[REŠENO] Nakon jučerašnje nadogradnje currenta pukao X
Pade mi nešto na pamet... ETFovi serveri su u poslednje vreme malo sporiji. Možda da pokušaš downgrade na verzije koje su kod njih.
Mislim, zeroov predlog je ok i sigurno jedna od opcija, ali ne znam koliko imaš strpljenja za to (kao što se bojim i da ćeš se spetljati nege usput).
Uh, da. On koristi propriatry drajvere.zero wrote:Takođe, drajver za grafiku je bilo potrebno reinstalirati!
Hvala zero,
evo tačnog ispisa greške, ovo je iz mog naloga:
xauth: file /home/zeljko/.serverauth.5498 does not exist
X.Org X Server 1.13.4
Release Date: 2013-04-17
X Protocol Version 11, Revision 0
Build Operating System: Slackware 14.1 Slackware Linux Project
Current Operating System: Linux stereo 3.10.9-smp #2 SMP Wed Aug 21 15:35:02 CDT 2013 i686
Kernel command line: auto BOOT_IMAGE=Slackware ro root=811 vt.default_utf8=1
Build Date: 18 April 2013 01:51:03AM
Current version of pixman: 0.30.2
Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Sep 12 12:52:06 2013
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Initializing built-in extension Generic Event Extension
Initializing built-in extension SHAPE
Initializing built-in extension MIT-SHM
Initializing built-in extension XInputExtension
Initializing built-in extension XTEST
Initializing built-in extension BIG-REQUESTS
Initializing built-in extension SYNC
Initializing built-in extension XKEYBOARD
Initializing built-in extension XC-MISC
Initializing built-in extension XINERAMA
Initializing built-in extension XFIXES
Initializing built-in extension RENDER
Initializing built-in extension RANDR
Initializing built-in extension COMPOSITE
Initializing built-in extension DAMAGE
Initializing built-in extension MIT-SCREEN-SAVER
Initializing built-in extension DOUBLE-BUFFER
Initializing built-in extension RECORD
Initializing built-in extension DPMS
Initializing built-in extension X-Resource
Initializing built-in extension XVideo
Initializing built-in extension XVideo-MotionCompensation
Initializing built-in extension XFree86-VidModeExtension
Initializing built-in extension XFree86-DGA
Initializing built-in extension XFree86-DRI
Initializing built-in extension DRI2
Loading extension GLX
(WW) fglrx: No matching Device section for instance (BusID PCI:0@2:0:1) found
Loading extension ATIFGLRXDRI
Loading extension FGLRXEXTENSION
Loading extension GLESX
Loading extension AMDXVOPL
Loading extension AMDXVBA
(EE) module ABI major version (19) doesn't match the server's version (18)
/usr/bin/startxfce4: X server already running on display :0
/usr/libexec/xfce4/panel-plugins/xfce4-xkb-plugin: error while loading shared libraries: libxcb-util.so.0: cannot open shared object file: No such file or directory
(process:5557): GLib-WARNING **: (gerror.c:390):g_error_new_valist: runtime check failed: (domain != 0)
(process:5557): xfce4-panel-wrapper-CRITICAL **: Wrapper mixer-2: Failed to open plugin module "/usr/lib/xfce4/panel/plugins/libmixer.so": libxcb-util.so.0: cannot open shared object file: No such file or directory.
xfce4-panel-Message: Plugin mixer-2 has been automatically restarted after crash.
xfce4-panel-Message: Plugin xkb-plugin-5 has been automatically restarted after crash.
** Message: applet now removed from the notification area
** Message: applet now embedded in the notification area
(process:5607): GLib-WARNING **: (gerror.c:390):g_error_new_valist: runtime check failed: (domain != 0)
(process:5607): xfce4-panel-wrapper-CRITICAL **: Wrapper mixer-2: Failed to open plugin module "/usr/lib/xfce4/panel/plugins/libmixer.so": libxcb-util.so.0: cannot open shared object file: No such file or directory.
(xfdesktop:5549): GLib-GIO-CRITICAL **: g_file_get_path: assertion `G_IS_FILE (file)' failed
Thunar :Failed to load plugin `thunar-uca.so': libxcb-util.so.0: cannot open shared object file: No such file or directory
xfce4-session: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
xfwm4: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.0.
xinit: connection to X server lost
waiting for X server to shut down xscreensaver: 12:52:56: SIGHUP received: restarting...
xscreensaver: 12:52:56: initial effective uid/gid was zeljko/shadow (1000/43)
xscreensaver: 12:52:56: running as zeljko/users (1000/100)
(xfsettingsd:5550): libxfce4ui-WARNING **: ICE I/O Error
(xfsettingsd:5550): libxfce4ui-WARNING **: Disconnected from session manager.
g_dbus_connection_real_closed: Remote peer vanished with error: Underlying GIOStream returned 0 bytes on an async read (g-io-error-quark, 0). Exiting.
(xfdesktop:5549): libxfce4ui-WARNING **: ICE I/O Error
(xfdesktop:5549): libxfce4ui-WARNING **: Disconnected from session manager.
xfsettingsd: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.0.
xfdesktop: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.0.
xscreensaver: 12:52:57: Can't open display: :0.0
xscreensaver: 12:52:57: initial effective uid/gid was zeljko/shadow (1000/43)
xscreensaver: 12:52:57: running as zeljko/users (1000/100)
xscreensaver: 12:52:57: Errors at startup are usually authorization problems.
But you're not logging in as root (good!) so something
else must be wrong. Did you read the manual and the FAQ?
http://www.jwz.org/xscreensaver/faq.html
http://www.jwz.org/xscreensaver/man.html
Server terminated successfully (0). Closing log file.
Mogu i to,bocke wrote:Uh, da. On koristi propriatry drajvere.zero wrote:Takođe, drajver za grafiku je bilo potrebno reinstalirati!
# aticonfig --initial
Reinstalaciju xfce ostavljam za sam kraj
Poznata ličnostoffline - Posts: 99
Da, istu grešku sam i ja dobio. Ne postoji više libxcb-util.so.0 već je to sada libxcb-util.so.1, tako da moraš sačekati da Pat izgradi ponovo XFCE pakete, ili da to sam uradiš.
Nije do drajvera. Tada bi pisalo nešto kao screen not found, ili slično.
Edit: Evo i kod drugih: http://www.linuxquestions.org/questions ... 175476836/" onclick="window.open(this.href);return false;
Ok, pokupio sam pakete sa ETF servera, zaista deluje da kasne malo. Nadogradiću libxcb i xcb-util sa ovim paketima pa ću se javiti uskoro.
Nadogradnja paketa sa ETF-a nije pomogla. Reinstalirao sam i drajver. Pratim link sa LQ da vidim dešavanje a i ja sam prijavio problem. Drugi korisnici su imali problema sa Mate na currentu a ja imam problema sa svim okruženjima
Menjaj taj ETF za nešto drugo. Sad sam uporedio ChangeLog-e za Current na Slackware-ovom sajtu i na ETF-u.
Primer razlike:
Primer razlike:
xfce4-session-4.10.1-i486-3.txz - Sep 9 - slackware.com
xfce4-session-4.10.0-i486-1.txz - 20-Jul-2012 - ETF
Ja sam neke xfce pakete već imao novije. Sad mi je već hitno jer imam posla. Da li da odradim reinstall xfce? Hoće li mi to rešiti problem i sa ostalim okruženjima? Možda samo deo xfce paketa?
Users browsing this forum: No registered users and 26 guests
