Slack na Thinkpad R23
Post Napisano: 18 Apr 2013, 17:03
Moji predlozi su CrunchBang 10 koji si već probao (znači OpenBox sa Thunar windows menadžerom) ili možda još bolje VectorLinux 7.0 "Light" verzija.
Evo šta kaže dokumentacija
VectorLinux 7.0 Light is completed and released. The term 'Light' is relative. This 4-in-1 edition gives you the choice of several window managers, in progressively heavier configurations. These are layered on top of the VectorLinux 7.0 Standard base, so the expected libraries, toolkits, compilers and codecs remain available. For those who want a starting point for their own customized desktop, there is the 'Barebone' option. It is managed by the super-lightweight JWM, without much fluff. Netsurf, a small and speedy web browser, gives you access to the power of the Internet. Use the included build tools and package manager to download and install the programs of your choice. This configuration has been tested on a Pentium 3 with 128 MB of memory
Znači on je upravo testiran na gotovo istom hardveru kao kod ovog laptopa. Single core CPU u rangu P III sa 128 mb RAM-a.
Ja bih ipak išao na Vectora 7 Light verziju.
Matična stranica
https://vector.ecosq.com/ic/" onclick="window.open(this.href);return false;
ISO
http://vectorlinux.osuosl.org/veclinux- ... -LIGHT.iso" onclick="window.open(this.href);return false;
Post Napisano: 19 Apr 2013, 00:13
OpenBSD - nije linux, ali je sličan...
Uspevali su da ga poguraju sa gnome2 ispod 90 mb rama.
64M RAM or better: If you wish to run X, 128M would be a better starting point.
Čini mi se da linux više nije tako lagan - npr. Zenwalk je važio za tako nešto - do poslednje serije, ali verovatno ima gomile drugih.
OpenBSD je ono što bih ja postavio...
