Novosti u *current* -u
Post Napisano: 21 Oct 2023, 22:51
Slackware 64-bit
Sat Oct 21 18:59:54 UTC 2023
a/btrfs-progs-6.5.3-x86_64-1.txz: Upgraded.
d/meson-1.2.3-x86_64-1.txz: Upgraded.
d/subversion-1.14.2-x86_64-6.txz: Rebuilt.
       Recompiled against utf8proc-2.9.0.
l/nodejs-20.8.1-x86_64-1.txz: Upgraded.
       Stick with the (future) LTS release to avoid compatibility issues.
       Thanks to gildbg.
l/utf8proc-2.9.0-x86_64-1.txz: Upgraded.
n/irssi-1.4.5-x86_64-2.txz: Rebuilt.
xap/gnuplot-5.4.10-x86_64-1.txz: Upgraded.
Fri Oct 20 21:46:56 UTC 2023
x/libdrm-2.4.117-x86_64-2.txz: Rebuilt.
       Rebuilt with -Dintel=enabled. Thanks to Petri Kaukasoina and marav.
Fri Oct 20 17:37:35 UTC 2023
a/kernel-firmware-20231019_d983107-noarch-1.txz: Upgraded.
a/kernel-generic-6.1.59-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.59-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.59-x86_64-1.txz: Upgraded.
a/os-prober-1.81-x86_64-1.txz: Upgraded.
d/kernel-headers-6.1.59-x86-1.txz: Upgraded.
k/kernel-source-6.1.59-noarch-1.txz: Upgraded.
l/gtkmm3-3.24.8-x86_64-1.txz: Upgraded.
l/gvfs-1.52.1-x86_64-1.txz: Upgraded.
x/libdrm-2.4.117-x86_64-1.txz: Upgraded.
x/xcb-util-cursor-0.1.5-x86_64-1.txz: Upgraded.
isolinux/initrd.img: Rebuilt.
kernels/*: Upgraded.
Slackware 32-bit
a/btrfs-progs-6.5.3-i586-1.txz: Upgraded.
d/meson-1.2.3-i586-1.txz: Upgraded.
d/subversion-1.14.2-i586-6.txz: Rebuilt.
l/nodejs-20.8.1-i586-1.txz: Upgraded.
       Thanks to gildbg.
l/utf8proc-2.9.0-i586-1.txz: Upgraded.
n/irssi-1.4.5-i586-2.txz: Rebuilt.
xap/gnuplot-5.4.10-i586-1.txz: Upgraded.
x/libdrm-2.4.117-i586-2.txz: Rebuilt.
a/kernel-generic-6.1.59-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.59_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.59-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.59_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.59-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.59_smp-i686-1.txz: Upgraded.
a/os-prober-1.81-i586-1.txz: Upgraded.
d/kernel-headers-6.1.59_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.59_smp-noarch-1.txz: Upgraded.
l/gtkmm3-3.24.8-i586-1.txz: Upgraded.
l/gvfs-1.52.1-i586-1.txz: Upgraded.
x/libdrm-2.4.117-i586-1.txz: Upgraded.
x/xcb-util-cursor-0.1.5-i586-1.txz: Upgraded.
extra/linux-6.1.59-nosmp-sdk/*: Upgraded.
Post Napisano: 29 Oct 2023, 21:05
Slackware 64-bit
Sun Oct 29 19:21:20 UTC 2023
xfce/xfconf-4.18.2-x86_64-2.txz: Rebuilt.
       [PATCH] cache: Fix uncached value.
       Thanks to baldzhang.
Sat Oct 28 22:03:51 UTC 2023
d/rust-1.70.0-x86_64-3.txz: Rebuilt.
       Fixed the installation of rls and added rust-analyzer (the successor to rls)
       and rust-demangler. Thanks to Heinz Wiesinger.
l/enchant-2.6.2-x86_64-1.txz: Upgraded.
l/gexiv2-0.14.2-x86_64-2.txz: Rebuilt.
       Recompiled against exiv2-0.28.0.
l/libsigc++3-3.6.0-x86_64-1.txz: Upgraded.
l/vid.stab-1.1.1-x86_64-1.txz: Upgraded.
x/ibus-m17n-1.4.23-x86_64-1.txz: Upgraded.
testing/packages/rust-1.73.0-x86_64-2.txz: Rebuilt.
Fri Oct 27 19:47:36 UTC 2023
a/exfatprogs-1.2.2-x86_64-1.txz: Upgraded.
kde/digikam-8.1.0-x86_64-2.txz: Rebuilt.
kde/gwenview-23.08.2-x86_64-2.txz: Rebuilt.
kde/kfilemetadata-5.111.0-x86_64-2.txz: Rebuilt.
kde/krename-5.0.2-x86_64-2.txz: Rebuilt.
kde/krita-5.2.0-x86_64-2.txz: Rebuilt.
kde/libkexiv2-23.08.2-x86_64-2.txz: Rebuilt.
l/QtAV-20220226_fdc613dc-x86_64-1.txz: Removed.
       This is no longer used by digikam, so let's just remove it.
l/exiv2-0.28.0-x86_64-1.txz: Upgraded.
l/libsoup3-3.4.4-x86_64-1.txz: Upgraded.
n/c-ares-1.21.0-x86_64-1.txz: Upgraded.
n/gpgme-1.23.1-x86_64-1.txz: Upgraded.
n/nghttp2-1.58.0-x86_64-1.txz: Upgraded.
xap/geeqie-2.1-x86_64-3.txz: Rebuilt.
Thu Oct 26 19:55:16 UTC 2023
a/kernel-firmware-20231024_4ee0175-noarch-1.txz: Upgraded.
a/kernel-generic-6.1.60-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.60-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.60-x86_64-1.txz: Upgraded.
a/shadow-4.14.1-x86_64-1.txz: Upgraded.
d/kernel-headers-6.1.60-x86-1.txz: Upgraded.
k/kernel-source-6.1.60-noarch-1.txz: Upgraded.
       Hey folks, if you've been following LQ you know I've talked before about
       dropping the huge kernel and moving the distribution to use only the generic
       kernel plus an initrd. After mulling this over for a few months, I think I
       was looking at the problem in the wrong way. First of all, it's clear that
       some Slackware users have been using the huge kernel all along, without an
       initrd, and are (to say the least) unhappy about the prospect of a new
       requirement to start using one. I've been recommending the generic kernel for
       some time, and a major reason is that we've been using the same set of kernel
       modules with two slightly different kernels. Because of this, there have
       always been a few (generally seldom used) kernel modules that won't load into
       the huge kernel. These are things that aren't built into the huge kernel, but
       because of a difference in some kernel module dependency, they won't load.
       The conclusion that I've come to here is that rather than drop the huge
       kernel, or slap a LOCALVERSION on it and provide a whole duplicate tree of
       kernel modules especially for the huge kernel, it would be better to make the
       generic kernel more huge, and minimize the differences between the two kernel
       configs.
       That's what I've done here.
       Shown below are the differences between the previous generic kernel config
       and the one shipping in this update. You'll notice that most of the popular
       filesystems are built in. At this point the main difference it that the huge
       kernel has a couple of dozen SCSI drivers built into it. The modules for those
       drivers won't load into the huge kernel, but they're fully built in so that
       doesn't matter. If you find any other modules that will not load into the huge
       kernel, please make a note about it on LQ and I'll see what can be done.
       So, tl;dr - what does this change mean?
       Unless your root device is on SCSI, if you were able to use the huge kernel
       without an initrd previously, you should now be able to use the generic
       kernel without an initrd. The kernel is a bit bigger, but we probably have
       enough RAM these days that it won't make a difference.
       Enjoy! :-)
       -CIFS_SMB_DIRECT n
       9P_FS m -> y
       9P_FSCACHE n -> y
       BTRFS_FS m -> y
       CIFS m -> y
       CRYPTO_CMAC m -> y
       CRYPTO_CRC32 m -> y
       CRYPTO_XXHASH m -> y
       CRYPTO_ZSTD m -> y
       EFIVAR_FS m -> y
       EXFAT_FS m -> y
       EXT2_FS m -> y
       EXT3_FS m -> y
       EXT4_FS m -> y
       F2FS_FS m -> y
       FAILOVER m -> y
       FAT_FS m -> y
       FSCACHE m -> y
       FS_ENCRYPTION_ALGS m -> y
       FS_MBCACHE m -> y
       HW_RANDOM_VIRTIO m -> y
       ISO9660_FS m -> y
       JBD2 m -> y
       JFS_FS m -> y
       LZ4HC_COMPRESS m -> y
       LZ4_COMPRESS m -> y
       MSDOS_FS m -> y
       NETFS_SUPPORT m -> y
       NET_9P m -> y
       NET_9P_FD m -> y
       NET_9P_VIRTIO m -> y
       NET_FAILOVER m -> y
       NFSD m -> y
       NLS_CODEPAGE_437 m -> y
       NTFS3_FS m -> y
       NTFS_FS m -> y
       PSTORE_LZ4_COMPRESS n -> m
       PSTORE_LZO_COMPRESS n -> m
       PSTORE_ZSTD_COMPRESS n -> y
       QFMT_V2 m -> y
       QUOTA_TREE m -> y
       REISERFS_FS m -> y
       RPCSEC_GSS_KRB5 m -> y
       SMBFS m -> y
       SQUASHFS m -> y
       UDF_FS m -> y
       VFAT_FS m -> y
       VIRTIO_BALLOON m -> y
       VIRTIO_BLK m -> y
       VIRTIO_CONSOLE m -> y
       VIRTIO_INPUT m -> y
       VIRTIO_MMIO m -> y
       VIRTIO_NET m -> y
       VIRTIO_PCI m -> y
       VIRTIO_PCI_LIB m -> y
       VIRTIO_PCI_LIB_LEGACY m -> y
       VIRTIO_PMEM m -> y
       XFS_FS m -> y
       ZONEFS_FS n -> m
       ZSTD_COMPRESS m -> y
       +NFS_FSCACHE y
       +PSTORE_LZ4_COMPRESS_DEFAULT n
       +PSTORE_LZO_COMPRESS_DEFAULT n
       +PSTORE_ZSTD_COMPRESS_DEFAULT n
kde/plasma-workspace-5.27.9.1-x86_64-1.txz: Upgraded.
l/glib2-2.78.1-x86_64-1.txz: Upgraded.
l/netpbm-11.04.03-x86_64-1.txz: Upgraded.
l/newt-0.52.24-x86_64-1.txz: Upgraded.
n/gpgme-1.23.0-x86_64-1.txz: Upgraded.
n/p11-kit-0.25.1-x86_64-1.txz: Upgraded.
n/php-8.2.12-x86_64-1.txz: Upgraded.
       This is a bugfix release.
       https://www.php.net/ChangeLog-8.php#8.2.12
x/xorg-server-21.1.9-x86_64-1.txz: Upgraded.
       OOB write in XIChangeDeviceProperty/RRChangeOutputProperty.
       Use-after-free bug in DestroyWindow.
       https://lists.x.org/archives/xorg-announce/2023-October/003430.html
       https://www.cve.org/CVERecord?id=CVE-2023-5367
       https://www.cve.org/CVERecord?id=CVE-2023-5380
x/xorg-server-xephyr-21.1.9-x86_64-1.txz: Upgraded.
x/xorg-server-xnest-21.1.9-x86_64-1.txz: Upgraded.
x/xorg-server-xvfb-21.1.9-x86_64-1.txz: Upgraded.
x/xorg-server-xwayland-23.2.2-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-115.4.1-x86_64-1.txz: Upgraded.
       https://www.mozilla.org/en-US/thunderbird/115.4.1/releasenotes/
       https://www.mozilla.org/en-US/security/advisories/mfsa2023-47/
       https://www.cve.org/CVERecord?id=CVE-2023-5721
       https://www.cve.org/CVERecord?id=CVE-2023-5732
       https://www.cve.org/CVERecord?id=CVE-2023-5724
       https://www.cve.org/CVERecord?id=CVE-2023-5725
       https://www.cve.org/CVERecord?id=CVE-2023-5726
       https://www.cve.org/CVERecord?id=CVE-2023-5727
       https://www.cve.org/CVERecord?id=CVE-2023-5728
       https://www.cve.org/CVERecord?id=CVE-2023-5730
xfce/thunar-4.18.8-x86_64-1.txz: Upgraded.
Tue Oct 24 22:26:20 UTC 2023
a/openssl-solibs-3.1.4-x86_64-1.txz: Upgraded.
ap/vim-9.0.2063-x86_64-1.txz: Upgraded.
