$ ls /var/log/packages/ | grep open
openjdk-7u40_b31-x86_64-1alien
openjre-7u40_b31-x86_64-1alienModerator: Urednik
Piše na više mesta u temi, pogotovo u prvom postu.bocke wrote:Nisi napisao šta je šta.
Potreban vam je jedan od paketa: OpenJDK ili OpenJRE. OpenJRE sadrži samo runtime okruženje. OpenJDK već *uključuje* JRE, zajedno sa razvojnim okruženjem za razvoj JAVA aplikacija. Rhino je zavisnost OpenJDK, ali ne i OpenJRE. IcedTea je plugin za web browsere.
Preuzimanja sa standardnih lokacija:- S8006900, CVE-2013-3829: Add new date/time capability
- S8008589: Better MBean permission validation
- S8011071, CVE-2013-5780: Better crypto provider handling
- S8011081, CVE-2013-5772: Improve jhat
- S8011157, CVE-2013-5814: Improve CORBA portablility
- S8012071, CVE-2013-5790: Better Building of Beans
- S8012147: Improve tool support
- S8012277: CVE-2013-5849: Improve AWT DataFlavor
- S8012425, CVE-2013-5802: Transform TransformerFactory
- S8013503, CVE-2013-5851: Improve stream factories
- S8013506: Better Pack200 data handling
- S8013510, CVE-2013-5809: Augment image writing code
- S8013514: Improve stability of cmap class
- S8013739, CVE-2013-5817: Better LDAP resource management
- S8013744, CVE-2013-5783: Better tabling for AWT
- S8014085: Better serialization support in JMX classes
- S8014093, CVE-2013-5782: Improve parsing of images
- S8014098: Better profile validation
- S8014102, CVE-2013-5778: Improve image conversion
- S8014341, CVE-2013-5803: Better service from Kerberos servers
- S8014349, CVE-2013-5840: (cl) Class.getDeclaredClass problematic in some class loader configurations
- S8014530, CVE-2013-5825: Better digital signature processing
- S8014534: Better profiling support
- S8014987, CVE-2013-5842: Augment serialization handling
- S8015614: Update build settings
- S8015731: Subject java.security.auth.subject to improvements
- S8015743, CVE-2013-5774: Address internet addresses
- S8016256: Make finalization final
- S8016653, CVE-2013-5804: javadoc should ignore ignoreable characters in names
- S8016675, CVE-2013-5797: Make Javadoc pages more robust
- S8017196, CVE-2013-5850: Ensure Proxies are handled appropriately
- S8017287, CVE-2013-5829: Better resource disposal
- S8017291, CVE-2013-5830: Cast Proxies Aside
- S8017298, CVE-2013-4002: Better XML support
- S8017300, CVE-2013-5784: Improve Interface Implementation
- S8017505, CVE-2013-5820: Better Client Service
- S8019292: Better Attribute Value Exceptions
- S8019617: Better view of objects
- S8020293: JVM crash
- S8021275, CVE-2013-5805: Better screening for ScreenMenu
- S8021282, CVE-2013-5806: Better recycling of object instances
- S8021286: Improve MacOS resourcing
- S8021290, CVE-2013-5823: Better signature validation
- S8022931, CVE-2013-5800: Enhance Kerberos exceptions
- S8022940: Enhance CORBA translations
- S8023683: Enhance class file parsing
OpenJDK i OpenJRE —> http://taper.alienbase.nl/mirrors/peopl ... s/openjdk/" onclick="window.open(this.href);return false;* Security fixes
- S6727821: Enhance JAAS Configuration
- S7068126, CVE-2014-0373: Enhance SNMP statuses
- S8010935: Better XML handling
- S8011786, CVE-2014-0368: Better applet networking
- S8021257, S8025022, CVE-2013-5896 : com.sun.corba.se.** should be on restricted package list
- S8021271, S8021266, CVE-2014-0408: Better buffering in ObjC code
- S8022904: Enhance JDBC Parsers
- S8022927: Input validation for byte/endian conversions
- S8022935: Enhance Apache resolver classes
- S8022945: Enhance JNDI implementation classes
- S8023057: Enhance start up image display
- S8023069, CVE-2014-0411: Enhance TLS connections
- S8023245, CVE-2014-0423: Enhance Beans decoding
- S8023301: Enhance generic classes
- S8023338: Update jarsigner to encourage timestamping
- S8023672: Enhance jar file validation
- S8024302: Clarify jar verifications
- S8024306, CVE-2014-0416: Enhance Subject consistency
- S8024530: Enhance font process resilience
- S8024867: Enhance logging start up
- S8025014: Enhance Security Policy
- S8025018, CVE-2014-0376: Enhance JAX-P set up
- S8025026, CVE-2013-5878: Enhance canonicalization
- S8025034, CVE-2013-5907: Improve layout lookups
- S8025448: Enhance listening events
- S8025758, CVE-2014-0422: Enhance Naming management
- S8025767, CVE-2014-0428: Enhance IIOP Streams
- S8026172: Enhance UI Management
- S8026176: Enhance document printing
- S8026193, CVE-2013-5884: Enhance CORBA stub factories
- S8026204: Enhance auth login contexts
- S8026417, CVE-2013-5910: Enhance XML canonicalization
- S8026502: java/lang/invoke/MethodHandleConstants.java fails on all platforms
- S8027201, CVE-2014-0376: Enhance JAX-P set up
- S8029507, CVE-2013-5893: Enhance JVM method processing
- S8029533: REGRESSION: closed/java/lang/invoke/8008140/Test8008140.java fails agains
* Bug fixes
- PR1618: Include defs.make in vm.make so VM_LITTLE_ENDIAN is defined on Zero builds
- D729448: 32-bit alignment on mips and mipsel
- PR1623: Collision between OpenJDK 6 & 7 classes when bootstrapping with OpenJDK 6
Users browsing this forum: Claude User [Bot] and 22 guests
