Upgraded.
kde/khotkeys-5.24.0-i586-1.txz: Upgraded.
kde/kidentitymanagement-21.12.2-i586-1.txz: Upgraded.
kde/kig-21.12.2-i586-1.txz: Upgraded.
kde/kigo-21.12.2-i586-1.txz: Upgraded.
kde/killbots-21.12.2-i586-1.txz: Upgraded.
kde/kimagemapeditor-21.12.2-i586-1.txz: Upgraded.
kde/kimap-21.12.2-i586-1.txz: Upgraded.
kde/kinfocenter-5.24.0-i586-1.txz: Upgraded.
kde/kio-extras-21.12.2-i586-1.txz: Upgraded.
kde/kio-gdrive-21.12.2-i586-1.txz: Upgraded.
kde/kipi-plugins-21.12.2-i586-1.txz: Upgraded.
kde/kirigami-gallery-21.12.2-i586-1.txz: Upgraded.
kde/kiriki-21.12.2-i586-1.txz: Upgraded.
kde/kiten-21.12.2-i586-1.txz: Upgraded.
kde/kitinerary-21.12.2-i586-1.txz: Upgraded.
kde/kjumpingcube-21.12.2-i586-1.txz: Upgraded.
kde/kldap-21.12.2-i586-1.txz: Upgraded.
kde/kleopatra-21.12.2-i586-1.txz: Upgraded.
kde/klickety-21.12.2-i586-1.txz: Upgraded.
kde/klines-21.12.2-i586-1.txz: Upgraded.
kde/kmag-21.12.2-i586-1.txz: Upgraded.
kde/kmahjongg-21.12.2-i586-1.txz: Upgraded.
kde/kmail-21.12.2-i586-1.txz: Upgraded.
kde/kmail-account-wizard-21.12.2-i586-1.txz: Upgraded.
kde/kmailtransport-21.12.2-i586-1.txz: Upgraded.
kde/kmbox-21.12.2-i586-1.txz: Upgraded.
kde/kmenuedit-5.24.0-i586-1.txz: Upgraded.
kde/kmime-21.12.2-i586-1.txz: Upgraded.
kde/kmines-21.12.2-i586-1.txz: Upgraded.
kde/kmix-21.12.2-i586-1.txz: Upgraded.
kde/kmousetool-21.12.2-i586-1.txz: Upgraded.
kde/kmouth-21.12.2-i586-1.txz: Upgraded.
kde/kmplot-21.12.2-i586-1.txz: Upgraded.
kde/knavalbattle-21.12.2-i586-1.txz: Upgraded.
kde/knetwalk-21.12.2-i586-1.txz: Upgraded.
kde/knights-21.12.2-i586-1.txz: Upgraded.
kde/knotes-21.12.2-i586-1.txz: Upgraded.
kde/kolf-21.12.2-i586-1.txz: Upgraded.
kde/kollision-21.12.2-i586-1.txz: Upgraded.
kde/kolourpaint-21.12.2-i586-1.txz: Upgraded.
kde/kompare-21.12.2-i586-1.txz: Upgraded.
kde/konqueror-21.12.2-i586-1.txz: Upgraded.
kde/konquest-21.12.2-i586-1.txz: Upgraded.
kde/konsole-21.12.2-i586-1.txz: Upgraded.
kde/kontact-21.12.2-i586-1.txz: Upgraded.
kde/kontactinterface-21.12.2-i586-1.txz: Upgraded.
kde/kontrast-21.12.2-i586-1.txz: Upgraded.
kde/konversation-21.12.2-i586-1.txz: Upgraded.
kde/kopeninghours-21.12.2-i586-1.txz: Upgraded.
kde/kopete-21.12.2-i586-1.txz: Upgraded.
kde/korganizer-21.12.2-i586-1.txz: Upgraded.
kde/kosmindoormap-21.12.2-i586-1.txz: Upgraded.
kde/kpat-21.12.2-i586-1.txz: Upgraded.
kde/kpimtextedit-21.12.2-i586-1.txz: Upgraded.
kde/kpkpass-21.12.2-i586-1.txz: Upgraded.
kde/kpmcore-21.12.2-i586-1.txz: Upgraded.
kde/kpublictransport-21.12.2-i586-1.txz: Upgraded.
kde/kqtquickcharts-21.12.2-i586-1.txz: Upgraded.
kde/krdc-21.12.2-i586-1.txz: Upgraded.
kde/kreversi-21.12.2-i586-1.txz: Upgraded.
