"Par" pitanja
Post Napisano: 28 Jul 2014, 14:08
Neće. :(
Evo celog loga:
[    88.782]
X.Org X Server 1.14.3
Release Date: 2013-09-12
[    88.783] X Protocol Version 11, Revision 0
[    88.783] Build Operating System: Slackware 14.1 Slackware Linux Project
[    88.783] Current Operating System: Linux desktop 3.10.17-smp #2 SMP Wed Oct 23 17:13:14 CDT 2013 i686
[    88.783] Kernel command line: BOOT_IMAGE=Linux ro root=805 vt.default_utf8=0
[    88.783] Build Date: 09 October 2013  09:56:03PM
[    88.784]
[    88.784] Current version of pixman: 0.30.2
[    88.784] 	Before reporting problems, check http://wiki.x.org
[    88.784] Markers: (--) probed, (**) from config file, (==) default setting,
[    88.785] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jul 28 15:04:24 2014
[    88.785] (==) Using config file: "/etc/X11/xorg.conf"
[    88.786] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    88.786] (==) ServerLayout "Layout0"
[    88.786] (**) |-->Screen "Screen0" (0)
[    88.786] (**) |   |-->Monitor "Monitor0"
[    88.786] (**) |   |-->Device "Device0"
[    88.786] (**) |-->Input Device "Keyboard0"
[    88.786] (**) |-->Input Device "Mouse0"
[    88.786] (**) Option "Xinerama" "0"
[    88.786] (==) Automatically adding devices
[    88.786] (==) Automatically enabling devices
[    88.786] (==) Automatically adding GPU devices
[    88.786] (WW) The directory "/usr/share/fonts/local" does not exist.
[    88.786] 	Entry deleted from font path.
[    88.786] (WW) The directory "/usr/share/fonts/CID" does not exist.
[    88.786] (**) FontPath set to:
	/usr/lib/X11/fonts/misc/:unscaled,
	/usr/lib/X11/fonts/100dpi/:unscaled,
	/usr/lib/X11/fonts/75dpi/:unscaled,
	/usr/lib/X11/fonts/misc/,
	/usr/lib/X11/fonts/Type1/,
	/usr/lib/X11/fonts/Speedo/,
	/usr/lib/X11/fonts/100dpi/,
	/usr/lib/X11/fonts/75dpi/,
	/usr/lib/X11/fonts/cyrillic/,
	/usr/lib/X11/fonts/TTF/,
	/usr/share/fonts/TTF,
	/usr/share/fonts/OTF,
	/usr/share/fonts/Type1,
	/usr/share/fonts/misc,
	/usr/share/fonts/100dpi/:unscaled,
	/usr/share/fonts/75dpi,
	/usr/share/fonts/100dpi,
	/usr/share/fonts/cyrillic
[    88.786] (==) ModulePath set to "/usr/lib/xorg/modules"
[    88.786] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    88.786] (WW) Disabling Keyboard0
[    88.786] (WW) Disabling Mouse0
[    88.786] (II) Loader magic: 0x82553a0
[    88.786] (II) Module ABI versions:
[    88.786] 	X.Org ANSI C Emulation: 0.4
[    88.786] 	X.Org Video Driver: 14.1
[    88.786] 	X.Org XInput driver : 19.1
[    88.786] 	X.Org Server Extension : 7.0
[    88.787] (--) PCI:*(0:0:13:0) 10de:03d6:1849:03d6 rev 162, Mem @ 0xee000000/16777216, 0xd0000000/268435456, 0xed000000/16777216, BIOS @ 0x????????/131072
[    88.787] (II) Open ACPI successful (/var/run/acpid.socket)
[    88.787] Initializing built-in extension Generic Event Extension
[    88.787] Initializing built-in extension SHAPE
[    88.787] Initializing built-in extension MIT-SHM
[    88.788] Initializing built-in extension XInputExtension
[    88.788] Initializing built-in extension XTEST
[    88.788] Initializing built-in extension BIG-REQUESTS
[    88.788] Initializing built-in extension SYNC
[    88.788] Initializing built-in extension XKEYBOARD
[    88.788] Initializing built-in extension XC-MISC
[    88.789] Initializing built-in extension XINERAMA
[    88.789] Initializing built-in extension XFIXES
[    88.789] Initializing built-in extension RENDER
[    88.789] Initializing built-in extension RANDR
[    88.789] Initializing built-in extension COMPOSITE
[    88.789] Initializing built-in extension DAMAGE
[    88.790] Initializing built-in extension MIT-SCREEN-SAVER
