Slackpkg download/install paketa
Post Napisano: 18 Dec 2015, 16:52
Pozdrav!
Bocke, hvala za savet.
Evo šta kaže teminal nakon preporučenih izmena u /etc/slackpkg/slackpkgplus.conf:
slackpkg update gpg
2015-12-18 15:53:29 URL:http://slakfinder.org/slackpkg+/GPG-KEY [1823/1823] -> "/tmp/slackpkg.Ro1fpQ/gpgkey-tmp" [1]
gpg: key ED123FBC: "Matteo Rossini <zerouno@slacky.it>" not changed
gpg: Total number processed: 1
gpg:              unchanged: 1
2015-12-18 15:53:29 URL:http://slackware.uk/people/alien/multilib/14.1/GPG-KEY [11137/11137] -> "/tmp/slackpkg.Ro1fpQ/gpgkey-tmp" [1]
gpg: key A75CBDA0: "Eric Hameleers <alien@slackware.com>" not changed
gpg:              unchanged: 1
2015-12-18 15:53:29 URL:http://slackware.uk/people/alien/restricted_sbrepos/14.1/x86_64/GPG-KEY [11465/11465] -> "/tmp/slackpkg.Ro1fpQ/gpgkey-tmp" [1]
gpg:              unchanged: 1
http://slackware.uk/peoople/alien/sbrepos/14.1/x86_64/GPG-KEY:
2015-12-18 15:53:30 ERROR 404: Not Found.
                   !!! W A R N I N G !!!
    Repository 'alienbob' does NOT contain the GPG-KEY
    You SHOULD disable GPG check by setting 'CHECKGPG=off'
    in /etc/slackpkg/slackpkg.conf or use slackpkg with
    '-checkgpg=off' : 'slackpkg -checkgpg=off install packge'
Odlučio da ipak pokušam i ...
bash-4.2# slackpkg update
2015-12-18 15:55:00 URL:http://slakfinder.org/slackpkg+/GPG-KEY [1823/1823] -> "/tmp/slackpkg.voedyL/gpgkey-tmp" [1]
gpg:              unchanged: 1
2015-12-18 15:55:00 URL:http://slackware.uk/people/alien/multilib/14.1/GPG-KEY [11137/11137] -> "/tmp/slackpkg.voedyL/gpgkey-tmp" [1]
gpg:              unchanged: 1
2015-12-18 15:55:01 URL:http://slackware.uk/people/alien/restricted_sbrepos/14.1/x86_64/GPG-KEY [11465/11465] -> "/tmp/slackpkg.voedyL/gpgkey-tmp" [1]
gpg:              unchanged: 1
2015-12-18 15:55:01 ERROR 404: Not Found.
Updating the package lists...
	Downloading...
2015-12-18 15:55:47 URL:http://slakfinder.org/slackpkg+/CHECKSUMS.md5 [1237/1237] -> "/tmp/slackpkg.voedyL/CHECKSUMS.md5-slackpkgplus" [1]
2015-12-18 15:55:48 URL:http://slackware.uk/people/alien/multilib/14.1/CHECKSUMS.md5 [99882/99882] -> "/tmp/slackpkg.voedyL/CHECKSUMS.md5-multilib" [1]
2015-12-18 15:55:48 URL:http://slackware.uk/people/alien/restricted_sbrepos/14.1/x86_64/CHECKSUMS.md5 [2587/2587] -> "/tmp/slackpkg.voedyL/CHECKSUMS.md5-restricted" [1]
http://slackware.uk/peoople/alien/sbrepos/14.1/x86_64/CHECKSUMS.md5:
2015-12-18 15:55:48 ERROR 404: Not Found.
                        !!! F A T A L !!!
    Repository 'alienbob' FAILS the CHECKSUMS.md5 download
    The repository may be invalid and will be SKIPPED.
Files /var/lib/slackpkg/ChangeLog.txt and /tmp/slackpkg.voedyL/ChangeLog.txt differ
List of all files
2015-12-18 15:59:19 URL:http://slakfinder.org/slackpkg+/MANIFEST.bz2 [498/498] -> "/tmp/slackpkg.voedyL/SLACKPKGPLUS_slackpkgplus-MANIFEST.bz2" [1]
2015-12-18 15:59:20 URL:http://slackware.uk/people/alien/multilib/14.1/MANIFEST.bz2 [257987/257987] -> "/tmp/slackpkg.voedyL/SLACKPKGPLUS_multilib-MANIFEST.bz2" [1]
2015-12-18 15:59:20 URL:http://slackware.uk/people/alien/restricted_sbrepos/14.1/x86_64/MANIFEST.bz2 [20406/20406] -> "/tmp/slackpkg.voedyL/SLACKPKGPLUS_restricted-MANIFEST.bz2" [1]
		Checksums
2015-12-18 16:00:43 URL:http://slakfinder.org/slackpkg+/CHECKSUMS.md5.asc [473/473] -> "/tmp/slackpkg.voedyL/CHECKSUMS.md5-slackpkgplus.asc" [1]
		ERROR: Verification of the  gpg signature on CHECKSUMS.md5
		       failed! This could mean that the file is out of date
		       or has been tampered with.
