Napisano: 27 Jun 2023, 20:07
08. VI 2023.
Sveži mozilla-thunderbird, php8 i python3 paketi za Slackware 15.0 i -current:
patches/packages/mozilla-thunderbird-102.12.0-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/102.12.0/releasenotes/
extra/php81/php81-8.1.20-i586-1_slack15.0.txz: Upgraded.
https://www.php.net/ChangeLog-8.php#8.1.20
patches/packages/python3-3.9.17-i586-1_slack15.0.txz: Upgraded.
This update fixes bugs and a security issue:
urllib.parse.urlsplit() now strips leading C0 control and space characters
following the specification for URLs defined by WHATWG.
https://www.cve.org/CVERecord?id=CVE-2023-24329
Napisano: 27 Jun 2023, 20:08
15. VI 2023.
Sveži libX11 paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/libX11-1.8.6-i586-1_slack15.0.txz: Upgraded.
This update fixes buffer overflows in InitExt.c that could at least cause
the client to crash due to memory corruption.
https://www.cve.org/CVERecord?id=CVE-2023-3138
Napisano: 27 Jun 2023, 20:10
21. VI 2023.
Sveži bind paketi za Slackware 15.0 i -current:
patches/packages/bind-9.16.42-i586-1_slack15.0.txz: Upgraded.
Exceeding the recursive-clients quota may cause named to terminate
unexpectedly when stale-answer-client-timeout is set to 0.
https://kb.isc.org/docs/cve-2023-2911
https://www.cve.org/CVERecord?id=CVE-2023-2911
Sveži kernel paketi za Slackware 15.0:
patches/packages/linux-5.15.118/*: Upgraded.
These updates fix various bugs and security issues.
Fixed in 5.15.93:
https://www.cve.org/CVERecord?id=CVE-2023-2162
https://www.cve.org/CVERecord?id=CVE-2023-32269
Fixed in 5.15.94:
https://www.cve.org/CVERecord?id=CVE-2023-1078
https://www.cve.org/CVERecord?id=CVE-2022-27672
Fixed in 5.15.95:
https://www.cve.org/CVERecord?id=CVE-2023-1513
https://www.cve.org/CVERecord?id=CVE-2023-1281
https://www.cve.org/CVERecord?id=CVE-2023-26545
Fixed in 5.15.96:
https://www.cve.org/CVERecord?id=CVE-2023-0459
https://www.cve.org/CVERecord?id=CVE-2022-3707
https://www.cve.org/CVERecord?id=CVE-2022-2196
Fixed in 5.15.99:
https://www.cve.org/CVERecord?id=CVE-2023-2985
https://www.cve.org/CVERecord?id=CVE-2023-1079
https://www.cve.org/CVERecord?id=CVE-2023-25012
https://www.cve.org/CVERecord?id=CVE-2023-1076
https://www.cve.org/CVERecord?id=CVE-2023-1077
https://www.cve.org/CVERecord?id=CVE-2023-1118
Fixed in 5.15.100:
https://www.cve.org/CVERecord?id=CVE-2023-23004
https://www.cve.org/CVERecord?id=CVE-2023-1829
Fixed in 5.15.104:
https://www.cve.org/CVERecord?id=CVE-2023-30456
https://www.cve.org/CVERecord?id=CVE-2023-2235
https://www.cve.org/CVERecord?id=CVE-2023-1855
https://www.cve.org/CVERecord?id=CVE-2023-1990
Fixed in 5.15.105:
https://www.cve.org/CVERecord?id=CVE-2023-2483
https://www.cve.org/CVERecord?id=CVE-2023-30772
https://www.cve.org/CVERecord?id=CVE-2023-33203
https://www.cve.org/CVERecord?id=CVE-2023-33288
https://www.cve.org/CVERecord?id=CVE-2022-4379
https://www.cve.org/CVERecord?id=CVE-2023-1670
https://www.cve.org/CVERecord?id=CVE-2022-4269
https://www.cve.org/CVERecord?id=CVE-2023-1989
https://www.cve.org/CVERecord?id=CVE-2023-28466
https://www.cve.org/CVERecord?id=CVE-2023-2194
Fixed in 5.15.106:
https://www.cve.org/CVERecord?id=CVE-2023-1611
Fixed in 5.15.108:
https://www.cve.org/CVERecord?id=CVE-2023-1859
Fixed in 5.15.109:
https://www.cve.org/CVERecord?id=CVE-2023-2156
https://www.cve.org/CVERecord?id=CVE-2023-31436
https://www.cve.org/CVERecord?id=CVE-2023-2248
Fixed in 5.15.110:
https://www.cve.org/CVERecord?id=CVE-2023-1380
https://www.cve.org/CVERecord?id=CVE-2023-2002
Fixed in 5.15.111:
https://www.cve.org/CVERecord?id=CVE-2023-32233
https://www.cve.org/CVERecord?id=CVE-2023-2269
Fixed in 5.15.112:
https://www.cve.org/CVERecord?id=CVE-2023-34256
Fixed in 5.15.113:
https://www.cve.org/CVERecord?id=CVE-2022-48425
22. VI 2023.
Sveži cups paketi za Slackware 14.2, 15.0 i -current:
patches/packages/cups-2.4.6-i586-1_slack15.0.txz: Upgraded.
