Napisano: 22 Nov 2022, 20:33
17.XI 2022.
Sveži freerdp paketi za Slackware 15.0 i -current:
patches/packages/freerdp-2.9.0-i586-1_slack15.0.txz: Upgraded.
Fixed multiple client side input validation issues.
https://www.cve.org/CVERecord?id=CVE-2022-39316
https://www.cve.org/CVERecord?id=CVE-2022-39317
https://www.cve.org/CVERecord?id=CVE-2022-39318
https://www.cve.org/CVERecord?id=CVE-2022-39319
https://www.cve.org/CVERecord?id=CVE-2022-39320
https://www.cve.org/CVERecord?id=CVE-2022-41877
https://www.cve.org/CVERecord?id=CVE-2022-39347
Napisano: 27 Nov 2022, 22:37
24. XI 2022.
Sveži ruby paketi za Slackware 15.0 i -current:
patches/packages/ruby-3.0.5-i586-1_slack15.0.txz: Upgraded.
This release includes a security fix:
HTTP response splitting in CGI.
https://www.cve.org/CVERecord?id=CVE-2021-33621
Napisano: 04 Dec 2022, 21:58
29. XI 2022.
Sveži kernel paketi za Slackware 15.0:
patches/packages/linux-5.15.80/*: Upgraded.
These updates fix various bugs and security issues.
Fixed in 5.15.63:
https://www.cve.org/CVERecord?id=CVE-2022-3629
https://www.cve.org/CVERecord?id=CVE-2022-3635
https://www.cve.org/CVERecord?id=CVE-2022-3633
https://www.cve.org/CVERecord?id=CVE-2022-3625
Fixed in 5.15.64:
https://www.cve.org/CVERecord?id=CVE-2022-39190
https://www.cve.org/CVERecord?id=CVE-2022-3028
https://www.cve.org/CVERecord?id=CVE-2022-2905
Fixed in 5.15.65:
https://www.cve.org/CVERecord?id=CVE-2022-42703
https://www.cve.org/CVERecord?id=CVE-2022-3176
Fixed in 5.15.66:
https://www.cve.org/CVERecord?id=CVE-2022-4095
https://www.cve.org/CVERecord?id=CVE-2022-20421
Fixed in 5.15.68:
https://www.cve.org/CVERecord?id=CVE-2022-3303
https://www.cve.org/CVERecord?id=CVE-2022-2663
https://www.cve.org/CVERecord?id=CVE-2022-40307
https://www.cve.org/CVERecord?id=CVE-2022-3586
Fixed in 5.15.70:
https://www.cve.org/CVERecord?id=CVE-2022-0171
https://www.cve.org/CVERecord?id=CVE-2022-39842
https://www.cve.org/CVERecord?id=CVE-2022-3061
Fixed in 5.15.72:
https://www.cve.org/CVERecord?id=CVE-2022-2308
Fixed in 5.15.73:
https://www.cve.org/CVERecord?id=CVE-2022-2978
https://www.cve.org/CVERecord?id=CVE-2022-43750
Fixed in 5.15.74:
https://www.cve.org/CVERecord?id=CVE-2022-40768
https://www.cve.org/CVERecord?id=CVE-2022-42721
https://www.cve.org/CVERecord?id=CVE-2022-3621
https://www.cve.org/CVERecord?id=CVE-2022-42722
https://www.cve.org/CVERecord?id=CVE-2022-42719
https://www.cve.org/CVERecord?id=CVE-2022-41674
https://www.cve.org/CVERecord?id=CVE-2022-3649
https://www.cve.org/CVERecord?id=CVE-2022-3646
https://www.cve.org/CVERecord?id=CVE-2022-42720
Fixed in 5.15.75:
https://www.cve.org/CVERecord?id=CVE-2022-43945
https://www.cve.org/CVERecord?id=CVE-2022-41849
https://www.cve.org/CVERecord?id=CVE-2022-3535
https://www.cve.org/CVERecord?id=CVE-2022-3594
https://www.cve.org/CVERecord?id=CVE-2022-2602
https://www.cve.org/CVERecord?id=CVE-2022-41850
https://www.cve.org/CVERecord?id=CVE-2022-3565
https://www.cve.org/CVERecord?id=CVE-2022-3542
Fixed in 5.15.77:
https://www.cve.org/CVERecord?id=CVE-2022-3524
Fixed in 5.15.78:
https://www.cve.org/CVERecord?id=CVE-2022-3628
https://www.cve.org/CVERecord?id=CVE-2022-3623
https://www.cve.org/CVERecord?id=CVE-2022-42896
https://www.cve.org/CVERecord?id=CVE-2022-42895
https://www.cve.org/CVERecord?id=CVE-2022-3543
https://www.cve.org/CVERecord?id=CVE-2022-3564
https://www.cve.org/CVERecord?id=CVE-2022-3619
Fixed in 5.15.80:
https://www.cve.org/CVERecord?id=CVE-2022-3521
https://www.cve.org/CVERecord?id=CVE-2022-3169
Napisano: 04 Dec 2022, 21:59
02.XII 2022.