[    88.790] Initializing built-in extension DOUBLE-BUFFER
[    88.790] Initializing built-in extension RECORD
[    88.790] Initializing built-in extension DPMS
[    88.790] Initializing built-in extension X-Resource
[    88.790] Initializing built-in extension XVideo
[    88.791] Initializing built-in extension XVideo-MotionCompensation
[    88.791] Initializing built-in extension XFree86-VidModeExtension
[    88.791] Initializing built-in extension XFree86-DGA
[    88.791] Initializing built-in extension XFree86-DRI
[    88.791] Initializing built-in extension DRI2
[    88.791] (II) LoadModule: "glx"
[    88.792] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    88.815] (II) Module glx: vendor="NVIDIA Corporation"
[    88.815] 	compiled for 4.0.2, module version = 1.0.0
[    88.815] 	Module class: X.Org Server Extension
[    88.815] (II) NVIDIA GLX Module  304.108  Wed Jul 31 20:27:22 PDT 2013
[    88.816] Loading extension GLX
[    88.816] (II) LoadModule: "nvidia"
[    88.816] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    88.816] (II) Module nvidia: vendor="NVIDIA Corporation"
[    88.816] 	compiled for 4.0.2, module version = 1.0.0
[    88.816] 	Module class: X.Org Video Driver
[    88.817] (II) NVIDIA dlloader X Driver  304.108  Wed Jul 31 20:05:17 PDT 2013
[    88.817] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    88.817] (--) using VT number 7
[    88.822] (II) Loading sub module "fb"
[    88.822] (II) LoadModule: "fb"
[    88.822] (II) Loading /usr/lib/xorg/modules/libfb.so
[    88.823] (II) Module fb: vendor="X.Org Foundation"
[    88.823] 	compiled for 1.14.3, module version = 1.0.0
[    88.823] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    88.823] (II) Loading sub module "wfb"
[    88.823] (II) LoadModule: "wfb"
[    88.823] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    88.823] (II) Module wfb: vendor="X.Org Foundation"
[    88.824] (II) Loading sub module "ramdac"
[    88.824] (II) LoadModule: "ramdac"
[    88.824] (II) Module "ramdac" already built-in
[    88.824] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[    88.824] (==) NVIDIA(0): RGB weight 888
[    88.824] (==) NVIDIA(0): Default visual is TrueColor
[    88.824] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    88.824] (**) NVIDIA(0): Option "Stereo" "0"
[    88.824] (**) NVIDIA(0): Option "nvidiaXineramaInfoOrder" "CRT-0"
[    88.824] (**) NVIDIA(0): Stereo disabled by request
[    88.824] (**) NVIDIA(0): Option "MetaModes" "1368x768_60 +0+0"
[    88.824] (**) NVIDIA(0): Enabling 2D acceleration
[    89.157] (II) NVIDIA(GPU-0): Display (Ancor Communications Inc ASUS VS197 (CRT-0)) does not
[    89.157] (II) NVIDIA(GPU-0):     support NVIDIA 3D Vision stereo.
[    89.157] (II) NVIDIA(0): NVIDIA GPU GeForce 7025 / nForce 630a (C61) at PCI:0:13:0
[    89.157] (II) NVIDIA(0):     (GPU-0)
[    89.157] (--) NVIDIA(0): Memory: 524288 kBytes
[    89.157] (--) NVIDIA(0): VideoBIOS: 05.61.32.28.01
[    89.157] (--) NVIDIA(0): Interlaced video modes are supported on this GPU
[    89.157] (--) NVIDIA(0): Valid display device(s) on GeForce 7025 / nForce 630a at PCI:0:13:0
[    89.157] (--) NVIDIA(0):     Ancor Communications Inc ASUS VS197 (CRT-0) (connected)
[    89.157] (--) NVIDIA(0): Ancor Communications Inc ASUS VS197 (CRT-0): 350.0 MHz maximum pixel clock
[    89.157] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    89.157] (**) NVIDIA(0):     device Ancor Communications Inc ASUS VS197 (CRT-0) (Using
[    89.157] (**) NVIDIA(0):     EDID frequencies has been enabled on all display
[    89.158] (**) NVIDIA(0):     devices.)
