Locked
Post Napisano: 19 Oct 2013, 12:29
19.10.2013.
Libtiff za Slackware 12.1, 12.2, 13.0, 13.1, 13.37, 14.0 i -current
patches/packages/libtiff-3.9.7-i486-1_slack14.0.txz:  Upgraded.
  Patched overflows, crashes, and out of bounds writes.
  Thanks to mancha for the backported patches.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2088
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-2113
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-4447
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-4564
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-1960
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-1961
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4231
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4232
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4244
Hplip za Slackware 13.1, 13.37, 14.0 i -current
patches/packages/hplip-3.12.9-i486-3_slack14.0.txz:  Rebuilt.
  This fixes a polkit race condition that could allow local users to bypass
  intended access restrictions.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4325
Post Napisano: 03 Nov 2013, 10:46
03.11.2013.
Nadogradnja Thunderbird-a samo za Slackware 14:
patches/packages/mozilla-thunderbird-17.0.10esr-i486-1_slack14.0.txz:  Upgraded.
    http://www.mozilla.org/security/known-vulnerabilities/thunderbirdESR.html
Post Napisano: 19 Nov 2013, 15:28
18.11.2013.
Mozilla Firefox za Slackware 13.37, 14.0, 14.1 i -current
patches/packages/mozilla-firefox-24.1.1esr-i486-1_slack14.1.txz:  Upgraded.
OpenSSH za Slackware 14.1 i -current
patches/packages/openssh-6.4p1-i486-1_slack14.1.txz:  Upgraded.
  sshd(8): fix a memory corruption problem triggered during rekeying
  when an AES-GCM cipher is selected.
    http://www.openssh.com/txt/gcmrekey.adv
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4548
Samba za Slackware 14.0, 14.1 i -current
patches/packages/samba-4.1.1-i486-1_slack14.1.txz:  Upgraded.
  * Samba versions 3.2.0 and above do not check the underlying file or
    directory ACL when opening an alternate data stream.
  * In setups which provide ldap(s) and/or https services, the private key
    for SSL/TLS encryption might be world readable.  This typically happens
    in active directory domain controller setups.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4475
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4476
  Added tdb.h, tdb.pc, and a libtdb.so symlink.  Thanks to Matteo Bernardini.
Seamonkey za Slackware 14.0, 14.1 i -current
patches/packages/seamonkey-2.22-i486-1_slack14.1.txz:  Upgraded.
patches/packages/seamonkey-solibs-2.22-i486-1_slack14.1.txz:  Upgraded.
Post Napisano: 06 Dec 2013, 11:23
05.12.2013.
Mozilla-nss za Slackware 14.0, 14.1 i current:
patches/packages/mozilla-nss-3.15.3-i486-1_slack14.1.txz:  Upgraded.
    http://www.mozilla.org/security/announce/2013/mfsa2013-103.html
Mozilla Thunderbird za Slackware 13.37, 14.0, 14.1 i current:
patches/packages/mozilla-thunderbird-24.1.1-i486-1_slack14.1.txz:  Upgraded.
Seamonkey 2.22.1 za Slackware 14.0.14.1 i current:
patches/packages/seamonkey-2.22.1-i486-1_slack14.1.txz:  Upgraded.
patches/packages/seamonkey-solibs-2.22.1-i486-1_slack14.1.txz:  Upgraded.
Hplip bezbedbosna nadogradnja paketa samo za Slackware 14.0:
patches/packages/hplip-3.12.9-i486-4_slack14.0.txz:  Rebuilt.
  This update disables the automatic upgrade feature which can be easily
  fooled into downloading an arbitrary binary and executing it.  This
  issue affects only Slackware 14.0 (earlier versions do not have the
  feature, and newer ones had already disabled it).
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6427
Post Napisano: 17 Dec 2013, 10:28
16.12.2013.
Libjpeg nadogradnja za 13.0, 13.1, 13.37, 14.0, 14.1 i -current:
patches/packages/libjpeg-v8a-i486-2_slack14.1.txz:  Rebuilt.
  Fix use of uninitialized memory when decoding images with missing SOS data
  for the luminance component (Y) in presence of valid chroma data (Cr, Cb).
  This could allow remote attackers to obtain sensitive information from
  uninitialized memory locations via a crafted JPEG image.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6629
Libiodbc i ruby nadogradnje za Slackware 13.1, 13.37, 14.0, 14.1 i -current:
patches/packages/libiodbc-3.52.8-i486-1_slack14.1.txz:  Upgraded.
  This update fixes an rpath pointing to a location in /tmp that was found in
  two test programs (iodbctest and iodbctestw).  This could have allowed a
  local attacker with write access to /tmp to add modified libraries (and
  execute arbitrary code) as any user running the test programs.
  Thanks to Christopher Oliver for the bug report.
patches/packages/ruby-1.9.3_p484-i486-1_slack14.1.txz:  Upgraded.
  This update fixes a heap overflow in floating point parsing.  A specially
  crafted string could cause a heap overflow leading to a denial of service
  attack via segmentation faults and possibly arbitrary code execution.
    https://www.ruby-lang.org/en/news/2013/11/22/heap-overflow-in-floating-point-parsing-cve-2013-4164/
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4164
Seamonkey i llvm nadogradnje za Slackware 14.0, 14,1 i -current:
patches/packages/seamonkey-2.23-i486-1_slack14.1.txz:  Upgraded.
patches/packages/seamonkey-solibs-2.23-i486-1_slack14.1.txz:  Upgraded.
patches/packages/llvm-3.3-i486-3_slack14.1.txz:  Rebuilt.