       Fixed use-after-free security issue.
       https://www.cve.org/CVERecord?id=CVE-2023-5535
d/parallel-20231022-noarch-1.txz: Upgraded.
kde/bluedevil-5.27.9-x86_64-1.txz: Upgraded.
kde/breeze-5.27.9-x86_64-1.txz: Upgraded.
kde/breeze-grub-5.27.9-x86_64-1.txz: Upgraded.
kde/breeze-gtk-5.27.9-x86_64-1.txz: Upgraded.
kde/drkonqi-5.27.9-x86_64-1.txz: Upgraded.
kde/kactivitymanagerd-5.27.9-x86_64-1.txz: Upgraded.
kde/kde-cli-tools-5.27.9-x86_64-1.txz: Upgraded.
kde/kde-gtk-config-5.27.9-x86_64-1.txz: Upgraded.
kde/kdecoration-5.27.9-x86_64-1.txz: Upgraded.
kde/kdeplasma-addons-5.27.9-x86_64-1.txz: Upgraded.
kde/kgamma5-5.27.9-x86_64-1.txz: Upgraded.
kde/khotkeys-5.27.9-x86_64-1.txz: Upgraded.
kde/kinfocenter-5.27.9-x86_64-1.txz: Upgraded.
kde/kmenuedit-5.27.9-x86_64-1.txz: Upgraded.
kde/kpipewire-5.27.9-x86_64-1.txz: Upgraded.
kde/kscreen-5.27.9-x86_64-1.txz: Upgraded.
kde/kscreenlocker-5.27.9-x86_64-1.txz: Upgraded.
kde/ksshaskpass-5.27.9-x86_64-1.txz: Upgraded.
kde/ksystemstats-5.27.9-x86_64-1.txz: Upgraded.
kde/kwallet-pam-5.27.9-x86_64-1.txz: Upgraded.
kde/kwayland-integration-5.27.9-x86_64-1.txz: Upgraded.
kde/kwin-5.27.9-x86_64-1.txz: Upgraded.
kde/kwrited-5.27.9-x86_64-1.txz: Upgraded.
kde/layer-shell-qt-5.27.9-x86_64-1.txz: Upgraded.
kde/libkscreen-5.27.9-x86_64-1.txz: Upgraded.
kde/libksysguard-5.27.9-x86_64-1.txz: Upgraded.
kde/milou-5.27.9-x86_64-1.txz: Upgraded.
kde/oxygen-5.27.9-x86_64-1.txz: Upgraded.
kde/oxygen-sounds-5.27.9-x86_64-1.txz: Upgraded.
kde/plasma-browser-integration-5.27.9-x86_64-1.txz: Upgraded.
kde/plasma-desktop-5.27.9-x86_64-1.txz: Upgraded.
kde/plasma-disks-5.27.9-x86_64-1.txz: Upgraded.
kde/plasma-firewall-5.27.9-x86_64-1.txz: Upgraded.
kde/plasma-integration-5.27.9-x86_64-1.txz: Upgraded.
kde/plasma-nm-5.27.9-x86_64-1.txz: Upgraded.
kde/plasma-pa-5.27.9-x86_64-1.txz: Upgraded.
kde/plasma-sdk-5.27.9-x86_64-1.txz: Upgraded.
kde/plasma-systemmonitor-5.27.9-x86_64-1.txz: Upgraded.
kde/plasma-vault-5.27.9-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.27.9-x86_64-1.txz: Upgraded.
kde/plasma-workspace-wallpapers-5.27.9-noarch-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.27.9-x86_64-1.txz: Upgraded.
kde/powerdevil-5.27.9-x86_64-1.txz: Upgraded.
kde/qqc2-breeze-style-5.27.9-x86_64-1.txz: Upgraded.
kde/sddm-kcm-5.27.9-x86_64-1.txz: Upgraded.
kde/systemsettings-5.27.9-x86_64-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.27.9-x86_64-1.txz: Upgraded.
l/frei0r-plugins-2.3.1-x86_64-1.txz: Upgraded.
l/nodejs-20.9.0-x86_64-1.txz: Upgraded.
n/openssl-3.1.4-x86_64-1.txz: Upgraded.
       Incorrect cipher key & IV length processing.
       https://www.openssl.org/news/secadv/20231024.txt
       https://www.cve.org/CVERecord?id=CVE-2023-5363
x/xterm-388-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-115.4.0esr-x86_64-1.txz: Upgraded.
       https://www.mozilla.org/en-US/firefox/115.4.0/releasenotes/
       https://www.mozilla.org/security/advisories/mfsa2023-46/
xap/mozilla-thunderbird-115.4.0-x86_64-1.txz: Upgraded.
       https://www.mozilla.org/en-US/thunderbird/115.4.0/releasenotes/
xap/vim-gvim-9.0.2063-x86_64-1.txz: Upgraded.
Sun Oct 22 19:30:42 UTC 2023
a/lvm2-2.03.22-x86_64-1.txz: Upgraded.
kde/kstars-3.6.7-x86_64-1.txz: Upgraded.
       It's time for KStars in Slackware to be less of a toy and more of a useful
       tool. The required dependencies have been added for EKOS, the INDI client
       included in KStars, which will allow for computer control of astronomy
       devices. Additional deps and drivers may be required, but these are runtime
       dependencies. See (for example) gpsd, libdc1394, libftdi1, libindi-libraries,
       and libindi-drivers, all of which can be found on slackbuilds.org.
       Huge thanks to Edward W. Koenig for the detailed writeup - it was extremely
       helpful! :-) Here's a link to the article:
       https://www.linuxgalaxy.org/kingbeowulf/astronomy-device-control-in-slackware-15-and-current/
kde/libindi-2.0.4-x86_64-1.txz: Added.
       This is required by kstars-3.6.7.
kde/libnova-0.15.0-x86_64-1.txz: Added.
       Thanks to Chris Abela, Ryan P.C. McQuen, and Philip Lacroix.
kde/stellarsolver-2.5-x86_64-1.txz: Added.
kde/wcslib-8.1-x86_64-1.txz: Added.
l/LibRaw-0.21.1-x86_64-2.txz: Rebuilt.
       A heap-buffer-overflow was found in raw2image_ex(int), which may lead to
       application crash by maliciously crafted input file.
       https://www.cve.org/CVERecord?id=CVE-2023-1729
l/imagemagick-7.1.1_21-x86_64-1.txz: Upgraded.
l/libev-4.33-x86_64-1.txz: Added.
       As this package may have more general usage than just kstars, we'll put it
       in the L series.
       Thanks to AA ime Ramov and Matteo Bernardini.
l/vte-0.74.1-x86_64-1.txz: Upgraded.
Slackware 32-bit
xfce/xfconf-4.18.2-i586-2.txz: Rebuilt.
d/rust-1.70.0-i686-3.txz: Rebuilt.
l/enchant-2.6.2-i586-1.txz: Upgraded.
l/gexiv2-0.14.2-i586-2.txz: Rebuilt.
l/libsigc++3-3.6.0-i586-1.txz: Upgraded.
l/vid.stab-1.1.1-i586-1.txz: Upgraded.
x/ibus-m17n-1.4.23-i586-1.txz: Upgraded.
testing/packages/rust-1.73.0-i686-2.txz: Rebuilt.
a/exfatprogs-1.2.2-i586-1.txz: Upgraded.
kde/digikam-8.1.0-i586-2.txz: Rebuilt.
kde/gwenview-23.08.2-i586-2.txz: Rebuilt.
kde/kfilemetadata-5.111.0-i586-2.txz: Rebuilt.
kde/krename-5.0.2-i586-2.txz: Rebuilt.
kde/krita-5.2.0-i586-2.txz: Rebuilt.
kde/libkexiv2-23.08.2-i586-2.txz: Rebuilt.
l/QtAV-20220226_fdc613dc-i586-1.txz: Removed.
l/exiv2-0.28.0-i586-1.txz: Upgraded.
l/libsoup3-3.4.4-i586-1.txz: Upgraded.
n/c-ares-1.21.0-i586-1.txz: Upgraded.
n/gpgme-1.23.1-i586-1.txz: Upgraded.
n/nghttp2-1.58.0-i586-1.txz: Upgraded.
xap/geeqie-2.1-i586-3.txz: Rebuilt.
a/kernel-generic-6.1.60-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.60_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.60-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.60_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.60-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.60_smp-i686-1.txz: Upgraded.
a/shadow-4.14.1-i586-1.txz: Upgraded.
d/kernel-headers-6.1.60_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.60_smp-noarch-1.txz: Upgraded.
       configs.
       Enjoy! :-)
       -CIFS_SMB_DIRECT n
       9P_FS m -> y
       9P_FSCACHE n -> y
       BTRFS_FS m -> y
       CIFS m -> y
       CRYPTO_CMAC m -> y
       CRYPTO_CRC32 m -> y
       CRYPTO_ZSTD m -> y
       EFIVAR_FS m -> y
       EXFAT_FS m -> y
       EXT2_FS m -> y
       EXT3_FS m -> y
       EXT4_FS m -> y
       F2FS_FS m -> y
       FAILOVER m -> y
       FAT_FS m -> y
       FSCACHE m -> y
       FS_MBCACHE m -> y
       ISO9660_FS m -> y
       JBD2 m -> y
       JFS_FS m -> y
       LZ4_COMPRESS m -> y
       MSDOS_FS m -> y
       NET_9P m -> y
       NET_9P_FD m -> y
       NET_FAILOVER m -> y
       NFSD m -> y
       NTFS3_FS m -> y
       NTFS_FS m -> y
       QFMT_V2 m -> y
       QUOTA_TREE m -> y
       REISERFS_FS m -> y
       SMBFS m -> y
       SQUASHFS m -> y
       UDF_FS m -> y
       VFAT_FS m -> y
       VIRTIO_BLK m -> y
       VIRTIO_INPUT m -> y
       VIRTIO_MMIO m -> y
       VIRTIO_NET m -> y
       VIRTIO_PCI m -> y
       VIRTIO_PMEM m -> y
       XFS_FS m -> y
       ZONEFS_FS n -> m
       +NFS_FSCACHE y
kde/plasma-workspace-5.27.9.1-i586-1.txz: Upgraded.
l/glib2-2.78.1-i586-1.txz: Upgraded.
l/netpbm-11.04.03-i586-1.txz: Upgraded.
l/newt-0.52.24-i586-1.txz: Upgraded.
n/gpgme-1.23.0-i586-1.txz: Upgraded.
n/p11-kit-0.25.1-i586-1.txz: Upgraded.
n/php-8.2.12-i586-1.txz: Upgraded.
x/xorg-server-21.1.9-i586-1.txz: Upgraded.
x/xorg-server-xephyr-21.1.9-i586-1.txz: Upgraded.
x/xorg-server-xnest-21.1.9-i586-1.txz: Upgraded.
x/xorg-server-xvfb-21.1.9-i586-1.txz: Upgraded.
x/xorg-server-xwayland-23.2.2-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-115.4.1-i686-1.txz: Upgraded.
xfce/thunar-4.18.8-i586-1.txz: Upgraded.
extra/linux-6.1.60-nosmp-sdk/*: Upgraded.
a/openssl-solibs-3.1.4-i586-1.txz: Upgraded.
ap/vim-9.0.2063-i586-1.txz: Upgraded.
kde/bluedevil-5.27.9-i586-1.txz: Upgraded.
kde/breeze-5.27.9-i586-1.txz: Upgraded.
kde/breeze-grub-5.27.9-i586-1.txz: Upgraded.
kde/breeze-gtk-5.27.9-i586-1.txz: Upgraded.
kde/drkonqi-5.27.9-i586-1.txz: Upgraded.
kde/kactivitymanagerd-5.27.9-i586-1.txz: Upgraded.
kde/kde-cli-tools-5.27.9-i586-1.txz: Upgraded.
kde/kde-gtk-config-5.27.9-i586-1.txz: Upgraded.
kde/kdecoration-5.27.9-i586-1.txz: Upgraded.
kde/kdeplasma-addons-5.27.9-i586-1.txz: Upgraded.
kde/kgamma5-5.27.9-i586-1.txz: Upgraded.
kde/khotkeys-5.27.9-i586-1.txz: Upgraded.
kde/kinfocenter-5.27.9-i586-1.txz: Upgraded.
kde/kmenuedit-5.27.9-i586-1.txz: Upgraded.
kde/kpipewire-5.27.9-i586-1.txz: Upgraded.
kde/kscreen-5.27.9-i586-1.txz: Upgraded.
kde/kscreenlocker-5.27.9-i586-1.txz: Upgraded.
kde/ksshaskpass-5.27.9-i586-1.txz: Upgraded.
kde/ksystemstats-5.27.9-i586-1.txz: Upgraded.
kde/kwallet-pam-5.27.9-i586-1.txz: Upgraded.
kde/kwayland-integration-5.27.9-i586-1.txz: Upgraded.
kde/kwin-5.27.9-i586-1.txz: Upgraded.
kde/kwrited-5.27.9-i586-1.txz: Upgraded.
kde/layer-shell-qt-5.27.9-i586-1.txz: Upgraded.
