Moderators: Slackmuz, Urednik
Napisano: 29 Jun 2012, 15:16
Instalirao sam OpenBox i radi skoro sve. Problem mi nastaje kod ObConfa, jer izgleda da na Slackbuildsu ne postoji source...evo malo "dokumentacije":
Building obconf
obconf:
obconf not found in /var/cache/sbopkg.
--2012-06-29 15:16:21-- ftp://harrier.slackbuilds.org/misc/obconf-git_cc7a188076.tar.xz
=> "obconf-git_cc7a188076.tar.xz"
Resolving harrier.slackbuilds.org (harrier.slackbuilds.org)... 207.223.116.211
Connecting to harrier.slackbuilds.org (harrier.slackbuilds.org)|207.223.116.211|:21... failed: Connection refused.
obconf:
Would you like to continue processing the rest of the
build queue or would you like to abort? If this failed
package is a dependency of another package in the queue
then it may not make sense to continue.
(Y)es to continue, (N)o to abort, (R)etry the build?: Y
PACKAGE BUILDING/INSTALLATION SUMMARY LOG
Using the SBo repository for Slackware 13.37
Queue Process: Build and install
obconf:
Download failed.
Error occurred with build. Please check the log.
Queue process complete!
Što mi je činiti?
Napisano: 29 Jun 2012, 16:16
Trenutno je (iz ko zna kog razloga) nemoguće preuzeti source sa pomenute lokacije (harrier.slackbuilds.org). Rešenje da preuzmeš alien-ov slackbuild (i sve neophodne fajlove) sa sledeće lokacije:
http://connie.slackware.com/~alien/slac ... box/build/
Dakle, preuzmi sledeće fajlove (i smesti ih u jedan folder):
- obconf.SlackBuild
- obconf-2.0.3.tar.gz
- slack-desc.obconf
- slack-required.obconf
Nakon preuzimanja, uđi u folder u kome se nalaze, u terminalu se loguj kao root a zatim pokreni izvršavanje skripte komandom:
(ako ti se javi greška, skripta nije izvršna...to rešavaš komandom
chmod +x obconf.SlackBuild)
Ako kompajliranje prođe kako treba, gotov paket ćeš naći u /tmp folderu
Napisano: 29 Jun 2012, 17:05
hvala, sad ću probat, pa javim rezultate
kao, instalirao ga je, ali ne mogu ga pokrenit...bad command or file name
Napisano: 29 Jun 2012, 21:41
Ček malo, da li si instalirao paket koji se nalazi u /tmp folderu...komandom installpkg?
Dakle, nakon kompajliranja Sbo skripte (koje je objašnjeno u mojoj prethodnoj poruci) sledi instalacija paketa sledećom komandom:
# upgradepkg --install-new /tmp/ime_paketa.ekstenzija
(umesto ime_paketa.ekstenzija ide recimo obconf-2.0.3-i486-1alien.tgz)
Napisano: 29 Jun 2012, 21:45
instalirah ga sa:
# installpkg /tmp/obconf-blabla.tgz
i kad ga idem pokrenit, kaže mi
bash: obconf: command not found
removepkg-ao ga, pa opet sa upgradepkg kako si naveo u prošlom postu, opet ista stvar...
dakle, instalacija "prođe", ali ne mogu pokrenit taj program
Napisano: 29 Jun 2012, 22:09
Koristiš 32bit ili 64bit Slackware?
Napisano: 29 Jun 2012, 22:20
32
Napisano: 29 Jun 2012, 22:21
Ok...upravo testiram na svom sistemu pa ću javiti rezultat
Napisano: 29 Jun 2012, 22:22
super, hvala
Napisano: 29 Jun 2012, 22:27
Meni je instalacija prošla bez ikakvih problema i radi mi obconf. Koju verziju openbox-a koristiš? Daj izlaz komande:
# ls -l /var/log/packages | grep openbox
