LibreOffice 3.x
Post Napisano: 13 Apr 2012, 21:23
Iako nema nikakve veze sa Brokovim problemom, mala napomena iz Erikove objave o dostupnosti novih paketa:
One word of caution!
LibreOffice changed the location of its configuration directory (again). Originally using ~/.ooo it switched to ~/.libreoffice which will probably be where you will find your custom settings stored. The 3.5 releases however, use ~/.config/libreoffice . The best thing to do is move your current configuration directory to the new location, so that LibreOffice keeps working as expected:
    $ mv ~/.libreoffice ~/.config/libreoffice
If you had already started the new LibreOffice program, then you will have to delete the fresh and almost empty ~/.config/libreoffice directory first of course.
Post Napisano: 13 Apr 2012, 21:39
qki wrote:Iako nema nikakve veze sa Brokovim problemom
Nemam ja nikakavih problema barem kada je u pitanju LibreOffice :D , jes' malo cudno isao upgarde ali je odradjen posao.
Post Napisano: 13 Apr 2012, 21:49
Na upgrade sam i mislio. ;)
Post Napisano: 09 May 2012, 15:04
LibreOffice 3.5.3 je dostupan za Slackware 13.37 i -current (Alienovi paketi).
Pakete možete preuzeti sa sledećih linkova: 32-bit 64-bit
Post Napisano: 01 Jun 2012, 22:53
LibreOffice 3.5.4 je dostupan za Slackware 13.37 i -current (Alienovi paketi). Kako Erik (AlienBOB) piše, ovo izdanje karakterišu značajno poboljšane performanse, pogotovo u radu sa većim dokumentima.
Up to 100% performance improvements thanks to the efforts of a diverse and growing developer and QA community
Post Napisano: 02 Jun 2012, 09:44
Instalirao sam ga juce ujutru :)
Post Napisano: 12 Jul 2012, 10:18
LibreOffice 3.5.5 je dostupan za Slackware 13.37 i -current (Alienovi paketi).
Napomena: U trenutku pisanja ovog posta, paketi za 64-bitni Slackware još uvijek nisu bili dostupni. Vjerujem da će ih Alien u relativno kratkom roku staviti na raspolaganje.
Post Napisano: 24 Aug 2012, 11:52
LibreOffice 3.5.6 je dostupan (malo kasnimo) od 16.08.2012. za Slackware 13.37 i -current (Alienovi paketi).
Pakete možete preuzeti sa sledećih linkova: 32-bit 64-bit.
Prikaz
LibreOffice 3.5.6
Post Napisano: 30 Sep 2012, 15:51
LibreOffice 3.6.1 [za Slackware 14]
Od juce je dostupna LibreOffice stabilna verzija 3.6.1 i za Slekver.
Preuzimanje:
http://taper.alienbase.nl/mirrors/slack ... breoffice/" onclick="window.open(this.href);return false;
Langpack paketi za LibreOffice 3.6.1:
http://taper.alienbase.nl/mirrors/slack ... -langpack/" onclick="window.open(this.href);return false;
Maticna stranica projekta:
http://www.libreoffice.org" onclick="window.open(this.href);return false;
Prikaz verzije:
Post Napisano: 02 Oct 2012, 11:30
Pokretanje ove novije verzije je neverovatno brzo, već sam imao prilike da je probam na Salixu. Tamo je sleteo pre skoro mesec dana. Za one kojima je bitno, dodatak ootranslit za preslovljavanje iz latinice u ćirilicu (i obrnuto) radi bez problema i u novoj verziji.