kde/libkscreen-5.27.9-i586-1.txz: Upgraded.
kde/libksysguard-5.27.9-i586-1.txz: Upgraded.
kde/milou-5.27.9-i586-1.txz: Upgraded.
kde/oxygen-5.27.9-i586-1.txz: Upgraded.
kde/oxygen-sounds-5.27.9-i586-1.txz: Upgraded.
kde/plasma-browser-integration-5.27.9-i586-1.txz: Upgraded.
kde/plasma-desktop-5.27.9-i586-1.txz: Upgraded.
kde/plasma-disks-5.27.9-i586-1.txz: Upgraded.
kde/plasma-firewall-5.27.9-i586-1.txz: Upgraded.
kde/plasma-integration-5.27.9-i586-1.txz: Upgraded.
kde/plasma-nm-5.27.9-i586-1.txz: Upgraded.
kde/plasma-pa-5.27.9-i586-1.txz: Upgraded.
kde/plasma-sdk-5.27.9-i586-1.txz: Upgraded.
kde/plasma-systemmonitor-5.27.9-i586-1.txz: Upgraded.
kde/plasma-vault-5.27.9-i586-1.txz: Upgraded.
kde/plasma-workspace-5.27.9-i586-1.txz: Upgraded.
kde/polkit-kde-agent-1-5.27.9-i586-1.txz: Upgraded.
kde/powerdevil-5.27.9-i586-1.txz: Upgraded.
kde/qqc2-breeze-style-5.27.9-i586-1.txz: Upgraded.
kde/sddm-kcm-5.27.9-i586-1.txz: Upgraded.
kde/systemsettings-5.27.9-i586-1.txz: Upgraded.
kde/xdg-desktop-portal-kde-5.27.9-i586-1.txz: Upgraded.
l/frei0r-plugins-2.3.1-i586-1.txz: Upgraded.
l/nodejs-20.9.0-i586-1.txz: Upgraded.
n/openssl-3.1.4-i586-1.txz: Upgraded.
x/xterm-388-i586-1.txz: Upgraded.
xap/mozilla-firefox-115.4.0esr-i686-1.txz: Upgraded.
xap/mozilla-thunderbird-115.4.0-i686-1.txz: Upgraded.
xap/vim-gvim-9.0.2063-i586-1.txz: Upgraded.
a/lvm2-2.03.22-i586-1.txz: Upgraded.
kde/kstars-3.6.7-i586-1.txz: Upgraded.
kde/libindi-2.0.4-i586-1.txz: Added.
kde/libnova-0.15.0-i586-1.txz: Added.
kde/stellarsolver-2.5-i586-1.txz: Added.
kde/wcslib-8.1-i586-1.txz: Added.
l/LibRaw-0.21.1-i586-2.txz: Rebuilt.
l/imagemagick-7.1.1_21-i586-1.txz: Upgraded.
l/libev-4.33-i586-1.txz: Added.
       in the L series.
l/vte-0.74.1-i586-1.txz: Upgraded.
Post Napisano: 12 Nov 2023, 14:19
Slackware 64-bit
 Fri Nov 10 18:46:44 UTC 2023
a/bash-5.2.021-x86_64-1.txz: Upgraded.
ap/rdfind-1.6.0-x86_64-1.txz: Added.
ap/sudo-1.9.15p2-x86_64-1.txz: Upgraded.
l/ffmpeg-5.1.4-x86_64-1.txz: Upgraded.
n/dhcpcd-10.0.5-x86_64-1.txz: Upgraded.
n/whois-5.5.20-x86_64-1.txz: Upgraded.
       Added the .gn TLD server.
       Removed 6 new gTLDs which are no longer active.
xfce/xfce4-whiskermenu-plugin-2.8.1-x86_64-1.txz: Upgraded.
Thu Nov 9 21:50:09 UTC 2023
a/kbd-2.6.3-x86_64-2.txz: Rebuilt.
       Fixed /etc/pam.d/vlock installation. Thanks to ctrlaltca.
kde/akonadi-23.08.3-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-23.08.3-x86_64-1.txz: Upgraded.
kde/akonadi-calendar-tools-23.08.3-x86_64-1.txz: Upgraded.
kde/akonadi-contacts-23.08.3-x86_64-1.txz: Upgraded.
kde/akonadi-import-wizard-23.08.3-x86_64-1.txz: Upgraded.
kde/akonadi-mime-23.08.3-x86_64-1.txz: Upgraded.
kde/akonadi-notes-23.08.3-x86_64-1.txz: Upgraded.
kde/akonadi-search-23.08.3-x86_64-1.txz: Upgraded.
kde/akonadiconsole-23.08.3-x86_64-1.txz: Upgraded.
kde/akregator-23.08.3-x86_64-1.txz: Upgraded.
kde/alligator-23.08.3-x86_64-1.txz: Upgraded.
kde/analitza-23.08.3-x86_64-1.txz: Upgraded.
kde/ark-23.08.3-x86_64-1.txz: Upgraded.
kde/artikulate-23.08.3-x86_64-1.txz: Upgraded.
kde/audiocd-kio-23.08.3-x86_64-1.txz: Upgraded.
kde/baloo-widgets-23.08.3-x86_64-1.txz: Upgraded.
kde/blinken-23.08.3-x86_64-1.txz: Upgraded.
kde/bomber-23.08.3-x86_64-1.txz: Upgraded.
kde/bovo-23.08.3-x86_64-1.txz: Upgraded.
kde/calendarsupport-23.08.3-x86_64-1.txz: Upgraded.
kde/cantor-23.08.3-x86_64-1.txz: Upgraded.
kde/cervisia-23.08.3-x86_64-1.txz: Upgraded.
kde/dolphin-23.08.3-x86_64-1.txz: Upgraded.
kde/dolphin-plugins-23.08.3-x86_64-1.txz: Upgraded.
kde/dragon-23.08.3-x86_64-1.txz: Upgraded.
kde/elisa-23.08.3-x86_64-1.txz: Upgraded.
kde/eventviews-23.08.3-x86_64-1.txz: Upgraded.
kde/falkon-23.08.3-x86_64-1.txz: Upgraded.
kde/ffmpegthumbs-23.08.3-x86_64-1.txz: Upgraded.
kde/filelight-23.08.3-x86_64-1.txz: Upgraded.
kde/ghostwriter-23.08.3-x86_64-1.txz: Upgraded.
kde/granatier-23.08.3-x86_64-1.txz: Upgraded.
kde/grantlee-editor-23.08.3-x86_64-1.txz: Upgraded.
kde/grantleetheme-23.08.3-x86_64-1.txz: Upgraded.
kde/gwenview-23.08.3-x86_64-1.txz: Upgraded.
kde/incidenceeditor-23.08.3-x86_64-1.txz: Upgraded.
kde/itinerary-23.08.3-x86_64-1.txz: Upgraded.
kde/juk-23.08.3-x86_64-1.txz: Upgraded.
kde/k3b-23.08.3-x86_64-1.txz: Upgraded.
kde/kaddressbook-23.08.3-x86_64-1.txz: Upgraded.
kde/kalarm-23.08.3-x86_64-1.txz: Upgraded.
kde/kalgebra-23.08.3-x86_64-1.txz: Upgraded.
kde/kalzium-23.08.3-x86_64-1.txz: Upgraded.
kde/kamera-23.08.3-x86_64-1.txz: Upgraded.
kde/kamoso-23.08.3-x86_64-1.txz: Upgraded.
kde/kanagram-23.08.3-x86_64-1.txz: Upgraded.
kde/kapman-23.08.3-x86_64-1.txz: Upgraded.
kde/kapptemplate-23.08.3-x86_64-1.txz: Upgraded.
kde/kate-23.08.3-x86_64-1.txz: Upgraded.
kde/katomic-23.08.3-x86_64-1.txz: Upgraded.
kde/kbackup-23.08.3-x86_64-1.txz: Upgraded.
kde/kblackbox-23.08.3-x86_64-1.txz: Upgraded.
kde/kblocks-23.08.3-x86_64-1.txz: Upgraded.
kde/kbounce-23.08.3-x86_64-1.txz: Upgraded.
kde/kbreakout-23.08.3-x86_64-1.txz: Upgraded.
kde/kbruch-23.08.3-x86_64-1.txz: Upgraded.
kde/kcachegrind-23.08.3-x86_64-1.txz: Upgraded.
kde/kcalc-23.08.3-x86_64-1.txz: Upgraded.
kde/kcalutils-23.08.3-x86_64-1.txz: Upgraded.
kde/kcharselect-23.08.3-x86_64-1.txz: Upgraded.
kde/kcolorchooser-23.08.3-x86_64-1.txz: Upgraded.
kde/kcron-23.08.3-x86_64-1.txz: Upgraded.
kde/kde-dev-scripts-23.08.3-x86_64-1.txz: Upgraded.
kde/kde-dev-utils-23.08.3-x86_64-1.txz: Upgraded.
kde/kde-inotify-survey-23.08.3-x86_64-1.txz: Upgraded.
kde/kdebugsettings-23.08.3-x86_64-1.txz: Upgraded.
kde/kdeconnect-kde-23.08.3-x86_64-1.txz: Upgraded.
kde/kdeedu-data-23.08.3-x86_64-1.txz: Upgraded.
kde/kdegraphics-mobipocket-23.08.3-x86_64-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-23.08.3-x86_64-1.txz: Upgraded.
kde/kdenetwork-filesharing-23.08.3-x86_64-1.txz: Upgraded.
kde/kdenlive-23.08.3-x86_64-1.txz: Upgraded.
kde/kdepim-addons-23.08.3-x86_64-1.txz: Upgraded.
kde/kdepim-runtime-23.08.3-x86_64-1.txz: Upgraded.
kde/kdesdk-kio-23.08.3-x86_64-1.txz: Upgraded.
kde/kdesdk-thumbnailers-23.08.3-x86_64-1.txz: Upgraded.
kde/kdev-php-23.08.3-x86_64-1.txz: Upgraded.
kde/kdev-python-23.08.3-x86_64-1.txz: Upgraded.
kde/kdevelop-23.08.3-x86_64-1.txz: Upgraded.
kde/kdf-23.08.3-x86_64-1.txz: Upgraded.
kde/kdialog-23.08.3-x86_64-1.txz: Upgraded.
kde/kdiamond-23.08.3-x86_64-1.txz: Upgraded.
kde/keditbookmarks-23.08.3-x86_64-1.txz: Upgraded.
kde/keysmith-23.08.3-x86_64-1.txz: Upgraded.
kde/kfind-23.08.3-x86_64-1.txz: Upgraded.
kde/kfourinline-23.08.3-x86_64-1.txz: Upgraded.
kde/kgeography-23.08.3-x86_64-1.txz: Upgraded.
kde/kget-23.08.3-x86_64-1.txz: Upgraded.
kde/kgoldrunner-23.08.3-x86_64-1.txz: Upgraded.
kde/kgpg-23.08.3-x86_64-1.txz: Upgraded.
kde/khangman-23.08.3-x86_64-1.txz: Upgraded.
kde/khelpcenter-23.08.3-x86_64-1.txz: Upgraded.
kde/kidentitymanagement-23.08.3-x86_64-1.txz: Upgraded.
kde/kig-23.08.3-x86_64-1.txz: Upgraded.
kde/kigo-23.08.3-x86_64-1.txz: Upgraded.
kde/killbots-23.08.3-x86_64-1.txz: Upgraded.
kde/kimagemapeditor-23.08.3-x86_64-1.txz: Upgraded.
kde/kimap-23.08.3-x86_64-1.txz: Upgraded.
kde/kio-admin-23.08.3-x86_64-1.txz: Upgraded.
kde/kio-extras-23.08.3-x86_64-1.txz: Upgraded.
kde/kio-gdrive-23.08.3-x86_64-1.txz: Upgraded.
kde/kio-zeroconf-23.08.3-x86_64-1.txz: Upgraded.
kde/kipi-plugins-23.08.3-x86_64-1.txz: Upgraded.
kde/kirigami-gallery-23.08.3-x86_64-1.txz: Upgraded.
kde/kiriki-23.08.3-x86_64-1.txz: Upgraded.
kde/kiten-23.08.3-x86_64-1.txz: Upgraded.
kde/kitinerary-23.08.3-x86_64-1.txz: Upgraded.
kde/kjumpingcube-23.08.3-x86_64-1.txz: Upgraded.
kde/kldap-23.08.3-x86_64-1.txz: Upgraded.
kde/kleopatra-23.08.3-x86_64-1.txz: Upgraded.
kde/klickety-23.08.3-x86_64-1.txz: Upgraded.
kde/klines-23.08.3-x86_64-1.txz: Upgraded.
kde/kmag-23.08.3-x86_64-1.txz: Upgraded.
kde/kmahjongg-23.08.3-x86_64-1.txz: Upgraded.
