Uklanjanje starih kernela
Zdravo, drugari. Juče sam kompajlirao najnoviju stabilnu verziju kernela, 3.2.9... Sve je prošlo u najboljem redu i sve radi savršeno. Muči me jedino kako da izbrišem stari kernel...?
Radio sam to na Debianu i Fedori, ali ovde ne mogu da se po'vatam
Trebao bi nam izlaz sledećih komandi:
i
kako bi ti što preciznije odgovorili...
$ ls -l /boot
$ cat /etc/lilo.conf
petar@petar:~$ ls -l /boot
total 22076
lrwxrwxrwx 1 root root 37 Feb 17 23:21 README.initrd -> /usr/doc/mkinitrd-1.4.6/README.initrd
lrwxrwxrwx 1 root root 22 Mar 7 01:05 System.map -> /boot/System.map-3.2.9
-rw-r--r-- 1 root root 3294976 Mar 7 01:02 System.map-3.2.9
-rw-r--r-- 1 root root 1782099 Apr 9 2011 System.map-generic-2.6.37.6
-rw-r--r-- 1 root root 2706772 Apr 10 2011 System.map-huge-2.6.37.6
lrwxrwxrwx 1 root root 24 Feb 17 23:29 System.old -> System.map-huge-2.6.37.6
-rw-r--r-- 1 root root 512 Feb 17 23:30 boot.0800
-rw-r--r-- 1 root root 209 Feb 17 23:30 boot_message.txt
lrwxrwxrwx 1 root root 18 Mar 7 01:06 config -> /boot/config-3.2.9
-rw-r--r-- 1 root root 116667 Mar 7 01:06 config-3.2.9
-rw-r--r-- 1 root root 112324 Apr 9 2011 config-generic-2.6.37.6
-rw-r--r-- 1 root root 112298 Apr 10 2011 config-huge-2.6.37.6
-rw-r--r-- 1 root root 5040 Mar 27 2011 diag1.img
-rw-r--r-- 1 root root 17932 Mar 27 2011 diag2.img
-rw------- 1 root root 88576 Mar 7 01:03 map
lrwxrwxrwx 1 root root 19 Mar 7 01:05 vmlinuz -> /boot/vmlinuz-3.2.9
-rw-r--r-- 1 root root 5495168 Mar 7 01:02 vmlinuz-3.2.9
-rw-r--r-- 1 root root 2956592 Apr 9 2011 vmlinuz-generic-2.6.37.6
-rw-r--r-- 1 root root 5866144 Apr 10 2011 vmlinuz-huge-2.6.37.6
lrwxrwxrwx 1 root root 21 Feb 17 23:29 vmlinuz.old -> vmlinuz-huge-2.6.37.6
petar@petar:~$ cat /etc/lilo.conf
# LILO configuration file
# generated by 'liloconfig'
# Start LILO global section
append=" vt.default_utf8=0"
boot = /dev/sda
# Boot BMP Image.
bitmap = /boot/slack.bmp
bmp-table = 60,6,1,16
bmp-timer = 65,27,0,255
# Standard menu.
# first entry immediately):
prompt
timeout = 1200
change-rules
reset
# Normal VGA console
vga = normal
#vga = ask
#vga=791
#vga=790
#vga=773
#vga=788
#vga=787
#vga=771
#vga=785
#vga=784
#vga=769
# End LILO global section
# Windows bootable partition config begins
other = /dev/sda1
label = Windows
table = /dev/sda
# Windows bootable partition config ends
image = /boot/vmlinuz
root = /dev/sda9
label = Slackware
read-only
UPDATE:
U Debian-u sam to postizao purge komandom (brisao linux-image), u Fedora-i pomoću package-cleanup --oldkernels...
Dobro si ovo napomenuoSamo da napomenem, koristim GRUB2 koji je vezan za drugu Linux distribuciju, a ne Lilo...
Koliko slack kernela imaš u meniju Grub2 bootloader-a?
U principu, sve se svodi na brisanje onih kernela i odgovarajućih pratećih fajlova (config i System.map) koje više ne želiš koristiti iz /boot foldera a potom update i/ili reinstalacija GRUB2 u toj drugoj distribuciji.
