slackpkg+
Post Napisano: 29 Jul 2014, 22:40
Samo da dopunim prethodni post:
2014-07-29 23:31:11 URL:http://rlworkman.net/pkgs/14.1/GPG-KEY [3179/3179] -> "/tmp/slackpkg.PKU9Tv/gpgkey-tmp" [1]
gpg: key FEA5B2FB: public key "Robby Workman <rworkman@slackware.com>" imported
gpg: Total number processed: 1
gpg:               imported: 1
gpg: no ultimately trusted keys found
                        Slackware Linux Project's GPG key added
Post Napisano: 30 Jul 2014, 00:06
Hvala ti puno stereo. :beer:
Ipak, ti verovatno radiš nešto što ja ne radim jer meni to ne radi.. :D
Meni izbacuje ovo:
root@laptopic:/home/ivan# slackpkg update gpg
2014-07-30 00:53:15 URL: ftp://ftp.fu-berlin.de/unix/linux/slack ... .1/GPG-KEY" onclick="window.open(this.href);return false; [1572] -> "/tmp/slackpkg.mhxc5y/gpgkey" [1]
2014-07-30 00:53:15 URL:http://slakfinder.org/slackpkg+/GPG-KEY [1823/1823] -> "/tmp/slackpkg.mhxc5y/gpgkey-tmp" [1]
gpg: key ED123FBC: "Matteo Rossini <zerouno@slacky.it>" not changed
gpg: unchanged: 1
2014-07-30 00:53:16 URL:http://taper.alienbase.nl/mirrors/peopl ... 86/GPG-KEY [11482/11482] -> "/tmp/slackpkg.mhxc5y/gpgkey-tmp" [1]
gpg: key A75CBDA0: "Eric Hameleers <alien@slackware.com>" not changed
gpg: unchanged: 1
2014-07-30 00:53:17 URL:http://taper.alienbase.nl/mirrors/peopl ... 86/GPG-KEY [11482/11482] -> "/tmp/slackpkg.mhxc5y/gpgkey-tmp" [1]
gpg: unchanged: 1
2014-07-30 00:53:17 URL:http://repository.slacky.eu/slackware-14.1/GPG-KEY [1760/1760] -> "/tmp/slackpkg.mhxc5y/gpgkey-tmp" [1]
gpg: key D153E90E: "Slacky.eu packagers (packages by Slacky.eu) <packages@slacky.it>" not changed
gpg: unchanged: 1
http://rlworkman.net/pkgs/14.1/i486/GPG-KEY" onclick="window.open(this.href);return false;:
2014-07-30 00:53:18 ERROR 404: Not Found.
!!! W A R N I N G !!!
Repository 'rlworkman' does NOT contain the GPG-KEY
You SHOULD disable GPG check by setting 'CHECKGPG=off'
in /etc/slackpkg/slackpkg.conf or use slackpkg with
'-checkgpg=off' : 'slackpkg -checkgpg=off install packge'
slackpkgplus.conf mi izgleda ovako:
# Enable (on) / Disable (off) slackpkg+
SLACKPKGPLUS=on
# set to '0' to never show the download progress bar
# set to '1' to show the bar only in download packages (default)
# set to '2' to always show the download bar
# set to '3' for a debug mode
VERBOSE=1
# Enable (1) / Disable (0) the official slackpkg blacklist. May be useful to temporarily skip
# the slackware blacklist. You can also override it from command line:
# 'USEBL=0 slackpkg upgrade-all'
USEBL=1
# Add custom option to 'wget'.
# You can solve the repository indisponibility issue by set a timeout here
WGETOPTS="--timeout=5 --tries=1"
# Enable (on) / Disable (off) notification events (see notifymsg.conf)
#ENABLENOTIFY=off
# Enable (on) / Disable (off) the greylist feature. See /etc/slackpkg/greylist
GREYLIST=on
# If two or more repositories contains some same packages, you can specify
# from which repository you prefer to search it.
# The syntax is "<repository_name>:<package_name>"
# Accepts regular expressions. To give priority to an entire repository use "<repository_name>:.*"
# Examples:
#PKGS_PRIORITY=( restricted:vlc )
#PKGS_PRIORITY=( myrepo:.* )