kde/kmail-23.08.3-x86_64-1.txz: Upgraded.
kde/kmail-account-wizard-23.08.3-x86_64-1.txz: Upgraded.
kde/kmailtransport-23.08.3-x86_64-1.txz: Upgraded.
kde/kmbox-23.08.3-x86_64-1.txz: Upgraded.
kde/kmime-23.08.3-x86_64-1.txz: Upgraded.
kde/kmines-23.08.3-x86_64-1.txz: Upgraded.
kde/kmix-23.08.3-x86_64-1.txz: Upgraded.
kde/kmousetool-23.08.3-x86_64-1.txz: Upgraded.
kde/kmouth-23.08.3-x86_64-1.txz: Upgraded.
kde/kmplot-23.08.3-x86_64-1.txz: Upgraded.
kde/knavalbattle-23.08.3-x86_64-1.txz: Upgraded.
kde/knetwalk-23.08.3-x86_64-1.txz: Upgraded.
kde/knights-23.08.3-x86_64-1.txz: Upgraded.
kde/knotes-23.08.3-x86_64-1.txz: Upgraded.
kde/kolf-23.08.3-x86_64-1.txz: Upgraded.
kde/kollision-23.08.3-x86_64-1.txz: Upgraded.
kde/kolourpaint-23.08.3-x86_64-1.txz: Upgraded.
kde/kompare-23.08.3-x86_64-1.txz: Upgraded.
kde/konqueror-23.08.3-x86_64-1.txz: Upgraded.
kde/konquest-23.08.3-x86_64-1.txz: Upgraded.
kde/konsole-23.08.3-x86_64-1.txz: Upgraded.
kde/kontact-23.08.3-x86_64-1.txz: Upgraded.
kde/kontactinterface-23.08.3-x86_64-1.txz: Upgraded.
kde/kontrast-23.08.3-x86_64-1.txz: Upgraded.
kde/konversation-23.08.3-x86_64-1.txz: Upgraded.
kde/kopeninghours-23.08.3-x86_64-1.txz: Upgraded.
kde/kopete-23.08.3-x86_64-1.txz: Upgraded.
kde/korganizer-23.08.3-x86_64-1.txz: Upgraded.
kde/kosmindoormap-23.08.3-x86_64-1.txz: Upgraded.
kde/kpat-23.08.3-x86_64-1.txz: Upgraded.
kde/kpimtextedit-23.08.3-x86_64-1.txz: Upgraded.
kde/kpkpass-23.08.3-x86_64-1.txz: Upgraded.
kde/kpmcore-23.08.3-x86_64-1.txz: Upgraded.
kde/kpublictransport-23.08.3-x86_64-1.txz: Upgraded.
kde/kqtquickcharts-23.08.3-x86_64-1.txz: Upgraded.
kde/kquickimageeditor-0.3.0-x86_64-1.txz: Upgraded.
kde/krdc-23.08.3-x86_64-1.txz: Upgraded.
kde/kreversi-23.08.3-x86_64-1.txz: Upgraded.
kde/krfb-23.08.3-x86_64-1.txz: Upgraded.
kde/kross-interpreters-23.08.3-x86_64-1.txz: Upgraded.
kde/kruler-23.08.3-x86_64-1.txz: Upgraded.
kde/ksanecore-23.08.3-x86_64-1.txz: Upgraded.
kde/kshisen-23.08.3-x86_64-1.txz: Upgraded.
kde/ksirk-23.08.3-x86_64-1.txz: Upgraded.
kde/ksmtp-23.08.3-x86_64-1.txz: Upgraded.
kde/ksnakeduel-23.08.3-x86_64-1.txz: Upgraded.
kde/kspaceduel-23.08.3-x86_64-1.txz: Upgraded.
kde/ksquares-23.08.3-x86_64-1.txz: Upgraded.
kde/ksudoku-23.08.3-x86_64-1.txz: Upgraded.
kde/ksystemlog-23.08.3-x86_64-1.txz: Upgraded.
kde/kteatime-23.08.3-x86_64-1.txz: Upgraded.
kde/ktimer-23.08.3-x86_64-1.txz: Upgraded.
kde/ktnef-23.08.3-x86_64-1.txz: Upgraded.
kde/ktorrent-23.08.3-x86_64-1.txz: Upgraded.
kde/ktouch-23.08.3-x86_64-1.txz: Upgraded.
kde/kturtle-23.08.3-x86_64-1.txz: Upgraded.
kde/kubrick-23.08.3-x86_64-1.txz: Upgraded.
kde/kwalletmanager-23.08.3-x86_64-1.txz: Upgraded.
kde/kwave-23.08.3-x86_64-1.txz: Upgraded.
kde/kwordquiz-23.08.3-x86_64-1.txz: Upgraded.
kde/libgravatar-23.08.3-x86_64-1.txz: Upgraded.
kde/libkcddb-23.08.3-x86_64-1.txz: Upgraded.
kde/libkcompactdisc-23.08.3-x86_64-1.txz: Upgraded.
kde/libkdcraw-23.08.3-x86_64-1.txz: Upgraded.
kde/libkdegames-23.08.3-x86_64-1.txz: Upgraded.
kde/libkdepim-23.08.3-x86_64-1.txz: Upgraded.
kde/libkeduvocdocument-23.08.3-x86_64-1.txz: Upgraded.
kde/libkexiv2-23.08.3-x86_64-1.txz: Upgraded.
kde/libkgapi-23.08.3-x86_64-1.txz: Upgraded.
kde/libkipi-23.08.3-x86_64-1.txz: Upgraded.
kde/libkleo-23.08.3-x86_64-1.txz: Upgraded.
kde/libkmahjongg-23.08.3-x86_64-1.txz: Upgraded.
kde/libkomparediff2-23.08.3-x86_64-1.txz: Upgraded.
kde/libksane-23.08.3-x86_64-1.txz: Upgraded.
kde/libksieve-23.08.3-x86_64-1.txz: Upgraded.
kde/libktorrent-23.08.3-x86_64-1.txz: Upgraded.
kde/lokalize-23.08.3-x86_64-1.txz: Upgraded.
kde/lskat-23.08.3-x86_64-1.txz: Upgraded.
kde/mailcommon-23.08.3-x86_64-1.txz: Upgraded.
kde/mailimporter-23.08.3-x86_64-1.txz: Upgraded.
kde/marble-23.08.3-x86_64-1.txz: Upgraded.
kde/markdownpart-23.08.3-x86_64-1.txz: Upgraded.
kde/mbox-importer-23.08.3-x86_64-1.txz: Upgraded.
kde/merkuro-23.08.3-x86_64-1.txz: Upgraded.
kde/messagelib-23.08.3-x86_64-1.txz: Upgraded.
kde/minuet-23.08.3-x86_64-1.txz: Upgraded.
kde/okular-23.08.3-x86_64-1.txz: Upgraded.
kde/palapeli-23.08.3-x86_64-1.txz: Upgraded.
kde/parley-23.08.3-x86_64-1.txz: Upgraded.
kde/partitionmanager-23.08.3-x86_64-1.txz: Upgraded.
kde/picmi-23.08.3-x86_64-1.txz: Upgraded.
kde/pim-data-exporter-23.08.3-x86_64-1.txz: Upgraded.
kde/pim-sieve-editor-23.08.3-x86_64-1.txz: Upgraded.
kde/pimcommon-23.08.3-x86_64-1.txz: Upgraded.
kde/poxml-23.08.3-x86_64-1.txz: Upgraded.
kde/print-manager-23.08.3-x86_64-1.txz: Upgraded.
kde/rocs-23.08.3-x86_64-1.txz: Upgraded.
kde/skanlite-23.08.3-x86_64-1.txz: Upgraded.
kde/skanpage-23.08.3-x86_64-1.txz: Upgraded.
kde/spectacle-23.08.3-x86_64-1.txz: Upgraded.
kde/step-23.08.3-x86_64-1.txz: Upgraded.
kde/svgpart-23.08.3-x86_64-1.txz: Upgraded.
kde/sweeper-23.08.3-x86_64-1.txz: Upgraded.
kde/umbrello-23.08.3-x86_64-1.txz: Upgraded.
kde/yakuake-23.08.3-x86_64-1.txz: Upgraded.
kde/zanshin-23.08.3-x86_64-1.txz: Upgraded.
n/autofs-5.1.9-x86_64-1.txz: Upgraded.
n/openvpn-2.6.7-x86_64-1.txz: Upgraded.
x/fcitx5-5.1.5-x86_64-1.txz: Upgraded.
Wed Nov 8 22:04:25 UTC 2023
a/kbd-2.6.3-x86_64-1.txz: Upgraded.
       Thanks to Robby Workman.
a/kernel-firmware-20231107_2340796-noarch-1.txz: Upgraded.
a/kernel-generic-6.1.62-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.62-x86_64-1.txz: Upgraded.
a/kernel-modules-6.1.62-x86_64-1.txz: Upgraded.
ap/sudo-1.9.15p1-x86_64-1.txz: Upgraded.
       This is a bugfix release:
       Fixed a bug introduced in sudo 1.9.15 that prevented LDAP-based sudoers
       from being able to read the ldap.conf file.
d/kernel-headers-6.1.62-x86-1.txz: Upgraded.
k/kernel-source-6.1.62-noarch-1.txz: Upgraded.
kde/plasma-wayland-protocols-1.11.0-x86_64-1.txz: Upgraded.
l/liburing-2.5-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-115.4.2-x86_64-1.txz: Upgraded.
       https://www.mozilla.org/en-US/thunderbird/115.4.2/releasenotes/
xap/xlockmore-5.74-x86_64-1.txz: Upgraded.
Tue Nov 7 19:57:12 UTC 2023
ap/sudo-1.9.15-x86_64-1.txz: Upgraded.
       The sudoers plugin has been modified to make it more resilient to ROWHAMMER
       attacks on authentication and policy matching.
       The sudoers plugin now constructs the user time stamp file path name using
       the user-ID instead of the user name. This avoids a potential problem with
       user names that contain a path separator ('/') being interpreted as part of
       the path name.
       https://www.cve.org/CVERecord?id=CVE-2023-42465
       https://www.cve.org/CVERecord?id=CVE-2023-42456
ap/vim-9.0.2092-x86_64-1.txz: Upgraded.
l/libuv-1.47.0-x86_64-1.txz: Upgraded.
l/xapian-core-1.4.24-x86_64-1.txz: Upgraded.
n/bind-9.18.19-x86_64-2.txz: Rebuilt.
       Don't go automatically chowning files in /var/named, since some users may
       have special requirements. But in case anyone finds that behavior useful,
       you may set NAMED_CHOWN=YES in /etc/default/named to turn it back on.
       Unless anyone has a good objection to it, this change is considered pending
       for the next BIND upgrades in -stable.
       Thanks to Mig21.
xap/vim-gvim-9.0.2092-x86_64-1.txz: Upgraded.
Mon Nov 6 20:15:40 UTC 2023
a/btrfs-progs-6.6.1-x86_64-1.txz: Upgraded.
d/mercurial-6.5.3-x86_64-1.txz: Upgraded.
d/rust-bindgen-0.69.1-x86_64-1.txz: Upgraded.
l/exiv2-0.28.1-x86_64-1.txz: Upgraded.
l/jasper-4.0.1-x86_64-1.txz: Upgraded.
x/fcitx5-5.1.4-x86_64-1.txz: Upgraded.
xap/gimp-2.10.36-x86_64-1.txz: Upgraded.
Sat Nov 4 17:56:53 UTC 2023
l/sof-firmware-2023.09.1-noarch-1.txz: Upgraded.
n/iproute2-6.6.0-x86_64-1.txz: Upgraded.
x/fcitx5-5.1.3-x86_64-1.txz: Upgraded.
x/fcitx5-qt-5.1.3-x86_64-1.txz: Upgraded.
Fri Nov 3 23:47:27 UTC 2023
a/btrfs-progs-6.6-x86_64-1.txz: Upgraded.
a/hwdata-0.376-noarch-1.txz: Upgraded.
l/elfutils-0.190-x86_64-1.txz: Upgraded.
xfce/elementary-xfce-0.18-x86_64-2.txz: Rebuilt.
       Eliminate dangling symlinks. Thanks to marav.
extra/sendmail/sendmail-8.17.2-x86_64-3.txz: Rebuilt.
       Recompiled against icu4c-74.1. Thanks to HQuest.
extra/sendmail/sendmail-cf-8.17.2-noarch-3.txz: Rebuilt.
Fri Nov 3 18:38:03 UTC 2023
a/sysvinit-scripts-15.1-noarch-8.txz: Rebuilt.
       rc.S: clear /tmp/{.ICE-unix,.X11-unix}. Thanks to selfprogrammed.
ap/inxi-3.3.31_2-noarch-1.txz: Upgraded.
d/git-2.42.1-x86_64-1.txz: Upgraded.
l/SDL2-2.28.5-x86_64-1.txz: Upgraded.
l/fuse3-3.16.2-x86_64-1.txz: Upgraded.
l/libgsf-1.14.51-x86_64-1.txz: Upgraded.