Imam 2.6.37.6, ovaj novi 3.2.9 i vmlinuz-huge 2.6.37.6...
Znači na taj način se uklanja sve? Palo je meni to na pamet ali sam mislio da postoji neki način potpunog uklanjanja starih kernela.
Je l' nakon toga ne ostaje ništa od starih kernela u sistemu? Da li da brišem i linux-2.6.37.6 iz /usr/src fascikle? To sam na ovim pomenutim distroima uklanjao takođe...
Možeš i to da obrišeš ukoliko ne koristiš. Vodi samo računa da ne obrišeš simbolički link /usr/src/linux jer on vodi ka novom kernelu. Možeš li da proveriš gde vodi ovaj simbolički link pa da kreiramo novi ako treba?
Ček malo, najjednostavnije rešenje bi bilo da se deinstaliraju samo paketi koji imaju veze sa starim kernelom...To bi trebalo da su ovi paketi:
Brisanjem ovih paketa obrisaćeš sve fajlove koji su za njih vezani (i module i source). Ovo je najjednostavniji način. Nakon ovoga pređi u drugi distro i update-uj GRUB2.
kernel-firmware-2.6.37.6-noarch-2
kernel-generic-2.6.37.6-x86_64-2
kernel-headers-2.6.37.6-x86-2
kernel-huge-2.6.37.6-x86_64-2
kernel-modules-2.6.37.6-x86_64-2
kernel-source-2.6.37.6-noarch-2
E, to...
Znam za symlink, kreirao sam ga tokom kompajliranja novog kernela... Kasnije ću da budem u Slackware-u i odradiću posao
Hvala i poZz
Hvala i poZz
Odlicno, hvala Drummer, ovo ce i meni trebati premda i ja imam grub a ne lilo.
@Drummer, kad sam obrisao sve ono, to je povuklo i linux (symlink) u /usr/src. Neće da uđe u X, ja sam ponovo kreirao link ali neće i dalje.
[ 35.763]
X.Org X Server 1.9.5
Release Date: 2011-03-17
[ 35.768] X Protocol Version 11, Revision 0
[ 35.769] Build Operating System: Slackware 13.37 Slackware Linux Project
[ 35.771] Current Operating System: Linux petar 3.2.9 #1 SMP Wed Mar 7 00:51:37 CET 2012 x86_64
[ 35.773] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.9 root=/dev/sda9
[ 35.774] Build Date: 17 March 2011 10:50:17PM
[ 35.776]
[ 35.778] Current version of pixman: 0.20.2
[ 35.779] Before reporting problems, check http://wiki.x.org
[ 35.783] Markers: (--) probed, (**) from config file, (==) default setting,
[ 35.788] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Mar 7 22:28:07 2012
[ 35.826] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 35.834] (==) No Layout section. Using the first Screen section.
[ 35.834] (==) No screen section available. Using defaults.
[ 35.834] (**) |-->Screen "Default Screen Section" (0)
[ 35.834] (**) | |-->Monitor "<default monitor>"
[ 35.834] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 35.834] (==) Automatically adding devices
[ 35.834] (==) Automatically enabling devices
[ 35.835] (WW) The directory "/usr/share/fonts/local" does not exist.
[ 35.835] Entry deleted from font path.
[ 35.835] (WW) The directory "/usr/share/fonts/CID" does not exist.
