Napisano: 03 Dec 2023, 23:23
30. XI 2023.
Sveži samba paketi za Slackware 15.0 i -current:
patches/packages/samba-4.18.9-i586-1_slack15.0.txz: Upgraded.
This is a security release in order to address the following defect:
An information leak vulnerability was discovered in Samba's LDAP server.
Due to missing access control checks, an authenticated but unprivileged
attacker could discover the names and preserved attributes of deleted objects
in the LDAP store. Upgrading to this package will not prevent this
information leak - if you are using Samba as an Active Directory Domain
Controller, you will need to follow the instructions in the samba.org link
given below.
https://www.samba.org/samba/security/CVE-2018-14628.html
https://www.cve.org/CVERecord?id=CVE-2018-14628
Napisano: 15 Jan 2024, 23:25
09. XII 2023.
Sveži libxml2 paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/libxml2-2.12.2-i586-1_slack15.0.txz: Upgraded.
Add --sysconfdir=/etc option so that this can find the xml catalog.
Thanks to SpiderTux.
Fix the following security issues:
Fix integer overflows with XML_PARSE_HUGE.
Fix dict corruption caused by entity reference cycles.
Hashing of empty dict strings isn't deterministic.
Fix null deref in xmlSchemaFixupComplexType.
https://www.cve.org/CVERecord?id=CVE-2022-40303
https://www.cve.org/CVERecord?id=CVE-2022-40304
https://www.cve.org/CVERecord?id=CVE-2023-29469
https://www.cve.org/CVERecord?id=CVE-2023-28484
Napisano: 15 Jan 2024, 23:26
13. XII 2023.
Sveži xorg-server paketi za Slackware 15.0 i -current:
patches/packages/xorg-server-1.20.14-i586-10_slack15.0.txz: Rebuilt.
Out-of-bounds memory write in XKB button actions.
Out-of-bounds memory read in RRChangeOutputProperty and
RRChangeProviderProperty.
https://lists.x.org/archives/xorg/2023-December/061517.html
https://www.cve.org/CVERecord?id=CVE-2023-6377
https://www.cve.org/CVERecord?id=CVE-2023-6478
patches/packages/xorg-server-xephyr-1.20.14-i586-10_slack15.0.txz: Rebuilt.
patches/packages/xorg-server-xnest-1.20.14-i586-10_slack15.0.txz: Rebuilt.
patches/packages/xorg-server-xvfb-1.20.14-i586-10_slack15.0.txz: Rebuilt.
patches/packages/xorg-server-xwayland-21.1.4-i586-9_slack15.0.txz: Rebuilt.
Napisano: 15 Jan 2024, 23:27
14. XII 2023.
Sveži bluez paketi za Slackware 15.0 i -current:
patches/packages/bluez-5.71-i586-1_slack15.0.txz: Upgraded.
It may have been possible for an attacker within Bluetooth range to inject
keystrokes (and possibly execute commands) while devices were discoverable.
https://www.cve.org/CVERecord?id=CVE-2023-45866
Napisano: 15 Jan 2024, 23:29
19. XII 2023.
Sveži mozilla-thunderbird i mozilla-firefox paketi za Slackware 15.0 i -current:
patches/packages/mozilla-thunderbird-115.6.0-i686-1_slack15.0.txz: Upgraded.
https://www.thunderbird.net/en-US/thunderbird/115.6.0/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2023-55/
https://www.cve.org/CVERecord?id=CVE-2023-50762
https://www.cve.org/CVERecord?id=CVE-2023-50761
https://www.cve.org/CVERecord?id=CVE-2023-6856
https://www.cve.org/CVERecord?id=CVE-2023-6857
https://www.cve.org/CVERecord?id=CVE-2023-6858
https://www.cve.org/CVERecord?id=CVE-2023-6859
https://www.cve.org/CVERecord?id=CVE-2023-6860
https://www.cve.org/CVERecord?id=CVE-2023-6861
https://www.cve.org/CVERecord?id=CVE-2023-6862
https://www.cve.org/CVERecord?id=CVE-2023-6863
https://www.cve.org/CVERecord?id=CVE-2023-6864
patches/packages/mozilla-firefox-115.6.0esr-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/115.6.0/releasenotes/
https://www.mozilla.org/security/advisories/mfsa2023-54/
https://www.cve.org/CVERecord?id=CVE-2023-6865
https://www.cve.org/CVERecord?id=CVE-2023-6867
Sveži libssh paketi za Slackware 14.2, 15.0 i -current:
patches/packages/libssh-0.10.6-i586-1_slack15.0.txz: Upgraded.