Thu Nov 2 20:33:13 UTC 2023
a/gawk-5.3.0-x86_64-1.txz: Upgraded.
a/kernel-firmware-20231030_2b304bf-noarch-1.txz: Upgraded.
a/kernel-generic-6.1.61-x86_64-1.txz: Upgraded.
a/kernel-huge-6.1.61-x86_64-1.txz: Upgraded.
       -EXT2_FS_POSIX_ACL y
       -EXT2_FS_SECURITY y
       -EXT2_FS_XATTR y
       -EXT3_FS_POSIX_ACL y
       -EXT3_FS_SECURITY y
       EXT2_FS y -> n
       EXT3_FS y -> n
       NLS_ISO8859_15 m -> y
       SCSI_SMARTPQI m -> y
       +EXT4_USE_FOR_EXT2 y
a/kernel-modules-6.1.61-x86_64-1.txz: Upgraded.
d/kernel-headers-6.1.61-x86-1.txz: Upgraded.
k/kernel-source-6.1.61-noarch-1.txz: Upgraded.
       -EXT2_FS_SECURITY y
       -EXT2_FS_XATTR y
       -EXT3_FS_SECURITY y
       EXT2_FS y -> n
       EXT3_FS y -> n
       NLS_ISO8859_1 m -> y
       NLS_UTF8 m -> y
       SCSI_VIRTIO m -> y
kde/calligra-3.2.1-x86_64-35.txz: Rebuilt.
       Recompiled against poppler-23.11.0.
kde/cantor-23.08.2-x86_64-2.txz: Rebuilt.
kde/fcitx5-configtool-5.1.2-x86_64-1.txz: Upgraded.
kde/kfilemetadata-5.111.0-x86_64-3.txz: Rebuilt.
kde/kile-2.9.93-x86_64-29.txz: Rebuilt.
kde/kitinerary-23.08.2-x86_64-2.txz: Rebuilt.
kde/krita-5.2.1-x86_64-2.txz: Rebuilt.
kde/okular-23.08.2-x86_64-2.txz: Rebuilt.
l/pipewire-0.3.84-x86_64-1.txz: Upgraded.
l/poppler-23.11.0-x86_64-1.txz: Upgraded.
n/postfix-3.8.3-x86_64-1.txz: Upgraded.
x/fcitx5-5.1.2-x86_64-1.txz: Upgraded.
x/fcitx5-anthy-5.1.2-x86_64-1.txz: Upgraded.
x/fcitx5-chinese-addons-5.1.2-x86_64-1.txz: Upgraded.
x/fcitx5-hangul-5.1.1-x86_64-1.txz: Upgraded.
x/fcitx5-qt-5.1.2-x86_64-1.txz: Upgraded.
x/fcitx5-sayura-5.1.1-x86_64-1.txz: Upgraded.
x/libime-1.1.3-x86_64-1.txz: Upgraded.
Wed Nov 1 23:42:44 UTC 2023
a/aaa_libraries-15.1-x86_64-22.txz: Rebuilt.
       Upgraded: libz.so.1.3, libcares.so.2.7.2, libglib-2.0.so.0.7800.1,
       libgmodule-2.0.so.0.7800.1, libjson-c.so.5.3.0, liblzma.so.5.4.5,
       libmpfr.so.6.2.1.
       Removed: libboost_*.so.1.82.0, libicu*.so.72.1.
       Added (temporarily): libicu*.so.73.2.
a/mcelog-196-x86_64-1.txz: Upgraded.
a/shadow-4.14.2-x86_64-1.txz: Upgraded.
a/xfsprogs-6.5.0-x86_64-2.txz: Rebuilt.
a/xz-5.4.5-x86_64-1.txz: Upgraded.
ap/ghostscript-10.02.1-x86_64-1.txz: Upgraded.
ap/inxi-3.3.31_1-noarch-1.txz: Upgraded.
ap/sqlite-3.44.0-x86_64-1.txz: Upgraded.
       Compiled against icu4c-74.1.
kde/kdeplasma-addons-5.27.9-x86_64-2.txz: Rebuilt.
kde/konsole-23.08.2-x86_64-2.txz: Rebuilt.
kde/krita-5.2.1-x86_64-1.txz: Upgraded.
kde/plasma-workspace-5.27.9.1-x86_64-2.txz: Rebuilt.
l/boost-1.83.0-x86_64-2.txz: Rebuilt.
l/harfbuzz-8.2.2-x86_64-2.txz: Rebuilt.
l/icu4c-74.1-x86_64-1.txz: Upgraded.
l/libical-3.0.17-x86_64-2.txz: Rebuilt.
l/libqalculate-4.8.1-x86_64-2.txz: Rebuilt.
l/libvisio-0.1.7-x86_64-12.txz: Rebuilt.
l/mozjs102-102.15.1esr-x86_64-2.txz: Rebuilt.
l/nodejs-20.9.0-x86_64-2.txz: Rebuilt.
l/qt5-5.15.11_20231024_2b45d158-x86_64-1.txz: Upgraded.
l/qt5-webkit-5.212.0_alpha4-x86_64-12.txz: Rebuilt.
l/vte-0.74.1-x86_64-2.txz: Rebuilt.
n/dovecot-2.3.21-x86_64-2.txz: Rebuilt.
n/php-8.2.12-x86_64-2.txz: Rebuilt.
n/postfix-3.8.2-x86_64-2.txz: Rebuilt.
n/samba-4.19.2-x86_64-2.txz: Rebuilt.
n/tin-2.6.2-x86_64-3.txz: Rebuilt.
t/texlive-2023.230322-x86_64-6.txz: Rebuilt.
tcl/tcl-8.6.13-x86_64-2.txz: Rebuilt.
xfce/xfconf-4.18.3-x86_64-1.txz: Upgraded.
Tue Oct 31 18:49:18 UTC 2023
ap/ispell-3.4.06-x86_64-1.txz: Upgraded.
d/llvm-17.0.4-x86_64-1.txz: Upgraded.
d/strace-6.6-x86_64-1.txz: Upgraded.
l/libsigc++-2.12.1-x86_64-1.txz: Upgraded.
n/p11-kit-0.25.2-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/bash-5.2.021-i586-1.txz: Upgraded.
ap/rdfind-1.6.0-i586-1.txz: Added.
ap/sudo-1.9.15p2-i586-1.txz: Upgraded.
l/ffmpeg-5.1.4-i586-1.txz: Upgraded.
n/dhcpcd-10.0.5-i586-1.txz: Upgraded.
n/whois-5.5.20-i586-1.txz: Upgraded.
xfce/xfce4-whiskermenu-plugin-2.8.1-i586-1.txz: Upgraded.
a/kbd-2.6.3-i586-2.txz: Rebuilt.
kde/akonadi-23.08.3-i586-1.txz: Upgraded.
kde/akonadi-calendar-23.08.3-i586-1.txz: Upgraded.
kde/akonadi-calendar-tools-23.08.3-i586-1.txz: Upgraded.
kde/akonadi-contacts-23.08.3-i586-1.txz: Upgraded.
kde/akonadi-import-wizard-23.08.3-i586-1.txz: Upgraded.
kde/akonadi-mime-23.08.3-i586-1.txz: Upgraded.
kde/akonadi-notes-23.08.3-i586-1.txz: Upgraded.
kde/akonadi-search-23.08.3-i586-1.txz: Upgraded.
kde/akonadiconsole-23.08.3-i586-1.txz: Upgraded.
kde/akregator-23.08.3-i586-1.txz: Upgraded.
kde/alligator-23.08.3-i586-1.txz: Upgraded.
kde/analitza-23.08.3-i586-1.txz: Upgraded.
kde/ark-23.08.3-i586-1.txz: Upgraded.
kde/artikulate-23.08.3-i586-1.txz: Upgraded.
kde/audiocd-kio-23.08.3-i586-1.txz: Upgraded.
kde/baloo-widgets-23.08.3-i586-1.txz: Upgraded.
kde/blinken-23.08.3-i586-1.txz: Upgraded.
kde/bomber-23.08.3-i586-1.txz: Upgraded.
kde/bovo-23.08.3-i586-1.txz: Upgraded.
kde/calendarsupport-23.08.3-i586-1.txz: Upgraded.
kde/cantor-23.08.3-i586-1.txz: Upgraded.
kde/cervisia-23.08.3-i586-1.txz: Upgraded.
kde/dolphin-23.08.3-i586-1.txz: Upgraded.
kde/dolphin-plugins-23.08.3-i586-1.txz: Upgraded.
kde/dragon-23.08.3-i586-1.txz: Upgraded.
kde/elisa-23.08.3-i586-1.txz: Upgraded.
kde/eventviews-23.08.3-i586-1.txz: Upgraded.
kde/falkon-23.08.3-i586-1.txz: Upgraded.
kde/ffmpegthumbs-23.08.3-i586-1.txz: Upgraded.
kde/filelight-23.08.3-i586-1.txz: Upgraded.
kde/ghostwriter-23.08.3-i586-1.txz: Upgraded.
kde/granatier-23.08.3-i586-1.txz: Upgraded.
kde/grantlee-editor-23.08.3-i586-1.txz: Upgraded.
kde/grantleetheme-23.08.3-i586-1.txz: Upgraded.
kde/gwenview-23.08.3-i586-1.txz: Upgraded.
kde/incidenceeditor-23.08.3-i586-1.txz: Upgraded.
kde/itinerary-23.08.3-i586-1.txz: Upgraded.
kde/juk-23.08.3-i586-1.txz: Upgraded.
kde/k3b-23.08.3-i586-1.txz: Upgraded.
kde/kaddressbook-23.08.3-i586-1.txz: Upgraded.
kde/kalarm-23.08.3-i586-1.txz: Upgraded.
kde/kalgebra-23.08.3-i586-1.txz: Upgraded.
kde/kalzium-23.08.3-i586-1.txz: Upgraded.
kde/kamera-23.08.3-i586-1.txz: Upgraded.
kde/kamoso-23.08.3-i586-1.txz: Upgraded.
kde/kanagram-23.08.3-i586-1.txz: Upgraded.
kde/kapman-23.08.3-i586-1.txz: Upgraded.
kde/kapptemplate-23.08.3-i586-1.txz: Upgraded.
kde/kate-23.08.3-i586-1.txz: Upgraded.
kde/katomic-23.08.3-i586-1.txz: Upgraded.
kde/kbackup-23.08.3-i586-1.txz: Upgraded.
kde/kblackbox-23.08.3-i586-1.txz: Upgraded.
kde/kblocks-23.08.3-i586-1.txz: Upgraded.
kde/kbounce-23.08.3-i586-1.txz: Upgraded.
kde/kbreakout-23.08.3-i586-1.txz: Upgraded.
kde/kbruch-23.08.3-i586-1.txz: Upgraded.
kde/kcachegrind-23.08.3-i586-1.txz: Upgraded.
kde/kcalc-23.08.3-i586-1.txz: Upgraded.
kde/kcalutils-23.08.3-i586-1.txz: Upgraded.
kde/kcharselect-23.08.3-i586-1.txz: Upgraded.
kde/kcolorchooser-23.08.3-i586-1.txz: Upgraded.
kde/kcron-23.08.3-i586-1.txz: Upgraded.
kde/kde-dev-scripts-23.08.3-i586-1.txz: Upgraded.
kde/kde-dev-utils-23.08.3-i586-1.txz: Upgraded.
kde/kde-inotify-survey-23.08.3-i586-1.txz: Upgraded.
kde/kdebugsettings-23.08.3-i586-1.txz: Upgraded.
kde/kdeconnect-kde-23.08.3-i586-1.txz: Upgraded.
kde/kdeedu-data-23.08.3-i586-1.txz: Upgraded.
kde/kdegraphics-mobipocket-23.08.3-i586-1.txz: Upgraded.
kde/kdegraphics-thumbnailers-23.08.3-i586-1.txz: Upgraded.
kde/kdenetwork-filesharing-23.08.3-i586-1.txz: Upgraded.
kde/kdenlive-23.08.3-i586-1.txz: Upgraded.
kde/kdepim-addons-23.08.3-i586-1.txz: Upgraded.
kde/kdepim-runtime-23.08.3-i586-1.txz: Upgraded.
kde/kdesdk-kio-23.08.3-i586-1.txz: Upgraded.
kde/kdesdk-thumbnailers-23.08.3-i586-1.txz: Upgraded.
kde/kdev-php-23.08.3-i586-1.txz: Upgraded.
kde/kdev-python-23.08.3-i586-1.txz: Upgraded.
kde/kdevelop-23.08.3-i586-1.txz: Upgraded.