[ 35.856] (==) FontPath set to:
/usr/share/fonts/TTF,
/usr/share/fonts/OTF,
/usr/share/fonts/Type1,
/usr/share/fonts/misc,
/usr/share/fonts/100dpi/:unscaled,
/usr/share/fonts/75dpi,
/usr/share/fonts/100dpi,
/usr/share/fonts/cyrillic
[ 35.856] (==) ModulePath set to "/usr/lib64/xorg/modules"
[ 35.856] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 35.856] (II) Loader magic: 0x7d2500
[ 35.856] (II) Module ABI versions:
[ 35.856] X.Org ANSI C Emulation: 0.4
[ 35.856] X.Org Video Driver: 8.0
[ 35.856] X.Org XInput driver : 11.0
[ 35.856] X.Org Server Extension : 4.0
[ 35.856] (--) PCI:*(0:2:0:0) 1002:9498:1787:2269 rev 0, Mem @ 0xc0000000/268435456, 0xdfff0000/65536, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[ 35.856] (II) Open ACPI successful (/var/run/acpid.socket)
[ 35.856] (II) LoadModule: "extmod"
[ 35.857] (II) Loading /usr/lib64/xorg/modules/extensions/libextmod.so
[ 35.866] (II) Module extmod: vendor="X.Org Foundation"
[ 35.866] compiled for 1.9.5, module version = 1.0.0
[ 35.866] Module class: X.Org Server Extension
[ 35.866] ABI class: X.Org Server Extension, version 4.0
[ 35.866] (II) Loading extension MIT-SCREEN-SAVER
[ 35.866] (II) Loading extension XFree86-VidModeExtension
[ 35.866] (II) Loading extension XFree86-DGA
[ 35.866] (II) Loading extension DPMS
[ 35.866] (II) Loading extension XVideo
[ 35.866] (II) Loading extension XVideo-MotionCompensation
[ 35.866] (II) Loading extension X-Resource
[ 35.866] (II) LoadModule: "dbe"
[ 35.866] (II) Loading /usr/lib64/xorg/modules/extensions/libdbe.so
[ 35.867] (II) Module dbe: vendor="X.Org Foundation"
[ 35.867] compiled for 1.9.5, module version = 1.0.0
[ 35.867] Module class: X.Org Server Extension
[ 35.867] ABI class: X.Org Server Extension, version 4.0
[ 35.867] (II) Loading extension DOUBLE-BUFFER
[ 35.867] (II) LoadModule: "glx"
[ 35.868] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 35.882] (II) Module glx: vendor="X.Org Foundation"
[ 35.882] compiled for 1.9.5, module version = 1.0.0
[ 35.882] ABI class: X.Org Server Extension, version 4.0
[ 35.882] (==) AIGLX enabled
[ 35.882] (II) Loading extension GLX
[ 35.883] (II) LoadModule: "record"
[ 35.883] (II) Loading /usr/lib64/xorg/modules/extensions/librecord.so
[ 35.883] (II) Module record: vendor="X.Org Foundation"
[ 35.883] compiled for 1.9.5, module version = 1.13.0
[ 35.883] Module class: X.Org Server Extension
[ 35.883] ABI class: X.Org Server Extension, version 4.0
[ 35.883] (II) Loading extension RECORD
[ 35.883] (II) LoadModule: "dri"
[ 35.883] (II) Loading /usr/lib64/xorg/modules/extensions/libdri.so
[ 35.884] (II) Module dri: vendor="X.Org Foundation"
[ 35.884] compiled for 1.9.5, module version = 1.0.0
[ 35.884] ABI class: X.Org Server Extension, version 4.0
[ 35.884] (II) Loading extension XFree86-DRI
[ 35.884] (II) LoadModule: "dri2"
[ 35.884] (II) Loading /usr/lib64/xorg/modules/extensions/libdri2.so
[ 35.886] (II) Module dri2: vendor="X.Org Foundation"
[ 35.886] compiled for 1.9.5, module version = 1.2.0
[ 35.886] ABI class: X.Org Server Extension, version 4.0
[ 35.886] (II) Loading extension DRI2
[ 35.886] (==) Matched ati as autoconfigured driver 0
