DetaolB
Post Napisano: 07 Jan 2012, 15:44
Nešto jako zanimljivo. DetaolB je distribucija bazirana na uClibc. U 64 megabajta Deltaolb donosi kompletno razvojno okruženje bazirano na uClibc, uključujući gcc 3.4.6, tcc, git, gdb i mnoštvo editora (vim, scite, qemacs, nedit, zile).  DetaolB koristi TinyX i Fvwm 2.4.20. Od X aplikacija instalirani su još i Rox filer, conky, dillo, rxvt i mrxvt. Prvobitno je bio namenjen pokretanju pod emulatorima, ali u poslednjim verzijama je uspešno korišćen i na pravim računarima. GCC je u i686 verziji, a potrošnja memorije nije prelazila 30 mb.
DetaolB is a small size x86/uclibc distro, aimed mostly for emulators/virtualizers. With this iso's size around 60Mb, you've a small yet functional desktop distro which can help developping/debugging C/C++/Fortran/Perl software or compiling the linux kernel. It can then self emulate with included qemu-0.9.0 ;-) You can play with the grub menu (press the key 'e') at boot sequence and choose the framebuffer resolution you want using the "screen" parameter (example: screen=vga or svga or xga or sxga). You can choose between a french keyboard (kmap=fr) or stick to the us default.
Poslednja verzija je 0.8.1 iz 2008.
http://detaolb.sourceforge.net/