patches/packages/mozilla-thunderbird-102.5.1-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/102.5.1/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2022-50/
https://www.cve.org/CVERecord?id=CVE-2022-45414
Napisano: 11 Dec 2022, 22:20
07. XII 2022.
Sveži python3 paketi za Slackware 15.0 i -current:
patches/packages/python3-3.9.16-i586-1_slack15.0.txz: Upgraded.
gh-98739: Updated bundled libexpat to 2.5.0 to fix CVE-2022-43680
(heap use-after-free).
gh-98433: The IDNA codec decoder used on DNS hostnames by socket or asyncio
related name resolution functions no longer involves a quadratic algorithm
to fix CVE-2022-45061. This prevents a potential CPU denial of service if an
out-of-spec excessive length hostname involving bidirectional characters were
decoded. Some protocols such as urllib http 3xx redirects potentially allow
for an attacker to supply such a name.
gh-100001: python -m http.server no longer allows terminal control characters
sent within a garbage request to be printed to the stderr server log.
gh-87604: Avoid publishing list of active per-interpreter audit hooks via the
gc module.
gh-97514: On Linux the multiprocessing module returns to using filesystem
backed unix domain sockets for communication with the forkserver process
instead of the Linux abstract socket namespace. Only code that chooses to use
the "forkserver" start method is affected. This prevents Linux CVE-2022-42919
(potential privilege escalation) as abstract sockets have no permissions and
could allow any user on the system in the same network namespace (often the
whole system) to inject code into the multiprocessing forkserver process.
Filesystem based socket permissions restrict this to the forkserver process
user as was the default in Python 3.8 and earlier.
gh-98517: Port XKCP's fix for the buffer overflows in SHA-3 to fix
CVE-2022-37454.
gh-68966: The deprecated mailcap module now refuses to inject unsafe text
(filenames, MIME types, parameters) into shell commands to address
CVE-2015-20107. Instead of using such text, it will warn and act as if a
match was not found (or for test commands, as if the test failed).
https://pythoninsider.blogspot.com/2022/12/python-3111-3109-3916-3816-3716-and.html
https://www.cve.org/CVERecord?id=CVE-2022-43680
https://www.cve.org/CVERecord?id=CVE-2022-45061
https://www.cve.org/CVERecord?id=CVE-2022-42919
https://www.cve.org/CVERecord?id=CVE-2022-37454
https://www.cve.org/CVERecord?id=CVE-2015-20107
Napisano: 11 Dec 2022, 22:21
08. XII 2022.
Sveži emacs i vim paketi za Slackware 15.0 i -current:
patches/packages/emacs-27.2-i586-2_slack15.0.txz: Rebuilt.
GNU Emacs through 28.2 allows attackers to execute commands via shell
metacharacters in the name of a source-code file, because lib-src/etags.c
uses the system C library function in its implementation of the ctags
program. For example, a victim may use the "ctags *" command (suggested in
the ctags documentation) in a situation where the current working directory
has contents that depend on untrusted input.
https://www.cve.org/CVERecord?id=CVE-2022-45939
patches/packages/vim-9.0.1034-i586-1_slack15.0.txz: Upgraded.
This update fixes various security issues such as a heap-based buffer
overflow and use after free.
https://www.cve.org/CVERecord?id=CVE-2022-4141
https://www.cve.org/CVERecord?id=CVE-2022-3591
https://www.cve.org/CVERecord?id=CVE-2022-3520
https://www.cve.org/CVERecord?id=CVE-2022-3491
https://www.cve.org/CVERecord?id=CVE-2022-4292
https://www.cve.org/CVERecord?id=CVE-2022-4293
patches/packages/vim-gvim-9.0.1034-i586-1_slack15.0.txz: Upgraded.
Napisano: 11 Dec 2022, 22:22
09. XII 2022.
Sveži libarchive paketi za Slackware 14.1, 14.2, 15.0 i -current:
patches/packages/libarchive-3.6.2-i586-1_slack15.0.txz: Upgraded.
This is a bugfix and security release.