[ 35.886] (==) Matched vesa as autoconfigured driver 1
[ 35.886] (==) Matched fbdev as autoconfigured driver 2
[ 35.886] (==) Assigned the driver to the xf86ConfigLayout
[ 35.886] (II) LoadModule: "ati"
[ 35.887] (II) Loading /usr/lib64/xorg/modules/drivers/ati_drv.so
[ 35.899] (II) Module ati: vendor="X.Org Foundation"
[ 35.899] compiled for 1.9.5, module version = 6.14.1
[ 35.899] Module class: X.Org Video Driver
[ 35.899] ABI class: X.Org Video Driver, version 8.0
[ 35.899] (II) LoadModule: "radeon"
[ 35.899] (II) Loading /usr/lib64/xorg/modules/drivers/radeon_drv.so
[ 35.938] (II) Module radeon: vendor="X.Org Foundation"
[ 35.938] compiled for 1.9.5, module version = 6.14.1
[ 35.938] Module class: X.Org Video Driver
[ 35.938] ABI class: X.Org Video Driver, version 8.0
[ 35.938] (II) LoadModule: "vesa"
[ 35.939] (II) Loading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[ 35.944] (II) Module vesa: vendor="X.Org Foundation"
[ 35.944] compiled for 1.9.2, module version = 2.3.0
[ 35.944] Module class: X.Org Video Driver
[ 35.944] ABI class: X.Org Video Driver, version 8.0
[ 35.944] (II) LoadModule: "fbdev"
[ 35.945] (WW) Warning, couldn't open module fbdev
[ 35.945] (II) UnloadModule: "fbdev"
[ 35.945] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 35.946] (II) RADEON: Driver for ATI Radeon chipsets:
ATI Radeon Mobility X600 (M24) 3150 (PCIE), ATI FireMV 2400 (PCI),
ATI Radeon Mobility X300 (M24) 3152 (PCIE),
ATI FireGL M24 GL 3154 (PCIE), ATI FireMV 2400 3155 (PCI),
ATI Radeon X600 (RV380) 3E50 (PCIE),
ATI FireGL V3200 (RV380) 3E54 (PCIE), ATI Radeon IGP320 (A3) 4136,
ATI Radeon IGP330/340/350 (A4) 4137, ATI Radeon 9500 AD (AGP),
ATI Radeon 9500 AE (AGP), ATI Radeon 9600TX AF (AGP),
ATI FireGL Z1 AG (AGP), ATI Radeon 9800SE AH (AGP),
ATI Radeon 9800 AI (AGP), ATI Radeon 9800 AJ (AGP),
ATI FireGL X2 AK (AGP), ATI Radeon 9600 AP (AGP),
ATI Radeon 9600SE AQ (AGP), ATI Radeon 9600XT AR (AGP),
ATI Radeon 9600 AS (AGP), ATI FireGL T2 AT (AGP), ATI Radeon 9650,
ATI FireGL RV360 AV (AGP), ATI Radeon 7000 IGP (A4+) 4237,
ATI Radeon 8500 AIW BB (AGP), ATI Radeon IGP320M (U1) 4336,
ATI Radeon IGP330M/340M/350M (U2) 4337,
ATI Radeon Mobility 7000 IGP 4437, ATI Radeon 9000/PRO If (AGP/PCI),
ATI Radeon 9000 Ig (AGP/PCI), ATI Radeon X800 (R420) JH (AGP),
ATI Radeon X800PRO (R420) JI (AGP),
ATI Radeon X800SE (R420) JJ (AGP), ATI Radeon X800 (R420) JK (AGP),
ATI Radeon X800 (R420) JL (AGP), ATI FireGL X3 (R420) JM (AGP),
ATI Radeon Mobility 9800 (M18) JN (AGP),
ATI Radeon X800 SE (R420) (AGP), ATI Radeon X800XT (R420) JP (AGP),
ATI Radeon X800 VE (R420) JT (AGP), ATI Radeon X850 (R480) (AGP),
ATI Radeon X850 XT (R480) (AGP), ATI Radeon X850 SE (R480) (AGP),
ATI Radeon X850 PRO (R480) (AGP), ATI Radeon X850 XT PE (R480) (AGP),
ATI Radeon Mobility M7 LW (AGP),
ATI Mobility FireGL 7800 M7 LX (AGP),
ATI Radeon Mobility M6 LY (AGP), ATI Radeon Mobility M6 LZ (AGP),
ATI FireGL Mobility 9000 (M9) Ld (AGP),
ATI Radeon Mobility 9000 (M9) Lf (AGP),
ATI Radeon Mobility 9000 (M9) Lg (AGP), ATI Radeon 9700 Pro ND (AGP),
ATI Radeon 9700/9500Pro NE (AGP), ATI Radeon 9600TX NF (AGP),
