Locked
Post Napisano: 05 Feb 2023, 16:58
02. II 2023.
Sveži openssh paketi Slackware 15.0 i -current:
patches/packages/openssh-9.2p1-i586-1_slack15.0.txz:  Upgraded.
  This release contains fixes for two security problems and a memory safety
  problem. The memory safety problem is not believed to be exploitable, but
  upstream reports most network-reachable memory faults as security bugs.
  This update contains some potentially incompatible changes regarding the
  scp utility. For more information, see:
    https://www.openssh.com/releasenotes.html#9.0
    https://www.openssh.com/releasenotes.html#9.2
Post Napisano: 11 Feb 2023, 17:51
07. II 2023.
Sveži openssl i xorg-server paketi Slackware 15.0 i -current:
patches/packages/openssl-1.1.1t-i586-1_slack15.0.txz:  Upgraded.
  X.400 address type confusion in X.509 GeneralName.
  Timing Oracle in RSA Decryption.
  Use-after-free following BIO_new_NDEF.
  Double free after calling PEM_read_bio_ex.
    https://www.openssl.org/news/secadv/20230207.txt
    https://www.cve.org/CVERecord?id=CVE-2023-0286
    https://www.cve.org/CVERecord?id=CVE-2022-4304
    https://www.cve.org/CVERecord?id=CVE-2023-0215
    https://www.cve.org/CVERecord?id=CVE-2022-4450
patches/packages/openssl-solibs-1.1.1t-i586-1_slack15.0.txz:  Upgraded.
patches/packages/xorg-server-1.20.14-i586-7_slack15.0.txz:  Rebuilt.
  [PATCH] Xi: fix potential use-after-free in DeepCopyPointerClasses.
  Also merged another patch to prevent crashes when using a compositor with
  the NVIDIA blob. Thanks to mdinslage, willysr, and Daedra.
    https://www.cve.org/CVERecord?id=CVE-2023-0494
patches/packages/xorg-server-xephyr-1.20.14-i586-7_slack15.0.txz:  Rebuilt.
patches/packages/xorg-server-xnest-1.20.14-i586-7_slack15.0.txz:  Rebuilt.
patches/packages/xorg-server-xvfb-1.20.14-i586-7_slack15.0.txz:  Rebuilt.
patches/packages/xorg-server-xwayland-21.1.4-i586-6_slack15.0.txz:  Rebuilt.
Post Napisano: 11 Feb 2023, 17:52
10. II 2023.
Sveži gnutls paketi Slackware 15.0 i -current:
patches/packages/gnutls-3.7.9-i586-1_slack15.0.txz:  Upgraded.
  libgnutls: Fix a Bleichenbacher oracle in the TLS RSA key exchange.
  Reported by Hubert Kario (#1050). Fix developed by Alexander Sosedkin.
  [GNUTLS-SA-2020-07-14, CVSS: medium] [CVE-2023-0361]
    https://www.cve.org/CVERecord?id=CVE-2023-0361
Post Napisano: 20 Feb 2023, 23:49
14. II 2023.
Sveži mozilla-firefox i php paketi Slackware 15.0 i -current:
patches/packages/mozilla-firefox-102.8.0esr-i686-1_slack15.0.txz:  Upgraded.
    https://www.mozilla.org/en-US/firefox/102.8.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2023-06/
    https://www.cve.org/CVERecord?id=CVE-2023-25728
    https://www.cve.org/CVERecord?id=CVE-2023-25730
    https://www.cve.org/CVERecord?id=CVE-2023-25743
    https://www.cve.org/CVERecord?id=CVE-2023-0767
    https://www.cve.org/CVERecord?id=CVE-2023-25735
    https://www.cve.org/CVERecord?id=CVE-2023-25737
    https://www.cve.org/CVERecord?id=CVE-2023-25738
    https://www.cve.org/CVERecord?id=CVE-2023-25739
    https://www.cve.org/CVERecord?id=CVE-2023-25729
    https://www.cve.org/CVERecord?id=CVE-2023-25732
    https://www.cve.org/CVERecord?id=CVE-2023-25734
    https://www.cve.org/CVERecord?id=CVE-2023-25742
    https://www.cve.org/CVERecord?id=CVE-2023-25746
patches/packages/php-7.4.33-i586-3_slack15.0.txz:  Rebuilt.
  Core: Password_verify() always return true with some hash.
  Core: 1-byte array overrun in common path resolve code.
  SAPI: DOS vulnerability when parsing multipart request body.
    https://www.cve.org/CVERecord?id=CVE-2023-0567
    https://www.cve.org/CVERecord?id=CVE-2023-0568
    https://www.cve.org/CVERecord?id=CVE-2023-0662
extra/php80/php80-8.0.28-i586-1_slack15.0.txz:  Upgraded.
extra/php81/php81-8.1.16-i586-1_slack15.0.txz:  Upgraded.
Post Napisano: 20 Feb 2023, 23:51
15. II 2023.
Sveži curl i git paketi Slackware 14.0, 14.1, 14.2, 15.0 i current:
patches/packages/curl-7.88.0-i586-1_slack15.0.txz:  Upgraded.
  HTTP multi-header compression denial of service.
  HSTS amnesia with --parallel.
  HSTS ignored on multiple requests.
    https://curl.se/docs/CVE-2023-23916.html
    https://curl.se/docs/CVE-2023-23915.html
    https://curl.se/docs/CVE-2023-23914.html
    https://www.cve.org/CVERecord?id=CVE-2023-23916
    https://www.cve.org/CVERecord?id=CVE-2023-23915
    https://www.cve.org/CVERecord?id=CVE-2023-23914
patches/packages/git-2.35.7-i586-1_slack15.0.txz:  Upgraded.
