Locked
Post Napisano: 25 Sep 2022, 07:40
20.09.2022.
Sveži mozilla-firefox paketi za Slackware 15 i -current:
patches/packages/mozilla-firefox-102.3.0esr-i686-1_slack15.0.txz:  Upgraded.
    https://www.mozilla.org/en-US/firefox/102.3.0/releasenotes/
    https://www.mozilla.org/security/advisories/mfsa2022-41/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-40959
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-40960
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-40958
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-40956
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-40957
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-40962
Post Napisano: 25 Sep 2022, 07:41
21.09.2022.
Sveži bind paketi za Slackware 15 i -current:
patches/packages/bind-9.16.33-i586-1_slack15.0.txz:  Upgraded.
  This update fixes bugs and the following security issues:
  Fix memory leak in EdDSA verify processing.
  Fix memory leak in ECDSA verify processing.
  Fix serve-stale crash that could happen when stale-answer-client-timeout
  was set to 0 and there was a stale CNAME in the cache for an incoming query.
  Prevent excessive resource use while processing large delegations.
    https://kb.isc.org/docs/cve-2022-38178
    https://kb.isc.org/docs/cve-2022-38177
    https://kb.isc.org/docs/cve-2022-3080
    https://kb.isc.org/docs/cve-2022-2795
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-38178
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-38177
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-3080
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-2795
23.09.2022.
Sveži vim paketi za Slackware 15 i -current:
patches/packages/vim-9.0.0558-i586-1_slack15.0.txz:  Upgraded.
  Fixed use after free.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-3256
patches/packages/vim-gvim-9.0.0558-i586-1_slack15.0.txz:  Upgraded.
Post Napisano: 01 Oct 2022, 15:34
26.09.2022.
Sveži dnsmasq paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/dnsmasq-2.87-i586-1_slack15.0.txz:  Upgraded.
  Fix write-after-free error in DHCPv6 server code.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0934
Sveži vim paketi za Slackware 15.0 i -current:
patches/packages/vim-9.0.0594-i586-1_slack15.0.txz:  Upgraded.
  Fixed stack-based buffer overflow.
  In addition, Mig21 pointed out an issue where the defaults.vim file might
  need to be edited for some purposes as its contents will override the
  settings in the system-wide vimrc. Usually this file is replaced whenever
  vim is upgraded, which in those situations would be inconvenient for the
  admin. So, I've added support for a file named defaults.vim.custom which
  (if it exists) will be used instead of the defaults.vim file shipped in
  the packages and will persist through upgrades.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-3296
patches/packages/vim-gvim-9.0.0594-i586-1_slack15.0.txz:  Upgraded.
Post Napisano: 01 Oct 2022, 15:35
28.09.2022.
Sveži xorg-server-xwayland paketi za Slackware 15.0 i -current:
patches/packages/xorg-server-xwayland-21.1.4-i586-2_slack15.0.txz:  Rebuilt.
  xkb: switch to array index loops to moving pointers.
  xkb: add request length validation for XkbSetGeometry.
  xkb: swap XkbSetDeviceInfo and XkbSetDeviceInfoCheck.
  I hadn't realized that the xorg-server patches were needed (or applied
  cleanly) to Xwayland. Thanks to LuckyCyborg for the kind reminder. :-)
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-2319
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-2320
Post Napisano: 01 Oct 2022, 15:37
30.09.2022.
Sveži mozilla-thunderbird, php, seamonkey i vim paketi za Slackware 15.0 i -current:
patches/packages/mozilla-thunderbird-102.3.1-i686-1_slack15.0.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/102.3.1/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2022-43/
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-39249
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-39250
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-39251
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-39236
patches/packages/php-7.4.32-i586-1_slack15.0.txz:  Upgraded.
  phar wrapper: DOS when using quine gzip file.
  Don't mangle HTTP variable names that clash with ones that have a specific
  semantic meaning.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-31628
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-31629
patches/packages/seamonkey-2.53.14-i686-1_slack15.0.txz:  Upgraded.
    https://www.seamonkey-project.org/releases/seamonkey2.53.14
patches/packages/vim-9.0.0623-i586-1_slack15.0.txz:  Upgraded.
  Fixed use-after-free and stack-based buffer overflow.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=2022-3352
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=2022-3324
patches/packages/vim-gvim-9.0.0623-i586-1_slack15.0.txz:  Upgraded.
Post Napisano: 15 Oct 2022, 14:31
05.10.2022.
Sveži dhcp paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/dhcp-4.4.3_P1-i586-1_slack15.0.txz:  Upgraded.
  Corrected a reference count leak that occurs when the server builds
  responses to leasequery packets.
  Corrected a memory leak that occurs when unpacking a packet that has an
  FQDN option (81) that contains a label with length greater than 63 bytes.
  Thanks to VictorV of Cyber Kunlun Lab for reporting these issues.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-2928
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-2929
Post Napisano: 15 Oct 2022, 14:33
08.10.2022.
Sveži libksba paketi za Slackware 14.2, 15.0 i -current:
patches/packages/libksba-1.6.2-i586-1_slack15.0.txz:  Upgraded.
  Detect a possible overflow directly in the TLV parser.
  This patch detects possible integer overflows immmediately when creating
  the TI object.
  Reported-by: ZDI-CAN-18927, ZDI-CAN-18928, ZDI-CAN-18929
Post Napisano: 15 Oct 2022, 14:34
13.10.2022.
Sveži python3 paketi za Slackware 15.0 i -current:
patches/packages/python3-3.9.15-i586-1_slack15.0.txz:  Upgraded.
  Bundled libexpat was upgraded from 2.4.7 to 2.4.9 which fixes a heap
  use-after-free vulnerability in function doContent.
  gh-97616: a fix for a possible buffer overflow in list *= int.
  gh-97612: a fix for possible shell injection in the example script
  get-remote-certificate.py.
  gh-96577: a fix for a potential buffer overrun in msilib.
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-40674
Post Napisano: 24 Oct 2022, 06:43
15.10.2022.
Sveži zlib paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/zlib-1.2.13-i586-1_slack15.0.txz:  Upgraded.
  Fixed a bug when getting a gzip header extra field with inflateGetHeader().
    https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-37434
Locked
Users browsing this forum: No registered users and 24 guests
