Slackware 13.37 (rcX --> final)
Post Napisano: 23 Mar 2011, 10:39
Stigao i RC3
Tue Mar 22 06:59:13 UTC 2011
We'll call this Slackware 13.37 release candidate 3. It seems like most of the
important pieces are in place now. :-)
a/mkinitrd-1.4.6-i486-7.txz: Rebuilt.
       Use "mdadm -S -s" in the init script to fix device numbers.
       Thanks to Eric Hameleers.
       Poke the kernel with fdisk after assembling RAID.
       Thanks to Csaba Biegl.
a/sysvinit-scripts-1.2-noarch-39.txz: Rebuilt.
       In rc.6 and rc.6, use -f when unmounting remote filesystems to avoid getting
       stuck in the case of a dead server.
       In rc.M, start /etc/rc.d/rc.autofs if it is executable.
ap/linuxdoc-tools-0.9.66-i486-8.txz: Rebuilt.
       Upgraded to gnome-doc-utils-0.20.4.
kde/polkit-qt-1-r1145513-i486-2.txz: Rebuilt.
       Patched to fix a crash at logout.
l/gdk-pixbuf2-2.23.1-i486-1.txz: Upgraded.
l/pycups-1.9.55-i486-1.txz: Upgraded.
l/system-config-printer-1.2.7-i486-1.txz: Upgraded.
n/nfs-utils-1.2.3-i486-3.txz: Rebuilt.
       Added /etc/nfsmount.conf set to protocol version 3 by default.
       Thanks to Niels Horn.
x/libhangul-0.0.12-i486-1.txz: Upgraded.
xap/gnuchess-5.08-i486-2.txz: Rebuilt.
       Upgraded to xboard-4.5.1.
       Fixed xboard.desktop. Thanks to Eric Hameleers.
xap/mozilla-firefox-4.0-i486-1.txz: Upgraded.
       Thanks to the Mozilla Foundation for all the hard work on Firefox 4.0!
extra/bash-completion/bash-completion-1.3-noarch-3.txz: Rebuilt.
       Complete on 'sh' the same as stock bash. Thanks to Robby Workman.
extra/google-chrome/*: Added.
       Added a google-chrome.SlackBuild to convert the Google Chrome .deb
       packages for Slackware. Thanks to Erik Hanson.
       Also added GConf and ORBit2 packages for Google Chrome in this directory.
Slackware-current ChangeLog
Konacno FF4, i par novotarija :)
Post Napisano: 23 Mar 2011, 12:49
Malo off topic, al' kad ga pomenu - FF4 mi je prilično živahan, mogu reći :)
Post Napisano: 23 Mar 2011, 13:06
Apsolutno se slažem! FF4 leti, evo sinoć sam upgrade-ovao sa RC1 na stable, mada je i RC1 bio potpuno stabilan. Jedino FireFTP add-on izgleda još uvek nije kompatibilan sa FF4, a to je bio baš dobar add-on kada je FTP port (21, ili 22 za ssh ako me sećanje dobro služi) pod firewall-om, npr. kada ste u nekom kafeu ili na Hemijskom faXu... To je prava magija kako FireFTP bez problema dovlači... Nisam baš toliko upućen u mreže, zato kažem da je magija, inače sigurno nije neki big-deal i verovatno je problem premostiv i sa gftp i lftp programima, ali "time waits for no one" tako da je dobro sve što radi. :)
Post Napisano: 23 Mar 2011, 23:26
Upravo update-ovao firefox na stable verziju na 64-bit slacku. Problem sa zakucavanjem i crasho-vanjem flash-a vise ne postoji :)
Post Napisano: 27 Mar 2011, 14:02
Novi RC,
13.37 RC-Pi  :D
Sun Mar 27 08:28:47 UTC 2011
There have been quite a few changes so we will have one more release
candidate: Slackware 13.37 RC 3.14159265358979323846264338327950288419716.
Very close now! But we'll likely hold out for 2.6.37.6.
ChangeLog
Post Napisano: 29 Mar 2011, 10:33
Tue Mar 29 05:46:13 UTC 2011
d/git-1.7.4.2-i486-1.txz: Upgraded.
a/btrfs-progs-20110327-i486-1.txz: Upgraded.
      In fsck.btrfs script, don't check a filesystem that's mounted as /, even if
      it is mounted read-only. This fix allows using btrfs as a root filesystem,
      but /boot will still need to be on another partition using ext2 (or some
      other filesystem) as btrfs is tricky to boot directly.