  WARNING! One or more errors occurred while slackpkg was running
alienbob: SKIPPING Invalid repository (fails to download CHECKSUMS.md5)
OK, sada jedan od Alien Bob-ovih servera nije dostupan, ali primetio sam još nešto.
Izgleda da je problem kod odabranog mirrora u fajlu /etc/slackpkg/mirrors, tj. makedonski blizoo.mk.
(http://slackware.blizoo.mk/slackware/slackware64-14.1/" onclick="window.open(this.href);return false;)
Nisam uspeo da pristupim adresi preko pregledača (Firefox, Chromium, Vivaldi),
pa sumnjam da je tu problem.
DOPUNA: 18:15
Promenio mirror u /etc/slackpkg/mirrors i odabrao holandski http://ftp.nluug.nl/os/Linux/distr/slac ... re64-14.1/" onclick="window.open(this.href);return false;
Osim greške vezane za Alien Bob-ov server (okačeno gore), nema problema i sve teče glatko.
Hoću reći, obe varijante - slackpkg update gpg & update. :rolleyes:
Ako vam nije problem, dajte da razjasnimo celu stvar zbog ostalih korisnika.
Znam da sam (verovatno) najneiskusniji među prisutnima na forumu, ali znam da će reč nekog iskusnog,
prekratiti moguće muke.
Post Napisano: 18 Dec 2015, 18:17
Taj link koji ne radi je zbog greške u kuckanju. U adresi: "http://slackware.uk/peoople/alien/sbrepos/14.1/x86_64/" je napisaon "peoople" umesto people.
Ali bez obzira ne bi trebalo da javlja gpg grešku. Jesi li odradio i:
slackpkg update gpg
Posle svake izmene u konfiguraciji forsiraj slackpkg update.
Post Napisano: 18 Dec 2015, 18:23
Kucali smo istovremeno. :P
Izgleda da ta greška igra glavnu ulogu u ovoj maloj drami. :P
Sa greškom (peoople):
slackpkg update gpg
2015-12-18 18:17:20 ERROR 404: Not Found.
Samo 'update' prijavljuje sledeće:
2015-12-18 18:06:28 ERROR 404: Not Found.
                        !!! F A T A L !!!
Nakon ispravke (people) sve radi kako treba. :grlj:
Još kada bi dobacio preporuku za riznice... :rolleyes:
Post Napisano: 18 Dec 2015, 18:31
Napisao sam ti iznad da je link neispravan. :) Nađi liniju koja sadrži "peoople" u /etc/slackpkgplus.conf i ispravi u "people". Zatim ponovi gpg update i update.
Post Napisano: 18 Dec 2015, 18:36
:D Opet sudar u kucanju!
Prethodni post izmenjen.
Post Napisano: 18 Dec 2015, 18:56
dr_mr_foo wrote:Još kada bi dobacio preporuku za riznice... :rolleyes:
Ne znam na šta misliš. :) Mislim, kapiram da je vezano za nešto o čemu smo pričali, ali ne znam konkretno za šta.
Post Napisano: 18 Dec 2015, 19:05
Mislim na priču o Slacky repou u 'slackpkgplus.conf'. Izbacio sam ga (#), pa pomislih da ne bi bilo loše
opet imati četiri komada. :P
Mada, ubacio sam tri Alienova koja si preporučio, pa možda i nema potrebe za dodatnim
mirrorplus serverima. :question:
Post Napisano: 19 Dec 2015, 14:08
Nažalost ne koristim Slacky. :) Morao bih da to pogledam/testiram.
Ali, pozivam ljude koji koriste Slacky repo da se jave da li i oni imaju problema s njime. :)
Post Napisano: 13 Jan 2016, 10:14
Pozdrav, narode.
Jutros sam proveravao blizoo.mk mirror i izgleda da je server sada u funkciji. MD5SUM je osvežen jutros oko pola dva,
a nove 'zakrpe' su takođe na serveru.
Živeli! :beer:
Post Napisano: 31 May 2019, 08:40
Pozdrav, ako može mala pomoć ili barem informacija.
Evo šta sam uradio, kada je podignut 14.2 64-bit, urađen je update, zatim upgrade-all. Zatim instalirano dosta toga, pa onda opet urađen update, upgrade-all, zatim se postavlja pitanje za pakete (keep old ones, overwrite, itd.), išao sam na overwrite, ali dosta biblioteka nedostaje sada i nije realno da to sve zakrpim ručno, pa se pitam, da li uopšte treba se upuštati na takav korak, ili se držati samo update-a? Ne razumem baš najbolje opcije install-new, možda je trebalo to uraditi posle update-a...?