ATI FireGL X1 NG (AGP), ATI Radeon 9800PRO NH (AGP),
ATI Radeon 9800 NI (AGP), ATI FireGL X2 NK (AGP),
ATI Radeon 9800XT NJ (AGP),
ATI Radeon Mobility 9600/9700 (M10/M11) NP (AGP),
ATI Radeon Mobility 9600 (M10) NQ (AGP),
ATI Radeon Mobility 9600 (M11) NR (AGP),
ATI Radeon Mobility 9600 (M10) NS (AGP),
ATI FireGL Mobility T2 (M10) NT (AGP),
ATI FireGL Mobility T2e (M11) NV (AGP), ATI Radeon QD (AGP),
ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
ATI FireGL 8700/8800 QH (AGP), ATI Radeon 8500 QL (AGP),
ATI Radeon 9100 QM (AGP), ATI Radeon 7500 QW (AGP/PCI),
ATI Radeon 7500 QX (AGP/PCI), ATI Radeon VE/7000 QY (AGP/PCI),
ATI Radeon VE/7000 QZ (AGP/PCI), ATI ES1000 515E (PCI),
ATI Radeon Mobility X300 (M22) 5460 (PCIE),
ATI Radeon Mobility X600 SE (M24C) 5462 (PCIE),
ATI FireGL M22 GL 5464 (PCIE), ATI Radeon X800 (R423) UH (PCIE),
ATI Radeon X800PRO (R423) UI (PCIE),
ATI Radeon X800LE (R423) UJ (PCIE),
ATI Radeon X800SE (R423) UK (PCIE),
ATI Radeon X800 XTP (R430) (PCIE), ATI Radeon X800 XL (R430) (PCIE),
ATI Radeon X800 SE (R430) (PCIE), ATI Radeon X800 (R430) (PCIE),
ATI FireGL V7100 (R423) (PCIE), ATI FireGL V5100 (R423) UQ (PCIE),
ATI FireGL unknown (R423) UR (PCIE),
ATI FireGL unknown (R423) UT (PCIE),
ATI Mobility FireGL V5000 (M26) (PCIE),
ATI Mobility Radeon X700 XL (M26) (PCIE),
ATI Mobility Radeon X700 (M26) (PCIE),
ATI Radeon X550XTX 5657 (PCIE), ATI Radeon 9100 IGP (A5) 5834,
ATI Radeon Mobility 9100 IGP (U3) 5835,
ATI Radeon XPRESS 200 5954 (PCIE),
ATI Radeon XPRESS 200M 5955 (PCIE), ATI Radeon 9250 5960 (AGP),
ATI Radeon 9200 5961 (AGP), ATI Radeon 9200 5962 (AGP),
ATI Radeon 9200SE 5964 (AGP), ATI FireMV 2200 (PCI),
ATI ES1000 5969 (PCI), ATI Radeon XPRESS 200 5974 (PCIE),
ATI Radeon XPRESS 200M 5975 (PCIE),
ATI Radeon XPRESS 200 5A41 (PCIE),
ATI Radeon XPRESS 200M 5A42 (PCIE),
ATI Radeon XPRESS 200 5A61 (PCIE),
ATI Radeon XPRESS 200M 5A62 (PCIE),
ATI Radeon X300 (RV370) 5B60 (PCIE),
ATI Radeon X600 (RV370) 5B62 (PCIE),
ATI Radeon X550 (RV370) 5B63 (PCIE),
ATI FireGL V3100 (RV370) 5B64 (PCIE),
ATI FireMV 2200 PCIE (RV370) 5B65 (PCIE),
ATI Radeon Mobility 9200 (M9+) 5C61 (AGP),
ATI Radeon Mobility 9200 (M9+) 5C63 (AGP),
ATI Mobility Radeon X800 XT (M28) (PCIE),
ATI Mobility FireGL V5100 (M28) (PCIE),
ATI Mobility Radeon X800 (M28) (PCIE), ATI Radeon X850 5D4C (PCIE),
ATI Radeon X850 XT PE (R480) (PCIE),
ATI Radeon X850 SE (R480) (PCIE), ATI Radeon X850 PRO (R480) (PCIE),
ATI unknown Radeon / FireGL (R480) 5D50 (PCIE),
ATI Radeon X850 XT (R480) (PCIE),
ATI Radeon X800XT (R423) 5D57 (PCIE),
ATI FireGL V5000 (RV410) (PCIE), ATI Radeon X700 XT (RV410) (PCIE),
ATI Radeon X700 PRO (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X700 (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X1800,
ATI Mobility Radeon X1800 XT, ATI Mobility Radeon X1800,
ATI Mobility FireGL V7200, ATI FireGL V7200, ATI FireGL V5300,
ATI Mobility FireGL V7100, ATI Radeon X1800, ATI Radeon X1800,
ATI Radeon X1800, ATI Radeon X1800, ATI Radeon X1800,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1300/X1550,
ATI Radeon X1550 64-bit, ATI Mobility Radeon X1300,
