Nvidia i ATI graficki drajveri!
Post Napisano: 21 Sep 2015, 06:31
Pročitao sam ispočetka našu prepisku i vidim da mi je ovo promaklo:
dr_mr_foo wrote:Međutim, nije mi jasno zašto "lsmod" još uvek vidi "i915"?
Evo samo nekoliko linija:
ttm                    72700  1 radeon
drm_kms_helper         93465  2 i915,radeon...
drm                   272237  6 ttm,i915,drm_kms_helper,radeon..
i2c_algo_bit            5488  2 i915,radeon...
video                  13136  1 i915
Da li je još uvek tako?
Ako da, proveri sadržaj fajla /etc/modprobe.d/blacklist-i915.conf.
Post Napisano: 21 Sep 2015, 09:58
Jutro!
Da, ista priča.
Na kernelu 4.16 modul je još uvek tu, dok na 3.18.21 nije prisutan otkad sam
isključio integrisanu grafiku. Međutim, ispis komandi u vezi Mesa i OpenGL isti su.
Fajl /etc/modprobe.d/blacklist-i915.conf sadrži samo liniju "blacklist i915" (bez "").
Čitao sam malo o "modinfo" komandi koja bi mogla pomoći, ali slabo se snalazim sa
kernel argumentima.
Da li ovaj prost ispis može koristiti? :rolleyes:
modinfo -p radeon
no_wb:Disable AGP writeback for scratch registers (int)
modeset:Disable/Enable modesetting (int)
dynclks:Disable/Enable dynamic clocks (int)
r4xx_atom:Enable ATOMBIOS modesetting for R4xx (int)
vramlimit:Restrict VRAM for testing, in megabytes (int)
agpmode:AGP Mode (-1 == PCI) (int)
gartsize:Size of PCIE/IGP gart to setup in megabytes (32, 64, etc., -1 = auto) (int)
benchmark:Run benchmark (int)
test:Run tests (int)
connector_table:Force connector table (int)
tv:TV enable (0 = disable) (int)
audio:Audio enable (-1 = auto, 0 = disable, 1 = enable) (int)
disp_priority:Display Priority (0 = auto, 1 = normal, 2 = high) (int)
hw_i2c:hw i2c engine enable (0 = disable) (int)
pcie_gen2:PCIE Gen2 mode (-1 = auto, 0 = disable, 1 = enable) (int)
msi:MSI support (1 = enable, 0 = disable, -1 = auto) (int)
lockup_timeout:GPU lockup timeout in ms (default 10000 = 10 seconds, 0 = disable) (int)
fastfb:Direct FB access for IGP chips (0 = disable, 1 = enable) (int)
dpm:DPM support (1 = enable, 0 = disable, -1 = auto) (int)
aspm:ASPM support (1 = enable, 0 = disable, -1 = auto) (int)
runpm:PX runtime pm (1 = force enable, 0 = disable, -1 = PX only default) (int)
hard_reset:PCI config reset (1 = force enable, 0 = disable (default)) (int)
vm_size:VM address space size in gigabytes (default 4GB) (int)
vm_block_size:VM page table size in bits (default depending on vm_size) (int)
deep_color:Deep Color support (1 = enable, 0 = disable (default)) (int)
use_pflipirq:Pflip irqs for pageflip completion (0 = disable, 1 = as fallback, 2 = exclusive (default)) (int)
bapm:BAPM support (1 = enable, 0 = disable, -1 = auto) (int)
backlight:backlight support (1 = enable, 0 = disable, -1 = auto) (int)
auxch:Use native auxch experimental support (1 = enable, 0 = disable, -1 = auto) (int)
mst:DisplayPort MST experimental support (1 = enable, 0 = disable) (int)
Post Napisano: 21 Sep 2015, 12:37
Da izlaz modinfo može da koristi, reagovao bih prvi put kad si pitao. :P
Što se tiče 3.18.21 vs 4.1.6. Ako imaš viška vremena možeš proveriti izlaze sledećih komandi na oba:
su -c /sbin/lspci
lsmod
xrandr
glxinfo.