[    89.158] (II) NVIDIA(0): Validated MetaModes:
[    89.158] (II) NVIDIA(0):     "1368x768_60+0+0"
[    89.158] (II) NVIDIA(0): Virtual screen size determined to be 1368 x 768
[    89.158] (--) NVIDIA(0): DPI set to (84, 84); computed from "UseEdidDpi" X config
[    89.158] (--) NVIDIA(0):     option
[    89.158] (--) Depth 24 pixmap format is 32 bpp
[    89.163] (II) NVIDIA(0): Setting mode "1368x768_60+0+0"
[    89.244] Loading extension NV-GLX
[    89.267] (==) NVIDIA(0): Disabling shared memory pixmaps
[    89.267] (==) NVIDIA(0): Backing store disabled
[    89.267] (==) NVIDIA(0): Silken mouse enabled
[    89.267] (**) NVIDIA(0): DPMS enabled
[    89.267] Loading extension NV-CONTROL
[    89.268] Loading extension XINERAMA
[    89.268] (II) Loading sub module "dri2"
[    89.268] (II) LoadModule: "dri2"
[    89.268] (II) Module "dri2" already built-in
[    89.268] (II) NVIDIA(0): [DRI2] Setup complete
[    89.268] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    89.268] (--) RandR disabled
[    89.274] (II) Initializing extension GLX
[    89.506] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    89.507] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    89.507] (**) Power Button: Applying InputClass "keyboard-all"
[    89.507] (II) LoadModule: "evdev"
[    89.507] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    89.507] (II) Module evdev: vendor="X.Org Foundation"
[    89.507] 	compiled for 1.14.3, module version = 2.8.2
[    89.507] 	Module class: X.Org XInput Driver
[    89.507] 	ABI class: X.Org XInput driver, version 19.1
[    89.507] (II) Using input driver 'evdev' for 'Power Button'
[    89.507] (**) Power Button: always reports core events
[    89.507] (**) evdev: Power Button: Device: "/dev/input/event2"
[    89.507] (--) evdev: Power Button: Vendor 0 Product 0x1
[    89.507] (--) evdev: Power Button: Found keys
[    89.507] (II) evdev: Power Button: Configuring as keyboard
[    89.507] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[    89.507] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    89.507] (**) Option "xkb_rules" "evdev"
[    89.507] (**) Option "xkb_model" "pc104"
[    89.507] (**) Option "xkb_layout" "us"
[    89.507] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    89.533] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[    89.533] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    89.533] (**) Power Button: Applying InputClass "keyboard-all"
[    89.533] (II) Using input driver 'evdev' for 'Power Button'
[    89.533] (**) Power Button: always reports core events
[    89.533] (**) evdev: Power Button: Device: "/dev/input/event1"
[    89.533] (--) evdev: Power Button: Vendor 0 Product 0x1
[    89.533] (--) evdev: Power Button: Found keys
[    89.533] (II) evdev: Power Button: Configuring as keyboard
[    89.533] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input1/event1"
[    89.533] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    89.533] (**) Option "xkb_rules" "evdev"
[    89.533] (**) Option "xkb_model" "pc104"
[    89.533] (**) Option "xkb_layout" "us"
[    89.533] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    89.533] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event6)
[    89.533] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[    89.533] (**) Logitech USB Receiver: Applying InputClass "keyboard-all"
[    89.533] (II) Using input driver 'evdev' for 'Logitech USB Receiver'
[    89.533] (**) Logitech USB Receiver: always reports core events
[    89.533] (**) evdev: Logitech USB Receiver: Device: "/dev/input/event6"
[    89.533] (--) evdev: Logitech USB Receiver: Vendor 0x46d Product 0xc517
[    89.533] (--) evdev: Logitech USB Receiver: Found keys
[    89.533] (II) evdev: Logitech USB Receiver: Configuring as keyboard
[    89.533] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb2/2-2/2-2:1.0/input/input6/event6"
[    89.533] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 8)
[    89.534] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event7)
[    89.534] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[    89.534] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[    89.534] (**) Logitech USB Receiver: Applying InputClass "keyboard-all"
[    89.534] (II) Using input driver 'evdev' for 'Logitech USB Receiver'
[    89.534] (**) Logitech USB Receiver: always reports core events
[    89.534] (**) evdev: Logitech USB Receiver: Device: "/dev/input/event7"
[    89.534] (--) evdev: Logitech USB Receiver: Vendor 0x46d Product 0xc517
[    89.534] (--) evdev: Logitech USB Receiver: Found 12 mouse buttons
[    89.534] (--) evdev: Logitech USB Receiver: Found scroll wheel(s)
[    89.534] (--) evdev: Logitech USB Receiver: Found relative axes
[    89.534] (--) evdev: Logitech USB Receiver: Found x and y relative axes
[    89.534] (--) evdev: Logitech USB Receiver: Found absolute axes
[    89.534] (II) evdev: Logitech USB Receiver: Forcing absolute x/y axes to exist.
