Dodavanje ulaza za druge distribucije u LILO
Postavi ceo lilo.conf da pogledamo.
petar@petar:~$ cat /etc/lilo.conf
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
append=" vt.default_utf8=0"
boot = /dev/sda
# Boot BMP Image.
bitmap = /boot/slack.bmp
bmp-table = 60,6,1,16
bmp-timer = 65,27,0,255
# Standard menu.
# first entry immediately):
prompt
timeout = 1200
change-rules
reset
# Normal VGA console
vga = normal
#vga = ask
#vga=791
#vga=790
#vga=773
#vga=788
#vga=787
#vga=771
#vga=785
#vga=784
#vga=769
# End LILO global section
# Windows bootable partition config begins
other = /dev/sda1
label = Windows
table = /dev/sda
# Windows bootable partition config ends
image = /boot/vmlinuz
root = /dev/root
label = Slackware
read-only
root = /dev/sda5
initrd = /boot/initrd.img
label = Cinnamon
read-only
Neka stoji ovo kao poslednje rešenje ako ni jedno ne može da se nađe. Ne instalira mi se baš bootloader na svaku particiju. Ja, osim Mint-a, bih ubacio i Kubuntu i Crunchbang...
boot = /dev/sda
prompt
# Timeout before the first entry boots. This is given in tenths of a second, so 600 for every minute:
timeout = 1200
change-rules
reset
vga = normal
other = /dev/sda1
label = Windows
table = /dev/sda
root = /dev/root
label = Slackware
read-only
image = /boot/vmlinuz-3.0.0-12-generic
root = /dev/sda5
initrd = /boot/initrd.img-3.0.0-12-generic
label = Cinnamon
read-only
Reason: ispavljen typo
Pazi, meni je Grub2 instaliran na particiju na kojoj se nalazi Kubuntu (sda9). Evo ga grub.cfg iz Kubuntu-a:
bash-4.1$ cat grub.cfg
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
set default="0"
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
insmod part_msdos
insmod ext2
set root='(hd0,msdos9)'
search --no-floppy --fs-uuid --set=root 13c9eb93-e2c6-44ea-b57a-864160e6c43c
if loadfont /usr/share/grub/unicode.pf2 ; then
set gfxmode=auto
load_video
insmod gfxterm
insmod part_msdos
insmod ext2
set locale_dir=($root)/boot/grub/locale
set lang=en_US
insmod gettext
fi
terminal_output gfxterm
insmod part_msdos
insmod ext2
insmod jpeg
background_image -m stretch /home/petar/Pictures/Persian_cat_hd_wallpaper.jpg
if [ "${recordfail}" = 1 ]; then
set timeout=-1
else
set timeout=10
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
insmod part_msdos
insmod ext2
insmod jpeg
if background_image /home/petar/Pictures/Persian_cat_hd_wallpaper.jpg; then
true
else
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
if background_color 0,71,115; then
clear
fi
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="$1"
if [ "$1" = "keep" ]; then
set vt_handoff=vt.handoff=7
else
set vt_handoff=
fi
if [ ${recordfail} != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
if [ "$linux_gfx_mode" != "text" ]; then load_video; fi
menuentry 'Ubuntu, with Linux 3.3.1-petar' --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
gfxmode $linux_gfx_mode
insmod gzio
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-3.3.1-petar root=UUID=13c9eb93-e2c6-44ea-b57a-864160e6c43c ro quiet splash $vt_handoff
initrd /boot/initrd.img-3.3.1-petar
menuentry 'Ubuntu, with Linux 3.3.1-petar (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os {
recordfail
insmod gzio
insmod part_msdos
insmod ext2
echo 'Loading Linux 3.3.1-petar ...'
linux /boot/vmlinuz-3.3.1-petar root=UUID=13c9eb93-e2c6-44ea-b57a-864160e6c43c ro recovery nomodeset
echo 'Loading initial ramdisk ...'
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry "Memory test (memtest86+)" {
insmod part_msdos
insmod ext2
linux16 /boot/memtest86+.bin
menuentry "Memory test (memtest86+, serial console 115200)" {
insmod part_msdos
insmod ext2
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry "Windows 7 (loader) (on /dev/sda1)" --class windows --class os {
insmod part_msdos
insmod ntfs
set root='(hd0,msdos1)'
search --no-floppy --fs-uuid --set=root 667C68AE7C687B27
chainloader +1
menuentry "Slackware Linux (Slackware 13.37.0) (on /dev/sda10)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
set root='(hd0,msdos10)'
search --no-floppy --fs-uuid --set=root a9859b3a-1e55-4ea6-91a1-8fe671db8d1c
linux /boot/vmlinuz root=/dev/sda10
insmod part_msdos
insmod ext2
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-generic-2.6.37.6 root=/dev/sda10
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-huge-2.6.37.6 root=/dev/sda10
menuentry "Sabayon GNU/Linux, with Linux x86_64-3.2.0-sabayon (on /dev/sda11)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
set root='(hd0,msdos11)'
search --no-floppy --fs-uuid --set=root af81e662-81ab-4cdc-9670-a460335d7f63