Po meni je veliki problem što se i915 učitava i ako mu je rečeno da se ne učitava i čak je onemogućen u BIOSu.
Post Napisano: 21 Sep 2015, 15:25
Mesa 11.0 za Slackware64 14.1 i sve zavisnosti. Ovo je samo za 64-bitne aplikacije/igre. Neće raditi sa Steamom i 32-bitnim aplikacijama/igrama. Izgrađeno bez podrške za video akceleraciju (libva). Izgrađeno na čistoj Slack64 14.1 instalaciji.
Za testiranje, ali ako sam u pravu šta je uzrok problema, ne verujem da će pomoći.
http://slackware-srbija.org/download/di ... esa.tar.gz" onclick="window.open(this.href);return false;
Otpakuj arhivu:
tar xvf mesa.tar.gz
Uđi u direktorijum mesa
cd mesa
Instaliraj sve pakete iz njega
su -c "upgradepkg --install-new *.t?z"
Post Napisano: 21 Sep 2015, 17:03
Hvala!
Zaista ne znam da li bi me živci služili ovako dugo, da nisi priskočio u pomoć. ;)
Odradio sve po uputstvu. Evo nekoliko ispisa za početak.
Primetio sam da je "glxinfo" sad detaljniji, tj. ispis ima mnooogo više redova. :O
Izostaviću ga iz tog razloga. Okačiću ako/kad zatreba.
LIBGL_DEBUG=verbose glxinfo | head
libGL: OpenDriver: trying /usr/lib64/xorg/modules/dri/tls/r600_dri.so
libGL: OpenDriver: trying /usr/lib64/xorg/modules/dri/r600_dri.so
libGL: Can't open configuration file /root/.drirc: No such file or directory.
libGL: Using DRI2 for screen 0
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
    GLX_ARB_create_context, GLX_ARB_create_context_profile,
    GLX_ARB_multisample, GLX_EXT_create_context_es2_profile,
    GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,
    GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer
glxinfo | grep renderer
    GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
OpenGL renderer string: Gallium 0.4 on AMD CAICOS (DRM 2.42.0, LLVM 3.7.0)
glxinfo | grep -i version
client glx version string: 1.4
GLX version: 1.4
OpenGL core profile version string: 3.3 (Core Profile) Mesa 11.0.0
OpenGL core profile shading language version string: 3.30
OpenGL version string: 3.0 Mesa 11.0.0
OpenGL shading language version string: 1.30
OpenGL ES profile version string: OpenGL ES 3.0 Mesa 11.0.0
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00
Ne znam šta si sve zamislio u vezi testiranja, ali me zbunjuje (da ne kažem plaši)
ova rečenica. :lipsrsealed:
bocke wrote:Za testiranje, ali ako sam u pravu šta je uzrok problema, ne verujem da će pomoći.
Post Napisano: 21 Sep 2015, 17:24
Oho, jesu li to neki pomaci? :)
Hajde postavi ceo output glxinfo da bih bio siguran. Ako je to to, onda je možda dovoljan samo upgrade Mese.
Na kom kernelu si to testirao? :) 4.1.6?
P.S. Probaj sad SuperTuxKart. ;)
Post Napisano: 21 Sep 2015, 17:50
Oho, jesu!
Nisam se usudio prvi da pomenem, zbog uroka. :D
Kernel 4.1.6, ona "brza" varijanta koju smo odradili pre nekoliko dana.
Nisam još probao sa 3.18.21, ali se nadam da će i to biti ok.
Ne dozvoljava da okačim kompletan "glxinfo", zbog broja karaktera.
