sbopkg
Post Napisano: 15 Apr 2010, 00:04
Interesuju me iskustva ako je neko probao/koristio sbopkg
Zanimljivih karakteristika
Sbopkg is a command-line and dialog-based tool to synchronize with the SlackBuilds.org ("SBo") repository, a collection of third-party SlackBuild scripts to build Slackware packages.
Jedino sto me malko cudi, mada moguce da nema potreba za izmenama, da je su u ChangeLog-u aktivnosti iz
Sun Nov  1 02:54:29 UTC 2009 Sbopkg 0.31.0 released.
Jos mi se cini da nece biti sjajno kad je u pitanju -current, posto sam morao dosta slackbuild skript-ova da prepravljam i da dodajem patcheve kako bih uspeo da prevedem paket za -current
Evo i par slicica sbopkg-a u akciji ;)
Post Napisano: 30 Jun 2010, 17:29
Ovo je odličan alat koji prilično olakšava i ubrzava rad sa SlackBuild skriptama :)
Veliko hvala, Branko :)
Post Napisano: 20 Jul 2010, 12:00
Nova verzija sbopkg-a 0.33.2, koja donosi ispravke sigurnosnih propusta
evo i vest sa slckbuilds-users liste
Post Napisano: 28 Apr 2011, 10:58
Nova verzija sbopkg-a, koji uveliko olaksava rad sa SBo skriptama (automatizacija)
@slackbuilds-users list
Greetings, all. This release includes a few small features, a few
modifications, and a few more or less minor bugs. Thanks to everyone who
helped. Congrats to Pat, et al., on the new Slackware.
sbopkg 0.35.0 (2011-04-28 02:48 UTC)
    FEATURES
        * This release of sbopkg is Slackware 13.37-ready. (Congrats to
          all involved in the Slackware release.)
        * The READMEs of all installed packages can now be read from the
          main menu's list/uninstall item. (Selection state will also
          now be remembered.) Thanks to dmotaleite for the RFE.
        * Similarly, the -R and -p flags can now be combined to page
          through the READMEs of all installed packages.
        * Added ponce's repo (SBo variant for -current) to the default
          repos. Thanks to Mauro for suggesting this about a year ago.
          Note that this is unsupported (if a build from this repo
          breaks in sbopkg you get to keep both pieces) but people seem
          pleased with this repo and it'll save a step for new users.
          Note that the default repo files have been reordered, as well.
          50-sb64 is now 70, 60-local is now 50, and the new one is 60.
          This puts the unsupported repos last. If by chance you have a
          file with those names already in there, upgrading sbopkg will
          clobber them. See each of the two following sections for more
          repo-related modifications and bugfixing.
        * Added a bash completion file for sbopkg. This is independent
          of the bash-completion package. It can be found in the new
          doc/contrib directory. Source the file (in your shell startup
          files if you want it always on automatically) from its current
          location or wherever you wish to copy it and you should be
          able to complete some of sbopkg's flags and their arguments.
          Also see the KNOWN_ISSUES file. Thanks to Sergey V. for this
          contribution.
    MODIFICATIONS
        * Updated French man pages. Thanks to Marie-Claude Collilieux.
        * Revised documentation: moved the queuefiles directory into a
          new contrib directory, renamed the README-*.d documents,
          stripping the '.d'. Clarified/updated the dialog nav/certcheck
          sections of KNOWN_ISSUES, brought the missing 0.27.0 and
          0.33.1 branch changes from their ChangeLogs into NEWS, added a
          block in README describing all the plain text documents, added
          a note about making corrections to THANKS, a couple of TODO
          items, etc.
        * Note also that symlinks are now made from README-repos and
          README-renames to READMEs in the corresponding /etc/sbopkg/*.d
          directories. NOTE that renames files must now end in .renames
          so, if you have custom files in renames.d, you'll need to
          rename them.
        * The 'Choose a repository' dialog widget is now titled
          'Repository Selection' and the widget text was revised. Also,
          the menu itself used to say 'BRANCH (REPO) DESCRIPTION' and
          now says 'REPO (BRANCH) DESCRIPTION'. The relevant item in the
          Utilities menu that shows which repo/branch you're on and
          takes you to the Repository Selection widget was similarly
          re-ordered.
        * When a repository directory does not exist, sbopkg now
          displays, e.g.
          REPO_{ROOT,NAME,BRANCH} -> /var/lib/sbopkg/,SBo/,13.1
          or, in the case of git repos which don't currently have BRANCH
          directories, it just shows REPO_{ROOT,NAME}. It used to
          display
          REPO_ROOT -----------> /var/lib/sbopkg/
          While the new line may be odd looking, it should be clear
          enough that it means REPO_ROOT is /var/lib/sbopkg/, REPO_NAME
          is SBo/ and REPO_BRANCH is 13.1 and that these are path
          components and that the path is missing. Before, it would say
          /var/lib/sbopkg/ didn't exist if, e.g., 13.1 was missing even
          when /var/lib/sbopkg/ did exist.
    BUGFIXES
        * Fixed an issue where URL redirects and SSL certificate check
          failures could combine to cause a download failure. Thanks to
          vbatts for raising this issue.
        * Fixed a documentation bug where the ability to keep a
          ~/.sbopkg.conf file to override the system config file (since
          0.25.0) wasn't documented anywhere other than this file. It's
          now in both manuals. Thanks to Bill Kirkpatrick for raising
          this issue.
        * Fixed an issue where 'Invert all' in file removal dialogs
          didn't 'invert' but turned everything on or off, regardless of
          selection state. If it was really intended to be
          'Select/Deselect all', then changing the button to "Invert
          Sel" and making it do that was a feature/modification instead
          of a bugfix. ;)
        * Fixed an issue were the user could switch repos, receive a
          directory creation prompt, abort it, and the active repo would
          be switched anyway, despite the directory not being created.
          Now, the original repo is restored as the active one.
        * Fixed a bug in a previous bugfix that would still let sbopkg
          download source files whose DOWNLOAD value ended in
          '/download' even when the source files were cached.
        * Fixed a depth-restriction bug triggered when an app
          directory's subdirectory has the same name as another app
          directory, causing sbopkg to match things or try to use things
          like openvswitch/xen/foo when xen/foo is intended. Thanks to
          David Somero for reporting this.
Post Napisano: 03 Nov 2014, 23:34
Nešto sa sbopkg-users mailing liste: zakrpa koja dodaje podršku za http repoe.
http://sbopkg.org/pipermail/sbopkg-user ... 00675.html
Privremeni repo koji sadrži izmenjen sbopkg: https://github.com/asafo/sbopkg" onclick="window.open(this.href);return false;.
Ovo je još iz januara. Chess Griffin je prokomentarisao da će pogledati kad stigne, ali nema naznaka da je to i uradio. Zakrpa je za verziju 0.37.0.
Inače ovo dodaje mogućnost korišćenja http direktorijuma kao sbopkg repoa. Ova mogućnost se već nalazi u nekim Slackware derivatima. Upstream zvanično podržava rsync i git repoe, pri čemu su samo rsync repoi i zvanično podržani.
