Cyan
Post Napisano: 26 Aug 2020, 17:30
Cyan
Nešto interesantno za pripremu za štampu. Trenutno nemam vremena za prevođenje pa sam prepisao opisni tekst na engleskom sa njihovog sajta. Izmeniću kad uhvatim vremena.
Cyan is an open source cross-platform image viewer and converter, designed for prepress (print) work. Like converting an image from RGB to CMYK, or the other way around. Cyan supports color profiles complying with the International Color Consortium (ICC) standard, and strives to create as color-accurate images as possible, with support for RGB, CMYK and GRAY with up to 32-bit image depth.
Features
  • Supports RGB/CMYK/GRAY 8/16/32 bit images
  • Supports ICC/ICM v2/v4 color profiles
  • Supports PNG, JPEG, TIFF, XCF and PSD image input
  • Supports TIFF, JPEG and PSD image output
  • Supports TIFF, XCF and PSD image layers
  • Extract embedded ICC color profiles from images
  • Add ICC color profile to image
  • Edit ICC color profile tags
  • Convert to and from RGB/CMYK/GRAY
  • Change image bit depth
  • GIMP integration (import/export)
Requirements
  • Windows Microsoft Windows 7/8/10 x64
  • Mac Apple Mac OS X 10.10-10.14
  • Linux GNU/Linux x86_64 (glibc 2.23+/libgcc 5.4+)
Recommended
  • A bitmap editor
    • GIMP
    • Krita
    • AzPainter
  • A vector editor
    • sK1
    • Inkscape
  • A DTP editor
    • Scribus
  • A color calibrated monitor (with available profile)
    • DisplayCAL
  • ICC color profiles
    • colormanagement.org
    • Adobe ICC
https://cyan.fxarena.net/
Preuzimanje
https://github.com/rodlie/cyan/releases/latest