linux /boot/kernel-genkernel-x86_64-3.2.0-sabayon ro init=/linuxrc splash=silent,theme:sabayon video=vesafb:ywrap,mtrr:3 vga=791 console=tty1 quiet dokeymap keymap=us domdadm root=UUID=af81e662-81ab-4cdc-9670-a460335d7f63 docrypt
initrd /boot/initramfs-genkernel-x86_64-3.2.0-sabayon
menuentry "Sabayon GNU/Linux, with Linux x86_64-3.2.0-sabayon (recovery mode) (on /dev/sda11)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
linux /boot/kernel-genkernel-x86_64-3.2.0-sabayon ro single init_opts=single init=/linuxrc splash=verbose,theme:sabayon video=vesafb:ywrap,mtrr:3 vga=791 console=tty1 quiet dokeymap keymap=us domdadm root=UUID=af81e662-81ab-4cdc-9670-a460335d7f63 docrypt
menuentry "Linux Mint 12 64-bit, 3.0.0-12-generic (/dev/sda5) (on /dev/sda5)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
set root='(hd0,msdos5)'
search --no-floppy --fs-uuid --set=root 7eedd72f-13f0-40f0-82d3-e454be3bb897
linux /boot/vmlinuz-3.0.0-12-generic root=UUID=7eedd72f-13f0-40f0-82d3-e454be3bb897 ro quiet splash vt.handoff=7
initrd /boot/initrd.img-3.0.0-12-generic
menuentry "Linux Mint 12 64-bit, 3.0.0-12-generic (/dev/sda5) -- recovery mode (on /dev/sda5)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-3.0.0-12-generic root=UUID=7eedd72f-13f0-40f0-82d3-e454be3bb897 ro recovery nomodeset
menuentry "CrunchBang Linux, with Linux 3.2.0-0.bpo.1-amd64 (on /dev/sda8)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
set root='(hd0,msdos8)'
search --no-floppy --fs-uuid --set=root ee4aff19-db71-4fbf-90b9-496c0daba243
linux /boot/vmlinuz-3.2.0-0.bpo.1-amd64 root=UUID=ee4aff19-db71-4fbf-90b9-496c0daba243 ro quiet splash
initrd /boot/initrd.img-3.2.0-0.bpo.1-amd64
menuentry "CrunchBang Linux, with Linux 3.2.0-0.bpo.1-amd64 (recovery mode) (on /dev/sda8)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
linux /boot/vmlinuz-3.2.0-0.bpo.1-amd64 root=UUID=ee4aff19-db71-4fbf-90b9-496c0daba243 ro single
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
Ako je instaliran na tu particiju onda za njega nije ni potreban. Njega ćemo pozvati direkt. Nego ovaj Cinammon, to je Mint? Šta on koristi?
Isto grub2... Da, mint je, okruženje u mint-u.
Evo sadržaja grub.cfg:
To je on napravio kad sam ga instalirao, davno beše Onda sam ja ponovo vratio grub2 na Kubuntu (dev/sda9).
load_env
fi
set default="0"
set boot_once=true
fi
fi
set recordfail=1
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
insmod part_msdos
insmod ext2
set gfxmode=auto
load_video
insmod gfxterm
insmod part_msdos
insmod ext2
set lang=en_US
insmod gettext
fi
set timeout=-1
else
set timeout=10
fi
if background_color 0,0,0; then
clear
fi
### BEGIN /etc/grub.d/06_mint_theme ###
set menu_color_highlight=white/light-gray
### END /etc/grub.d/06_mint_theme ###
else
fi
else
fi
else
fi
else
fi
menuentry 'Linux Mint 12 64-bit, 3.0.0-12-generic (/dev/sda5)' --class linuxmint --class gnu-linux --class gnu --class os {
recordfail
set gfxpayload=$linux_gfx_mode
insmod gzio
insmod part_msdos
insmod ext2
menuentry 'Linux Mint 12 64-bit, 3.0.0-12-generic (/dev/sda5) -- recovery mode' --class linuxmint --class gnu-linux --class gnu --class os {
recordfail
insmod gzio
insmod part_msdos
insmod ext2
echo 'Loading Linux 3.0.0-12-generic ...'
### BEGIN /etc/grub.d/10_lupin ###
### END /etc/grub.d/10_lupin ###
insmod part_msdos
insmod ext2
insmod part_msdos
insmod ext2
insmod part_msdos
insmod ntfs
chainloader +1
insmod part_msdos
insmod ext2
insmod part_msdos
insmod ext2
menuentry "Slackware (on /dev/sda9)" --class gnu-linux --class gnu --class os {
insmod part_msdos
insmod ext2
search --no-floppy --fs-uuid --set=root 016a06a3-7732-4c69-9478-676ae5ed6107
linux /boot/vmlinuz root=/dev/sda9 ro vt.default_utf8=0 vga = normal
fi
E, ovako:
Napravljen je mali pomak. Nakon izmene lilo-ovog konfiguracionog fajla (/etc/lilo.conf) da izgleda ovako:
Windows i Linux (Slackware) se uredno učitavaju pri odabiru u LILO-u. Probao sam sa ubacivanjem novih sistema (ulaza) i situacija je sledeća:
Kad stavim parametar initd izbaci grešku pri komandi:
Fatal error i pominje initrd i kaže da ne može da ga nađe. Kad izbacim taj parametar, onda uredno, nakon prethodne komande, izlista sve sisteme. ali kad startujem neki sistem (osim Windows-a i Slackware-a) iz LILO-a krene učitavanje i dođe do prijavnog ekrana.
Tu sve stane, blinka kursor u polju Password, ali miš i tastatura ne reaguju. Pa mora fizički restart. Tako da sam opet morao da vratim grub2
boot = /dev/sda
prompt
timeout = 10
change-rules
reset
vga = normal
other = /dev/sda1
label = Windows
table = /dev/sda
root = /dev/sda6
label = Slackware
read-only
su -c lilo
Hajde da probamo ovako. Daj prvo izlaz
Zatim napiši na kojoj je particiji koji operativni sistem.
blkid
Users browsing this forum: No registered users and 22 guests