Ovo je prvi deo.
bash-4.2# glxinfo
    GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,
    GLX_OML_swap_method, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
    GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_SGI_swap_control
client glx vendor string: Mesa Project and SGI
client glx extensions:
    GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
    GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
    GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,
    GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
    GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
    GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
    GLX_EXT_create_context_es2_profile, GLX_EXT_import_context,
    GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
OpenGL vendor string: X.Org
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
    GL_AMD_conservative_depth, GL_AMD_draw_buffers_blend,
    GL_AMD_pinned_memory, GL_AMD_seamless_cubemap_per_texture,
    GL_AMD_shader_stencil_export, GL_AMD_shader_trinary_minmax,
    GL_AMD_vertex_shader_layer, GL_AMD_vertex_shader_viewport_index,
    GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
    GL_ARB_ES2_compatibility, GL_ARB_ES3_compatibility, GL_ARB_base_instance,
    GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
    GL_ARB_clear_buffer_object, GL_ARB_clip_control,
    GL_ARB_compressed_texture_pixel_storage,
    GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
    GL_ARB_copy_buffer, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
    GL_ARB_depth_clamp, GL_ARB_derivative_control, GL_ARB_direct_state_access,
    GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
    GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect,
    GL_ARB_draw_instanced, GL_ARB_explicit_attrib_location,
    GL_ARB_explicit_uniform_location, GL_ARB_fragment_coord_conventions,
    GL_ARB_fragment_layer_viewport, GL_ARB_fragment_shader,
    GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
    GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,
    GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
    GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
    GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
    GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
    GL_ARB_occlusion_query2, GL_ARB_pipeline_statistics_query,
    GL_ARB_pixel_buffer_object, GL_ARB_point_sprite,
    GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
    GL_ARB_robustness, GL_ARB_sample_shading, GL_ARB_sampler_objects,
    GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture,
    GL_ARB_separate_shader_objects, GL_ARB_shader_bit_encoding,
    GL_ARB_shader_objects, GL_ARB_shader_stencil_export,
    GL_ARB_shader_subroutine, GL_ARB_shader_texture_lod,
    GL_ARB_shading_language_420pack, GL_ARB_shading_language_packing,
    GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_texture_barrier,
    GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
    GL_ARB_texture_buffer_range, GL_ARB_texture_compression_bptc,
    GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map_array,
    GL_ARB_texture_float, GL_ARB_texture_gather,
    GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_multisample,
    GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels,
    GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
    GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8,
    GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,
    GL_ARB_texture_swizzle, GL_ARB_timer_query, GL_ARB_transform_feedback2,
    GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
    GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
    GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
    GL_ARB_vertex_shader, GL_ARB_vertex_type_10f_11f_11f_rev,
    GL_ARB_vertex_type_2_10_10_10_rev, GL_ARB_viewport_array,
    GL_ATI_blend_equation_separate, GL_ATI_texture_compression_3dc,
    GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_EXT_abgr,
    GL_EXT_blend_equation_separate, GL_EXT_draw_buffers2,
    GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,
    GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
    GL_EXT_framebuffer_sRGB, GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
    GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp,
    GL_EXT_provoking_vertex, GL_EXT_shader_integer_mix, GL_EXT_texture_array,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_latc,
    GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer,
    GL_EXT_texture_mirror_clamp, GL_EXT_texture_sRGB,
    GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent,
    GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query,
    GL_EXT_transform_feedback, GL_EXT_vertex_array_bgra,
    GL_IBM_multimode_draw_arrays, GL_KHR_context_flush_control, GL_KHR_debug,
    GL_MESA_pack_invert, GL_MESA_texture_signed_rgba,
    GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_packed_depth_stencil,
    GL_NV_texture_barrier, GL_NV_vdpau_interop, GL_OES_EGL_image,
    GL_OES_read_format, GL_S3_s3tc
OpenGL context flags: (none)
OpenGL extensions:
    GL_APPLE_packed_pixels, GL_APPLE_vertex_array_object,
    GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
    GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_derivative_control,
    GL_ARB_draw_elements_base_vertex, GL_ARB_draw_instanced,
    GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
    GL_ARB_fragment_coord_conventions, GL_ARB_fragment_program,
    GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
    GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multisample,
    GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
    GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,
    GL_ARB_point_parameters, GL_ARB_point_sprite,
    GL_ARB_shader_texture_lod, GL_ARB_shading_language_100,
    GL_ARB_shadow, GL_ARB_stencil_texturing, GL_ARB_sync,
    GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
    GL_ARB_texture_compression, GL_ARB_texture_compression_bptc,
    GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map,
    GL_ARB_texture_cube_map_array, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
    GL_ARB_texture_env_dot3, GL_ARB_texture_float, GL_ARB_texture_gather,
    GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
    GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
    GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
    GL_ARB_texture_stencil8, GL_ARB_texture_storage,
    GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
    GL_ARB_transpose_matrix, GL_ARB_uniform_buffer_object,
    GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
    GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
    GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
    GL_ARB_window_pos, GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,
    GL_ATI_separate_stencil, GL_ATI_texture_compression_3dc,
    GL_ATI_texture_env_combine3, GL_ATI_texture_float,
    GL_ATI_texture_mirror_once, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
    GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
    GL_EXT_copy_texture, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
    GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
    GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
    GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays,
    GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_packed_pixels,
    GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
    GL_EXT_polygon_offset, GL_EXT_polygon_offset_clamp,
    GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color, GL_EXT_shader_integer_mix,
    GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,
    GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
    GL_EXT_texture_array, GL_EXT_texture_compression_dxt1,
    GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
    GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_texture_sRGB,
    GL_EXT_transform_feedback, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
    GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
    GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
    GL_KHR_context_flush_control, GL_KHR_debug, GL_MESA_pack_invert,
    GL_MESA_texture_signed_rgba, GL_MESA_window_pos, GL_NV_blend_square,
    GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance,
    GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
    GL_NV_primitive_restart, GL_NV_texgen_reflection, GL_NV_texture_barrier,
    GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_NV_vdpau_interop,
    GL_OES_EGL_image, GL_OES_read_format, GL_S3_s3tc,
    GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
    GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile extensions:
    GL_APPLE_texture_max_level, GL_EXT_blend_minmax,
    GL_EXT_color_buffer_float, GL_EXT_discard_framebuffer,
    GL_EXT_draw_buffers, GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
    GL_EXT_read_format_bgra, GL_EXT_separate_shader_objects,
    GL_EXT_shader_integer_mix, GL_EXT_texture_compression_dxt1,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_format_BGRA8888,
    GL_EXT_texture_rg, GL_EXT_texture_type_2_10_10_10_REV,
    GL_EXT_unpack_subimage, GL_KHR_context_flush_control, GL_NV_draw_buffers,
    GL_NV_fbo_color_attachments, GL_NV_read_buffer, GL_NV_read_depth,
    GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_OES_EGL_image,
    GL_OES_EGL_image_external, GL_OES_EGL_sync,
    GL_OES_compressed_ETC1_RGB8_texture, GL_OES_depth24, GL_OES_depth_texture,
    GL_OES_depth_texture_cube_map, GL_OES_element_index_uint,
    GL_OES_fbo_render_mipmap, GL_OES_get_program_binary, GL_OES_mapbuffer,
    GL_OES_packed_depth_stencil, GL_OES_rgb8_rgba8,
    GL_OES_standard_derivatives, GL_OES_stencil8, GL_OES_surfaceless_context,
    GL_OES_texture_3D, GL_OES_texture_float, GL_OES_texture_float_linear,
    GL_OES_texture_half_float, GL_OES_texture_half_float_linear,
    GL_OES_texture_npot, GL_OES_vertex_array_object
480 GLX Visuals
    visual  x   bf lv rg d st  colorbuffer  sr ax dp st accumbuffer  ms  cav
  id dep cl sp  sz l  ci b ro  r  g  b  a F gb bf th cl  r  g  b  a ns b eat
0x021 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x022 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x2c6 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x2c7 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x2c8 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x2c9 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x2ca 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x2cb 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x2cc 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x2cd 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x2ce 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x2cf 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x2d0 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x2d1 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x2d2 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x2d3 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x2d4 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x2d5 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x2d6 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x2d7 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x2d8 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x2d9 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x2da 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x2db 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x2dc 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  2 1 None
0x2dd 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x2de 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x2df 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  2 1 None
0x2e0 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x2e1 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x2e2 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  2 1 None
0x2e3 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x2e4 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x2e5 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  2 1 None
0x2e6 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  4 1 None
0x2e7 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  8 1 None
0x2e8 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  2 1 None
0x2e9 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  4 1 None
0x2ea 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  8 1 None
0x2eb 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  2 1 None
0x2ec 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  4 1 None
0x2ed 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  8 1 None
0x2ee 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  2 1 None
0x2ef 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  4 1 None
0x2f0 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  8 1 None
0x2f1 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  2 1 None
0x2f2 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  4 1 None
0x2f3 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  8 1 None
0x2f4 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  2 1 None
0x2f5 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  4 1 None
0x2f6 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  8 1 None
0x2f7 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  2 1 None
0x2f8 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x2f9 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x2fa 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  2 1 None
0x2fb 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x2fc 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x2fd 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  2 1 None
0x2fe 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x2ff 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x300 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x301 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x302 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x303 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x304 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x305 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x306 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x307 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x308 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x309 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x30a 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x30b 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x30c 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x30d 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x30e 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x30f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x310 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x311 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x312 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x313 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x314 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x315 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x316 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x317 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x318 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  2 1 None
0x319 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x31a 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x31b 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  2 1 None
0x31c 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x31d 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x31e 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  2 1 None
0x31f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x320 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x321 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  2 1 None
0x322 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  4 1 None
0x323 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  8 1 None
0x324 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  2 1 None
0x325 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  4 1 None
0x326 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  8 1 None
0x327 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  2 1 None
0x328 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  4 1 None
0x329 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  8 1 None
0x32a 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  2 1 None
0x32b 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  4 1 None
0x32c 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  8 1 None
0x32d 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  2 1 None