[    89.534] (--) evdev: Logitech USB Receiver: Found keys
[    89.534] (II) evdev: Logitech USB Receiver: Configuring as mouse
[    89.534] (II) evdev: Logitech USB Receiver: Configuring as keyboard
[    89.534] (II) evdev: Logitech USB Receiver: Adding scrollwheel support
[    89.534] (**) evdev: Logitech USB Receiver: YAxisMapping: buttons 4 and 5
[    89.534] (**) evdev: Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    89.534] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb2/2-2/2-2:1.1/input/input7/event7"
[    89.534] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 9)
[    89.534] (**) Option "xkb_rules" "evdev"
[    89.534] (**) Option "xkb_model" "pc104"
[    89.534] (**) Option "xkb_layout" "us"
[    89.534] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    89.534] (II) evdev: Logitech USB Receiver: initialized for relative axes.
[    89.534] (WW) evdev: Logitech USB Receiver: ignoring absolute axes.
[    89.534] (**) Logitech USB Receiver: (accel) keeping acceleration scheme 1
[    89.534] (**) Logitech USB Receiver: (accel) acceleration profile 0
[    89.534] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[    89.534] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[    89.534] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse0)
[    89.535] (II) No input driver specified, ignoring this device.
[    89.535] (II) This device may have been added with another device file.
[    89.535] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event8)
[    89.535] (**) Logitech USB Receiver: Applying InputClass "evdev pointer catchall"
[    89.535] (II) Using input driver 'evdev' for 'Logitech USB Receiver'
[    89.535] (**) Logitech USB Receiver: always reports core events
[    89.535] (**) evdev: Logitech USB Receiver: Device: "/dev/input/event8"
[    89.535] (--) evdev: Logitech USB Receiver: Vendor 0x46d Product 0xc52f
[    89.535] (--) evdev: Logitech USB Receiver: Found 20 mouse buttons
[    89.535] (--) evdev: Logitech USB Receiver: Found scroll wheel(s)
[    89.535] (--) evdev: Logitech USB Receiver: Found relative axes
[    89.535] (--) evdev: Logitech USB Receiver: Found x and y relative axes
[    89.535] (II) evdev: Logitech USB Receiver: Configuring as mouse
[    89.535] (II) evdev: Logitech USB Receiver: Adding scrollwheel support
[    89.535] (**) evdev: Logitech USB Receiver: YAxisMapping: buttons 4 and 5
[    89.535] (**) evdev: Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    89.535] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb2/2-4/2-4:1.0/input/input8/event8"
[    89.535] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: MOUSE, id 10)
[    89.535] (II) evdev: Logitech USB Receiver: initialized for relative axes.
[    89.535] (**) Logitech USB Receiver: (accel) keeping acceleration scheme 1
[    89.535] (**) Logitech USB Receiver: (accel) acceleration profile 0
[    89.535] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[    89.535] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[    89.535] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/mouse1)
[    89.535] (II) config/udev: Adding input device Logitech USB Receiver (/dev/input/event9)
[    89.535] (**) Logitech USB Receiver: Applying InputClass "evdev keyboard catchall"
[    89.535] (**) Logitech USB Receiver: Applying InputClass "keyboard-all"
[    89.535] (**) evdev: Logitech USB Receiver: Device: "/dev/input/event9"
[    89.535] (--) evdev: Logitech USB Receiver: Found 1 mouse buttons
[    89.535] (II) evdev: Logitech USB Receiver: Forcing relative x/y axes to exist.
[    89.535] (--) evdev: Logitech USB Receiver: Found absolute axes
[    89.535] (II) evdev: Logitech USB Receiver: Forcing absolute x/y axes to exist.