Command injection using proxycommand.
Potential downgrade attack using strict kex.
Missing checks for return values of MD functions.
https://www.cve.org/CVERecord?id=CVE-2023-6004
https://www.cve.org/CVERecord?id=CVE-2023-48795
https://www.cve.org/CVERecord?id=CVE-2023-6918
Napisano: 15 Jan 2024, 23:30
20. XII 2023.
Sveži proftpd paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/proftpd-1.3.8b-i586-1_slack15.0.txz: Upgraded.
mod_sftp: implemented mitigations for "Terrapin" SSH attack.
Napisano: 15 Jan 2024, 23:31
23. XII 2023.
Sveži postfix paketi za Slackware 15.0 i -current:
patches/packages/postfix-3.6.13-i586-1_slack15.0.txz: Upgraded.
Security: this release adds support to defend against an email spoofing
attack (SMTP smuggling) on recipients at a Postfix server. Sites
concerned about SMTP smuggling attacks should enable this feature on
Internet-facing Postfix servers. For compatibility with non-standard
clients, Postfix by default excludes clients in mynetworks from this
countermeasure.
The recommended settings are:
# Optionally disconnect remote SMTP clients that send bare newlines,
# but allow local clients with non-standard SMTP implementations
# such as netcat, fax machines, or load balancer health checks.
smtpd_forbid_bare_newline = yes
smtpd_forbid_bare_newline_exclusions = $mynetworks
The smtpd_forbid_bare_newline feature is disabled by default.
https://www.postfix.org/smtp-smuggling.html
25. XII 2023.
Sveži kernel paketi za Slackware 15.0:
patches/packages/linux-5.15.145/*: Upgraded.
These updates fix various bugs and security issues.
Thanks to jwoithe for the PCI fix!
Fixed in 5.15.140:
https://www.cve.org/CVERecord?id=CVE-2023-46862
Fixed in 5.15.141:
https://www.cve.org/CVERecord?id=CVE-2023-6121
Napisano: 25 Jan 2024, 21:16
16. I 2024.
Sveži gnutls i xorg-server paketi za Slackware 15.0 i -current:
patches/packages/gnutls-3.8.3-i586-1_slack15.0.txz: Upgraded.
This update fixes two medium severity security issues:
Fix more timing side-channel inside RSA-PSK key exchange.
Fix assertion failure when verifying a certificate chain with a cycle of
cross signatures.
https://www.cve.org/CVERecord?id=CVE-2024-0553
https://www.cve.org/CVERecord?id=CVE-2024-0567
patches/packages/xorg-server-1.20.14-i586-11_slack15.0.txz: Rebuilt.
Heap buffer overflow in DeviceFocusEvent and ProcXIQueryPointer.
Reattaching to different master device may lead to out-of-bounds memory access.
Heap buffer overflow in XISendDeviceHierarchyEvent.
Heap buffer overflow in DisableDevice.
SELinux context corruption.
SELinux unlabeled GLX PBuffer.
https://lists.x.org/archives/xorg/2024-January/061525.html
https://www.cve.org/CVERecord?id=CVE-2023-6816
https://www.cve.org/CVERecord?id=CVE-2024-0229
https://www.cve.org/CVERecord?id=CVE-2024-21885
https://www.cve.org/CVERecord?id=CVE-2024-21886
https://www.cve.org/CVERecord?id=CVE-2024-0408
https://www.cve.org/CVERecord?id=CVE-2024-0409
patches/packages/xorg-server-xephyr-1.20.14-i586-11_slack15.0.txz: Rebuilt.
patches/packages/xorg-server-xnest-1.20.14-i586-11_slack15.0.txz: Rebuilt.
patches/packages/xorg-server-xvfb-1.20.14-i586-11_slack15.0.txz: Rebuilt.
patches/packages/xorg-server-xwayland-21.1.4-i586-10_slack15.0.txz: Rebuilt.
Napisano: 25 Jan 2024, 21:17
21. I 2024.
Sveži tigervnc paketi za Slackware 15.0 i -current:
extra/tigervnc/tigervnc-1.12.0-i586-5_slack15.0.txz: Rebuilt.
Recompiled against xorg-server-1.20.14, including the latest patches for
several security issues. Thanks to marav.
