Napisano: 24 Oct 2022, 06:44
17.10.2022.
Sveži xorg-server paketi za Slackware 15.0 i -current:
patches/packages/xorg-server-1.20.14-i586-4_slack15.0.txz: Rebuilt.
xkb: proof GetCountedString against request length attacks.
xkb: fix some possible memleaks in XkbGetKbdByName.
xquartz: Fix a possible crash when editing the Application menu due
to mutating immutable arrays.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-3550
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-3551
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-3553
patches/packages/xorg-server-xephyr-1.20.14-i586-4_slack15.0.txz: Rebuilt.
patches/packages/xorg-server-xnest-1.20.14-i586-4_slack15.0.txz: Rebuilt.
patches/packages/xorg-server-xvfb-1.20.14-i586-4_slack15.0.txz: Rebuilt.
patches/packages/xorg-server-xwayland-21.1.4-i586-3_slack15.0.txz: Rebuilt.
Napisano: 24 Oct 2022, 06:45
18.10.2022.
Sveži git paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/git-2.35.5-i586-1_slack15.0.txz: Upgraded.
This release fixes two security issues:
* CVE-2022-39253:
When relying on the `--local` clone optimization, Git dereferences
symbolic links in the source repository before creating hardlinks
(or copies) of the dereferenced link in the destination repository.
This can lead to surprising behavior where arbitrary files are
present in a repository's `$GIT_DIR` when cloning from a malicious
repository.
Git will no longer dereference symbolic links via the `--local`
clone mechanism, and will instead refuse to clone repositories that
have symbolic links present in the `$GIT_DIR/objects` directory.
Additionally, the value of `protocol.file.allow` is changed to be
"user" by default.
* CVE-2022-39260:
An overly-long command string given to `git shell` can result in
overflow in `split_cmdline()`, leading to arbitrary heap writes and
remote code execution when `git shell` is exposed and the directory
`$HOME/git-shell-commands` exists.
`git shell` is taught to refuse interactive commands that are
longer than 4MiB in size. `split_cmdline()` is hardened to reject
inputs larger than 2GiB.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-39253
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-39260
Sveži mozilla-firefox paketi za Slackware 15.0 i -current:
patches/packages/mozilla-firefox-102.4.0esr-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/102.4.0/releasenotes/
https://www.mozilla.org/security/advisories/mfsa2022-45/
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-42927
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-42928
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-42929
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-42932
Napisano: 29 Oct 2022, 21:57
25.10.2022.
Sveži expat paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/expat-2.5.0-i586-1_slack15.0.txz: Upgraded.
Fix heap use-after-free after overeager destruction of a shared DTD in
function XML_ExternalEntityParserCreate in out-of-memory situations.
Expected impact is denial of service or potentially arbitrary code
execution.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-43680
Sveži samba paketi za Slackware 15.0 i -current:
patches/packages/samba-4.15.11-i586-1_slack15.0.txz: Upgraded.
This update fixes the following security issue:
There is a limited write heap buffer overflow in the GSSAPI unwrap_des()
and unwrap_des3() routines of Heimdal (included in Samba).
https://www.samba.org/samba/security/CVE-2022-3437.html
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-3437
Napisano: 29 Oct 2022, 21:58
26.10.2022.
Sveži curl paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/curl-7.86.0-i586-1_slack15.0.txz: Upgraded.
HSTS bypass via IDN.
HTTP proxy double-free.
.netrc parser out-of-bounds access.
POST following PUT confusion.
https://curl.se/docs/CVE-2022-42916.html
https://curl.se/docs/CVE-2022-42915.html
https://curl.se/docs/CVE-2022-35260.html
https://curl.se/docs/CVE-2022-32221.html
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-42916
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-42915
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-35260
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2022-32221
Napisano: 06 Nov 2022, 22:29
31. X 2022.
Sveži vim i php80/php81 paketi za Slackware 15.0 i -current:
patches/packages/vim-9.0.0814-i586-1_slack15.0.txz: Upgraded.
A vulnerability was found in vim and classified as problematic. Affected by
this issue is the function qf_update_buffer of the file quickfix.c of the
component autocmd Handler. The manipulation leads to use after free. The
attack may be launched remotely. Upgrading to version 9.0.0805 is able to
address this issue.
https://www.cve.org/CVERecord?id=CVE-2022-3705
patches/packages/vim-gvim-9.0.0814-i586-1_slack15.0.txz: Upgraded.
extra/php80/php80-8.0.25-i586-1_slack15.0.txz: Upgraded.