kde/kdf-23.08.3-i586-1.txz: Upgraded.
kde/kdialog-23.08.3-i586-1.txz: Upgraded.
kde/kdiamond-23.08.3-i586-1.txz: Upgraded.
kde/keditbookmarks-23.08.3-i586-1.txz: Upgraded.
kde/keysmith-23.08.3-i586-1.txz: Upgraded.
kde/kfind-23.08.3-i586-1.txz: Upgraded.
kde/kfourinline-23.08.3-i586-1.txz: Upgraded.
kde/kgeography-23.08.3-i586-1.txz: Upgraded.
kde/kget-23.08.3-i586-1.txz: Upgraded.
kde/kgoldrunner-23.08.3-i586-1.txz: Upgraded.
kde/kgpg-23.08.3-i586-1.txz: Upgraded.
kde/khangman-23.08.3-i586-1.txz: Upgraded.
kde/khelpcenter-23.08.3-i586-1.txz: Upgraded.
kde/kidentitymanagement-23.08.3-i586-1.txz: Upgraded.
kde/kig-23.08.3-i586-1.txz: Upgraded.
kde/kigo-23.08.3-i586-1.txz: Upgraded.
kde/killbots-23.08.3-i586-1.txz: Upgraded.
kde/kimagemapeditor-23.08.3-i586-1.txz: Upgraded.
kde/kimap-23.08.3-i586-1.txz: Upgraded.
kde/kio-admin-23.08.3-i586-1.txz: Upgraded.
kde/kio-extras-23.08.3-i586-1.txz: Upgraded.
kde/kio-gdrive-23.08.3-i586-1.txz: Upgraded.
kde/kio-zeroconf-23.08.3-i586-1.txz: Upgraded.
kde/kipi-plugins-23.08.3-i586-1.txz: Upgraded.
kde/kirigami-gallery-23.08.3-i586-1.txz: Upgraded.
kde/kiriki-23.08.3-i586-1.txz: Upgraded.
kde/kiten-23.08.3-i586-1.txz: Upgraded.
kde/kitinerary-23.08.3-i586-1.txz: Upgraded.
kde/kjumpingcube-23.08.3-i586-1.txz: Upgraded.
kde/kldap-23.08.3-i586-1.txz: Upgraded.
kde/kleopatra-23.08.3-i586-1.txz: Upgraded.
kde/klickety-23.08.3-i586-1.txz: Upgraded.
kde/klines-23.08.3-i586-1.txz: Upgraded.
kde/kmag-23.08.3-i586-1.txz: Upgraded.
kde/kmahjongg-23.08.3-i586-1.txz: Upgraded.
kde/kmail-23.08.3-i586-1.txz: Upgraded.
kde/kmail-account-wizard-23.08.3-i586-1.txz: Upgraded.
kde/kmailtransport-23.08.3-i586-1.txz: Upgraded.
kde/kmbox-23.08.3-i586-1.txz: Upgraded.
kde/kmime-23.08.3-i586-1.txz: Upgraded.
kde/kmines-23.08.3-i586-1.txz: Upgraded.
kde/kmix-23.08.3-i586-1.txz: Upgraded.
kde/kmousetool-23.08.3-i586-1.txz: Upgraded.
kde/kmouth-23.08.3-i586-1.txz: Upgraded.
kde/kmplot-23.08.3-i586-1.txz: Upgraded.
kde/knavalbattle-23.08.3-i586-1.txz: Upgraded.
kde/knetwalk-23.08.3-i586-1.txz: Upgraded.
kde/knights-23.08.3-i586-1.txz: Upgraded.
kde/knotes-23.08.3-i586-1.txz: Upgraded.
kde/kolf-23.08.3-i586-1.txz: Upgraded.
kde/kollision-23.08.3-i586-1.txz: Upgraded.
kde/kolourpaint-23.08.3-i586-1.txz: Upgraded.
kde/kompare-23.08.3-i586-1.txz: Upgraded.
kde/konqueror-23.08.3-i586-1.txz: Upgraded.
kde/konquest-23.08.3-i586-1.txz: Upgraded.
kde/konsole-23.08.3-i586-1.txz: Upgraded.
kde/kontact-23.08.3-i586-1.txz: Upgraded.
kde/kontactinterface-23.08.3-i586-1.txz: Upgraded.
kde/kontrast-23.08.3-i586-1.txz: Upgraded.
kde/konversation-23.08.3-i586-1.txz: Upgraded.
kde/kopeninghours-23.08.3-i586-1.txz: Upgraded.
kde/kopete-23.08.3-i586-1.txz: Upgraded.
kde/korganizer-23.08.3-i586-1.txz: Upgraded.
kde/kosmindoormap-23.08.3-i586-1.txz: Upgraded.
kde/kpat-23.08.3-i586-1.txz: Upgraded.
kde/kpimtextedit-23.08.3-i586-1.txz: Upgraded.
kde/kpkpass-23.08.3-i586-1.txz: Upgraded.
kde/kpmcore-23.08.3-i586-1.txz: Upgraded.
kde/kpublictransport-23.08.3-i586-1.txz: Upgraded.
kde/kqtquickcharts-23.08.3-i586-1.txz: Upgraded.
kde/kquickimageeditor-0.3.0-i586-1.txz: Upgraded.
kde/krdc-23.08.3-i586-1.txz: Upgraded.
kde/kreversi-23.08.3-i586-1.txz: Upgraded.
kde/krfb-23.08.3-i586-1.txz: Upgraded.
kde/kross-interpreters-23.08.3-i586-1.txz: Upgraded.
kde/kruler-23.08.3-i586-1.txz: Upgraded.
kde/ksanecore-23.08.3-i586-1.txz: Upgraded.
kde/kshisen-23.08.3-i586-1.txz: Upgraded.
kde/ksirk-23.08.3-i586-1.txz: Upgraded.
kde/ksmtp-23.08.3-i586-1.txz: Upgraded.
kde/ksnakeduel-23.08.3-i586-1.txz: Upgraded.
kde/kspaceduel-23.08.3-i586-1.txz: Upgraded.
kde/ksquares-23.08.3-i586-1.txz: Upgraded.
kde/ksudoku-23.08.3-i586-1.txz: Upgraded.
kde/ksystemlog-23.08.3-i586-1.txz: Upgraded.
kde/kteatime-23.08.3-i586-1.txz: Upgraded.
kde/ktimer-23.08.3-i586-1.txz: Upgraded.
kde/ktnef-23.08.3-i586-1.txz: Upgraded.
kde/ktorrent-23.08.3-i586-1.txz: Upgraded.
kde/ktouch-23.08.3-i586-1.txz: Upgraded.
kde/kturtle-23.08.3-i586-1.txz: Upgraded.
kde/kubrick-23.08.3-i586-1.txz: Upgraded.
kde/kwalletmanager-23.08.3-i586-1.txz: Upgraded.
kde/kwave-23.08.3-i586-1.txz: Upgraded.
kde/kwordquiz-23.08.3-i586-1.txz: Upgraded.
kde/libgravatar-23.08.3-i586-1.txz: Upgraded.
kde/libkcddb-23.08.3-i586-1.txz: Upgraded.
kde/libkcompactdisc-23.08.3-i586-1.txz: Upgraded.
kde/libkdcraw-23.08.3-i586-1.txz: Upgraded.
kde/libkdegames-23.08.3-i586-1.txz: Upgraded.
kde/libkdepim-23.08.3-i586-1.txz: Upgraded.
kde/libkeduvocdocument-23.08.3-i586-1.txz: Upgraded.
kde/libkexiv2-23.08.3-i586-1.txz: Upgraded.
kde/libkgapi-23.08.3-i586-1.txz: Upgraded.
kde/libkipi-23.08.3-i586-1.txz: Upgraded.
kde/libkleo-23.08.3-i586-1.txz: Upgraded.
kde/libkmahjongg-23.08.3-i586-1.txz: Upgraded.
kde/libkomparediff2-23.08.3-i586-1.txz: Upgraded.
kde/libksane-23.08.3-i586-1.txz: Upgraded.
kde/libksieve-23.08.3-i586-1.txz: Upgraded.
kde/libktorrent-23.08.3-i586-1.txz: Upgraded.
kde/lokalize-23.08.3-i586-1.txz: Upgraded.
kde/lskat-23.08.3-i586-1.txz: Upgraded.
kde/mailcommon-23.08.3-i586-1.txz: Upgraded.
kde/mailimporter-23.08.3-i586-1.txz: Upgraded.
kde/marble-23.08.3-i586-1.txz: Upgraded.
kde/markdownpart-23.08.3-i586-1.txz: Upgraded.
kde/mbox-importer-23.08.3-i586-1.txz: Upgraded.
kde/merkuro-23.08.3-i586-1.txz: Upgraded.
kde/messagelib-23.08.3-i586-1.txz: Upgraded.
kde/minuet-23.08.3-i586-1.txz: Upgraded.
kde/okular-23.08.3-i586-1.txz: Upgraded.
kde/palapeli-23.08.3-i586-1.txz: Upgraded.
kde/parley-23.08.3-i586-1.txz: Upgraded.
kde/partitionmanager-23.08.3-i586-1.txz: Upgraded.
kde/picmi-23.08.3-i586-1.txz: Upgraded.
kde/pim-data-exporter-23.08.3-i586-1.txz: Upgraded.
kde/pim-sieve-editor-23.08.3-i586-1.txz: Upgraded.
kde/pimcommon-23.08.3-i586-1.txz: Upgraded.
kde/poxml-23.08.3-i586-1.txz: Upgraded.
kde/print-manager-23.08.3-i586-1.txz: Upgraded.
kde/rocs-23.08.3-i586-1.txz: Upgraded.
kde/skanlite-23.08.3-i586-1.txz: Upgraded.
kde/skanpage-23.08.3-i586-1.txz: Upgraded.
kde/spectacle-23.08.3-i586-1.txz: Upgraded.
kde/step-23.08.3-i586-1.txz: Upgraded.
kde/svgpart-23.08.3-i586-1.txz: Upgraded.
kde/sweeper-23.08.3-i586-1.txz: Upgraded.
kde/umbrello-23.08.3-i586-1.txz: Upgraded.
kde/yakuake-23.08.3-i586-1.txz: Upgraded.
kde/zanshin-23.08.3-i586-1.txz: Upgraded.
n/autofs-5.1.9-i586-1.txz: Upgraded.
n/openvpn-2.6.7-i586-1.txz: Upgraded.
x/fcitx5-5.1.5-i586-1.txz: Upgraded.
a/kbd-2.6.3-i586-1.txz: Upgraded.
a/kernel-generic-6.1.62-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.62_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.62-i586-1.txz: Upgraded.
a/kernel-huge-smp-6.1.62_smp-i686-1.txz: Upgraded.
a/kernel-modules-6.1.62-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.62_smp-i686-1.txz: Upgraded.
ap/sudo-1.9.15p1-i586-1.txz: Upgraded.
d/kernel-headers-6.1.62_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.62_smp-noarch-1.txz: Upgraded.
kde/plasma-wayland-protocols-1.11.0-i586-1.txz: Upgraded.
l/liburing-2.5-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-115.4.2-i686-1.txz: Upgraded.
xap/xlockmore-5.74-i586-1.txz: Upgraded.
extra/linux-6.1.62-nosmp-sdk/*: Upgraded.
ap/sudo-1.9.15-i586-1.txz: Upgraded.
       the path name.
ap/vim-9.0.2092-i586-1.txz: Upgraded.
l/libuv-1.47.0-i586-1.txz: Upgraded.
l/xapian-core-1.4.24-i586-1.txz: Upgraded.
n/bind-9.18.19-i586-2.txz: Rebuilt.
       Thanks to Mig21.
xap/vim-gvim-9.0.2092-i586-1.txz: Upgraded.
a/btrfs-progs-6.6.1-i586-1.txz: Upgraded.
d/mercurial-6.5.3-i586-1.txz: Upgraded.
d/rust-bindgen-0.69.1-i686-1.txz: Upgraded.
l/exiv2-0.28.1-i586-1.txz: Upgraded.
l/jasper-4.0.1-i586-1.txz: Upgraded.
x/fcitx5-5.1.4-i586-1.txz: Upgraded.
xap/gimp-2.10.36-i586-1.txz: Upgraded.
n/iproute2-6.6.0-i586-1.txz: Upgraded.
x/fcitx5-5.1.3-i586-1.txz: Upgraded.
x/fcitx5-qt-5.1.3-i586-1.txz: Upgraded.
a/btrfs-progs-6.6-i586-1.txz: Upgraded.
l/elfutils-0.190-i586-1.txz: Upgraded.
xfce/elementary-xfce-0.18-i586-2.txz: Rebuilt.
extra/sendmail/sendmail-8.17.2-i586-3.txz: Rebuilt.
d/git-2.42.1-i586-1.txz: Upgraded.
l/SDL2-2.28.5-i586-1.txz: Upgraded.
l/fuse3-3.16.2-i586-1.txz: Upgraded.
l/libgsf-1.14.51-i586-1.txz: Upgraded.
a/gawk-5.3.0-i586-1.txz: Upgraded.
a/kernel-generic-6.1.61-i586-1.txz: Upgraded.
a/kernel-generic-smp-6.1.61_smp-i686-1.txz: Upgraded.
a/kernel-huge-6.1.61-i586-1.txz: Upgraded.