# List repositories you want to use (defined below)
# remember to launch 'slackpkg update' if you modify that row.
REPOPLUS=( slackpkgplus restricted alienbob slacky rlworkman )
# Define mirrors (uncomment one or more mirror; remember to add it to REPOPLUS)
# Note: only multilib,alienbob,restricted,slacky repositories support GPG. If you add others
# you may need to disable gpg check in slackpkg.conf
# Slackware 14.1 - i386
MIRRORPLUS['alienbob']=http://taper.alienbase.nl/mirrors/peopl ... /14.1/x86/
MIRRORPLUS['restricted']=http://taper.alienbase.nl/mirrors/peopl ... /14.1/x86/
MIRRORPLUS['slacky']=http://repository.slacky.eu/slackware-14.1/
MIRRORPLUS['rlworkman']=http://rlworkman.net/pkgs/14.1/i486/
# use this to keep the slackpkg+ package updated
MIRRORPLUS['slackpkgplus']=http://slakfinder.org/slackpkg+/
# Local repository:
#MIRRORPLUS['alienbob']=file://repositories/alien/sbrepos/14.1/x86/
# Local packages (you do not need metadata nor 'slackpkg update' command):
#MIRRORPLUS['myrepo']=dir://repositories/mypackages/
# Supported Repositories (see /usr/doc/slackpkg+-* for details):
#Supports GPG
#slackpkgplus: http://slakfinder.org/slackpkg+/" onclick="window.open(this.href);return false;
#multilib: http://taper.alienbase.nl/mirrors/peopl ... /multilib/" onclick="window.open(this.href);return false;{13.37,14.0,14.1,current}/
#alienbob: http://taper.alienbase.nl/mirrors/people/alien/sbrepos/" onclick="window.open(this.href);return false;{13.37,14.0,14.1,current}/{x86,x86_64}/
#ktown: http://taper.alienbase.nl/mirrors/alien-kde/" onclick="window.open(this.href);return false;{13.37,14.0,14.1,current}/latest/{x86,x86_64}/
#restricted: http://taper.alienbase.nl/mirrors/peopl ... d_sbrepos/" onclick="window.open(this.href);return false;{13.37,14.0,14.1,current}/{x86,x86_64}/
#slacky: http://repository.slacky.eu/slackware" onclick="window.open(this.href);return false;{,64}-{13.37,14.0,14.1}/
#mled: http://www.microlinux.fr/slackware/MLED-" onclick="window.open(this.href);return false;{14.0,14.1}-{32,64}bit/
#mles: http://www.microlinux.fr/slackware/MLES-" onclick="window.open(this.href);return false;{14.0,14.1}-{32,64}bit/
#msb: http://slackware.org.uk/msb/" onclick="window.open(this.href);return false;{14.0,14.1}/{1.6,1.8}/{x86,x86_64}/
#slackers: http://www.slackers.it/repository/" onclick="window.open(this.href);return false;
#slacke17: http://ngc891.blogdns.net/pub/slacke17/slackware" onclick="window.open(this.href);return false;{,64,arm}-{14.0,14.1}/
#studioware: http://studioware.org/files/packages/slackware" onclick="window.open(this.href);return false;{,64}-{13.37,14.0,14.1}/
#slackonly: http://slackonly.com/pub/packages/14.1-x86_64/" onclick="window.open(this.href);return false;
#rlworkman(*): http://rlworkman.net/pkgs/" onclick="window.open(this.href);return false;{13.37,14.0,14.1}/
#Does NOT support GPG
#salixos(*): http://download.salixos.org/" onclick="window.open(this.href);return false;{i486,x86_64}/{13.37,14.0,14.1}/
#salixext: http://people.salixos.org/ralvex/repository/x86_64/" onclick="window.open(this.href);return false;{14.0,14.1}/
#slackel: http://www.slackel.gr/repo/" onclick="window.open(this.href);return false;{i486,x86_64}/current/
Ubacio "rlworkman" u repoplus, ubacio link u mirrors, kopirao "rlworkman" liniju iz don`t support gpg u support gpg..
Workmanov repo bih koristio za XFCE pošto ga imam uz awesome na laptopu. U principu nema ništa specijalno što ne bih našao na slackbuilds ali čitajući danas Jetijev tekst vidim da su se alien i workman "podelili". Alienov repo je više za KDE dok Workman fura KDE više. Rekoh, zašto da ne, brže je nego da čekam da se instalira iz sorsa (slackbuilds) i rešim da to podesim.. :)
Mada mi nije jasan fazon uopšte.. Recimo deo gde podržava GPG stoji i alienov repo i slacky a ispred njih taraba. Taraba stojih ispred svega. Sad ne znam šta onda ona tu predstavlja? Prilikom apdejta najnormalnije skida ključeve (osm workmanovog).