kde/krfb-21.12.2-i586-1.txz: Upgraded.
kde/kross-interpreters-21.12.2-i586-1.txz: Upgraded.
kde/kruler-21.12.2-i586-1.txz: Upgraded.
kde/kscreen-5.24.0-i586-1.txz: Upgraded.
kde/kscreenlocker-5.24.0-i586-1.txz: Upgraded.
kde/kshisen-21.12.2-i586-1.txz: Upgraded.
kde/ksirk-21.12.2-i586-1.txz: Upgraded.
kde/ksmtp-21.12.2-i586-1.txz: Upgraded.
kde/ksnakeduel-21.12.2-i586-1.txz: Upgraded.
kde/kspaceduel-21.12.2-i586-1.txz: Upgraded.
kde/ksquares-21.12.2-i586-1.txz: Upgraded.
kde/ksshaskpass-5.24.0-i586-1.txz: Upgraded.
kde/ksudoku-21.12.2-i586-1.txz: Upgraded.
kde/ksystemlog-21.12.2-i586-1.txz: Upgraded.
kde/ksystemstats-5.24.0-i586-1.txz: Upgraded.
kde/kteatime-21.12.2-i586-1.txz: Upgraded.
kde/ktimer-21.12.2-i586-1.txz: Upgraded.
kde/ktnef-21.12.2-i586-1.txz: Upgraded.
kde/ktorrent-21.12.2-i586-1.txz: Upgraded.
kde/ktouch-21.12.2-i586-1.txz: Upgraded.
kde/kturtle-21.12.2-i586-1.txz: Upgraded.
kde/kubrick-21.12.2-i586-1.txz: Upgraded.
kde/kwallet-pam-5.24.0-i586-1.txz: Upgraded.
kde/kwalletmanager-21.12.2-i586-1.txz: Upgraded.
kde/kwave-21.12.2-i586-1.txz: Upgraded.
kde/kwayland-integration-5.24.0-i586-1.txz: Upgraded.
kde/kwayland-server-5.24.0-i586-1.txz: Upgraded.
kde/kwin-5.24.0-i586-1.txz: Upgraded.
kde/kwordquiz-21.12.2-i586-1.txz: Upgraded.
kde/kwrited-5.24.0-i586-1.txz: Upgraded.
kde/layer-shell-qt-5.24.0-i586-1.txz: Upgraded.
kde/libgravatar-21.12.2-i586-1.txz: Upgraded.
kde/libkcddb-21.12.2-i586-1.txz: Upgraded.
kde/libkcompactdisc-21.12.2-i586-1.txz: Upgraded.
kde/libkdcraw-21.12.2-i586-1.txz: Upgraded.
kde/libkdegames-21.12.2-i586-1.txz: Upgraded.
kde/libkdepim-21.12.2-i586-1.txz: Upgraded.
kde/libkeduvocdocument-21.12.2-i586-1.txz: Upgraded.
kde/libkexiv2-21.12.2-i586-1.txz: Upgraded.
kde/libkgapi-21.12.2-i586-1.txz: Upgraded.
kde/libkipi-21.12.2-i586-1.txz: Upgraded.
kde/libkleo-21.12.2-i586-1.txz: Upgraded.
kde/libkmahjongg-21.12.2-i586-1.txz: Upgraded.
kde/libkomparediff2-21.12.2-i586-1.txz: Upgraded.
kde/libksane-21.12.2-i586-1.txz: Upgraded.
kde/libkscreen-5.24.0-i586-1.txz: Upgraded.
kde/libksieve-21.12.2-i586-1.txz: Upgraded.
kde/libksysguard-5.24.0-i586-1.txz: Upgraded.
kde/libktorrent-21.12.2-i586-1.txz: Upgraded.
kde/lokalize-21.12.2-i586-1.txz: Upgraded.
kde/lskat-21.12.2-i586-1.txz: Upgraded.
kde/mailcommon-21.12.2-i586-1.txz: Upgraded.
kde/mailimporter-21.12.2-i586-1.txz: Upgraded.
kde/marble-21.12.2-i586-1.txz: Upgraded.
kde/markdownpart-21.12.2-i586-1.txz: Upgraded.
kde/mbox-importer-21.12.2-i586-1.txz: Upgraded.
kde/messagelib-21.12.2-i586-1.txz: Upgraded.
kde/milou-5.24.0-i586-1.txz: Upgraded.
