SMtube
Post Napisano: 18 Aug 2013, 00:17
SMtube je dodatak za SMplayer koji služi da pregledate YT video klipove bez potrebe da uključujete internet pretraživač. Trenutna verzija je 1.8 (u SBo je 1.7). Probao sam ga na mom netbooku koji ima celeron 900mhz i intel i915 vga sa nešto malo memorije koja mu je dodeljena. Video materijal radi u 720p bez problema. Materijal sa manjom rezolucijom će moći još lakše da se gleda. Odličan dodatak!
Sjajan za starije računare i laptopove :exclaim:
Informacije možete naći na istoj adresi kao i informacije za smplayer - http://smplayer.sourceforge.net/" onclick="window.open(this.href);return false;
Zapravo, tu ćete naći source code a od informacija skoro da ništa i nema. Više ima na SBo http://slackbuilds.org/repository/14.0/ ... ia/smtube/" onclick="window.open(this.href);return false;
Gotovi paketi za obe arhitekture:
smtube-1.8-i486-1_stereo.tgz
(450.94 KiB) Downloaded 610 times
smtube-1.8-x86_64-1_stereo.tgz
(453.4 KiB) Downloaded 593 times
Korišćena slackbuild skripta:
#!/bin/bash
# Slackware build script for SMTube
# Copyright 2012-2013  Fridrich von Stauffenberg <cancellor2@gmail.com>
# All rights reserved.
# Redistribution and use of this script, with or without modification, is
# permitted provided that the following conditions are met:
# 1. Redistributions of this script must retain the above copyright
#    notice, this list of conditions and the following disclaimer.
# THIS SOFTWARE IS PROVIDED BY THE AUTHOR ''AS IS'' AND ANY EXPRESS OR IMPLIED
# WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
# MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO
# EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
# SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
# PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
# OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
# WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
# OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
# ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
PRGNAM=smtube
VERSION=${VERSION:-1.8}
BUILD=${BUILD:-1}
TAG=${TAG:-_stereo}
if [ -z "$ARCH" ]; then
  case "$( uname -m )" in
    i?86) ARCH=i486 ;;
    arm*) ARCH=arm ;;
       *) ARCH=$( uname -m ) ;;
  esac
fi
CWD=$(pwd)
TMP=${TMP:-/tmp/SBo}
PKG=$TMP/package-$PRGNAM
OUTPUT=${OUTPUT:-/tmp}
if [ "$ARCH" = "i486" ]; then
  LIBDIRSUFFIX=""
elif [ "$ARCH" = "i686" ]; then
  SLKCFLAGS="-O2 -march=i686 -mtune=i686"
  LIBDIRSUFFIX=""
  SLKCFLAGS="-O2 -fPIC"
  LIBDIRSUFFIX="64"
else
  SLKCFLAGS="-O2"
  LIBDIRSUFFIX=""
fi
set -e
rm -rf $PKG
mkdir -p $TMP $PKG $OUTPUT
cd $TMP
rm -rf $PRGNAM-$VERSION
tar xvf $CWD/$PRGNAM-$VERSION.tar.bz2
cd $PRGNAM-$VERSION
chown -R root:root .
sed -i "/^PREFIX/s/=.*$/=\/usr/;
        /^DOC_PATH/s/\/.*$/\/doc\/$PRGNAM-$VERSION/;
        s/share\/man/man/g" Makefile
QMAKE_OPTS="QMAKE_CXXFLAGS=\"$SLKCFLAGS\"" \
make
make install DESTDIR=$PKG
find $PKG -print0 | xargs -0 file | grep -e "executable" -e "shared object" | grep ELF \
  | cut -f 1 -d : | xargs strip --strip-unneeded 2> /dev/null || true
cat $CWD/$PRGNAM.SlackBuild > $PKG/usr/doc/$PRGNAM-$VERSION/$PRGNAM.SlackBuild
mkdir -p $PKG/install
cat $CWD/doinst.sh > $PKG/install/doinst.sh
cd $PKG
/sbin/makepkg -l y -c n $OUTPUT/$PRGNAM-$VERSION-$ARCH-$BUILD$TAG.${PKGTYPE:-tgz}