ATI Mobility Radeon X1300, ATI Mobility Radeon X1300,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI Radeon X1300,
ATI RV505, ATI RV505, ATI FireGL V3300, ATI FireGL V3350,
ATI Radeon X1300, ATI Radeon X1550 64-bit, ATI Radeon X1300/X1550,
ATI Radeon X1600, ATI Radeon X1300/X1550, ATI Mobility Radeon X1450,
ATI Radeon X1300/X1550, ATI Mobility Radeon X2300,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI Mobility Radeon X1350, ATI Mobility Radeon X1450,
ATI Radeon X1300, ATI Radeon X1550, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1550 64-bit, ATI Radeon X1600,
ATI Radeon X1650, ATI Radeon X1600, ATI Radeon X1600,
ATI Mobility FireGL V5200, ATI Mobility Radeon X1600,
ATI Radeon X1650, ATI Radeon X1650, ATI Radeon X1600,
ATI Radeon X1300 XT/X1600 Pro, ATI FireGL V3400,
ATI Mobility FireGL V5250, ATI Mobility Radeon X1700,
ATI Mobility Radeon X1700 XT, ATI FireGL V5200,
ATI Mobility Radeon X1700, ATI Radeon X2300HD,
ATI Mobility Radeon HD 2300, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI Radeon X1950,
ATI Radeon X1900, ATI Radeon X1900, ATI Radeon X1900,
ATI AMD Stream Processor, ATI Radeon X1900, ATI Radeon X1950,
ATI RV560, ATI RV560, ATI Mobility Radeon X1900, ATI RV560,
ATI Radeon X1950 GT, ATI RV570, ATI RV570, ATI FireGL V7400,
ATI RV560, ATI Radeon X1650, ATI Radeon X1650, ATI RV560,
ATI Radeon 9100 PRO IGP 7834, ATI Radeon Mobility 9200 IGP 7835,
ATI Radeon X1200, ATI Radeon X1200, ATI Radeon X1200,
ATI Radeon X1200, ATI Radeon X1200, ATI RS740, ATI RS740M, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 XT,
ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro, ATI Radeon HD 2900 GT,
ATI FireGL V8650, ATI FireGL V8600, ATI FireGL V7600,
ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon 4800 Series, ATI Radeon HD 4850 x2,
ATI FirePro V8750 (FireGL), ATI FirePro V7760 (FireGL),
ATI Mobility RADEON HD 4850, ATI Mobility RADEON HD 4850 X2,
ATI Radeon 4800 Series, ATI FirePro RV770, AMD FireStream 9270,
AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI Mobility RADEON HD 4870, ATI Radeon 4800 Series,
ATI Radeon 4800 Series, ATI FirePro M7750, ATI M98, ATI M98, ATI M98,
ATI Mobility Radeon HD 4650, ATI Radeon RV730 (AGP),
ATI Mobility Radeon HD 4670, ATI FirePro M5750,
ATI Mobility Radeon HD 4670, ATI Radeon RV730 (AGP),
ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI Radeon HD 4770,
ATI FirePro M5750, ATI RV610, ATI Radeon HD 2400 XT,
ATI Radeon HD 2400 Pro, ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000,
ATI RV610, ATI Radeon HD 2350, ATI Mobility Radeon HD 2400 XT,
ATI Mobility Radeon HD 2400, ATI RADEON E2400, ATI RV610,
ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI RV670,
ATI Mobility Radeon HD 3870, ATI Mobility Radeon HD 3870 X2,
ATI Radeon HD3870 X2, ATI FireGL V7700, ATI Radeon HD3850,
ATI Radeon HD3690, AMD Firestream 9170, ATI Radeon HD 4550,
ATI Radeon RV710, ATI Radeon RV710, ATI Radeon RV710,
ATI Radeon HD 4350, ATI Mobility Radeon 4300 Series,
ATI Mobility Radeon 4500 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3450, ATI Radeon HD 3430,
ATI Radeon HD 3450, ATI FirePro V3700, ATI FireMV 2450,