kde/minuet-21.12.2-i586-1.txz: Upgraded.
kde/okular-21.12.2-i586-1.txz: Upgraded.
kde/oxygen-5.24.0-i586-1.txz: Upgraded.
kde/palapeli-21.12.2-i586-1.txz: Upgraded.
kde/parley-21.12.2-i586-1.txz: Upgraded.
kde/partitionmanager-21.12.2-i586-1.txz: Upgraded.
kde/picmi-21.12.2-i586-1.txz: Upgraded.
kde/pim-data-exporter-21.12.2-i586-1.txz: Upgraded.
kde/pim-sieve-editor-21.12.2-i586-1.txz: Upgraded.
kde/pimcommon-21.12.2-i586-1.txz: Upgraded.
kde/plasma-browser-integration-5.24.0-i586-1.txz: Upgraded.
kde/plasma-desktop-5.24.0-i586-1.txz: Upgraded.
kde/plasma-disks-5.24.0-i586-1.txz: Upgraded.
kde/plasma-firewall-5.24.0-i586-1.txz: Upgraded.
kde/plasma-integration-5.24.0-i586-1.txz: Upgraded.
kde/plasma-nm-5.24.0-i586-1.txz: Upgraded.
kde/plasma-pa-5.24.0-i586-1.txz: Upgraded.
kde/plasma-sdk-5.24.0-i586-1.txz: Upgraded.
kde/plasma-systemmonitor-5.24.0-i586-1.txz: Upgraded.
kde/plasma-vault-5.24.0-i586-1.txz: Upgraded.
kde/plasma-workspace-5.24.0-i586-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.24.0-i586-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.24.0-i586-1.txz: Upgraded.
kde/powerdevil-5.24.0-i586-1.txz: Upgraded.
kde/poxml-21.12.2-i586-1.txz: Upgraded.
kde/print-manager-21.12.2-i586-1.txz: Upgraded.
kde/qqc2-breeze-style-5.24.0-i586-1.txz: Upgraded.
kde/rocs-21.12.2-i586-1.txz: Upgraded.
kde/sddm-kcm-5.24.0-i586-1.txz: Upgraded.
kde/skanlite-21.12.2-i586-1.txz: Upgraded.
kde/spectacle-21.12.2-i586-1.txz: Upgraded.
kde/step-21.12.2-i586-1.txz: Upgraded.
kde/svgpart-21.12.2-i586-1.txz: Upgraded.
kde/sweeper-21.12.2-i586-1.txz: Upgraded.
kde/systemsettings-5.24.0-i586-1.txz: Upgraded.
kde/umbrello-21.12.2-i586-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.24.0-i586-1.txz: Upgraded.
kde/yakuake-21.12.2-i586-1.txz: Upgraded.
kde/zanshin-21.12.2-i586-1.txz: Upgraded.
kde/zeroconf-ioslave-21.12.2-i586-1.txz: Upgraded.
l/alsa-lib-1.2.6.1-i586-1.txz: Upgraded.
l/alsa-plugins-1.2.6-i586-1.txz: Upgraded.
l/gdbm-1.23-i586-1.txz: Upgraded.
l/gjs-1.70.1-i586-1.txz: Upgraded.
l/gst-plugins-bad-free-1.20.0-i586-1.txz: Upgraded.
l/gst-plugins-base-1.20.0-i586-1.txz: Upgraded.
l/gst-plugins-good-1.20.0-i586-1.txz: Upgraded.
l/gst-plugins-libav-1.20.0-i586-1.txz: Upgraded.
l/gstreamer-1.20.0-i586-1.txz: Upgraded.
l/harfbuzz-3.3.2-i586-1.txz: Upgraded.
l/imagemagick-7.1.0_23-i586-1.txz: Upgraded.
l/lcms2-2.13.1-i586-1.txz: Upgraded.
l/libical-3.0.14-i586-1.txz: Upgraded.
l/mozilla-nss-3.75-i586-1.txz: Upgraded.
l/pipewire-0.3.45-i586-1.txz: Upgraded.
l/quazip-1.2-i586-1.txz: Upgraded.
n/bind-9.18.0-i586-1.txz: Upgraded.
n/dovecot-2.3.18-i586-1.txz: Upgraded.
n/gnupg2-2.2.34-i586-1.txz: Upgraded.
n/gnutls-3.7.3-i586-1.txz: Upgraded.
n/libgcrypt-1.10.0-i586-1.txz: Upgraded.
n/postfix-3.7.0-i586-1.txz: Upgraded.
