SBodeps/slackdeps
Post Napisano: 06 Oct 2012, 10:06
SBodeps Slackdeps je novi alat za instaliranje softvera iz SlackBuilds.org repozitorijuma koji koristi novo (od verzije 14.0) polje "requires" u *.info datotekama. Takođe je u mogućnosti da izvede i rekurzivne zavisnosti.
SBodeps is used to build and install SlackBuilds from SlackBuilds.org. It can determine a SlackBuilds dependencies, check your system for these dependencies, and if any are missing it can determine a working build order, retrieve the sources, build and then install the dependencies and the SlackBuild in question. All of which is completely automated and started with a single command.
Matična strana
http://www.iquidus.org/sbodeps
Izmena 04.06.2013: Autor ima tendenciju da počinje ispočetka/preimenuje projekte. Ovo je treća iteracija alatki slične namene.
Slackdeps
slackdeps is used to test a .t{gz,bz,lz,xz} package to see if your Slackware system has the required dependencies. slackdeps may also be able to install any required packages. Any required packages or libraries missing from your system will be listed when the test completes. slackdeps can be used like this:
slackdeps -i n /path/to/gimp-2.6.11-x86_64-1.txz
slackdeps is an experimental script, it is currently in testing, some bugs are to be expected. The current version of this script is 20120908, once more testing has taken place and I am happy with the scripts performance I'll change the version from a date format to a proper versioning system. If you experience any unexpected behaviour or have feedback of any kind please don't hesitate to contact the author/maintaner of this script.
Note: slackdeps is in no way affiliated with or supported by Slackware Linux, please don't bother the Slackware team with your enquiries.
https://github.com/iquidus/slackdeps" onclick="window.open(this.href);return false;
Post Napisano: 06 Oct 2012, 10:13
Ово би требало доста да убрза инсталацију програма са великим бројем зависности
Post Napisano: 06 Oct 2012, 20:24
Испробано и ради. Преузео сам kfilebox са SlackBuilds.org и покренуо:
# sbodeps -i kfilebox
kfilebox захтева dropbox. Нисам преузео dropbox претходно, а sbodeps је решио зависност. Једино не инсталира пакет, само га креира, па остаје још тај корак да се одради.
Потврђено... Инсталирао сам LiVES који има три зависности и све је протекло у најбољем реду. Дакле, ради :)
Post Napisano: 06 Oct 2012, 21:13
Koji paket ne instalira, osnovni ili zavisnost? Ja sam malopre testirao sa qemu i instalirao ga je bez problema...
Post Napisano: 06 Oct 2012, 21:45
Основни... Изгради га, али не може да инсталира, па га ја ручно инсталирам... Оба пута ми се исто десило.
Post Napisano: 06 Oct 2012, 22:26
Ne znam, kod mene se paket sam instalira nakom kompajliranja (uključujući i deps). Sad sam kompajlirao qemu paket i bez problema ga je kompajlirao i instalirao na ovaj način.
Post Napisano: 06 Oct 2012, 22:51
Instalirah PiTiVi bez ikakvih problema. ;)
Post Napisano: 16 Jan 2013, 14:09
Izašla je nova verzija alata sbodeps-a, verzija 0.1.8 dok mi ovu koju koristimo, barem je kod mene tako, je verzije 0.1.1.
Najlakše je prijaviti se odnosno registrovati na https://github.com" onclick="window.open(this.href);return false; (besplatno je) i pratiti sbodeps git https://github.com/iquidus/sbodeps#readme" onclick="window.open(this.href);return false;
Čudi me da je sbodeps uklonio sa sajta :huh:
http://www.iquidus.org/sbodeps" onclick="window.open(this.href);return false;
Ima li neko insajderski info šta se događa?
Badvej, nije mi krenulo za rukom da instaliram shutter kao prošli put preko sbodeps-a, neki linkovi pucaju i ne rešava sve perl zavisnosti pri tome ne računajući paket perl-gtk2 kojeg sam ručno kompajlirao te instalirao.
Post Napisano: 16 Jan 2013, 14:19
Autor je prestao sa radom na sbodeps paketu, umesto toga nastao je sbotools...mislim da je na svom blogu već o tome pisao (bar sam ja video pre nekih mesec dana kada sam tražio sbodeps). Sbotools je set alata za automatsko preuzimanje i kompajliranje paketa (uključujući i zavisnosti)...
http://www.iquidus.org/sbotools" onclick="window.open(this.href);return false;
Post Napisano: 16 Jan 2013, 15:53
Hvala za info. :beer:
Juče sam baš instalirao sbotools, najsvežiju verziju 1.4.
