Locked
Post Napisano: 14 Aug 2018, 17:44
01.08.2018.
Sveži blueman paketi za Slackware 14.2 i -current:
patches/packages/blueman-2.0.6-i586-1_slack14.2.txz:  Upgraded.
  This update fixes an issue where blueman-mechanism did not enforce the
  polkit action 'org.blueman.network.setup' for which a polkit policy is
  shipped. This meant that any user with access to the D-Bus system bus was
  able to access the related API without authentication. The result was an
  unspecified impact on the networking stack.
  Thanks to Matthias Gerstner for discovering this issue.
Post Napisano: 14 Aug 2018, 17:46
02.08.2018.
Sveži lftp paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/lftp-4.8.4-i586-1_slack14.2.txz:  Upgraded.
  It has been discovered that lftp up to and including version 4.8.3 does
  not properly sanitize remote file names, leading to a loss of integrity
  on the local system when reverse mirroring is used. A remote attacker
  may trick a user to use reverse mirroring on an attacker controlled FTP
  server, resulting in the removal of all files in the current working
  directory of the victim's system.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10916
Post Napisano: 14 Aug 2018, 17:47
10.08.2018.
patches/packages/bind-9.10.8_P1-i586-1_slack14.2.txz:  Upgraded.
  Fixed a security issue where named could crash during recursive processing
  of DNAME records when "deny-answer-aliases" was in use resulting in a
  denial of service. Note that "deny-answer-aliases" is rarely used.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-5740
  (* Security fix*)
Post Napisano: 23 Aug 2018, 20:09
14.08.2018.
Sveži openssl paketi za Slackware 14.2 i -current:
patches/packages/openssl-1.0.2p-i586-1_slack14.2.txz:  Upgraded.
  This update fixes two low severity security issues:
  Client DoS due to large DH parameter.
  Cache timing vulnerability in RSA Key Generation.
    https://www.openssl.org/news/secadv/20180612.txt
    https://www.openssl.org/news/secadv/20180416.txt
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-0732
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-0737
patches/packages/openssl-solibs-1.0.2p-i586-1_slack14.2.txz:  Upgraded.
Post Napisano: 23 Aug 2018, 20:11
17.08.2018.
Sveži ntp i samba paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/ntp-4.2.8p12-i586-1_slack14.2.txz:  Upgraded.
  This release improves on one security fix in ntpd:
    LOW/MEDIUM: Sec 3012: Sybil vulnerability: ephemeral association attack
    While fixed in ntp-4.2.8p7 and with significant additional protections for
    this issue in 4.2.8p11, ntp-4.2.8p12 includes a fix for an edge case in
    the new noepeer support. Originally reported by Matt Van Gundy of Cisco.
    Edge-case hole reported by Martin Burnicki of Meinberg.
  And fixes another security issue in ntpq and ntpdc:
    LOW: Sec 3505: The openhost() function used during command-line hostname
    processing by ntpq and ntpdc can write beyond its buffer limit, which
    could allow  an attacker to achieve code execution or escalate to higher
    privileges via a long string as the argument for an IPv4 or IPv6
    command-line parameter. NOTE: It is unclear whether there are any common
    situations in which ntpq or ntpdc is used with a command line from an
    untrusted source. Reported by Fakhri Zulkifli.
    http://support.ntp.org/bin/view/Main/SecurityNotice#August_2018_ntp_4_2_8p12_NTP_Rel
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1549
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-12327
patches/packages/samba-4.6.16-i586-1_slack14.2.txz:  Upgraded.
  This is a security release in order to address the following defects:
  Insufficient input validation on client directory listing in libsmbclient.
  A malicious server could return a directory entry that could corrupt
  libsmbclient memory.
  Confidential attribute disclosure from the AD LDAP server.
  Missing access control checks allow discovery of confidential attribute
  values via authenticated LDAP search expressions.
    https://www.samba.org/samba/security/CVE-2018-10858.html
    https://www.samba.org/samba/security/CVE-2018-10919.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10858
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-10919
Post Napisano: 23 Aug 2018, 20:12
21.08.2018.
Sveži libX11 paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/libX11-1.6.6-i586-1_slack14.2.txz:  Upgraded.
  This update fixes some security issues:
  Fixed crash on invalid reply (CVE-2018-14598).
  Fixed off-by-one writes (CVE-2018-14599).
  Fixed out of boundary write (CVE-2018-14600).
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14598
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14599
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14600
Post Napisano: 21 Sep 2018, 20:10
28.08.2018.
patches/packages/linux-4.4.153/*:  Upgraded.
  This kernel update enables mitigations for L1 Terminal Fault aka
  Foreshadow and Foreshadow-NG vulnerabilities.
  Thanks to Bernhard Kaindl for bisecting the boot issue that was preventing
  us from upgrading to earlier 4.4.x kernels that contained this fix.
  To see the status of CPU vulnerability mitigations on your system, look at
  the files in: /sys/devices/system/cpu/vulnerabilities
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-3615
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-3620
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-3546
Post Napisano: 21 Sep 2018, 20:13
06.09.2018.
patches/packages/curl-7.61.1-i586-1_slack14.2.txz:  Upgraded.
  This update fixes an NTLM password overflow via integer overflow.
    https://curl.haxx.se/docs/CVE-2018-14618.html
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-14618
Sveži ghostscript, mozilla-firefox i mozilla-thunderbird paketi za Slackare 14.2 i -current:
patches/packages/ghostscript-9.24-i586-1_slack14.2.txz:  Upgraded.
  Patched multiple -dSAFER sandbox bypass vulnerabilities.
  Thanks to Tavis Ormandy.
    https://www.ghostscript.com/doc/9.24/News.htm
    https://www.kb.cert.org/vuls/id/332928
patches/packages/mozilla-firefox-60.2.0esr-i686-1_slack14.2.txz:  Upgraded.
patches/packages/mozilla-thunderbird-60.0-i686-1_slack14.2.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/60.0/releasenotes/
    https://www.mozilla.org/security/known-vulnerabilities/thunderbird.html
    https://www.mozilla.org/en-US/security/advisories/mfsa2018-19/
Post Napisano: 21 Sep 2018, 20:14
13.09.2018.
Sveži ghostscript paketi za Slackware 14.2 i -current:
patches/packages/ghostscript-9.25-i586-1_slack14.2.txz:  Upgraded.
  This release fixes problems with argument handling, some unintended
  results of the security fixes to the SAFER file access restrictions
  (specifically accessing ICC profile files), and some additional
  security issues over the recent 9.24 release.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-16509
Post Napisano: 21 Sep 2018, 20:15
14.09.2018.
Sveži php paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/php-5.6.38-i586-1_slack14.2.txz:  Upgraded.
  One security bug has been fixed in this release:
  Apache2: XSS due to the header Transfer-Encoding: chunked
    https://php.net/ChangeLog-5.php#5.6.38
Locked