GD: OOB read due to insufficient input validation in imageloadfont().
Hash: buffer overflow in hash_update() on long parameter.
https://www.cve.org/CVERecord?id=CVE-2022-31630
https://www.cve.org/CVERecord?id=CVE-2022-37454
extra/php81/php81-8.1.12-i586-1_slack15.0.txz: Upgraded.
Napisano: 06 Nov 2022, 22:30
3. XI 2022.
Sveži mozilla-nss paketi za Slackware 15.0 i -current:
patches/packages/mozilla-nss-3.84-i586-1_slack15.0.txz: Upgraded.
Fixed a segmentation fault when the server requests a client auth cert but
the client has no certs in its database.
https://www.cve.org/CVERecord?id=CVE-2022-3479
Napisano: 06 Nov 2022, 22:31
5. XI 2022.
Sveži
sudo paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/sudo-1.9.12p1-i586-1_slack15.0.txz: Upgraded.
Fixed a potential out-of-bounds write for passwords smaller than 8
characters when passwd authentication is enabled.
This does not affect configurations that use other authentication
methods such as PAM, AIX authentication or BSD authentication.
https://www.cve.org/CVERecord?id=CVE-2022-43995
Napisano: 11 Nov 2022, 22:48
9. XI 2022.
Sveži sysstat paketi za Slackware 14.2, 15.0 i -current:
patches/packages/sysstat-12.7.1-i586-1_slack15.0.txz: Upgraded.
On 32 bit systems, in versions 9.1.16 and newer but prior to 12.7.1,
allocate_structures contains a size_t overflow in sa_common.c. The
allocate_structures function insufficiently checks bounds before arithmetic
multiplication, allowing for an overflow in the size allocated for the
buffer representing system activities.
This issue may lead to Remote Code Execution (RCE).
https://www.cve.org/CVERecord?id=CVE-2022-39377
Sveži xfce4-settings paketi za Slackware 15.0 i -current:
patches/packages/xfce4-settings-4.16.4-i586-1_slack15.0.txz: Upgraded.
Fixed an argument injection vulnerability in xfce4-mime-helper.
https://www.cve.org/CVERecord?id=CVE-2022-45062
10. XI 2022.
Sveži php paketi za Slackware 15.0 i -current:
patches/packages/php-7.4.33-i586-1_slack15.0.txz: Upgraded.
Napisano: 22 Nov 2022, 20:33
16.XI 2022.
Sveži krb5, mozilla-firefox, mozilla-thunderbird i samba paketi za Slackware 15.0 i -current:
patches/packages/krb5-1.19.2-i586-3_slack15.0.txz: Rebuilt.
Fixed integer overflows in PAC parsing.
Fixed memory leak in OTP kdcpreauth module.
Fixed PKCS11 module path search.
https://www.cve.org/CVERecord?id=CVE-2022-42898
patches/packages/mozilla-firefox-102.5.0esr-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/102.5.0/releasenotes/
https://www.mozilla.org/security/advisories/mfsa2022-48/
https://www.cve.org/CVERecord?id=CVE-2022-45403
https://www.cve.org/CVERecord?id=CVE-2022-45404
https://www.cve.org/CVERecord?id=CVE-2022-45405
https://www.cve.org/CVERecord?id=CVE-2022-45406
https://www.cve.org/CVERecord?id=CVE-2022-45408
https://www.cve.org/CVERecord?id=CVE-2022-45409
https://www.cve.org/CVERecord?id=CVE-2022-45410
https://www.cve.org/CVERecord?id=CVE-2022-45411
https://www.cve.org/CVERecord?id=CVE-2022-45412
https://www.cve.org/CVERecord?id=CVE-2022-45416
https://www.cve.org/CVERecord?id=CVE-2022-45418
https://www.cve.org/CVERecord?id=CVE-2022-45420
https://www.cve.org/CVERecord?id=CVE-2022-45421
patches/packages/mozilla-thunderbird-102.5.0-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/102.5.0/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2022-49/
patches/packages/samba-4.15.12-i586-1_slack15.0.txz: Upgraded.
Fixed a security issue where Samba's Kerberos libraries and AD DC failed
to guard against integer overflows when parsing a PAC on a 32-bit system,
which allowed an attacker with a forged PAC to corrupt the heap.
https://www.samba.org/samba/security/CVE-2022-42898.html
Users browsing this forum: No registered users and 27 guests