ATI FireMV 2260, ATI FireMV 2260, ATI Radeon HD 3600 Series,
ATI Radeon HD 3650 AGP, ATI Radeon HD 3600 PRO,
ATI Radeon HD 3600 XT, ATI Radeon HD 3600 PRO,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon HD 3200 Graphics,
ATI Radeon 3000 Graphics, ATI Radeon HD 4200, ATI Radeon 4100,
ATI Mobility Radeon HD 4200, ATI Mobility Radeon 4100,
ATI Radeon HD 4290, ATI Radeon HD 4250, AMD Radeon HD 6310 Graphics,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6250 Graphics, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5800 Series, ATI Radeon HD 5800 Series,
ATI Radeon HD 5900 Series, ATI Radeon HD 5900 Series,
ATI Mobility Radeon HD 5800 Series,
ATI Mobility Radeon HD 5800 Series, ATI Radeon HD 5700 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 5700 Series,
ATI Mobility Radeon HD 5000 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI FirePro (FireGL) Graphics Adapter, ATI Radeon HD 5670,
ATI Radeon HD 5570, ATI Radeon HD 5500 Series, REDWOOD,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon Graphics,
ATI Mobility Radeon Graphics, CEDAR,
ATI FirePro (FireGL) Graphics Adapter, ATI FirePro 2270, CEDAR,
ATI Radeon HD 5450, CEDAR, CAYMAN, CAYMAN, CAYMAN, CAYMAN, CAYMAN,
CAYMAN, CAYMAN, CAYMAN, CAYMAN, CAYMAN, AMD Radeon HD 6900 Series,
AMD Radeon HD 6900 Series, CAYMAN, CAYMAN,
AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
BARTS, Mobility Radeon HD 6000 Series,
Mobility Radeon HD 6000 Series, BARTS, BARTS, BARTS, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6800 Series, TURKS, TURKS,
TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS,
TURKS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS,
[ 35.949] (II) VESA: driver for VESA chipsets: vesa
[ 35.949] (--) using VT number 7
[ 35.956] (II) [KMS] Kernel modesetting enabled.
[ 35.956] (WW) Falling back to old probe method for vesa
[ 35.957] (II) RADEON(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 35.957] (==) RADEON(0): Depth 24, (--) framebuffer bpp 32
[ 35.957] (II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 35.957] (==) RADEON(0): Default visual is TrueColor
[ 35.957] (==) RADEON(0): RGB weight 888
[ 35.957] (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
[ 35.957] (--) RADEON(0): Chipset: "ATI RV730 PRO [Radeon HD 4650]" (ChipID = 0x9498)
[ 35.957] (II) RADEON(0): PCIE card detected
[ 35.957] drmOpenDevice: node name is /dev/dri/card0
[ 35.957] drmOpenDevice: open result is 11, (OK)
[ 35.957] drmOpenByBusid: Searching for BusID pci:0000:02:00.0
[ 35.957] drmOpenByBusid: drmOpenMinor returns 11
[ 35.957] drmOpenByBusid: drmGetBusid reports pci:0000:02:00.0
[ 35.957] (II) RADEON(0): GPU accel disabled or not working, using shadowfb for KMS
[ 35.957] (II) Loading sub module "shadow"
[ 35.957] (II) LoadModule: "shadow"
[ 35.957] (II) Loading /usr/lib64/xorg/modules/libshadow.so
[ 35.962] (II) Module shadow: vendor="X.Org Foundation"
[ 35.962] compiled for 1.9.5, module version = 1.1.0
[ 35.962] ABI class: X.Org ANSI C Emulation, version 0.4
[ 35.962] (II) RADEON(0): KMS Color Tiling: disabled
[ 35.962] (II) RADEON(0): KMS Pageflipping: enabled