0x32e 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  4 1 None
0x32f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  8 1 None
0x330 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  2 1 None
0x331 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  4 1 None
0x332 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  8 1 None
0x333 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  2 1 None
0x334 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x335 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x336 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  2 1 None
0x337 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x338 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x339 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  2 1 None
0x33a 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x33b 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x33c 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x33d 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x33e 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x33f 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x340 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x341 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x342 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x343 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x344 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x345 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x346 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x347 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x348 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x349 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x34a 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x34b 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x34c 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x34d 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x34e 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x34f 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x350 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x351 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x352 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x353 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x354 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  2 1 None
0x355 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x356 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x357 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  2 1 None
0x358 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x359 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x35a 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  2 1 None
0x35b 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x35c 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x35d 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  2 1 None
0x35e 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  4 1 None
0x35f 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  8 1 None
0x360 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  2 1 None
0x361 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  4 1 None
0x362 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  8 1 None
0x363 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  2 1 None
0x364 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  4 1 None
0x365 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  8 1 None
0x366 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  2 1 None
0x367 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  4 1 None
0x368 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  8 1 None
0x369 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  2 1 None
0x36a 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  4 1 None
0x36b 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  8 1 None
0x36c 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  2 1 None
0x36d 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  4 1 None
0x36e 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  8 1 None
0x36f 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  2 1 None
0x370 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x371 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x372 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  2 1 None
0x373 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x374 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x375 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  2 1 None
0x376 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x377 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x378 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x379 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x37a 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x37b 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x37c 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x37d 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x37e 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x37f 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x380 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x381 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x382 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x383 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x384 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x385 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x386 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x387 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x388 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x389 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x38a 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x38b 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x38c 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x38d 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x38e 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x38f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x390 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  2 1 None
0x391 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x392 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x393 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  2 1 None
0x394 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x395 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x396 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  2 1 None
0x397 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x398 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x399 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  2 1 None
0x39a 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  4 1 None
0x39b 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  8 1 None
0x39c 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  2 1 None
0x39d 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  4 1 None
0x39e 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  8 1 None
0x39f 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  2 1 None
0x3a0 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  4 1 None
0x3a1 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  8 1 None
0x3a2 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  2 1 None
0x3a3 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  4 1 None
0x3a4 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  8 1 None
0x3a5 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  2 1 None
0x3a6 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  4 1 None
0x3a7 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  8 1 None
0x3a8 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  2 1 None
0x3a9 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  4 1 None
0x3aa 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  8 1 None
0x3ab 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  2 1 None
0x3ac 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x3ad 24 tc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x3ae 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  2 1 None
0x3af 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x3b0 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x3b1 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  2 1 None