       -EXT2_FS_SECURITY y
       -EXT2_FS_XATTR y
       -EXT3_FS_SECURITY y
       EXT2_FS y -> n
       EXT3_FS y -> n
a/kernel-huge-smp-6.1.61_smp-i686-1.txz: Upgraded.
       -EXT2_FS_SECURITY y
       -EXT2_FS_XATTR y
       -EXT3_FS_SECURITY y
       EXT2_FS y -> n
       EXT3_FS y -> n
a/kernel-modules-6.1.61-i586-1.txz: Upgraded.
a/kernel-modules-smp-6.1.61_smp-i686-1.txz: Upgraded.
d/kernel-headers-6.1.61_smp-x86-1.txz: Upgraded.
k/kernel-source-6.1.61_smp-noarch-1.txz: Upgraded.
       -EXT2_FS_SECURITY y
       -EXT2_FS_XATTR y
       -EXT3_FS_SECURITY y
       EXT2_FS y -> n
       EXT3_FS y -> n
       NLS_UTF8 m -> y
       SCSI_VIRTIO m -> y
kde/calligra-3.2.1-i586-35.txz: Rebuilt.
kde/cantor-23.08.2-i586-2.txz: Rebuilt.
kde/fcitx5-configtool-5.1.2-i586-1.txz: Upgraded.
kde/kfilemetadata-5.111.0-i586-3.txz: Rebuilt.
kde/kile-2.9.93-i586-29.txz: Rebuilt.
kde/kitinerary-23.08.2-i586-2.txz: Rebuilt.
kde/krita-5.2.1-i586-2.txz: Rebuilt.
kde/okular-23.08.2-i586-2.txz: Rebuilt.
l/pipewire-0.3.84-i586-1.txz: Upgraded.
l/poppler-23.11.0-i586-1.txz: Upgraded.
n/postfix-3.8.3-i586-1.txz: Upgraded.
x/fcitx5-5.1.2-i586-1.txz: Upgraded.
x/fcitx5-anthy-5.1.2-i586-1.txz: Upgraded.
x/fcitx5-chinese-addons-5.1.2-i586-1.txz: Upgraded.
x/fcitx5-hangul-5.1.1-i586-1.txz: Upgraded.
x/fcitx5-qt-5.1.2-i586-1.txz: Upgraded.
x/fcitx5-sayura-5.1.1-i586-1.txz: Upgraded.
x/libime-1.1.3-i586-1.txz: Upgraded.
extra/linux-6.1.61-nosmp-sdk/*: Upgraded.
a/aaa_libraries-15.1-i586-22.txz: Rebuilt.
       libmpfr.so.6.2.1.
a/mcelog-196-i586-1.txz: Upgraded.
a/shadow-4.14.2-i586-1.txz: Upgraded.
a/xfsprogs-6.5.0-i586-2.txz: Rebuilt.
a/xz-5.4.5-i586-1.txz: Upgraded.
ap/ghostscript-10.02.1-i586-1.txz: Upgraded.
ap/sqlite-3.44.0-i586-1.txz: Upgraded.
kde/kdeplasma-addons-5.27.9-i586-2.txz: Rebuilt.
kde/konsole-23.08.2-i586-2.txz: Rebuilt.
kde/krita-5.2.1-i586-1.txz: Upgraded.
kde/plasma-workspace-5.27.9.1-i586-2.txz: Rebuilt.
l/boost-1.83.0-i586-2.txz: Rebuilt.
l/harfbuzz-8.2.2-i586-2.txz: Rebuilt.
l/icu4c-74.1-i586-1.txz: Upgraded.
l/libical-3.0.17-i586-2.txz: Rebuilt.
l/libqalculate-4.8.1-i586-2.txz: Rebuilt.
l/libvisio-0.1.7-i586-12.txz: Rebuilt.
l/mozjs102-102.15.1esr-i686-2.txz: Rebuilt.
l/nodejs-20.9.0-i586-2.txz: Rebuilt.
l/qt5-5.15.11_20231024_2b45d158-i586-1.txz: Upgraded.
l/qt5-webkit-5.212.0_alpha4-i586-12.txz: Rebuilt.
l/vte-0.74.1-i586-2.txz: Rebuilt.
n/dovecot-2.3.21-i586-2.txz: Rebuilt.
n/php-8.2.12-i586-2.txz: Rebuilt.
n/postfix-3.8.2-i586-2.txz: Rebuilt.
n/samba-4.19.2-i586-2.txz: Rebuilt.
n/tin-2.6.2-i586-3.txz: Rebuilt.
t/texlive-2023.230322-i586-6.txz: Rebuilt.
tcl/tcl-8.6.13-i586-2.txz: Rebuilt.
xfce/xfconf-4.18.3-i586-1.txz: Upgraded.
ap/ispell-3.4.06-i586-1.txz: Upgraded.
d/llvm-17.0.4-i586-1.txz: Upgraded.
d/strace-6.6-i586-1.txz: Upgraded.
l/libsigc++-2.12.1-i586-1.txz: Upgraded.
n/p11-kit-0.25.2-i586-1.txz: Upgraded.
Post Napisano: 17 Nov 2023, 17:33
Slackware 64-bit
Thu Nov 16 20:51:47 UTC 2023
l/jasper-4.1.0-x86_64-1.txz: Upgraded.
l/pipewire-0.3.85-x86_64-1.txz: Upgraded.
l/sof-firmware-2023.09.2-noarch-1.txz: Upgraded.
n/gnutls-3.8.2-x86_64-1.txz: Upgraded.
n/libksba-1.6.5-x86_64-1.txz: Upgraded.
xap/pan-0.155-x86_64-1.txz: Upgraded.
testing/packages/rust-1.74.0-x86_64-1.txz: Upgraded.
Wed Nov 15 22:01:26 UTC 2023
a/btrfs-progs-6.6.2-x86_64-1.txz: Upgraded.
d/cmake-3.27.8-x86_64-1.txz: Upgraded.
l/netpbm-11.04.04-x86_64-1.txz: Upgraded.
l/woff2-20231106_0f4d304-x86_64-1.txz: Upgraded.
       Include the binary utilities. Thanks to TJ09.
n/bind-9.18.20-x86_64-1.txz: Upgraded.
n/c-ares-1.22.0-x86_64-1.txz: Upgraded.
n/libgcrypt-1.10.3-x86_64-1.txz: Upgraded.
n/p11-kit-0.25.3-x86_64-1.txz: Upgraded.
x/xf86-video-ati-22.0.0-x86_64-1.txz: Upgraded.
x/xf86-video-intel-20230201_b74b67f0-x86_64-1.txz: Upgraded.
x/xf86-video-nouveau-20231005_827f1e2-x86_64-1.txz: Upgraded.
x/xf86-video-r128-6.12.1-x86_64-1.txz: Upgraded.
xap/mozilla-thunderbird-115.4.3-x86_64-1.txz: Upgraded.
       https://www.mozilla.org/en-US/thunderbird/115.4.3/releasenotes/
Tue Nov 14 21:22:47 UTC 2023
a/pam-1.5.3-x86_64-2.txz: Rebuilt.
       Relocated pkgconfig files.
a/userspace-rcu-0.14.0-x86_64-2.txz: Rebuilt.
ap/mariadb-10.11.6-x86_64-1.txz: Upgraded.
       This update fixes bugs and a security issue:
       Vulnerability allows high privileged attacker with network access via
       multiple protocols to compromise the server. Successful attacks of this
       vulnerability can result in unauthorized ability to cause a hang or
       frequently repeatable crash.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2023-22084
d/llvm-17.0.5-x86_64-1.txz: Upgraded.
kde/plasma-wayland-protocols-1.11.1-x86_64-1.txz: Upgraded.
n/nfs-utils-2.6.3-x86_64-3.txz: Rebuilt.
       Only move the udev rule to /lib, don't grab libraries or pkgconfig files
       from under /usr.
Mon Nov 13 19:20:40 UTC 2023
d/vala-0.56.14-x86_64-1.txz: Upgraded.
l/gst-plugins-bad-free-1.22.7-x86_64-1.txz: Upgraded.
l/gst-plugins-base-1.22.7-x86_64-1.txz: Upgraded.
l/gst-plugins-good-1.22.7-x86_64-1.txz: Upgraded.
l/gst-plugins-libav-1.22.7-x86_64-1.txz: Upgraded.
l/gstreamer-1.22.7-x86_64-1.txz: Upgraded.
l/pango-1.51.1-x86_64-1.txz: Upgraded.
x/egl-wayland-1.1.13-x86_64-2.txz: Rebuilt.
       Install the NVidia ICD file. Thanks to marav.
extra/tigervnc/tigervnc-1.13.1-x86_64-2.txz: Rebuilt.
       Recompiled against xorg-server-21.1.9, which addresses some security issues.
       Thanks to marav.
       https://www.cve.org/CVERecord?id=CVE-2023-1393
Sun Nov 12 20:13:23 UTC 2023
a/usbutils-017-x86_64-1.txz: Upgraded.
ap/lsof-4.99.0-x86_64-1.txz: Upgraded.
kde/attica-5.112.0-x86_64-1.txz: Upgraded.
kde/baloo-5.112.0-x86_64-1.txz: Upgraded.
kde/bluez-qt-5.112.0-x86_64-1.txz: Upgraded.
kde/breeze-icons-5.112.0-noarch-1.txz: Upgraded.
kde/extra-cmake-modules-5.112.0-x86_64-1.txz: Upgraded.
kde/frameworkintegration-5.112.0-x86_64-1.txz: Upgraded.
kde/kactivities-5.112.0-x86_64-1.txz: Upgraded.
kde/kactivities-stats-5.112.0-x86_64-1.txz: Upgraded.
kde/kapidox-5.112.0-x86_64-1.txz: Upgraded.
kde/karchive-5.112.0-x86_64-1.txz: Upgraded.
kde/kauth-5.112.0-x86_64-1.txz: Upgraded.
kde/kbookmarks-5.112.0-x86_64-1.txz: Upgraded.
kde/kcalendarcore-5.112.0-x86_64-1.txz: Upgraded.
kde/kcmutils-5.112.0-x86_64-1.txz: Upgraded.
kde/kcodecs-5.112.0-x86_64-1.txz: Upgraded.
kde/kcompletion-5.112.0-x86_64-1.txz: Upgraded.
kde/kconfig-5.112.0-x86_64-1.txz: Upgraded.
kde/kconfigwidgets-5.112.0-x86_64-1.txz: Upgraded.
kde/kcontacts-5.112.0-x86_64-1.txz: Upgraded.
kde/kcoreaddons-5.112.0-x86_64-1.txz: Upgraded.
kde/kcrash-5.112.0-x86_64-1.txz: Upgraded.
kde/kdav-5.112.0-x86_64-1.txz: Upgraded.
kde/kdbusaddons-5.112.0-x86_64-1.txz: Upgraded.
kde/kdeclarative-5.112.0-x86_64-1.txz: Upgraded.
kde/kded-5.112.0-x86_64-1.txz: Upgraded.
kde/kdelibs4support-5.112.0-x86_64-1.txz: Upgraded.
kde/kdesignerplugin-5.112.0-x86_64-1.txz: Upgraded.
kde/kdesu-5.112.0-x86_64-1.txz: Upgraded.
kde/kdewebkit-5.112.0-x86_64-1.txz: Upgraded.
kde/kdnssd-5.112.0-x86_64-1.txz: Upgraded.
kde/kdoctools-5.112.0-x86_64-1.txz: Upgraded.
kde/kemoticons-5.112.0-x86_64-1.txz: Upgraded.
kde/kfilemetadata-5.112.0-x86_64-1.txz: Upgraded.
kde/kglobalaccel-5.112.0-x86_64-1.txz: Upgraded.
kde/kguiaddons-5.112.0-x86_64-1.txz: Upgraded.
kde/kholidays-5.112.0-x86_64-1.txz: Upgraded.
kde/khtml-5.112.0-x86_64-1.txz: Upgraded.
kde/ki18n-5.112.0-x86_64-1.txz: Upgraded.
kde/kiconthemes-5.112.0-x86_64-1.txz: Upgraded.
kde/kidletime-5.112.0-x86_64-1.txz: Upgraded.
kde/kimageformats-5.112.0-x86_64-1.txz: Upgraded.
