[REŠENO]Posle instalacije slackware14.1...
Post Napisano: 25 Dec 2013, 14:03
Pozdrav svima!
Juce sam instalirao slack 14.1, bez ikakvih problema je prosla sama instalacija, instalirao sam lilo novog sistema uu MBR, dodao stari slack14 u lilo.conf i to je proslo OK.
Problem nastaje kad hocu da pokrenem stari slack14, na njemu koristim LXDE i slim za njegovo pokretanje
Ovo je greska koju dobijem pri pokretanju u run level 4, reko ajde da promenim u run level 3 i dobijem sledecu gresku
Na ovom mestu mi je tastatura mrtva, ne daje znake zivota.
Mislio sam da nije nesto strasno i komplikovano, ali sam izgleda pogresno procenio. Citajuci postove na raznim forumima vidim da se trazi sadrzaj inittab-a i predlaze se reinstalacija driver-a za grafiku i instalacija desktop menadzera. Inace, sve je lepo radilo do instalacije novog slacka, nisam cak pravio ni tacke montiranja za / i /home starog slacka.
inittab
# inittab	This file describes how the INIT process should set up
#		the system in a certain run-level.
# Version:	@(#)inittab		2.04	17/05/93	MvS
#                                       2.10    02/10/95        PV
#                                       3.00    02/06/1999      PV
#                                       4.00    04/10/2002      PV
#                                      13.37    2011-03-25      PJV
# Author:	Miquel van Smoorenburg, <miquels@drinkel.nl.mugnet.org>
# Modified by:	Patrick J. Volkerding, <volkerdi@slackware.com>
# These are the default runlevels in Slackware:
#   0 = halt
#   1 = single user mode
#   2 = unused (but configured the same as runlevel 3)
#   3 = multiuser mode (default Slackware runlevel)
#   4 = X11 with KDM/GDM/XDM (session managers)
#   5 = unused (but configured the same as runlevel 3)
#   6 = reboot
# Default runlevel. (Do not set to 0 or 6)
# System initialization (runs when system boots).
si:S:sysinit:/etc/rc.d/rc.S
# Script to run when going single user (runlevel 1).
su:1S:wait:/etc/rc.d/rc.K
# Script to run when going multi user.
rc:2345:wait:/etc/rc.d/rc.M
# What to do at the "Three Finger Salute".
ca::ctrlaltdel:/sbin/shutdown -t5 -r now
# Runlevel 0 halts the system.
l0:0:wait:/etc/rc.d/rc.0
# Runlevel 6 reboots the system.
l6:6:wait:/etc/rc.d/rc.6
# What to do when power fails.
pf::powerfail:/sbin/genpowerfail start
# If power is back, cancel the running shutdown.
pg::powerokwait:/sbin/genpowerfail stop
# These are the standard console login getties in multiuser mode:
c1:12345:respawn:/sbin/agetty --noclear 38400 tty1 linux
c2:12345:respawn:/sbin/agetty 38400 tty2 linux
c3:12345:respawn:/sbin/agetty 38400 tty3 linux
c4:12345:respawn:/sbin/agetty 38400 tty4 linux
c5:12345:respawn:/sbin/agetty 38400 tty5 linux
c6:12345:respawn:/sbin/agetty 38400 tty6 linux
# Local serial lines:
#s1:12345:respawn:/sbin/agetty -L ttyS0 9600 vt100
#s2:12345:respawn:/sbin/agetty -L ttyS1 9600 vt100
# Dialup lines:
#d1:12345:respawn:/sbin/agetty -mt60 38400,19200,9600,2400,1200 ttyS0 vt100
#d2:12345:respawn:/sbin/agetty -mt60 38400,19200,9600,2400,1200 ttyS1 vt100
# Runlevel 4 also starts /etc/rc.d/rc.4 to run a display manager for X.
# Display managers are preferred in this order:  gdm, kdm, xdm
x1:4:respawn:/etc/rc.d/rc.4
# End of /etc/inittab
Ako se nekome slicno desavalo neka javi kako je resio problem.
Hvala!
Post Napisano: 25 Dec 2013, 15:10
Ako možeš okači i sadržaj /etc/lilo.conf fajla. Ovde mi nije jasno da stari slack pokreće novi kernel koji je default na slacku 14.1 (3.10.17).
Post Napisano: 25 Dec 2013, 15:26
Da, da, vidis, na to nisam ni obratioo paznju, hvlala @drummer.
lilo.conf slack14
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
append=" vt.default_utf8=0"
boot = /dev/sda
compact
# Boot BMP Image.
  bitmap = /boot/slack.bmp
# be used.  We don't specify it here, as there's just one column.
  bmp-table = 60,6,1,16
  bmp-timer = 65,27,0,255
# Standard menu.
# first entry immediately):
prompt
timeout = 30
change-rules
  reset
# Normal VGA console
vga = normal
#vga = ask
#vga=791
#vga=790
#vga=773
#vga=788
#vga=787
#vga=771
#vga=785
#vga=784
#vga=769
# End LILO global section
image = /boot/vmlinuz
  root = /dev/sda7
  label = Slaxkware14
  read-only
# Windows bootable partition config begins
other = /dev/sda1
  label = Windows7
  table = /dev/sda
# Windows bootable partition config ends
lilo.conf slack14.1
boot = /dev/sda
#compact        # faster, but won't work on all systems.
