Napisano: 24 Dec 2016, 10:41
21.11.2016.
Sveži ntp paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/ntp-4.2.8p9-i586-1_slack14.2.txz: Upgraded.
In addition to bug fixes and enhancements, this release fixes the
following 1 high- (Windows only :-), 2 medium-, 2 medium-/low, and
5 low-severity vulnerabilities, and provides 28 other non-security
fixes and improvements.
CVE-2016-9311: Trap crash
CVE-2016-9310: Mode 6 unauthenticated trap info disclosure and DDoS vector
CVE-2016-7427: Broadcast Mode Replay Prevention DoS
CVE-2016-7428: Broadcast Mode Poll Interval Enforcement DoS
CVE-2016-9312: Windows: ntpd DoS by oversized UDP packet
CVE-2016-7431: Regression: 010-origin: Zero Origin Timestamp Bypass
CVE-2016-7434: Null pointer dereference in _IO_str_init_static_internal()
CVE-2016-7429: Interface selection attack
CVE-2016-7426: Client rate limiting and server responses
CVE-2016-7433: Reboot sync calculation problem
https://www.kb.cert.org/vuls/id/633847
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9311
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9310
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-7427
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-7428
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9312
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-7431
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-7434
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-7429
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-7426
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-7433
Napisano: 24 Dec 2016, 10:42
01.12.2016.
Sveži mozilla-firefox i mozilla-thunderbird paketi za Slackware 14.1, 14.2 i -current:
patches/packages/mozilla-firefox-45.5.1esr-i586-1_slack14.2.txz: Upgraded.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9079
patches/packages/mozilla-thunderbird-45.5.1-i586-1_slack14.2.txz: Upgraded.
https://www.mozilla.org/security/known-vulnerabilities/thunderbird.html
Napisano: 24 Dec 2016, 10:49
12.12.2016.
Sveži php i mcabber paketi za Slackware 14.0, 14.1, 14,2 i -current:
patches/packages/loudmouth-1.5.3-i586-1_slack14.2.txz: Upgraded.
This update is needed for the mcabber security update.
patches/packages/mcabber-1.0.4-i586-1_slack14.2.txz: Upgraded.
This update fixes a security issue which can lead to a malicious actor
MITMing a conversation, or adding themselves as an entity on a third
parties roster (thereby granting themselves the associated priviledges
such as observing when the user is online).
https://gultsch.de/gajim_roster_push_and_message_interception.html
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9928
patches/packages/php-5.6.29-i586-1_slack14.2.txz: Upgraded.
https://php.net/ChangeLog-5.php#5.6.29
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9933
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9934
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9935
Sveži kernel paketi za Slackware 14.2 i -current:
patches/packages/linux-4.4.38/*: Upgraded.
This kernel fixes a security issue with a race condition in
net/packet/af_packet.c that can be exploited to gain kernel code execution
from unprivileged processes.
Thanks to Philip Pettersson for discovering the bug and providing a patch.
https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/?id=84ac7260236a49c79eede91617700174c2c19b0c
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-8655
Napisano: 24 Dec 2016, 10:51
13.12.2016.
Sveži mozila-firefox paketi za Slackware 14.1, 14.2 i -current:
patches/packages/mozilla-firefox-45.6.0esr-i586-1_slack14.2.txz: Upgraded.
Napisano: 24 Dec 2016, 10:54
23.12.2016.
Sveži httpd paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/httpd-2.4.25-i586-1_slack14.2.txz: Upgraded.
This update fixes the following security issues:
* CVE-2016-8740: mod_http2: Mitigate DoS memory exhaustion via endless
CONTINUATION frames.
* CVE-2016-5387: core: Mitigate [f]cgi "httpoxy" issues.
* CVE-2016-2161: mod_auth_digest: Prevent segfaults during client entry
allocation when the shared memory space is exhausted.
* CVE-2016-0736: mod_session_crypto: Authenticate the session data/cookie
with a MAC (SipHash) to prevent deciphering or tampering with a padding
oracle attack.
* CVE-2016-8743: Enforce HTTP request grammar corresponding to RFC7230 for
request lines and request headers, to prevent response splitting and
cache pollution by malicious clients or downstream proxies.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-8740
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5387
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2161
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0736
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-8743
Sveži openssh paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2, i -current:
patches/packages/openssh-7.4p1-i586-1_slack14.2.txz: Upgraded.
This is primarily a bugfix release, and also addresses security issues.
ssh-agent(1): Will now refuse to load PKCS#11 modules from paths outside
a trusted whitelist.
sshd(8): When privilege separation is disabled, forwarded Unix-domain
sockets would be created by sshd(8) with the privileges of 'root'.
sshd(8): Avoid theoretical leak of host private key material to
privilege-separated child processes via realloc().
sshd(8): The shared memory manager used by pre-authentication compression
support had a bounds checks that could be elided by some optimising
compilers to potentially allow attacks against the privileged monitor.
process from the sandboxed privilege-separation process.
sshd(8): Validate address ranges for AllowUser and DenyUsers directives at
configuration load time and refuse to accept invalid ones. It was
previously possible to specify invalid CIDR address ranges
(e.g. user@127.1.2.3/55) and these would always match, possibly resulting
in granting access where it was not intended.
https://www.openssh.com/txt/release-7.4
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-10009
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-10010
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-10011
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-10012
Napisano: 22 Jan 2017, 17:24
24.12.2016.