Fixed use-after-free when logging warnings in case of failures
in cupsdAcceptClient().
https://www.cve.org/CVERecord?id=CVE-2023-34241
Napisano: 27 Jun 2023, 20:11
26. VI 2023.
Sveži vim paketi za Slackware 15.0 i -current:
patches/packages/vim-9.0.1667-i586-1_slack15.0.txz: Upgraded.
This fixes a rare divide-by-zero bug that could cause vim to crash. In an
interactive program such as vim, I can't really see this qualifying as a
security issue, but since it was brought up as such on LQ we'll just go
along with it this time. :)
patches/packages/vim-gvim-9.0.1667-i586-1_slack15.0.txz: Upgraded.
Napisano: 09 Jul 2023, 18:17
04. VII 2023.
Sveži mozilla-firefox paketi za Slackware 15.0 i -current:
patches/packages/mozilla-firefox-102.13.0esr-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/102.13.0/releasenotes/
https://www.mozilla.org/security/advisories/mfsa2023-23/
https://www.cve.org/CVERecord?id=CVE-2023-37201
https://www.cve.org/CVERecord?id=CVE-2023-37202
https://www.cve.org/CVERecord?id=CVE-2023-37207
https://www.cve.org/CVERecord?id=CVE-2023-37208
https://www.cve.org/CVERecord?id=CVE-2023-37211
Napisano: 09 Jul 2023, 18:19
07. VII 2023.
patches/packages/mozilla-thunderbird-102.13.0-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/102.13.0/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2023-24/
Napisano: 26 Jul 2023, 20:15
12. VII 2023.
Sveži krb5 paketi za Slackware 15.0 i -current:
patches/packages/krb5-1.19.2-i586-4_slack15.0.txz: Rebuilt.
Fix potential uninitialized pointer free in kadm5 XDR parsing.
https://www.cve.org/CVERecord?id=CVE-2023-36054
Napisano: 26 Jul 2023, 20:17
19. VII 2023.
Sveži openssh paketi za Slackware 15.0 i -current:
patches/packages/openssh-9.3p2-i586-1_slack15.0.txz: Upgraded.
ssh-agent(1) in OpenSSH between and 5.5 and 9.3p1 (inclusive): remote code
execution relating to PKCS#11 providers.
The PKCS#11 support ssh-agent(1) could be abused to achieve remote code
execution via a forwarded agent socket if the following conditions are met:
* Exploitation requires the presence of specific libraries on the victim
system.
* Remote exploitation requires that the agent was forwarded to an
attacker-controlled system.
Exploitation can also be prevented by starting ssh-agent(1) with an empty
PKCS#11/FIDO allowlist (ssh-agent -P '') or by configuring an allowlist that
contains only specific provider libraries.
This vulnerability was discovered and demonstrated to be exploitable by the
Qualys Security Advisory team.
Potentially-incompatible changes:
* ssh-agent(8): the agent will now refuse requests to load PKCS#11 modules
issued by remote clients by default. A flag has been added to restore the
previous behaviour: "-Oallow-remote-pkcs11".
https://www.openssh.com/txt/release-9.3p2
https://www.cve.org/CVERecord?id=CVE-2023-38408
Sveži curl paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/curl-8.2.0-i586-1_slack15.0.txz: Upgraded.
fopen race condition.
https://curl.se/docs/CVE-2023-32001.html
https://www.cve.org/CVERecord?id=CVE-2023-32001
Napisano: 26 Jul 2023, 20:18
24. VII 2023.
Sveži kernel-firmware paketi za Slackware 14.2, 15.0 i -current:
patches/packages/kernel-firmware-20230724_59fbffa-noarch-1.txz: Upgraded.
AMD microcode updated to fix a use-after-free in AMD Zen2 processors.
From Tavis Ormandy's annoucement of the issue:
"The practical result here is that you can spy on the registers of other
processes. No system calls or privileges are required.
It works across virtual machines and affects all operating systems.
I have written a poc for this issue that's fast enough to reconstruct
keys and passwords as users log in."
https://seclists.org/oss-sec/2023/q3/59
https://www.cve.org/CVERecord?id=CVE-2023-20593
Users browsing this forum: No registered users and 13 guests