  Using a specially-crafted repository, Git can be tricked into using
  its local clone optimization even when using a non-local transport.
  Though Git will abort local clones whose source $GIT_DIR/objects
  directory contains symbolic links (c.f., CVE-2022-39253), the objects
  directory itself may still be a symbolic link.
  These two may be combined to include arbitrary files based on known
  paths on the victim's filesystem within the malicious repository's
  working copy, allowing for data exfiltration in a similar manner as
  CVE-2022-39253.
  By feeding a crafted input to "git apply", a path outside the
  working tree can be overwritten as the user who is running "git
  apply".
    https://www.cve.org/CVERecord?id=CVE-2023-22490
    https://www.cve.org/CVERecord?id=CVE-2023-23946
Post Napisano: 20 Feb 2023, 23:52
16. II 2023.
Sveži mozilla-thunderbird paketi Slackware 15.0 i current:
patches/packages/mozilla-thunderbird-102.8.0-i686-1_slack15.0.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/102.8.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2023-07/
    https://www.cve.org/CVERecord?id=CVE-2023-0616
Post Napisano: 20 Feb 2023, 23:53
17. II 2023.
Sveži kernel paketi Slackware 15.0 i current:
patches/packages/linux-5.15.80/*:  Upgraded.
  These updates fix various bugs and security issues.
    Fixed in 5.15.81:
    https://www.cve.org/CVERecord?id=CVE-2022-47519
    https://www.cve.org/CVERecord?id=CVE-2022-47518
    https://www.cve.org/CVERecord?id=CVE-2022-47520
    https://www.cve.org/CVERecord?id=CVE-2022-47521
    https://www.cve.org/CVERecord?id=CVE-2022-3344
    Fixed in 5.15.82:
    https://www.cve.org/CVERecord?id=CVE-2022-45869
    https://www.cve.org/CVERecord?id=CVE-2022-4378
    Fixed in 5.15.83:
    https://www.cve.org/CVERecord?id=CVE-2022-3643
    Fixed in 5.15.84:
    https://www.cve.org/CVERecord?id=CVE-2022-3545
    Fixed in 5.15.85:
    https://www.cve.org/CVERecord?id=CVE-2022-45934
    Fixed in 5.15.86:
    https://www.cve.org/CVERecord?id=CVE-2022-3534
    https://www.cve.org/CVERecord?id=CVE-2022-3424
    Fixed in 5.15.87:
    https://www.cve.org/CVERecord?id=CVE-2022-41218
    https://www.cve.org/CVERecord?id=CVE-2023-23455
    https://www.cve.org/CVERecord?id=CVE-2023-23454
    https://www.cve.org/CVERecord?id=CVE-2023-0045
    https://www.cve.org/CVERecord?id=CVE-2023-0210
    https://www.cve.org/CVERecord?id=CVE-2022-36280
    Fixed in 5.15.88:
    https://www.cve.org/CVERecord?id=CVE-2023-0266
    https://www.cve.org/CVERecord?id=CVE-2022-47929
    Fixed in 5.15.89:
    https://www.cve.org/CVERecord?id=CVE-2023-0179
    https://www.cve.org/CVERecord?id=CVE-2023-0394
    Fixed in 5.15.90:
    https://www.cve.org/CVERecord?id=CVE-2022-4382
    https://www.cve.org/CVERecord?id=CVE-2022-4842
    Fixed in 5.15.91:
    https://www.cve.org/CVERecord?id=CVE-2022-4129
    https://www.cve.org/CVERecord?id=CVE-2023-23559
Post Napisano: 13 Mar 2023, 17:49
08. III 2023.
Sveži httpd paketi za Slackware 14.0, 14.1, 14.2, 15.0 i -current:
patches/packages/httpd-2.4.56-i586-1_slack15.0.txz:  Upgraded.
  HTTP Response Smuggling vulnerability via mod_proxy_uwsgi.
  HTTP Request Smuggling attack via mod_rewrite and mod_proxy.
    https://downloads.apache.org/httpd/CHANGES_2.4.56
    https://www.cve.org/CVERecord?id=CVE-2023-27522
    https://www.cve.org/CVERecord?id=CVE-2023-25690
Post Napisano: 19 Mar 2023, 19:42
14. III 2023.
Sveži mozilla-firefox paketi za Slackware 15.0 i -current:
patches/packages/mozilla-firefox-102.9.0esr-i686-1_slack15.0.txz:  Upgraded.
    https://www.mozilla.org/en-US/firefox/102.9.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2023-10
    https://www.cve.org/CVERecord?id=CVE-2023-25751
    https://www.cve.org/CVERecord?id=CVE-2023-28164
    https://www.cve.org/CVERecord?id=CVE-2023-28162
    https://www.cve.org/CVERecord?id=CVE-2023-25752
    https://www.cve.org/CVERecord?id=CVE-2023-28163
    https://www.cve.org/CVERecord?id=CVE-2023-28176
16. III 2023.
Sveži mozilla-thunderbird i openssh paketi za Slackware 15.0 i -current:
patches/packages/mozilla-thunderbird-102.9.0-i686-1_slack15.0.txz:  Upgraded.
    https://www.mozilla.org/en-US/thunderbird/102.9.0/releasenotes/
    https://www.mozilla.org/en-US/security/advisories/mfsa2023-11/
patches/packages/openssh-9.3p1-i586-1_slack15.0.txz:  Upgraded.
  This release contains fixes for a security problem and a memory
  safety problem. The memory safety problem is not believed to be
  exploitable, but we report most network-reachable memory faults as
  security bugs.
    https://www.openssh.com/txt/release-9.3
Locked