      Thanks to gerasimos_h.
a/mkinitrd-1.4.6-i486-9.txz: Rebuilt.
      Avoid an infinite loop copying libraries to the initrd-tree in the case that
      preload or LD_PRELOAD are used.
      Thanks to David Somero and Ozan Türkyilmaz for the bug report.
      Thanks to Eric Hameleers for the patch.
a/procps-3.2.8-i486-2.txz: Rebuilt.
      Patched to support cgroups.
      Upgraded to psmisc-22.13.
ap/vim-7.3.146-i486-1.txz: Upgraded.
      Updated runtime syntax.
d/pmake-1.111-i486-4.txz: Rebuilt.
      Fixed duplications in *.mk files.
      Thanks to Ferenc Deak.
kde/kdelibs-4.5.5-i486-2.txz: Rebuilt.
      Patched CVE-2011-1168.
      http://cve.mitre.org/cgi-bin/cvename.cg ... -2011-1168
l/chmlib-0.40-i486-2.txz: Upgraded.
      Enabled building the example programs.
l/glib2-2.28.4-i486-1.txz: Upgraded.
      Fixed setenv syntax in /etc/profile.d/libglib2.csh.
      Thanks to crocket.
xap/vim-gvim-7.3.146-i486-1.txz: Upgraded.
Post Napisano: 09 Apr 2011, 00:32
Jos malo pa 13.37 final ;)
Fri Apr 8 06:58:48 UTC 2011
Hi folks,
One more. We'll call this 13.37 RC 4.6692. Thanks to Nicola for suggesting
the first Feigenbaum constant could be useful since we used pi, and it's too
late for e. This is pretty much it, but last call for any showstoppers.
btw.  da kazem da je sredjeno konacno par stvari koji su "nama" vazni,  mirror-i sa .yu sa slackware sajta su uklonjeni, kao i iz slackpkg/mirrors i dodati .rs :)
Post Napisano: 13 Apr 2011, 07:28
Kako su baš uboli 13.37, do sada je najdalje išlo do X.2  :)
Post Napisano: 13 Apr 2011, 11:12
pa svidelo se Pat-u  :grin:  1337
Evo ga i lilo_background (nije zvanican)
Post Napisano: 13 Apr 2011, 19:02
Jos jedan update kernel paketa. Drugih promena nema, izgleda da je vecina stvari vec "na mestu".  :)
Wed Apr 13 03:07:00 UTC 2011
a/kernel-firmware-2.6.37.6-noarch-2.txz: Rebuilt.
a/kernel-generic-2.6.37.6-i486-2.txz: Rebuilt.
a/kernel-generic-smp-2.6.37.6_smp-i686-2.txz: Rebuilt.
a/kernel-huge-2.6.37.6-i486-2.txz: Rebuilt.
a/kernel-huge-smp-2.6.37.6_smp-i686-2.txz: Rebuilt.
a/kernel-modules-2.6.37.6-i486-2.txz: Rebuilt.
a/kernel-modules-smp-2.6.37.6_smp-i686-2.txz: Rebuilt.
d/kernel-headers-2.6.37.6_smp-x86-2.txz: Rebuilt.
k/kernel-source-2.6.37.6_smp-noarch-2.txz: Rebuilt.
      Added patch 4da9484bdece39ab0b098fa711e095e3e9fc8684 from Linus' git tree:
      [PATCH] x86, hibernate: Initialize mmu_cr4_features during boot
      This fixes resume from hibernate.
testing/packages/kernel-firmware-2.6.38.2-noarch-2.txz: Rebuilt.
testing/packages/kernel-generic-smp-2.6.38.2_smp-i686-2.txz: Rebuilt.
testing/packages/kernel-headers-2.6.38.2_smp-x86-2.txz: Rebuilt.
testing/packages/kernel-huge-smp-2.6.38.2_smp-i686-2.txz: Rebuilt.
testing/packages/kernel-modules-smp-2.6.38.2_smp-i686-2.txz: Rebuilt.
testing/packages/kernel-source-2.6.38.2_smp-noarch-2.txz: Rebuilt.
extra/linux-2.6.37.6-nosmp-sdk/*: Rebuilt.
isolinux/initrd.img: Rebuilt.
kernels/*: Rebuilt.
Users browsing this forum: Claude User [Bot] and 13 guests
