Napisano: 01 May 2022, 11:09
30.04.2022.
Sveži pidgin paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/pidgin-2.14.9-i586-1_slack15.0.txz: Upgraded.
Mitigate the potential for a man in the middle attack via DNS spoofing by
removing the code that supported the _xmppconnect DNS TXT record.
https://www.pidgin.im/about/security/advisories/cve-2022-26491/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-26491
Napisano: 08 May 2022, 06:46
02.05.2022.
Sveži libxml2 paketi za Slackware 14., 14,1, 14.2, 15.0 i -current:
patches/packages/libxml2-2.9.14-i586-1_slack15.0.txz: Upgraded.
This update fixes bugs and the following security issues:
Fix integer overflow in xmlBuf and xmlBuffer.
Fix potential double-free in xmlXPtrStringRangeFunction.
Fix memory leak in xmlFindCharEncodingHandler.
Normalize XPath strings in-place.
Prevent integer-overflow in htmlSkipBlankChars() and xmlSkipBlankChars().
Fix leak of xmlElementContent.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-29824
Napisano: 08 May 2022, 06:50
04.05.2022.
patches/packages/mozilla-thunderbird-91.9.0-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/91.9.0/releasenotes/
Sveži openssl paketi za Slackware 14.2, 15.0 i -current:
patches/packages/openssl-1.1.1o-i586-1_slack15.0.txz: Upgraded.
Fixed a bug in the c_rehash script which was not properly sanitising shell
metacharacters to prevent command injection.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1292
patches/packages/openssl-solibs-1.1.1o-i586-1_slack15.0.txz: Upgraded.
Sveži seamonkey paketi za Slackware 15.0 i -current:
patches/packages/seamonkey-2.53.12-i686-1_slack15.0.txz: Upgraded.
https://www.seamonkey-project.org/releases/seamonkey2.53.12
Napisano: 21 May 2022, 14:46
09.05.2022.
Sveži kernel paketi za Slackware 15:
patches/packages/linux-5.15.38/*: Upgraded.
These updates fix various bugs and security issues.
Fixed in 5.15.27:
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0742
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-24958
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0494
Fixed in 5.15.28:
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23038
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23039
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23960
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23036
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23037
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0001
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0002
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23041
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23040
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23042
Fixed in 5.15.29:
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1199
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27666
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1011
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0995
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0854
Fixed in 5.15.32:
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1015
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-26490
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1048
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1016
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-28356
Fixed in 5.15.33:
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-28390
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0168
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1158
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1353
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1198
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-28389
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-28388
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1516
Fixed in 5.15.34:
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1263
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-29582
Fixed in 5.15.35:
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1204
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1205
Fixed in 5.15.37:
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-0500
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-23222
Napisano: 21 May 2022, 14:47
11.05.2022.
Sveži curl paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/curl-7.83.1-i586-1_slack15.0.txz: Upgraded.
HSTS bypass via trailing dot.
TLS and SSH connection too eager reuse.
CERTINFO never-ending busy-loop.
percent-encoded path separator in URL host.
cookie for trailing dot TLD.
curl removes wrong file on error.
https://curl.se/docs/CVE-2022-30115.html
https://curl.se/docs/CVE-2022-27782.html
https://curl.se/docs/CVE-2022-27781.html
https://curl.se/docs/CVE-2022-27780.html
https://curl.se/docs/CVE-2022-27779.html
https://curl.se/docs/CVE-2022-27778.html
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-30115
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27782
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27781
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27780
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27779
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27778
Napisano: 21 May 2022, 14:49
20.05.2022.
Sveži mozilla-firefox i mozilla-thunderbird paketi za Slackware 15.0 i -current:
patches/packages/mozilla-firefox-91.9.1esr-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/91.9.1/releasenotes/
https://www.mozilla.org/security/advisories/mfsa2022-19/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1802
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1529
patches/packages/mozilla-thunderbird-91.9.1-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/91.9.1/releasenotes/
Napisano: 29 May 2022, 19:51
21.05.2022.
Sveži mariadb paketi za Slackware 15.0 i -current:
patches/packages/mariadb-10.5.16-i586-1_slack15.0.txz: Upgraded.
This update fixes bugs and several security issues.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27376
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27377
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27378
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27379
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27380
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27381
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27382
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27383
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27384
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27386
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27387
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27444
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27445
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27446
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27447
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27448
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27449
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27451
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27452
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27455
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27456
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27457
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-27458
Napisano: 29 May 2022, 19:52
26.05.2022.
Sveži cups paketi za Slackware 14.2, 15.0 i -current:
patches/packages/cups-2.4.2-i586-1_slack15.0.txz: Upgraded.
Fixed certificate strings comparison for Local authorization.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-26691
Napisano: 06 Jun 2022, 15:22
26.05.2022.
Sveži mozilla-firefox paketi za Slackware 15.0 i -current:
patches/packages/mozilla-firefox-91.10.0esr-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/91.10.0/releasenotes/
https://www.mozilla.org/security/advisories/mfsa2022-21/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-31736
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-31737
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-31738
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-31739
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-31740
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-31741
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-31742
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-31747
02.06.2022.
patches/packages/mozilla-thunderbird-91.10.0-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/91.10.0/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2022-22/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-1834
Users browsing this forum: No registered users and 84 guests