kde/kinit-5.112.0-x86_64-1.txz: Upgraded.
kde/kio-5.112.0-x86_64-1.txz: Upgraded.
kde/kirigami2-5.112.0-x86_64-1.txz: Upgraded.
kde/kitemmodels-5.112.0-x86_64-1.txz: Upgraded.
kde/kitemviews-5.112.0-x86_64-1.txz: Upgraded.
kde/kjobwidgets-5.112.0-x86_64-1.txz: Upgraded.
kde/kjs-5.112.0-x86_64-1.txz: Upgraded.
kde/kjsembed-5.112.0-x86_64-1.txz: Upgraded.
kde/kmediaplayer-5.112.0-x86_64-1.txz: Upgraded.
kde/knewstuff-5.112.0-x86_64-1.txz: Upgraded.
kde/knotifications-5.112.0-x86_64-1.txz: Upgraded.
kde/knotifyconfig-5.112.0-x86_64-1.txz: Upgraded.
kde/kpackage-5.112.0-x86_64-1.txz: Upgraded.
kde/kparts-5.112.0-x86_64-1.txz: Upgraded.
kde/kpeople-5.112.0-x86_64-1.txz: Upgraded.
kde/kplotting-5.112.0-x86_64-1.txz: Upgraded.
kde/kpty-5.112.0-x86_64-1.txz: Upgraded.
kde/kquickcharts-5.112.0-x86_64-1.txz: Upgraded.
kde/kross-5.112.0-x86_64-1.txz: Upgraded.
kde/krunner-5.112.0-x86_64-1.txz: Upgraded.
kde/kservice-5.112.0-x86_64-1.txz: Upgraded.
kde/ktexteditor-5.112.0-x86_64-1.txz: Upgraded.
kde/ktextwidgets-5.112.0-x86_64-1.txz: Upgraded.
kde/kunitconversion-5.112.0-x86_64-1.txz: Upgraded.
kde/kwallet-5.112.0-x86_64-1.txz: Upgraded.
kde/kwayland-5.112.0-x86_64-1.txz: Upgraded.
kde/kwidgetsaddons-5.112.0-x86_64-1.txz: Upgraded.
kde/kwindowsystem-5.112.0-x86_64-1.txz: Upgraded.
kde/kxmlgui-5.112.0-x86_64-1.txz: Upgraded.
kde/kxmlrpcclient-5.112.0-x86_64-1.txz: Upgraded.
kde/modemmanager-qt-5.112.0-x86_64-1.txz: Upgraded.
kde/networkmanager-qt-5.112.0-x86_64-1.txz: Upgraded.
kde/oxygen-icons5-5.112.0-noarch-1.txz: Upgraded.
kde/plasma-framework-5.112.0-x86_64-1.txz: Upgraded.
kde/plasma-wayland-protocols-1.10.0-x86_64-2.txz: Rebuilt.
kde/prison-5.112.0-x86_64-1.txz: Upgraded.
kde/purpose-5.112.0-x86_64-1.txz: Upgraded.
kde/qqc2-desktop-style-5.112.0-x86_64-1.txz: Upgraded.
kde/solid-5.112.0-x86_64-1.txz: Upgraded.
kde/sonnet-5.112.0-x86_64-1.txz: Upgraded.
kde/syndication-5.112.0-x86_64-1.txz: Upgraded.
kde/syntax-highlighting-5.112.0-x86_64-1.txz: Upgraded.
kde/threadweaver-5.112.0-x86_64-1.txz: Upgraded.
l/harfbuzz-8.3.0-x86_64-1.txz: Upgraded.
l/shared-mime-info-2.4-x86_64-1.txz: Upgraded.
x/ibus-m17n-1.4.24-x86_64-1.txz: Upgraded.
x/ibus-table-1.17.4-x86_64-1.txz: Upgraded.
Slackware 32-bit
l/jasper-4.1.0-i586-1.txz: Upgraded.
l/pipewire-0.3.85-i586-1.txz: Upgraded.
n/gnutls-3.8.2-i586-1.txz: Upgraded.
n/libksba-1.6.5-i586-1.txz: Upgraded.
xap/pan-0.155-i586-1.txz: Upgraded.
testing/packages/rust-1.74.0-i686-1.txz: Upgraded.
a/btrfs-progs-6.6.2-i586-1.txz: Upgraded.
d/cmake-3.27.8-i586-1.txz: Upgraded.
l/netpbm-11.04.04-i586-1.txz: Upgraded.
l/woff2-20231106_0f4d304-i586-1.txz: Upgraded.
n/bind-9.18.20-i586-1.txz: Upgraded.
n/c-ares-1.22.0-i586-1.txz: Upgraded.
n/libgcrypt-1.10.3-i586-1.txz: Upgraded.
n/p11-kit-0.25.3-i586-1.txz: Upgraded.
x/xf86-video-ati-22.0.0-i586-1.txz: Upgraded.
x/xf86-video-intel-20230201_b74b67f0-i686-1.txz: Upgraded.
x/xf86-video-nouveau-20231005_827f1e2-i586-1.txz: Upgraded.
x/xf86-video-r128-6.12.1-i586-1.txz: Upgraded.
xap/mozilla-thunderbird-115.4.3-i686-1.txz: Upgraded.
a/pam-1.5.3-i586-2.txz: Rebuilt.
a/userspace-rcu-0.14.0-i586-2.txz: Rebuilt.
ap/mariadb-10.11.6-i586-1.txz: Upgraded.
d/llvm-17.0.5-i586-1.txz: Upgraded.
kde/plasma-wayland-protocols-1.11.1-i586-1.txz: Upgraded.
n/nfs-utils-2.6.3-i586-3.txz: Rebuilt.
       from under /usr.
d/vala-0.56.14-i586-1.txz: Upgraded.
l/gst-plugins-bad-free-1.22.7-i586-1.txz: Upgraded.
l/gst-plugins-base-1.22.7-i586-1.txz: Upgraded.
l/gst-plugins-good-1.22.7-i586-1.txz: Upgraded.
l/gst-plugins-libav-1.22.7-i586-1.txz: Upgraded.
l/gstreamer-1.22.7-i586-1.txz: Upgraded.
l/pango-1.51.1-i586-1.txz: Upgraded.
x/egl-wayland-1.1.13-i586-2.txz: Rebuilt.
extra/tigervnc/tigervnc-1.13.1-i586-2.txz: Rebuilt.
       Thanks to marav.
a/usbutils-017-i586-1.txz: Upgraded.
ap/lsof-4.99.0-i586-1.txz: Upgraded.
kde/attica-5.112.0-i586-1.txz: Upgraded.
kde/baloo-5.112.0-i586-1.txz: Upgraded.
kde/bluez-qt-5.112.0-i586-1.txz: Upgraded.
kde/extra-cmake-modules-5.112.0-i586-1.txz: Upgraded.
kde/frameworkintegration-5.112.0-i586-1.txz: Upgraded.
kde/kactivities-5.112.0-i586-1.txz: Upgraded.
kde/kactivities-stats-5.112.0-i586-1.txz: Upgraded.
kde/kapidox-5.112.0-i586-1.txz: Upgraded.
kde/karchive-5.112.0-i586-1.txz: Upgraded.
kde/kauth-5.112.0-i586-1.txz: Upgraded.
kde/kbookmarks-5.112.0-i586-1.txz: Upgraded.
kde/kcalendarcore-5.112.0-i586-1.txz: Upgraded.
kde/kcmutils-5.112.0-i586-1.txz: Upgraded.
kde/kcodecs-5.112.0-i586-1.txz: Upgraded.
kde/kcompletion-5.112.0-i586-1.txz: Upgraded.
kde/kconfig-5.112.0-i586-1.txz: Upgraded.
kde/kconfigwidgets-5.112.0-i586-1.txz: Upgraded.
kde/kcontacts-5.112.0-i586-1.txz: Upgraded.
kde/kcoreaddons-5.112.0-i586-1.txz: Upgraded.
kde/kcrash-5.112.0-i586-1.txz: Upgraded.
kde/kdav-5.112.0-i586-1.txz: Upgraded.
kde/kdbusaddons-5.112.0-i586-1.txz: Upgraded.
kde/kdeclarative-5.112.0-i586-1.txz: Upgraded.
kde/kded-5.112.0-i586-1.txz: Upgraded.
kde/kdelibs4support-5.112.0-i586-1.txz: Upgraded.
kde/kdesignerplugin-5.112.0-i586-1.txz: Upgraded.
kde/kdesu-5.112.0-i586-1.txz: Upgraded.
kde/kdewebkit-5.112.0-i586-1.txz: Upgraded.
kde/kdnssd-5.112.0-i586-1.txz: Upgraded.
kde/kdoctools-5.112.0-i586-1.txz: Upgraded.
kde/kemoticons-5.112.0-i586-1.txz: Upgraded.
kde/kfilemetadata-5.112.0-i586-1.txz: Upgraded.
kde/kglobalaccel-5.112.0-i586-1.txz: Upgraded.
kde/kguiaddons-5.112.0-i586-1.txz: Upgraded.
kde/kholidays-5.112.0-i586-1.txz: Upgraded.
kde/khtml-5.112.0-i586-1.txz: Upgraded.
kde/ki18n-5.112.0-i586-1.txz: Upgraded.
kde/kiconthemes-5.112.0-i586-1.txz: Upgraded.
kde/kidletime-5.112.0-i586-1.txz: Upgraded.
kde/kimageformats-5.112.0-i586-1.txz: Upgraded.
kde/kinit-5.112.0-i586-1.txz: Upgraded.
kde/kio-5.112.0-i586-1.txz: Upgraded.
kde/kirigami2-5.112.0-i586-1.txz: Upgraded.
kde/kitemmodels-5.112.0-i586-1.txz: Upgraded.
kde/kitemviews-5.112.0-i586-1.txz: Upgraded.
kde/kjobwidgets-5.112.0-i586-1.txz: Upgraded.
kde/kjs-5.112.0-i586-1.txz: Upgraded.
kde/kjsembed-5.112.0-i586-1.txz: Upgraded.
kde/kmediaplayer-5.112.0-i586-1.txz: Upgraded.
kde/knewstuff-5.112.0-i586-1.txz: Upgraded.
kde/knotifications-5.112.0-i586-1.txz: Upgraded.
kde/knotifyconfig-5.112.0-i586-1.txz: Upgraded.
kde/kpackage-5.112.0-i586-1.txz: Upgraded.
kde/kparts-5.112.0-i586-1.txz: Upgraded.
kde/kpeople-5.112.0-i586-1.txz: Upgraded.
kde/kplotting-5.112.0-i586-1.txz: Upgraded.
kde/kpty-5.112.0-i586-1.txz: Upgraded.
kde/kquickcharts-5.112.0-i586-1.txz: Upgraded.
kde/kross-5.112.0-i586-1.txz: Upgraded.
kde/krunner-5.112.0-i586-1.txz: Upgraded.
kde/kservice-5.112.0-i586-1.txz: Upgraded.
kde/ktexteditor-5.112.0-i586-1.txz: Upgraded.
kde/ktextwidgets-5.112.0-i586-1.txz: Upgraded.
kde/kunitconversion-5.112.0-i586-1.txz: Upgraded.
kde/kwallet-5.112.0-i586-1.txz: Upgraded.
kde/kwayland-5.112.0-i586-1.txz: Upgraded.
kde/kwidgetsaddons-5.112.0-i586-1.txz: Upgraded.
kde/kwindowsystem-5.112.0-i586-1.txz: Upgraded.
kde/kxmlgui-5.112.0-i586-1.txz: Upgraded.
kde/kxmlrpcclient-5.112.0-i586-1.txz: Upgraded.
kde/modemmanager-qt-5.112.0-i586-1.txz: Upgraded.
kde/networkmanager-qt-5.112.0-i586-1.txz: Upgraded.
kde/plasma-framework-5.112.0-i586-1.txz: Upgraded.
kde/plasma-wayland-protocols-1.10.0-i586-2.txz: Rebuilt.
kde/prison-5.112.0-i586-1.txz: Upgraded.
kde/purpose-5.112.0-i586-1.txz: Upgraded.
kde/qqc2-desktop-style-5.112.0-i586-1.txz: Upgraded.
kde/solid-5.112.0-i586-1.txz: Upgraded.
kde/sonnet-5.112.0-i586-1.txz: Upgraded.
kde/syndication-5.112.0-i586-1.txz: Upgraded.
kde/syntax-highlighting-5.112.0-i586-1.txz: Upgraded.
kde/threadweaver-5.112.0-i586-1.txz: Upgraded.
l/harfbuzz-8.3.0-i586-1.txz: Upgraded.
l/shared-mime-info-2.4-i586-1.txz: Upgraded.
x/ibus-m17n-1.4.24-i586-1.txz: Upgraded.
x/ibus-table-1.17.4-i586-1.txz: Upgraded.