x/freeglut-3.2.2-i586-1.txz: Upgraded.
xap/mozilla-firefox-97.0-i686-1.txz: Upgraded.
xap/mozilla-thunderbird-91.6.0-i686-1.txz: Upgraded.
extra/linux-5.16.8-nosmp-sdk/*: Upgraded.
extra/rust-for-mozilla/rust-1.57.0-i686-1.txz: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Napisano: 22 Feb 2022, 17:43
Slackware 64-bit
Mon Feb 21 20:21:38 UTC 2022
a/aaa_glibc-solibs-2.35-x86_64-1.txz: Upgraded.
a/kernel-firmware-20220218_c53073d-noarch-1.txz: Upgraded.
ap/flac-1.3.4-x86_64-1.txz: Upgraded.
This update fixes overflow issues with encoding and decoding.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2020-0499
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2021-0561
ap/ksh93-1.0_20220219_bc6c5dbd-x86_64-1.txz: Upgraded.
ap/mariadb-10.6.7-x86_64-2.txz: Rebuilt.
Removed dangling symlink.
ap/vim-8.2.4428-x86_64-1.txz: Upgraded.
Patched ctags for glibc-2.35. Thanks to nobodino.
d/autoconf-2.71-noarch-1.txz: Upgraded.
d/automake-1.16.5-noarch-1.txz: Upgraded.
d/binutils-2.38-x86_64-2.txz: Rebuilt.
Fixed the SlackBuild to not run autoconf in the libiberty and intl
subdirectories. It doesn't work with the latest autoconf, and there
doesn't seem to be any need for it anyway.
d/cmake-3.22.2-x86_64-1.txz: Upgraded.
d/meson-0.61.2-x86_64-1.txz: Upgraded.
d/rcs-5.10.0-x86_64-4.txz: Rebuilt.
Patched for glibc-2.35. Thanks to nobodino.
d/scons-4.3.0-x86_64-1.txz: Upgraded.
e/emacs-27.2-x86_64-2.txz: Rebuilt.
kde/digikam-7.5.0-x86_64-2.txz: Rebuilt.
Recompiled against jasper-3.0.2.
kde/wacomtablet-20220124_dd28b27-x86_64-1.txz: Upgraded.
l/LibRaw-0.20.2-x86_64-4.txz: Rebuilt.
l/accountsservice-22.07.5-x86_64-1.txz: Upgraded.
l/dconf-editor-3.38.3-x86_64-2.txz: Rebuilt.
Fixed build errors with meson.
l/expat-2.4.6-x86_64-1.txz: Upgraded.
l/fuse-2.9.9-x86_64-4.txz: Rebuilt.
l/gcr-3.40.0-x86_64-2.txz: Rebuilt.
l/gdk-pixbuf2-2.42.6-x86_64-2.txz: Rebuilt.
Fixed meson options.
l/gdk-pixbuf2-xlib-2.40.2-x86_64-4.txz: Rebuilt.
l/gegl-0.4.34-x86_64-3.txz: Rebuilt.
l/glade-3.38.2-x86_64-6.txz: Rebuilt.
Removed duplicated 'da' from help/LINGUAS.
l/glibc-2.35-x86_64-1.txz: Upgraded.
l/glibc-i18n-2.35-x86_64-1.txz: Upgraded.
l/glibc-profile-2.35-x86_64-1.txz: Upgraded.
l/gobject-introspection-1.71.0-x86_64-1.txz: Upgraded.
This update was needed to solve failing tests with the new meson.
l/gtk+2-2.24.33-x86_64-3.txz: Rebuilt.
Changed build/host to $ARCH-slackware-linux-gnu.
l/gtk4-4.4.1-x86_64-2.txz: Rebuilt.
l/gvfs-1.48.1-x86_64-2.txz: Rebuilt.
l/imagemagick-7.1.0_26-x86_64-1.txz: Upgraded.
l/jasper-3.0.2-x86_64-1.txz: Upgraded.
l/json-glib-1.6.6-x86_64-2.txz: Rebuilt.
l/libsecret-0.20.5-x86_64-1.txz: Upgraded.
l/netpbm-10.97.04-x86_64-1.txz: Upgraded.
l/qt5-5.15.3_20211130_014c375b-x86_64-3.txz: Rebuilt.
l/shared-mime-info-2.1-x86_64-4.txz: Rebuilt.
n/gpgme-1.17.0-x86_64-1.txz: Upgraded.
n/ntp-4.2.8p15-x86_64-9.txz: Rebuilt.
x/libinput-1.19.3-x86_64-2.txz: Rebuilt.
