Zbog ovoga sam napravio novi paket Nginx 1.5.4. Neophodna su testiranja da bi bio siguran da paket radi kako treba. Ja sam instalirao kod mene a svi koji su voljni mogu da provere da li sam dobro napravio paket.
Zbog neophodnih izmena u određenim fajlovima, pakujem ceo nginx direktorijum sa izvornim kodom, slackbuild skriptom i ostalim fajlovima.
SlackBuild skripta je preuzeta sa SBo i blago je izmenjena. Podrazumevani vlasnik je nobody i grupa je nobody, kao što i treba da bude.
#!/bin/sh
# Slackware build script for nginx
# Copyright 2008 Cherife Li <cherife-#-dotimes.com>
# Copyright 2011 Diogo Leal <diogo@diogoleal.com>
# Copyright 2012-13 Francisco Ambrozio <sbo@franciscoambrozio.com>
# All rights reserved.
# Redistribution and use of this script, with or without modification, is
# permitted provided that the following conditions are met:
# 1. Redistributions of this script must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# THIS SOFTWARE IS PROVIDED BY THE AUTHOR ''AS IS'' AND ANY EXPRESS OR IMPLIED
# WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
# MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
# EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
# SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
# PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
# OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
# WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
# OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
# ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# Special thanks to Thomas Morper for some configuration adjustments tips
PRGNAM=nginx
VERSION=${VERSION:-1.5.4}
BUILD=${BUILD:-1}
TAG=${TAG:-_stereo}
if [ -z "$ARCH" ]; then
case "$( uname -m )" in
i?86) ARCH=i486 ;;
arm*) ARCH=arm ;;
*) ARCH=$( uname -m ) ;;
esac
fi
CWD=$(pwd)
TMP=${TMP:-/tmp/SBo}
PKG=$TMP/package-$PRGNAM
OUTPUT=${OUTPUT:-/tmp}
USE_SPDY=${USE_SPDY:-no}
eval $(perl '-V:installvendorlib')
if [ "$ARCH" = "i486" ]; then
LIBDIRSUFFIX=""
elif [ "$ARCH" = "i686" ]; then
SLKCFLAGS="-O2 -march=i686 -mtune=i686"
LIBDIRSUFFIX=""
SLKCFLAGS="-O2 -fPIC"
LIBDIRSUFFIX="64"
else
SLKCFLAGS=""
LIBDIRSUFFIX=""
fi
set -e
rm -rf $PKG
mkdir -p $TMP $PKG $OUTPUT
cd $TMP
rm -rf $PRGNAM-$VERSION
tar xvf $CWD/$PRGNAM-$VERSION.tar.gz
cd $PRGNAM-$VERSION
chown -R root:root .
find . \
\( -perm 777 -o -perm 775 -o -perm 711 -o -perm 555 -o -perm 511 \) \
-exec chmod 755 {} \; -o \
\( -perm 666 -o -perm 664 -o -perm 600 -o -perm 444 -o -perm 440 -o -perm 400 \) \
-exec chmod 644 {} \;
if [ "$USE_SPDY" == "yes" ]; then
SPDY_MOD=" --with-http_spdy_module "
else
SPDY_MOD=""
fi
CFLAGS="$SLKCFLAGS" \
CXXFLAGS="$SLKCFLAGS" \
./configure \
--prefix=/usr \
--sbin-path=/usr/sbin/nginx \
--conf-path=/etc/nginx/nginx.conf \
--pid-path=/var/run/nginx.pid \
--lock-path=/var/lock/nginx \
--user=${NGINXUSER:=nobody} \
--group=${NGINXGROUP:=nogroup} \
--error-log-path=/var/log/nginx/error.log \
--http-log-path=/var/log/nginx/access.log \
--with-ipv6 \
--with-select_module \
--with-poll_module \
--with-http_ssl_module \
--with-http_realip_module \
--with-http_addition_module \
--with-http_xslt_module \
--with-http_sub_module \
--with-http_dav_module \
--with-http_flv_module \
--with-http_gzip_static_module \
--with-http_random_index_module \
--with-http_secure_link_module \
--with-http_stub_status_module \
--with-http_perl_module \
$SPDY_MOD \
--with-perl_modules_path=$installvendorlib \
--without-mail_pop3_module \
--without-mail_imap_module \
--without-mail_smtp_module
make
make install DESTDIR=$PKG
find $PKG -print0 | xargs -0 file | grep -e "executable" -e "shared object" | \
grep ELF | cut -f 1 -d : | xargs strip --strip-unneeded 2> /dev/null || true
find $PKG -name perllocal.pod -o -name ".packlist" -o -name "*.bs" | \
xargs rm -f 2> /dev/null
find $PKG -perm 444 -exec chmod 0644 {} \;
find $PKG -perm 555 -exec chmod 0755 {} \;
# Remove some other empty and/or unnecessary directories from the package
eval $(perl '-V:archlib')
rm -rf $PKG/$archlib $PKG/usr/html $PKG/var
# Add an init script
mkdir -p $PKG/etc/rc.d
cat $CWD/rc.nginx > $PKG/etc/rc.d/rc.nginx.new
mkdir -p $PKG/etc/logrotate.d
sed -e "s,@USER@,$NGINXUSER," -e "s,@GROUP@,$NGINXGROUP," $CWD/nginx.logrotate \
> $PKG/etc/logrotate.d/nginx.new
# Don't clobber config files
for file in fastcgi_params fastcgi.conf mime.types nginx.conf \
koi-utf koi-win scgi_params uwsgi_params win-utf ; do
mv $PKG/etc/nginx/$file $PKG/etc/nginx/$file.new ;
done
# Create the log dir and set the permissions
mkdir -p $PKG/var/log/nginx
chown $NGINXUSER $PKG/var/log/nginx
chmod 750 $PKG/var/log/nginx
mkdir -p $PKG/usr/doc/nginx-$VERSION
cp -a CHANGES* LICENSE README $PKG/usr/doc/nginx-$VERSION
cat $CWD/nginx.SlackBuild > $PKG/usr/doc/nginx-$VERSION/nginx.SlackBuild
mkdir -p $PKG/install
cat $CWD/doinst.sh > $PKG/install/doinst.sh
cd $PKG
/sbin/makepkg -l y -c n $OUTPUT/$PRGNAM-$VERSION-$ARCH-$BUILD$TAG.${PKGTYPE:-txz}