0x3b2 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x3b3 24 tc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x3b4 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x3b5 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x3b6 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x3b7 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x3b8 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x3b9 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x3ba 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x3bb 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x3bc 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x3bd 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x3be 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x3bf 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x3c0 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x3c1 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x3c2 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x3c3 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x3c4 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x3c5 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x3c6 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x3c7 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x3c8 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x3c9 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x3ca 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x3cb 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  2 1 None
0x3cc 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x3cd 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x3ce 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  2 1 None
0x3cf 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x3d0 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x3d1 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  2 1 None
0x3d2 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x3d3 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x3d4 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  2 1 None
0x3d5 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  4 1 None
0x3d6 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  8 1 None
0x3d7 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  2 1 None
0x3d8 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  4 1 None
0x3d9 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  8 1 None
0x3da 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  2 1 None
0x3db 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  4 1 None
0x3dc 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  8 1 None
0x3dd 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  2 1 None
0x3de 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  4 1 None
0x3df 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  8 1 None
0x3e0 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  2 1 None
0x3e1 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  4 1 None
0x3e2 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  8 1 None
0x3e3 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  2 1 None
0x3e4 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  4 1 None
0x3e5 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  8 1 None
0x3e6 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  2 1 None
0x3e7 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x3e8 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x3e9 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  2 1 None
0x3ea 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x3eb 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x3ec 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  2 1 None
0x3ed 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x3ee 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x3ef 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x3f0 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x3f1 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x3f2 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x3f3 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x3f4 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x3f5 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x3f6 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x3f7 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x3f8 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x3f9 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x3fa 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x3fb 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x3fc 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x3fd 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x3fe 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x3ff 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x400 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x401 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x402 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x403 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x404 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x405 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x406 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x407 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  2 1 None
0x408 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x409 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x40a 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  2 1 None
0x40b 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x40c 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x40d 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  2 1 None
0x40e 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x40f 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x410 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  2 1 None
0x411 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  4 1 None
0x412 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  8 1 None
0x413 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  2 1 None
0x414 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  4 1 None
0x415 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  8 1 None
0x416 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  2 1 None
0x417 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  4 1 None
0x418 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  8 1 None
0x419 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  2 1 None
0x41a 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  4 1 None
0x41b 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  8 1 None
0x41c 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  2 1 None
0x41d 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  4 1 None
0x41e 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  8 1 None
0x41f 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  2 1 None
0x420 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  4 1 None
0x421 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  8 1 None
0x422 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  2 1 None
0x423 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x424 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x425 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  2 1 None
0x426 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x427 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x428 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  2 1 None
0x429 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x42a 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x42b 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x42c 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x42d 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x42e 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x42f 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x430 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x431 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x432 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x433 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x434 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x435 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  0 0 None
0x436 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0 16 16 16 16  0 0 Slow
0x437 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x438 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x439 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x43a 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x43b 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  0 0 None