# Boot BMP Image.
# Standard menu.
prompt
timeout = 30
change-rules
  reset
vga = normal
#vga = ask
#vga=791
#vga=790
#vga=773
#vga=788
#vga=787
#vga=771
#vga=785
#vga=784
#vga=769
  root = /dev/sda7
  label = Slackware14
  read-only
  root = /dev/sda10
  label = Slackware14.1
  read-only
other = /dev/sda1
  label = Windows7
  table = /dev/sda
Sve sto sam menjao u novom lilo.conf je da sam dodao stari slack14 i vreme cekanja za pocetak ucitavanja sistema, e da, i imena svakog sistema, posto slack pri instalaciji samo upise Linux, pa da bi ih mogao razlikovati.
Post Napisano: 25 Dec 2013, 15:44
Dovoljno je da menjaš samo jedan lilo.conf jer je dovoljno imati samo jedan boot loader koji poziva sve instalirane sisteme. Pošto si izmene uneo u novi lilo.conf (slack14.1 sistem), pokreni Slack14.1, pregledaj ponovo sadržaj /etc/lilo.conf fajla i nakon izmene (ako je potrebno, mada ako je stanje kako si naveo u drugom ispisu onda je ok) u njemu i snimanja stanja unesi sledeću komandu:
# lilo -v /dev/sda
Ovom komandom se sadržaj upisuje u MBR (tek nakon restarta promene su vidljive). Dve napomene - parametar -v unosiš da bi imao detaljniji prikaz izvršavanja komande i on nije neophodan. Takođe, u primeru koj sam ja naveo lilo se zapisuje u MBR diska a ne particije.
Nakon unosa ove komande i njenog uspešnog završetka restartuj sistem i ako je sve ok dočekaće te ispravan boot meni.
Post Napisano: 25 Dec 2013, 15:51
Opet hvala @drummer.
Menjao sam samo novi lilo.conf, jer sam dozvolio u jucerasnjoj instalaciji da se taj novi instalira u MBR i naravno u njega sam dodao linije da se moze pokrenuti slack14 koji je vec bio na HDD i posle svih promena sam pokrenuo komandu #lilo da bi sacuvao napravljene promene, pri tom nikakvu gresku mi nije izbacio.
Sad cu odraditi ovo sto si napisao, pa javljam kakvo je stanje.
Post Napisano: 25 Dec 2013, 16:09
Probao sam komandu koju je predlozio @drummer i dobio
# lilo -v /dev/sda
usage: lilo [ -C config_file ] -q [ -m map_file ] [ -v N | -v ... ]
       lilo [ -C config_file ] [ -b boot_device ] [ -c ] [ -g | -l | -L ]
            [ -F ] [ -i boot_loader ] [ -m map_file ] [ -d delay ]
            [ -v N | -v ... ] [ -t ] [ -s save_file | -S save_file ]
            [ -p ][ -P fix | -P ignore ] [ -r root_dir ] [ -w | -w+ ]
       lilo [ -C config_file ] [ -m map_file ] -R [ word ... ]
       lilo [ -C config_file ] -I name [ options ]
       lilo [ -C config_file ] [ -s save_file ] -u | -U [ boot_device ]
       lilo -H                          install only to active discs (RAID-1)
       lilo -A /dev/XXX [ N ]           inquire/activate a partition
       lilo -M /dev/XXX [ mbr | ext ]   install master boot record
       lilo -T help                     list additional options
       lilo -X                          internal compile-time options
       lilo -V [ -v ]                   version information
U samom lilo.conf nisam imao sta da menjam, na kraju je dozvolio samo #lilo komandu da izvrsim i dalje nema promene, sistem se ponasa isto, nece da podigne slack14.
Post Napisano: 25 Dec 2013, 16:21
Probaj samo komandu bez -v. I iznesi ovde izlaz komande. Takođe, ako možeš, izbaci i izlaz komandi:
# fdisk -l
# blikd
Post Napisano: 25 Dec 2013, 16:43
# fdisk -l
Disk /dev/sda: 1000.2 GB, 1000204886016 bytes
255 heads, 63 sectors/track, 121601 cylinders, total 1953525168 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x1da9efb0
   Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *        2048   209717247   104857600    7  HPFS/NTFS/exFAT
/dev/sda2       209717304   695196809   242739753    7  HPFS/NTFS/exFAT
/dev/sda3       695196810   966579389   135691290    5  Extended
/dev/sda5       695196873   699405839     2104483+  82  Linux swap
/dev/sda6       699405903   699919919      257008+  83  Linux
/dev/sda7       699919983   741865634    20972826   83  Linux
/dev/sda8       741865698   825753599    41943951   83  Linux
/dev/sda9       825753663   826331939      289138+  83  Linux
/dev/sda10      826332003   886495364    30081681   83  Linux
/dev/sda11      886495428   966579389    40041981   83  Linux
# blikd
-su: blikd: command not found
# lilo /dev/sda
Post Napisano: 25 Dec 2013, 16:46
Greška u kucanju se provukla, komanda je:
# blkid
Post Napisano: 25 Dec 2013, 16:51
Izvini, moja greška (u brzini). Dakle, komanda je:
#blkid
Ukucaj samo
# lilo
I prekopiraj sadržaj ovde. Takođe, vrlo bitno je da ovo uradiš iz novog (14.1) sistema.