Recompiled against libwacom-2.1.0.
x/libva-2.14.0-x86_64-1.txz: Upgraded.
x/libva-utils-2.14.0-x86_64-1.txz: Upgraded.
x/libwacom-2.1.0-x86_64-1.txz: Upgraded.
x/motif-2.3.8-x86_64-6.txz: Rebuilt.
Fixed build with LEXLIB="-lfl".
x/vulkan-sdk-1.2.176.1-x86_64-3.txz: Rebuilt.
x/xf86-input-wacom-1.0.0-x86_64-1.txz: Upgraded.
xap/network-manager-applet-1.24.0-x86_64-3.txz: Rebuilt.
xap/vim-gvim-8.2.4428-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/aaa_glibc-solibs-2.35-i586-1.txz: Upgraded.
ap/flac-1.3.4-i586-1.txz: Upgraded.
ap/ksh93-1.0_20220219_bc6c5dbd-i586-1.txz: Upgraded.
ap/mariadb-10.6.7-i586-2.txz: Rebuilt.
ap/vim-8.2.4428-i586-1.txz: Upgraded.
d/binutils-2.38-i586-2.txz: Rebuilt.
d/cmake-3.22.2-i586-1.txz: Upgraded.
d/meson-0.61.2-i586-1.txz: Upgraded.
d/rcs-5.10.0-i586-4.txz: Rebuilt.
d/scons-4.3.0-i586-1.txz: Upgraded.
e/emacs-27.2-i586-2.txz: Rebuilt.
kde/digikam-7.5.0-i586-2.txz: Rebuilt.
kde/wacomtablet-20220124_dd28b27-i586-1.txz: Upgraded.
l/LibRaw-0.20.2-i586-4.txz: Rebuilt.
l/accountsservice-22.07.5-i586-1.txz: Upgraded.
l/dconf-editor-3.38.3-i586-2.txz: Rebuilt.
l/expat-2.4.6-i586-1.txz: Upgraded.
l/fuse-2.9.9-i586-4.txz: Rebuilt.
l/gcr-3.40.0-i586-2.txz: Rebuilt.
l/gdk-pixbuf2-2.42.6-i586-2.txz: Rebuilt.
l/gdk-pixbuf2-xlib-2.40.2-i586-4.txz: Rebuilt.
l/gegl-0.4.34-i586-3.txz: Rebuilt.
l/glade-3.38.2-i586-6.txz: Rebuilt.
l/glibc-2.35-i586-1.txz: Upgraded.
l/glibc-i18n-2.35-i586-1.txz: Upgraded.
l/glibc-profile-2.35-i586-1.txz: Upgraded.
l/gobject-introspection-1.71.0-i586-1.txz: Upgraded.
l/gtk+2-2.24.33-i586-3.txz: Rebuilt.
l/gtk4-4.4.1-i586-2.txz: Rebuilt.
l/gvfs-1.48.1-i586-2.txz: Rebuilt.
l/imagemagick-7.1.0_26-i586-1.txz: Upgraded.
l/jasper-3.0.2-i586-1.txz: Upgraded.
l/json-glib-1.6.6-i586-2.txz: Rebuilt.
l/libsecret-0.20.5-i586-1.txz: Upgraded.
l/netpbm-10.97.04-i586-1.txz: Upgraded.
l/qt5-5.15.3_20211130_014c375b-i586-3.txz: Rebuilt.
l/shared-mime-info-2.1-i586-4.txz: Rebuilt.
n/gpgme-1.17.0-i586-1.txz: Upgraded.
n/ntp-4.2.8p15-i586-9.txz: Rebuilt.
x/libinput-1.19.3-i586-2.txz: Rebuilt.
x/libva-2.14.0-i586-1.txz: Upgraded.
x/libva-utils-2.14.0-i586-1.txz: Upgraded.
x/libwacom-2.1.0-i586-1.txz: Upgraded.
x/motif-2.3.8-i586-6.txz: Rebuilt.
x/vulkan-sdk-1.2.176.1-i586-3.txz: Rebuilt.
x/xf86-input-wacom-1.0.0-i586-1.txz: Upgraded.
xap/network-manager-applet-1.24.0-i586-3.txz: Rebuilt.
xap/vim-gvim-8.2.4428-i586-1.txz: Upgraded.