[    89.535] (--) evdev: Logitech USB Receiver: Found keys
[    89.536] (II) evdev: Logitech USB Receiver: Configuring as keyboard
[    89.536] (II) evdev: Logitech USB Receiver: Adding scrollwheel support
[    89.536] (**) evdev: Logitech USB Receiver: YAxisMapping: buttons 4 and 5
[    89.536] (**) evdev: Logitech USB Receiver: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    89.536] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb2/2-4/2-4:1.1/input/input9/event9"
[    89.536] (II) XINPUT: Adding extended input device "Logitech USB Receiver" (type: KEYBOARD, id 11)
[    89.536] (**) Option "xkb_rules" "evdev"
[    89.536] (**) Option "xkb_model" "pc104"
[    89.536] (**) Option "xkb_layout" "us"
[    89.536] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    89.536] (II) evdev: Logitech USB Receiver: initialized for relative axes.
[    89.536] (WW) evdev: Logitech USB Receiver: ignoring absolute axes.
[    89.536] (**) Logitech USB Receiver: (accel) keeping acceleration scheme 1
[    89.536] (**) Logitech USB Receiver: (accel) acceleration profile 0
[    89.536] (**) Logitech USB Receiver: (accel) acceleration factor: 2.000
[    89.536] (**) Logitech USB Receiver: (accel) acceleration threshold: 4
[    89.536] (II) config/udev: Adding input device HDA NVidia Line Out (/dev/input/event3)
[    89.536] (II) No input driver specified, ignoring this device.
[    89.536] (II) This device may have been added with another device file.
[    89.536] (II) config/udev: Adding input device HDA NVidia Line (/dev/input/event4)
[    89.536] (II) config/udev: Adding input device HDA NVidia Rear Mic (/dev/input/event5)
[    89.537] (II) config/udev: Adding input device Speakup (/dev/input/event0)
[    89.537] (**) Speakup: Applying InputClass "evdev keyboard catchall"
[    89.537] (**) Speakup: Applying InputClass "keyboard-all"
[    89.537] (II) Using input driver 'evdev' for 'Speakup'
[    89.537] (**) Speakup: always reports core events
[    89.537] (**) evdev: Speakup: Device: "/dev/input/event0"
[    89.537] (--) evdev: Speakup: Vendor 0 Product 0
[    89.537] (--) evdev: Speakup: Found keys
[    89.537] (II) evdev: Speakup: Configuring as keyboard
[    89.537] (**) Option "config_info" "udev:/sys/devices/virtual/input/input0/event0"
[    89.537] (II) XINPUT: Adding extended input device "Speakup" (type: KEYBOARD, id 12)
[    89.537] (**) Option "xkb_rules" "evdev"
[    89.537] (**) Option "xkb_model" "pc104"
[    89.537] (**) Option "xkb_layout" "us"
[    89.537] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    90.823] (II) NVIDIA(GPU-0): Display (Ancor Communications Inc ASUS VS197 (CRT-0)) does not
[    90.823] (II) NVIDIA(GPU-0):     support NVIDIA 3D Vision stereo.
[    90.823] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    90.823] (**) NVIDIA(0):     device Ancor Communications Inc ASUS VS197 (CRT-0) (Using
[    90.823] (**) NVIDIA(0):     EDID frequencies has been enabled on all display
[    90.823] (**) NVIDIA(0):     devices.)
[    91.525] (II) NVIDIA(GPU-0): Display (Ancor Communications Inc ASUS VS197 (CRT-0)) does not
[    91.525] (II) NVIDIA(GPU-0):     support NVIDIA 3D Vision stereo.
[    91.525] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    91.525] (**) NVIDIA(0):     device Ancor Communications Inc ASUS VS197 (CRT-0) (Using
[    91.525] (**) NVIDIA(0):     EDID frequencies has been enabled on all display
[    91.525] (**) NVIDIA(0):     devices.)
[    99.857] (II) NVIDIA(GPU-0): Display (Ancor Communications Inc ASUS VS197 (CRT-0)) does not
[    99.857] (II) NVIDIA(GPU-0):     support NVIDIA 3D Vision stereo.
[    99.857] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    99.857] (**) NVIDIA(0):     device Ancor Communications Inc ASUS VS197 (CRT-0) (Using
[    99.857] (**) NVIDIA(0):     EDID frequencies has been enabled on all display
[    99.857] (**) NVIDIA(0):     devices.)