  The LLVM package included binaries with an rpath pointing to the build
  location in /tmp.   This allows an attacker with write access to /tmp to
  add modified libraries (and execute arbitrary code) as any user running
  the LLVM binaries.  This updated package rebuilds LLVM to exclude the
  build directories from the rpath information.
Mozilla Firefox i Thunderbird nadogradnje za Slackware 14.1 i -current:
patches/packages/mozilla-firefox-24.2.0esr-i486-1_slack14.1.txz:  Upgraded.
patches/packages/mozilla-thunderbird-24.2.0-i486-1_slack14.1.txz:  Upgraded.
Post Napisano: 22 Dec 2013, 00:16
21.12.2013.
Gnupg bezbednosne nadogradnje za Slackware 13.0, 13.1, 13.37, 14.0, 14.1 i -current:
  Fixed the RSA Key Extraction via Low-Bandwidth Acoustic
  Cryptanalysis attack as described by Genkin, Shamir, and Tromer.
    http://www.cs.tau.ac.il/~tromer/acoustic/
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4576
Post Napisano: 15 Jan 2014, 00:15
13.01.2014.
Prva nadogradnja ove godine :)
Samba, php, openssl i libXfont
Samba nadogradnja za Slackware 14.1 i current:
patches/packages/samba-4.1.4-i486-1_slack14.1.txz:  Upgraded.
  This update fixes a heap-based buffer overflow that may allow AD domain
  controllers to execute arbitrary code via an invalid fragment length in
  a DCE-RPC packet.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4408
Php nadogradnja za Slackware 14.0, 14.1 i current:
patches/packages/php-5.4.24-i486-1_slack14.1.txz:  Upgraded.
  The asn1_time_to_time_t function in ext/openssl/openssl.c in PHP before
  5.3.28, 5.4.x before 5.4.23, and 5.5.x before 5.5.7 does not properly
  parse (1) notBefore and (2) notAfter timestamps in X.509 certificates,
  which allows remote attackers to execute arbitrary code or cause a denial
  of service (memory corruption) via a crafted certificate that is not
  properly handled by the openssl_x509_parse function.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6420
Openssl nadogradnja za Slackware 14.0, 14.1 i current:
patches/packages/openssl-1.0.1f-i486-1_slack14.1.txz:  Upgraded.
  This update fixes the following security issues:
    Fix for TLS record tampering bug CVE-2013-4353
    Fix for TLS version checking bug CVE-2013-6449
    Fix for DTLS retransmission bug CVE-2013-6450
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-4353
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6449
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6450
patches/packages/openssl-solibs-1.0.1f-i486-1_slack14.1.txz:  Upgraded.
LibXfont nadogradnja za Slackware 13.0, 13.1, 13.37, 14.0, 14.1 i current:
patches/packages/libXfont-1.4.7-i486-1_slack14.1.txz:  Upgraded.
  This update fixes a stack overflow when reading a BDF font file containing
  a longer than expected string, which could lead to crashes or privilege
  escalation.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6462
Post Napisano: 29 Jan 2014, 02:13
28.01.2014.
Nadogradnja mozilla-nss paketa dostupna je za Slackware 14.0, 14.1 i current:
patches/packages/mozilla-nss-3.15.4-i486-1_slack14.1.txz:  Upgraded.
  Upgraded to nss-3.15.4 and nspr-4.10.3.
  Fixes a possible man-in-the-middle issue.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-1740
Nadogradnja bind paketa dostupna je za Slackware 13.0, 13.1, 13.37, 14.0, 14.1 current:
patches/packages/bind-9.9.4_P2-i486-1_slack14.1.txz:  Upgraded.
  This update fixes a defect in the handling of NSEC3-signed zones that can
  cause BIND to be crashed by a specific set of queries.
  NOTE:  According to the second link below, Slackware is probably not
  vulnerable since we aren't using glibc-2.18 yet.  Might as well fix it
  anyway, though.
    https://kb.isc.org/article/AA-01078
    https://kb.isc.org/article/AA-01085
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0591
Post Napisano: 04 Feb 2014, 00:20
03.02.2014.
Nove nadogradnje za pidgin za Slackware 13.0, 13.1, 13.37, 14.0, 14.1 i -current
patches/packages/pidgin-2.10.9-i486-1_slack14.1.txz:  Upgraded.
  This update fixes various security issues and other bugs.
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-6152
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6477
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6478
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6479
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6481
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6482
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6483
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6484
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6485
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6486
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6487
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6489
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2013-6490
    http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-0020
Post Napisano: 09 Feb 2014, 04:25
08.02.2014.
Firefox i Thunderbird za Slackware 14.1 i -current
patches/packages/seamonkey-2.24-i486-1_slack14.1.txz:  Upgraded.
patches/packages/seamonkey-solibs-2.24-i486-1_slack14.1.txz:  Upgraded.
patches/packages/mozilla-firefox-24.3.0esr-i486-1_slack14.1.txz:  Upgraded.
patches/packages/mozilla-thunderbird-24.3.0-i486-1_slack14.1.txz:  Upgraded.
Locked