Post Napisano: 30 Jul 2014, 00:10
Znam tačno gde si pogrešio, ne brini i ja sam ali sam zaboravio da napomenem, izvini :)
treba da bude
Post Napisano: 30 Jul 2014, 13:15
Radi. Hvala bratac.. :beer:
Post Napisano: 30 Jul 2014, 13:20
Nema na čemu, kad god mogu :)
Post Napisano: 02 Aug 2014, 23:16
Jel vam se dešava u zadnja dva dana error pri upgrade-all? Mene nešto zeza workmanov repo..
  WARNING! One or more errors occurred while slackpkg was running
texi2html-5.0-i486-1_rlw.txz.asc:	md5sum
xfce4-datetime-plugin-0.6.1-i486-1_rlw.txz.asc:	md5sum
xfce4-xkb-plugin-0.5.6-i486-1_rlw.txz.asc:	md5sum
Post Napisano: 03 Aug 2014, 11:40
Upravo sam uradio update, nemam nikakavih problema. Workamanove pakete ne koristim pa nisam siguran kako bih ti pomogao. Xfce4-xkb-plugin uvek kompajliram sa slackbuilds.org, kratko traje.
Ako uhvatim malo vremena pa da pogledam detaljnije ali sad teško da mogu da budem od koristi.
Post Napisano: 03 Aug 2014, 17:35
Nikakva frka i žurba. Znam da nije neka velika greška, dešava se s vremena na vreme. Bio sam na wifi, ume signal nekada malo da oslabi pa se javljaju razne greščice.. ;)
Post Napisano: 03 Aug 2014, 19:15
Lepo piše sve u .conf fajlu ali kada je neko slepac pa ne čita ono što su ljudi lepo napisali.. :)
Fazon je u tome što samo multilib, alien, slacky i restricted podržavaju GPG. Ako se u repoplus i mirrors ubaci neki repo koji to ne podržava (workman na primer) mora da se isključi GPG check u slackpkg.conf, tj.da se stavi na off.
Onda više nema problema. ;)
Post Napisano: 01 Dec 2014, 15:01
Pozdrav :azn: ,
Nadam se da ne dižem iz mrtvih temu, ali ne mogu naći gdje griješim:
slackpkg update gpg
2014-12-01 14:46:40 URL: ftp://odysseus.linux.cz/pub/linux/slackware/slackware64-14.1/GPG-KEY [1572] -> "/tmp/slackpkg.xNtl8s/gpgkey" [1]
wget: unable to resolve host address ‘slakfinder.org’
    Repository 'slackpkgplus' does NOT contain the GPG-KEY
wget: unable to resolve host address ‘taper.alienbase.nl’
    Repository 'multilib' does NOT contain the GPG-KEY
    Repository 'restricted' does NOT contain the GPG-KEY
    Repository 'alienbob' does NOT contain the GPG-KEY
wget: unable to resolve host address ‘repository.slacky.eu’
    Repository 'slacky' does NOT contain the GPG-KEY
wget: unable to resolve host address ‘rlworkman.net’
Instalirao sam zadnji slackpkg+ i dešava se ovo gore.
Da ne bude zabune, dodao sam i workman repo a potom dodao opciju CHECKGPG=off (pa i da nisam, ne bi trebalo biti greške za ostale repoe - default)
Ništa drugačije nije u /etc/slackpkg/slackpkgplus.conf (da ne postam sve, jer se ne razlikuje od vaših ovdje)
# Slackware 14.1 - x86_64
MIRRORPLUS['multilib']=http://taper.alienbase.nl/mirrors/people/alien/multilib/14.1/
MIRRORPLUS['alienbob']=http://taper.alienbase.nl/mirrors/people/alien/sbrepos/14.1/x86_64/
MIRRORPLUS['restricted']=http://taper.alienbase.nl/mirrors/people/alien/restricted_sbrepos/14.1/x86_64/
MIRRORPLUS['slacky']=http://repository.slacky.eu/slackware64-14.1/