Evo i xorg.conf:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 304.108  (root@desktop)  Sat Jul 19 02:52:37 CEST 2014
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
    FontPath        "/usr/lib/X11/fonts/misc/:unscaled"
    FontPath        "/usr/lib/X11/fonts/100dpi/:unscaled"
    FontPath        "/usr/lib/X11/fonts/75dpi/:unscaled"
    FontPath        "/usr/lib/X11/fonts/misc/"
    FontPath        "/usr/lib/X11/fonts/Type1/"
    FontPath        "/usr/lib/X11/fonts/Speedo/"
    FontPath        "/usr/lib/X11/fonts/100dpi/"
    FontPath        "/usr/lib/X11/fonts/75dpi/"
    FontPath        "/usr/lib/X11/fonts/cyrillic/"
    FontPath        "/usr/lib/X11/fonts/TTF/"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Ancor Communications Inc ASUS VS197"
    HorizSync       24.0 - 83.0
    VertRefresh     50.0 - 75.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce 7025 / nForce 630a"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "Stereo" "0"
    Option         "metamodes" "1368x768_60 +0+0"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Vi ste iskusniji i imate više znanja pa možda vidite neki problem, ja ne znam šta se dešava.
Post Napisano: 28 Jul 2014, 14:37
Problem je u tome sto se Slack i Nvidia cesto ne slazu... Ti si rucno stavljao Nvidia drajver?
Where there is a shell, there is a way.~UNIX
Post Napisano: 28 Jul 2014, 15:02
Jesam. Malo sam čačkao i mislim da je problem do KDE, da on nešto zeza. Probao sam awesome, XFCE, Flux, rade bez problema, više puta sam probao. KDE kako kada. Evo poslednjih par puta se nije dešavalo radio je normalno. Posebno je čudno što ne radi a onda kada se ponovi ista komanda radi sasvim normalno. Zato mislim da možda nekada ne učita neki modul kako treba pa da zato dolazi do tog problema.
Post Napisano: 28 Jul 2014, 15:08
Probaj da reinstaliras Mesu...
Post Napisano: 28 Jul 2014, 18:04
U logu nema ništa zanimljivo.
Inače, mene ovo, bez tačnog teksta greške, malo podseća na gatanje. Šta je "out of range"? Može da se odnosi na više stvari. Ali ok, nemam ništa protiv da nastavite sa igranjem, ali to ima i svoje rizike. Lično ne bih ništa preduzimao bez konkretnijih podataka. ;)
Post Napisano: 28 Jul 2014, 18:54
Ma znam i ja to ali šta podrazumevaš pod konkretnijim podacima o grešci? :) U tome i jeste stvar što ih nema. Log je čist, xorg.conf je ok, ne znam gde bih tražio grešku ili neki drugi log, jebem li ga zato sam i zbunjen. Out of range se sigurno odnosi ili na rezoluciju ili na refresh rate ali zbunjuje to, opet kažem, što čas radi, čas ne radi. To me još više tripuje. Jbš ga, nešto ili šljaka ili ne a ne ovako, čas radi čas ne..
Možda je do rezolucije splash screen-a. Glasno razmišljam.. To je na Mintu umelo da pravi problem. Ne prikazuje dobru rezoluciju na splash screen-u i onda je rezolucija prevelika ili premala.. Iz znatiželje sam probao da ubacim grafički login ali tu je tek sranie. Puca, ne prikazuje ga skoro uopšte, pola ekrana ili neke brljotine, linije.. Ludilo.. Za Moldera i Skali.. :D
Post Napisano: 28 Jul 2014, 19:02
Fali ti libGLU iz mesa biblioteke...
Post Napisano: 28 Jul 2014, 20:11
Šta ti je to? Gde to da nađem? Kako znaš? :)
Post Napisano: 28 Jul 2014, 20:18
Mesa ti je kolekcija biblioteka za video akceleraciju i rendering... (OpenGL)
To si verovatno obrisao kad si stelovao Nvidia drajvere, sto tipicno i nije greska jer Nvidia ima svoju OpenGL biblioteku, ali
KDE specificno zahteva bas tu.
Zato ti ostali DE rade normalno.
Zato pokusaj da reinstaliras mesu.
# slackpkg reinstall mesa
Post Napisano: 28 Jul 2014, 21:35
Probam pa javljam. Hvala ti. ;)
Users browsing this forum: No registered users and 33 guests