Relevant bugfixes:
rar5 reader: fix possible garbled output with bsdtar -O (#1745)
mtree reader: support reading mtree files with tabs (#1783)
Security fixes:
various small fixes for issues found by CodeQL
Napisano: 19 Dec 2022, 22:46
14. XII 2022.
Sveži mozila-firefox paketi za Slackware 15.0:
patches/packages/mozilla-firefox-102.6.0esr-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/firefox/102.6.0/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2022-52/
https://www.cve.org/CVERecord?id=CVE-2022-46880
https://www.cve.org/CVERecord?id=CVE-2022-46872
https://www.cve.org/CVERecord?id=CVE-2022-46881
https://www.cve.org/CVERecord?id=CVE-2022-46874
https://www.cve.org/CVERecord?id=CVE-2022-46875
https://www.cve.org/CVERecord?id=CVE-2022-46882
https://www.cve.org/CVERecord?id=CVE-2022-46878
Sveži mozilla-thunderbird i xorg-server paketi za Slackware 15.0 i -current:
patches/packages/mozilla-thunderbird-102.6.0-i686-1_slack15.0.txz: Upgraded.
https://www.mozilla.org/en-US/thunderbird/102.6.0/releasenotes/
https://www.mozilla.org/en-US/security/advisories/mfsa2022-53/
patches/packages/xorg-server-1.20.14-i586-5_slack15.0.txz: Rebuilt.
This release fixes 6 recently reported security vulnerabilities in
various extensions.
https://lists.x.org/archives/xorg-announce/2022-December/003302.html
https://www.cve.org/CVERecord?id=CVE-2022-46340
https://www.cve.org/CVERecord?id=CVE-2022-46341
https://www.cve.org/CVERecord?id=CVE-2022-46342
https://www.cve.org/CVERecord?id=CVE-2022-46343
https://www.cve.org/CVERecord?id=CVE-2022-46344
https://www.cve.org/CVERecord?id=CVE-2022-4283
patches/packages/xorg-server-xephyr-1.20.14-i586-5_slack15.0.txz: Rebuilt.
patches/packages/xorg-server-xnest-1.20.14-i586-5_slack15.0.txz: Rebuilt.
patches/packages/xorg-server-xvfb-1.20.14-i586-5_slack15.0.txz: Rebuilt.
patches/packages/xorg-server-xwayland-21.1.4-i586-4_slack15.0.txz: Rebuilt.
various extensions.
Napisano: 19 Dec 2022, 22:48
17. XII 2022.
Sveži samba paketi za Slackware 15.0 i -current:
patches/packages/samba-4.15.13-i586-1_slack15.0.txz: Upgraded.
This is the Samba CVE for the Windows Kerberos RC4-HMAC Elevation of
Privilege Vulnerability disclosed by Microsoft on Nov 8 2022.
A Samba Active Directory DC will issue weak rc4-hmac session keys for
use between modern clients and servers despite all modern Kerberos
implementations supporting the aes256-cts-hmac-sha1-96 cipher.
On Samba Active Directory DCs and members
'kerberos encryption types = legacy'
would force rc4-hmac as a client even if the server supports
aes128-cts-hmac-sha1-96 and/or aes256-cts-hmac-sha1-96.
This is the Samba CVE for the Windows Kerberos Elevation of Privilege
A service account with the special constrained delegation permission
could forge a more powerful ticket than the one it was presented with.
The "RC4" protection of the NetLogon Secure channel uses the same
algorithms as rc4-hmac cryptography in Kerberos, and so must also be
assumed to be weak.
Since the Windows Kerberos RC4-HMAC Elevation of Privilege Vulnerability
was disclosed by Microsoft on Nov 8 2022 and per RFC8429 it is assumed
that rc4-hmac is weak, Vulnerable Samba Active Directory DCs will issue
rc4-hmac encrypted tickets despite the target server supporting better
encryption (eg aes256-cts-hmac-sha1-96).
Note that there are several important behavior changes included in this
release, which may cause compatibility problems interacting with system
still expecting the former behavior.
Please read the advisories of CVE-2022-37966, CVE-2022-37967 and
CVE-2022-38023 carefully!
https://www.samba.org/samba/security/CVE-2022-37966.html
https://www.samba.org/samba/security/CVE-2022-37967.html
https://www.samba.org/samba/security/CVE-2022-38023.html
https://www.samba.org/samba/security/CVE-2022-45141.html
https://www.cve.org/CVERecord?id=CVE-2022-37966
https://www.cve.org/CVERecord?id=CVE-2022-37967
https://www.cve.org/CVERecord?id=CVE-2022-38023
https://www.cve.org/CVERecord?id=CVE-2022-45141
Napisano: 25 Dec 2022, 09:41
20. XII 2022.
Sveži libksba i sdl paketi za Slackware 14.2, 15.0 i -current:
patches/packages/libksba-1.6.3-i586-1_slack15.0.txz: Upgraded.
Fix another integer overflow in the CRL's signature parser.
patches/packages/sdl-1.2.15-i586-13_slack15.0.txz: Rebuilt.
This update fixes a heap overflow problem in video/SDL_pixels.c in SDL.
By crafting a malicious .BMP file, an attacker can cause the application
using this library to crash, denial of service, or code execution.
https://www.cve.org/CVERecord?id=CVE-2021-33657
