Ne radi youtube !
Obrada zvuka i slike, audio i video produkcija i slične teme
Povremen korisnik
Povremen korisnik
Post Napisano: 27 May 2016, 17:07
bash-4.2# lspci
00:00.0 RAM memory: NVIDIA Corporation MCP61 Host Bridge (rev a1)
00:01.0 ISA bridge: NVIDIA Corporation MCP61 LPC Bridge (rev a2)
00:01.1 SMBus: NVIDIA Corporation MCP61 SMBus (rev a2)
00:01.2 RAM memory: NVIDIA Corporation MCP61 Memory Controller (rev a2)
00:02.0 USB controller: NVIDIA Corporation MCP61 USB 1.1 Controller (rev a3)
00:02.1 USB controller: NVIDIA Corporation MCP61 USB 2.0 Controller (rev a3)
00:04.0 PCI bridge: NVIDIA Corporation MCP61 PCI bridge (rev a1)
00:05.0 Audio device: NVIDIA Corporation MCP61 High Definition Audio (rev a2)
00:06.0 IDE interface: NVIDIA Corporation MCP61 IDE (rev a2)
00:07.0 Bridge: NVIDIA Corporation MCP61 Ethernet (rev a2)
00:08.0 IDE interface: NVIDIA Corporation MCP61 SATA Controller (rev a2)
00:08.1 IDE interface: NVIDIA Corporation MCP61 SATA Controller (rev a2)
00:09.0 PCI bridge: NVIDIA Corporation MCP61 PCI Express bridge (rev a2)
00:0b.0 PCI bridge: NVIDIA Corporation MCP61 PCI Express bridge (rev a2)
00:0c.0 PCI bridge: NVIDIA Corporation MCP61 PCI Express bridge (rev a2)
00:0d.0 VGA compatible controller: NVIDIA Corporation C61 [GeForce 7025 / nForce 630a] (rev a2)
00:18.0 Host bridge: AMD [Advanced Micro Devices, Inc.] Family 10h Processor HyperTransport Configuration
00:18.1 Host bridge: AMD [Advanced Micro Devices, Inc.] Family 10h Processor Address Map
00:18.2 Host bridge: AMD [Advanced Micro Devices, Inc.] Family 10h Processor DRAM Controller
00:18.3 Host bridge: AMD [Advanced Micro Devices, Inc.] Family 10h Processor Miscellaneous Control
00:18.4 Host bridge: AMD [Advanced Micro Devices, Inc.] Family 10h Processor Link Control
bash-4.2# glxinfo | grep -i
Usage: grep [OPTION]... PATTERN [FILE]...
Try 'grep --help' for more information.
bash-4.2# glxinfo
name of display: :0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
    GLX_ARB_create_context, GLX_ARB_create_context_profile,
    GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
    GLX_ARB_multisample, GLX_EXT_create_context_es2_profile,
    GLX_EXT_create_context_es_profile, GLX_EXT_swap_control,
    GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_NV_float_buffer,
    GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_swap_control,
    GLX_SGI_video_sync
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
    GLX_ARB_get_proc_address, GLX_ARB_multisample,
    GLX_EXT_create_context_es2_profile, GLX_EXT_fbconfig_packed_float,
    GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_swap_control,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_NV_copy_image,
    GLX_NV_float_buffer, GLX_NV_multisample_coverage, GLX_NV_present_video,
    GLX_NV_swap_group, GLX_NV_video_capture, GLX_NV_video_out,
    GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
    GLX_EXT_create_context_es2_profile, GLX_EXT_swap_control,
    GLX_SGI_video_sync
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce 7025 / nForce 630a/integrated/SSE2
OpenGL version string: 2.1.2 NVIDIA 304.131
OpenGL shading language version string: 1.20 NVIDIA via Cg compiler
OpenGL extensions:
    GL_ARB_ES2_compatibility, GL_ARB_color_buffer_float,
    GL_ARB_compressed_texture_pixel_storage, GL_ARB_conservative_depth,
    GL_ARB_copy_buffer, GL_ARB_depth_clamp, GL_ARB_depth_texture,
    GL_ARB_draw_buffers, GL_ARB_explicit_attrib_location,
    GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
    GL_ARB_fragment_shader, GL_ARB_framebuffer_object,
    GL_ARB_get_program_binary, GL_ARB_half_float_pixel,
    GL_ARB_half_float_vertex, GL_ARB_imaging, GL_ARB_internalformat_query,
    GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multisample,
    GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
    GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
    GL_ARB_provoking_vertex, GL_ARB_robustness, GL_ARB_sampler_objects,
    GL_ARB_separate_shader_objects, GL_ARB_shader_objects,
    GL_ARB_shading_language_100, GL_ARB_shading_language_420pack,
    GL_ARB_shading_language_include, GL_ARB_shadow, GL_ARB_sync,
    GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
    GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
    GL_ARB_texture_env_dot3, GL_ARB_texture_float,
    GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_storage,
    GL_ARB_texture_swizzle, GL_ARB_timer_query, GL_ARB_transpose_matrix,
    GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_texture_float,
    GL_ATI_texture_mirror_once, GL_EXT_Cg_shader, GL_EXT_abgr, GL_EXT_bgra,
    GL_EXT_blend_color, GL_EXT_blend_equation_separate,
    GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
    GL_EXT_compiled_vertex_array, GL_EXT_depth_bounds_test,
    GL_EXT_direct_state_access, GL_EXT_draw_range_elements, GL_EXT_fog_coord,
    GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
    GL_EXT_framebuffer_object, GL_EXT_gpu_program_parameters,
    GL_EXT_import_sync_object, GL_EXT_multi_draw_arrays,
    GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels,
    GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
    GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_shader_objects, GL_EXT_separate_specular_color,
    GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,
    GL_EXT_texture3D, GL_EXT_texture_compression_dxt1,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_format_BGRA8888,
    GL_EXT_texture_lod, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
    GL_EXT_texture_object, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_decode,
    GL_EXT_texture_storage, GL_EXT_texture_swizzle, GL_EXT_timer_query,
    GL_EXT_vertex_array, GL_EXT_vertex_array_bgra, GL_EXT_x11_sync_object,
    GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
    GL_KTX_buffer_region, GL_NVX_conditional_render,
    GL_NV_ES1_1_compatibility, GL_NV_alpha_test, GL_NV_blend_minmax,
    GL_NV_blend_square, GL_NV_complex_primitives, GL_NV_copy_depth_to_color,
    GL_NV_depth_clamp, GL_NV_fbo_color_attachments, GL_NV_fence,
    GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragdepth,
    GL_NV_fragment_program, GL_NV_fragment_program2,
    GL_NV_fragment_program_option, GL_NV_framebuffer_multisample_coverage,
    GL_NV_half_float, GL_NV_light_max_exponent, GL_NV_multisample_filter_hint,
    GL_NV_occlusion_query, GL_NV_packed_depth_stencil, GL_NV_pixel_data_range,
    GL_NV_point_sprite, GL_NV_primitive_restart, GL_NV_register_combiners,
    GL_NV_register_combiners2, GL_NV_texgen_reflection, GL_NV_texture_barrier,
    GL_NV_texture_compression_vtc, GL_NV_texture_env_combine4,
    GL_NV_texture_expand_normal, GL_NV_texture_lod_clamp,
    GL_NV_texture_rectangle, GL_NV_texture_shader, GL_NV_texture_shader2,
    GL_NV_texture_shader3, GL_NV_vertex_array_range,
    GL_NV_vertex_array_range2, GL_NV_vertex_program, GL_NV_vertex_program1_1,
    GL_NV_vertex_program2, GL_NV_vertex_program2_option,
    GL_NV_vertex_program3, GL_OES_compressed_paletted_texture, GL_OES_depth24,
    GL_OES_depth32, GL_OES_depth_texture, GL_OES_element_index_uint,
    GL_OES_fbo_render_mipmap, GL_OES_get_program_binary, GL_OES_mapbuffer,
    GL_OES_packed_depth_stencil, GL_OES_point_size_array, GL_OES_point_sprite,
    GL_OES_read_format, GL_OES_rgb8_rgba8, GL_OES_standard_derivatives,
    GL_OES_texture_3D, GL_OES_texture_float, GL_OES_texture_float_linear,
    GL_OES_texture_half_float, GL_OES_texture_half_float_linear,
    GL_OES_texture_npot, GL_OES_vertex_array_object, GL_OES_vertex_half_float,
    GL_S3_s3tc, GL_SGIS_generate_mipmap, GL_SGIS_texture_lod,
    GL_SGIX_depth_texture, GL_SGIX_shadow, GL_SUN_slice_accum
Instalirao sam nvidia drajvere, preko ovoga> NVIDIA-Linux-x86_64-304.131.run
sve sam radio po uputstvu, nije mi prikazalo greske, skripta me je pitala da li da ukljuci OpenGL 32bit neke biblioteke, yes je bilo default i ja sam potvrdio.
Instalirao sam flash preko slackbuild-a i proradio mi je radio s, kao i orion iptv, ali youtube nece, prikaze, kao da je video uklonjen, takav sneg i gresku, ima info link tu, ali ne radi.
Sta nam je ciniti?
Post Napisano: 27 May 2016, 17:56
Koje browsere si testirao? Probaj sa drugim browserom (napr Firefox i Chrome). Ako je u pitanju Firefox, probaj neku ekstenziju koja omogućava prebacivanja sa HTML5 na Flash i obrnuto. Nisam je testirao, ali jedna od njih je ovde: https://addons.mozilla.org/en-US/firefo ... h-control/" onclick="window.open(this.href);return false;. Ako je aktivan Flash na Youtube-u, desni klik na video i probaj da skineš kvačicu sa "gpu acceleration".
Povremen korisnik
Povremen korisnik
Post Napisano: 27 May 2016, 18:05
Proradilo, probao sam to desni klik, ali nista konkretno nisam klikuo, pojma nemam, i proradilo, da safari je u pitanju. Moracu i firefox da instaliram :) navika
:grlj:
Povremen korisnik
Povremen korisnik
Post Napisano: 27 May 2016, 18:12
vidiiii ima firefox, aooo ovaj slack ima sve :) :afro:
Post Napisano: 27 May 2016, 18:14
Safari? :D
Koliko je meni poznato to čudo postoji samo za Mac i Win. :)
Povremen korisnik
Povremen korisnik
Post Napisano: 27 May 2016, 20:22
pa ovaj k-osvajac, google ga prepoznaje kao safari :)
cu ga cusnem negde ispod, a na povrsinu lisicu... pa ovih nekoliko dana planiram da skockam slakicja.
nego dodao sam svog usera a opet sam na root-u :) nego, da, kako da promenim hostname?
