Napisano: 12 Apr 2012, 18:17
/dev/sda1: LABEL="System Reserved" UUID="667C68AE7C687B27" TYPE="ntfs"
/dev/sda2: UUID="92EC8A8FEC8A6D73" TYPE="ntfs"
/dev/sda3: UUID="9EE40E71E40E4C49" TYPE="ntfs"
/dev/sda5: LABEL="Kubuntu" UUID="13c9eb93-e2c6-44ea-b57a-864160e6c43c" TYPE="ext4"
/dev/sda6: LABEL="Slackware" UUID="a9859b3a-1e55-4ea6-91a1-8fe671db8d1c" TYPE="ext4"
/dev/sda7: LABEL="Cinnamon" UUID="7eedd72f-13f0-40f0-82d3-e454be3bb897" TYPE="ext4"
/dev/sda8: LABEL="magacin" UUID="754d951f-ed05-430f-9523-7bd2efdcb77d" TYPE="ext4
sda1 - System reserved od windowsa, ono što on sam pravi
sda2 - windows (sistem)
sda3 - D
Za ostalo piše.
Napisano: 12 Apr 2012, 18:34
slackmuz wrote:Code: Select all
Uđi u Slack i montiraj /dev/sda5 i /dev/sda7. Napravi listing (ls -l) svih stavki u jednom, pa u drugom. Postavi ih odvojeno u odgovoru.
Napisano: 12 Apr 2012, 18:36
sda5 - Kubuntu
total 45316
-rw-r--r-- 1 root root 2814744 Apr 6 15:49 System.map-3.3.1-petar
-rw-r--r-- 1 root root 137987 Apr 6 15:21 config-3.3.1-petar
drwxr-xr-x 3 root root 12288 Apr 12 14:51 grub
-rw-r--r-- 1 root root 19369223 Apr 12 15:16 initrd.img-3.3.1-petar
-rw-r--r-- 1 root root 19369369 Apr 12 15:10 initrd.img-3.3.1-petar.dpkg-bak
-rw-r--r-- 1 root root 176764 Nov 27 10:00 memtest86+.bin
-rw-r--r-- 1 root root 178944 Nov 27 10:00 memtest86+_multiboot.bin
-rw-r--r-- 1 root root 4330336 Apr 6 15:49 vmlinuz-3.3.1-petar
sda7 - Cinnamon
total 27856
-rw------- 1 root root 2694177 Oct 7 2011 System.map-3.0.0-12-generic
-rw-r--r-- 1 root root 730503 Oct 7 2011 abi-3.0.0-12-generic
-rw-r--r-- 1 root root 134754 Oct 7 2011 config-3.0.0-12-generic
drwxr-xr-x 3 root root 12288 Apr 10 19:39 grub
-rw-r--r-- 1 root root 19922167 Mar 27 12:56 initrd.img-3.0.0-12-generic
-rw-r--r-- 1 root root 176764 May 2 2011 memtest86+.bin
-rw-r--r-- 1 root root 178944 May 2 2011 memtest86+_multiboot.bin
-rw------- 1 root root 1367 Oct 7 2011 vmcoreinfo-3.0.0-12-generic
-rw-r--r-- 1 root root 4658096 Nov 24 19:13 vmlinuz-3.0.0-12-generic
Slackmuz on 12 Apr 2012, 18:42, edited 1 time in total.
Napisano: 12 Apr 2012, 18:40
Sačuvaj ovo kao lilo.conf:
boot = /dev/sda
bitmap = /boot/slack.bmp
bmp-table = 60,6,1,16
bmp-timer = 65,27,0,255
prompt
timeout = 10
change-rules
reset
vga = normal
# Windows config begins
other = /dev/sda1
label = Windows
table = /dev/sda
# Windows config ends
# Slackware config begins
image = /boot/vmlinuz
root = /dev/sda6
label = Slackware
read-only
# Slackware config ends
# Kubuntu config begins
image = /boot/vmlinuz-3.3.1-petar
root = /dev/sda5
label = Kubuntu
initrd = /boot/initrd.img-3.3.1-petar
read-only
# Kubuntu config ends
# Mint config begins
image = /boot/vmlinuz-3.0.0-12-generic
root = /dev/sda7
label = Cinnamon
initrd = /boot/initrd.img-3.0.0-12-generic
read-only
# Mint config ends
Nakon promene otkucaj:
Kako bi lilo sačuvao promene.
Btw, postoji još jedna opcija. Slack ima alatku za konfiguraciju Lilo-a. Zove se liloconfig. Ovako nešto (dodavanje drugih distroa) bismo mogli da odradimo i iz "expert" menija.
Napisano: 12 Apr 2012, 19:27
Pa sad vidim gde je greška... Znači ja sam morao za svaku distribuciju da stavljam ono begin i end sa imanima? Ja sam tu roknuo Linux begin i end
Sad ću da probam...
UPDATE:
Evo šta izbaci:
Warning: LBA32 addressing assumed
Warning: Unable to determine video adapter in use in the present system.
Warning: Video adapter does not support VESA BIOS extensions needed for
display of 256 colors. Boot loader will fall back to TEXT only operation.
Added Windows *
Added Slackware
Fatal: open /boot/vmlinuz-3.3.1-petar: No such file or directory
Slackmuz on 12 Apr 2012, 19:35, edited 1 time in total.
Napisano: 12 Apr 2012, 19:33
To su komentari. Nema to veze.
Da li si pokretao lilo posle svake promene? Šta je (bio) ispis?
Napisano: 12 Apr 2012, 19:39
Ne, nego sam sve ubacio, pa pokrenuo lilo... Je l' treba posle svakog ulaza?
Napisano: 12 Apr 2012, 20:27
Evo ga rešenje:
http://wiki.zenwalk.org/index.php?title ... _with_LILO" onclick="window.open(this.href);return false;
LILO očekuje ili da kernel i initrd slika budu na istoj particiji na kojoj je i LILO, ili da te druge particije budu montirane. Zato imaš problem sa multiboot-om.
1. Jedno rešenje bi bilo da iskopiraš oba kernela i initrd slike u Slackov /boot. To bi trebalo da radi i sa ovom konfiguracijom iz prethodnog posta (btw, baci pogled - ispravio sam typo - cinammon je /dev/sda7 ne /dev/sda6).
2. Drugo rešenje... Ubaci Mint i Kubuntu particije u /etc/fstab, postavi pune putanje ispred kernela i initrd (na primer /mnt/sda7/boot/vmlinuz-blabla) kao što je to urađeno u ZenWalk uputstvu.
Napisano: 12 Apr 2012, 20:47
sa' ću da probam... Probao sam i iz liloconfig -> expert mode da ubacim Cinnamon, ali opet isto... Sad ću baš da vidim sa ovim.
UPDATE:
Kad kopiram u /boot izbaci mi ovo:
Added Windows *
Added Slackware
Fatal: Setup length exceeds 31 maximum; kernel setup will overwrite boot loader
Sa' ću da probam sa montiranjem
UPDATE2:
Isto, kaže da premašuje 31 karakter...
Napisano: 12 Apr 2012, 21:40
Update lilo paketa resava problem sa tom porukom. Dakle, potrebno je prvo update-ovati LILO, a zatim izvrsiti promene koje je bocke naveo. Ja sam imao isti problem (poruka o premasenom broju karaktera) koji se desava samo kada koristis kernele serije 3. Resio sam instaliranjem (update) paketa koji se nalazi u current-u...verzija 23.2
Users browsing this forum: No registered users and 26 guests