Novi expat paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/expat-2.2.0-i586-1_slack14.2.txz: Upgraded.
Multiple integer overflows in XML_GetBuffer.
Fix crash on malformed input.
Improve insufficient fix to CVE-2015-1283 / CVE-2015-2716.
Use more entropy for hash initialization.
Resolve troublesome internal call to srand.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-1283
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0718
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-4472
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-5300
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-6702
Napisano: 22 Jan 2017, 17:26
28.12.2016.
Novi python paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/python-2.7.13-i586-1_slack14.2.txz: Upgraded.
This release fixes security issues:
Issue #27850: Remove 3DES from ssl module's default cipher list to counter
measure sweet32 attack (CVE-2016-2183).
Issue #27568: Prevent HTTPoxy attack (CVE-2016-1000110). Ignore the
HTTP_PROXY variable when REQUEST_METHOD environment is set, which indicates
that the script is in CGI mode.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2183
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-1000110
Novi samba paketi za Slackware 14.2 i -current:
patches/packages/samba-4.4.8-i586-1_slack14.2.txz: Upgraded.
CVE-2016-2123 (Samba NDR Parsing ndr_pull_dnsp_name Heap-based Buffer
Overflow Remote Code Execution Vulnerability).
CVE-2016-2125 (Unconditional privilege delegation to Kerberos servers
in trusted realms).
CVE-2016-2126 (Flaws in Kerberos PAC validation can trigger privilege
elevation).
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2123
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2125
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2126
Napisano: 22 Jan 2017, 17:28
30.12.2016.
Novi libpng paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/libpng-1.6.27-i586-1_slack14.2.txz: Upgraded.
This release fixes an old NULL pointer dereference bug in png_set_text_2()
discovered and patched by Patrick Keshishian. The potential "NULL
dereference" bug has existed in libpng since version 0.71 of June 26, 1995.
To be vulnerable, an application has to load a text chunk into the png
structure, then delete all text, then add another text chunk to the same
png structure, which seems to be an unlikely sequence, but it has happened.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-10087
Novi mozilla-thunderbird i seamonkey paketi za Slackware 14.1, 14.2 i -current:
patches/packages/mozilla-thunderbird-45.6.0-i586-1_slack14.2.txz: Upgraded.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9899
patches/packages/seamonkey-2.46-i586-1_slack14.2.txz: Upgraded.
http://www.seamonkey-project.org/releases/seamonkey2.46
patches/packages/seamonkey-solibs-2.46-i586-1_slack14.2.txz: Upgraded.
Napisano: 22 Jan 2017, 17:31
11.01.2017.
Novi bind i irssi paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1, 14.2 i -current:
patches/packages/bind-9.10.4_P5-i586-1_slack14.2.txz: Upgraded.
This update fixes a denial-of-service vulnerability. An error in handling
certain queries can cause an assertion failure when a server is using the
nxdomain-redirect feature to cover a zone for which it is also providing
authoritative service. A vulnerable server could be intentionally stopped
by an attacker if it was using a configuration that met the criteria for
the vulnerability and if the attacker could cause it to accept a query
that possessed the required attributes.
Please note: This vulnerability affects the "nxdomain-redirect" feature,
which is one of two methods of handling NXDOMAIN redirection, and is only
available in certain versions of BIND. Redirection using zones of type
"redirect" is not affected by this vulnerability.
https://kb.isc.org/article/AA-01442
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-9778
patches/packages/irssi-0.8.21-i586-1_slack14.2.txz: Upgraded.
Fixed security issues that may result in a denial of service.
https://irssi.org/security/irssi_sa_2017_01.txt
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5193
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5194
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5195
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5196
Novi gnutls paketi za Slackware 14.0, 14.1, 14.2 i -current:
patches/packages/gnutls-3.5.8-i586-1_slack14.2.txz: Upgraded.
This update fixes some bugs and security issues.
https://gnutls.org/security.html#GNUTLS-SA-2017-1
https://gnutls.org/security.html#GNUTLS-SA-2017-2
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5334
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5335
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5336
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-5337
Napisano: 22 Jan 2017, 17:32
18.01.2017.
Novi mariadb paketi za Slackware 14.1, 14.2 i -current:
patches/packages/mariadb-10.0.29-i586-1_slack14.2.txz: Upgraded.
This update fixes several security issues.
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-6664
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3238
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3243
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3244
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3257
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3258
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3265
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3291
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3312
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3317
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2017-3318
Users browsing this forum: Bing [Bot] and 10 guests
