Napisano: 12 Feb 2016, 20:32
11.02.2016.
Osveženi firefox ESR paketi za Slackware 14.1 i -current:
patches/packages/mozilla-firefox-38.6.1esr-i486-1_slack14.1.txz: Upgraded.
Napisano: 17 Feb 2016, 15:39
14.02.2016.
Osveženi paket Mozilla Thunderbird za Slackware 14.1 i -current:
patches/packages/mozilla-thunderbird-38.6.0-i486-1_slack14.1.txz: Upgraded.
Napisano: 24 Feb 2016, 21:48
23.02.2016.
Sveži
ntp, libgcrypt i bind paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1 i -current:
patches/packages/ntp-4.2.8p6-i486-1_slack14.1.txz: Upgraded.
In addition to bug fixes and enhancements, this release fixes
several low and medium severity vulnerabilities.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-5300
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7973
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7974
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7975
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7976
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7977
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7978
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7979
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8138
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8158
patches/packages/libgcrypt-1.5.5-i486-1_slack14.1.txz: Upgraded.
Mitigate chosen cipher text attacks on ECDH with Weierstrass curves.
Use ciphertext blinding for Elgamal decryption.
http://www.cs.tau.ac.IL/~tromer/ecdh/
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7511
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-3591
patches/packages/bind-9.9.8_P3-i486-1_slack14.1.txz: Upgraded.
This release fixes two possible denial-of-service issues:
render_ecs errors were mishandled when printing out a OPT record resulting
in a assertion failure. (CVE-2015-8705) [RT #41397]
Specific APL data could trigger a INSIST. (CVE-2015-8704) [RT #41396]
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8704
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-8705
Sveži
glibc paketi za Slackware 14.1 i -current:
patches/packages/glibc-2.17-i486-11_slack14.1.txz: Rebuilt.
This update provides a patch to fix the stack-based buffer overflow in
libresolv that could allow specially crafted DNS responses to seize
control of execution flow in the DNS client (CVE-2015-7547). However,
due to a patch applied to Slackware's glibc back in 2009 (don't use the
gethostbyname4() lookup method as it was causing some cheap routers to
misbehave), we were not vulnerable to that issue. Nevertheless it seems
prudent to patch the overflows anyway even if we're not currently using
the code in question. Thanks to mancha for the backported patch.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7547
patches/packages/glibc-i18n-2.17-i486-11_slack14.1.txz: Rebuilt.
patches/packages/glibc-profile-2.17-i486-11_slack14.1.txz: Rebuilt.
patches/packages/glibc-solibs-2.17-i486-11_slack14.1.txz: Rebuilt.
Napisano: 27 Feb 2016, 13:03
26.02.2016
Osvežen libssh paket za Slackware 14.0, 14.1 i -current:
patches/packages/libssh-0.7.3-i486-1_slack14.1.txz: Upgraded.
Fixed weak key generation. Due to a bug in the ephemeral secret key
generation for the diffie-hellman-group1 and diffie-hellman-group14
methods, ephemeral secret keys of size 128 bits are generated, instead
of the recommended sizes of 1024 and 2048 bits, giving a practical
security of 63 bits.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0739
Napisano: 03 Mar 2016, 19:41
03.03.2016.
Openssl i mailx osveženi paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1 i -current:
patches/packages/mailx-12.5-i486-2_slack14.1.txz: Rebuilt.
Drop SSLv2 support (no longer supported by OpenSSL), and fix security issues
that could allow a local attacker to cause mailx to execute arbitrary
shell commands through the use of a specially-crafted email address.
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2004-2771
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2014-7844
patches/packages/openssl-1.0.1s-i486-1_slack14.1.txz: Upgraded.
This update fixes the following security issues:
Cross-protocol attack on TLS using SSLv2 (DROWN) (CVE-2016-0800)
Double-free in DSA code (CVE-2016-0705)
Memory leak in SRP database lookups (CVE-2016-0798)
BN_hex2bn/BN_dec2bn NULL pointer deref/heap corruption (CVE-2016-0797)
Fix memory issues in BIO_*printf functions (CVE-2016-0799)
Side channel attack on modular exponentiation (CVE-2016-0702)
To avoid breaking the ABI, "enable-ssl2" is used, but all the vulnerable or
weak ciphers have been removed.
https://www.openssl.org/news/secadv/20160301.txt
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0800
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0705
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0798
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0797
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0799
https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0702
patches/packages/openssl-solibs-1.0.1s-i486-1_slack14.1.txz: Upgraded.
PHP osveženi paket za Slackware 14.0, 14.1 i -current:
patches/packages/php-5.6.18-i486-1_slack14.1.txz: Upgraded.
http://php.net/ChangeLog-5.php#5.6.18
Napisano: 09 Mar 2016, 01:03
08.03.2016.
Samba i Firefox sveži paketi za Slackware 14.1 i -current:
patches/packages/samba-4.1.23-i486-1_slack14.1.txz: Upgraded.
This update fixes bugs, and two security issues:
Incorrect ACL get/set allowed on symlink path (CVE-2015-7560).
Out-of-bounds read in internal DNS server (CVE-2016-0771).
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2015-7560
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-0771
patches/packages/mozilla-firefox-38.7.0esr-i486-1_slack14.1.txz: Upgraded.
Napisano: 09 Apr 2016, 20:12
10.03.2016.
Svež openssh paket za Slackware 13.0, 13.1, 13.37, 14.0, 14.1 i -current:
patches/packages/openssh-7.2p2-i486-1_slack14.1.txz: Upgraded.
This release fixes a security bug:
sshd(8): sanitise X11 authentication credentials to avoid xauth
command injection when X11Forwarding is enabled.
http://www.openssh.com/txt/x11fwd.adv
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-3115
Napisano: 09 Apr 2016, 20:25
15.03.2016.
Sveži git paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1 i -current:
patches/packages/git-2.7.3-i486-1_slack14.1.txz: Upgraded.
Fixed buffer overflows allowing server and client side remote code
execution in all git versions before 2.7.1.
http://seclists.org/oss-sec/2016/q1/645
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2315
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2016-2324
Svež seamonkey paketi za Slackware 14.1 i -current:
patches/packages/seamonkey-2.40-i486-1_slack14.1.txz: Upgraded.
http://www.seamonkey-project.org/releases/seamonkey2.40
patches/packages/seamonkey-solibs-2.40-i486-1_slack14.1.txz: Upgraded.
Napisano: 09 Apr 2016, 20:26
17.03.2016.
Firefox paketi za Slackware 14.1 and -current:
patches/packages/mozilla-firefox-38.7.1esr-i486-1_slack14.1.txz: Upgraded.
Napisano: 09 Apr 2016, 20:35
18.03.2016.
Osveženi git paketi za Slackware 13.0, 13.1, 13.37, 14.0, 14.1 i -current:
patches/packages/git-2.7.4-i486-1_slack14.1.txz: Upgraded.
NOTE: Issuing this patch again since the bug reporter listed the
wrong git version (2.7.1) as fixed. The vulnerability was actually
patched in git-2.7.4.
execution in all git versions before 2.7.4.
Sveži mozilla thunderbird paketi za Slackware 14.1 i -current:
patches/packages/mozilla-thunderbird-38.7.0-i486-1_slack14.1.txz: Upgraded.