0x43c 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0 16 16 16 16  0 0 Slow
0x43d 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x43e 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x43f 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x440 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x441 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
0x442 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8 16 16 16 16  0 0 Slow
0x443 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  2 1 None
0x444 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x445 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x446 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  2 1 None
0x447 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x448 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x449 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  2 1 None
0x44a 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  4 1 None
0x44b 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  8 1 None
0x44c 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  2 1 None
0x44d 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  4 1 None
0x44e 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 16  0  0  0  0  0  8 1 None
0x44f 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  2 1 None
0x450 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  4 1 None
0x451 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  8 1 None
0x452 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  2 1 None
0x453 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  4 1 None
0x454 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 16  0  0  0  0  0  8 1 None
0x455 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  2 1 None
0x456 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  4 1 None
0x457 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  0  0  0  0  0  8 1 None
0x458 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  2 1 None
0x459 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  4 1 None
0x45a 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  8 1 None
0x45b 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  2 1 None
0x45c 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  4 1 None
0x45d 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  0  0  0  0  0  8 1 None
0x45e 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  2 1 None
0x45f 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x460 24 dc  0  32  0 r  . .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x461 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  2 1 None
0x462 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x463 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x464 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  2 1 None
0x465 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  4 1 None
0x466 24 dc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  8 1 None
0x467 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x468 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x469 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x46a 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x46b 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  0 0 None
0x46c 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0 16 16 16  0  0 0 Slow
0x46d 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x46e 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x46f 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x470 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x471 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  0 0 None
0x472 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0 16 16 16  0  0 0 Slow
0x473 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x474 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x475 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x476 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x477 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  0 0 None
0x478 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0 16 16 16  0  0 0 Slow
0x479 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x47a 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x47b 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x47c 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x47d 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  0 0 None
0x47e 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8 16 16 16  0  0 0 Slow
0x47f 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  2 1 None
0x480 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x481 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x482 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  2 1 None
0x483 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x484 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x485 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  2 1 None
0x486 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  4 1 None
0x487 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0  0  0  0  0  0  0  8 1 None
0x488 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  2 1 None
0x489 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  4 1 None
0x48a 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 16  0  0  0  0  0  8 1 None
0x48b 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  2 1 None
0x48c 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  4 1 None
0x48d 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  8 1 None
0x48e 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  2 1 None
0x48f 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  4 1 None
0x490 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 16  0  0  0  0  0  8 1 None
0x491 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  2 1 None
0x492 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  4 1 None
0x493 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  0  0  0  0  0  8 1 None
0x494 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  2 1 None
0x495 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  4 1 None
0x496 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  8 1 None
0x497 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  2 1 None
0x498 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  4 1 None
0x499 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  0  0  0  0  0  8 1 None
0x49a 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  2 1 None
0x49b 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x49c 24 dc  0  24  0 r  . .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x49d 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  2 1 None
0x49e 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x49f 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x4a0 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  2 1 None
0x4a1 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  4 1 None
0x4a2 24 dc  0  24  0 r  y .   8  8  8  0 .  .  0 24  8  0  0  0  0  8 1 None
0x06d 32 tc  0  32  0 r  y .   8  8  8  8 .  .  0 24  8  0  0  0  0  0 0 None
Treba li i drugi deo ispisa? Počinje sa...
600 GLXFBConfigs:
0x06e 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x06f 24 tc  0  32  0 r  . .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
0x070 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0  0  0  0  0  0 0 None
0x071 24 tc  0  32  0 r  y .   8  8  8  8 .  .  0  0  0 16 16 16 16  0 0 Slow
... i do kraja su slične vradžbine. :rolleyes:
SuperTuxKart 3D ne prigovara da je "driver too old". :grin:
Vidim poboljšanja, mada "full" grafičke opcije nisam probao.
Post Napisano: 21 Sep 2015, 18:03
To je onda to što se tiče Mese. :) Kernel ne moraš da menjaš.
Onda ti dugujem izvinjenje. Ipak je do verzije Mese. Iako je po dokumentaciji CAICOS chipset podržan od ranije.
Napraviću paket za Mesu 11.0 sa video akceleracijom (libva) pa ću okačiti. Koristiš li slackpkg+?
Post Napisano: 21 Sep 2015, 18:12
Ako ćemo pošteno, ja tebi dugujem izvinjenje za maltretiranje. ;)
Koristim slakpkg+ - poslednja verzija 1.5.0.
Post Napisano: 24 Sep 2015, 19:16
bocke wrote:Napraviću paket za Mesu 11.0 sa video akceleracijom (libva) pa ću okačiti. Koristiš li slackpkg+?
Izvini, neću se baviti ovim pre sledeće nedelje. :)