[ 35.962] (II) RADEON(0): SwapBuffers wait for vsync: enabled
[ 36.090] (II) RADEON(0): Output HDMI-0 has no monitor section
[ 36.148] (II) RADEON(0): Output VGA-0 has no monitor section
[ 36.164] (II) RADEON(0): Output DVI-0 has no monitor section
[ 36.280] (II) RADEON(0): EDID for output HDMI-0
[ 36.339] (II) RADEON(0): EDID for output VGA-0
[ 36.339] (II) RADEON(0): Manufacturer: SAM Model: 635 Serial#: 16843009
[ 36.339] (II) RADEON(0): Year: 2009 Week: 4
[ 36.339] (II) RADEON(0): EDID Version: 1.3
[ 36.339] (II) RADEON(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
[ 36.339] (II) RADEON(0): Sync: Separate Composite SyncOnGreen
[ 36.339] (II) RADEON(0): Max Image Size [cm]: horiz.: 48 vert.: 27
[ 36.339] (II) RADEON(0): Gamma: 2.20
[ 36.339] (II) RADEON(0): DPMS capabilities: Off; RGB/Color Display
[ 36.339] (II) RADEON(0): First detailed timing is preferred mode
[ 36.339] (II) RADEON(0): redX: 0.648 redY: 0.339 greenX: 0.282 greenY: 0.603
[ 36.339] (II) RADEON(0): blueX: 0.143 blueY: 0.070 whiteX: 0.312 whiteY: 0.329
[ 36.339] (II) RADEON(0): Supported established timings:
[ 36.339] (II) RADEON(0): 720x400@70Hz
[ 36.339] (II) RADEON(0): 640x480@60Hz
[ 36.339] (II) RADEON(0): 640x480@67Hz
[ 36.339] (II) RADEON(0): 640x480@72Hz
[ 36.339] (II) RADEON(0): 640x480@75Hz
[ 36.339] (II) RADEON(0): 800x600@56Hz
[ 36.339] (II) RADEON(0): 800x600@60Hz
[ 36.339] (II) RADEON(0): 800x600@72Hz
[ 36.339] (II) RADEON(0): 800x600@75Hz
[ 36.339] (II) RADEON(0): 832x624@75Hz
[ 36.339] (II) RADEON(0): 1024x768@60Hz
[ 36.339] (II) RADEON(0): 1024x768@70Hz
[ 36.339] (II) RADEON(0): 1024x768@75Hz
[ 36.339] (II) RADEON(0): 1280x1024@75Hz
[ 36.339] (II) RADEON(0): 1152x864@75Hz
[ 36.339] (II) RADEON(0): Manufacturer's mask: 0
[ 36.339] (II) RADEON(0): Supported standard timings:
[ 36.339] (II) RADEON(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 36.339] (II) RADEON(0): #1: hsize: 1280 vsize 800 refresh: 60 vid: 129
[ 36.339] (II) RADEON(0): #2: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 36.339] (II) RADEON(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 36.339] (II) RADEON(0): #4: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 36.339] (II) RADEON(0): #5: hsize: 1440 vsize 900 refresh: 75 vid: 3989
[ 36.339] (II) RADEON(0): #6: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
[ 36.339] (II) RADEON(0): #7: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 36.339] (II) RADEON(0): Supported detailed timing:
[ 36.339] (II) RADEON(0): clock: 148.5 MHz Image Size: 477 x 268 mm
[ 36.339] (II) RADEON(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 36.339] (II) RADEON(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 36.339] (II) RADEON(0): Ranges: V min: 56 V max: 75 Hz, H min: 31 H max: 80 kHz, PixClock max 175 MHz
[ 36.339] (II) RADEON(0): Monitor name: SMB2230N
[ 36.339] (II) RADEON(0): Serial No: H9CB115100
[ 36.339] (II) RADEON(0): EDID (in hex):
[ 36.339] (II) RADEON(0): 00ffffffffffff004c2d350601010101
[ 36.339] (II) RADEON(0): 041301030e301b782a3581a656489a24
[ 36.339] (II) RADEON(0): 125054bfef80714f8100814081809500
[ 36.339] (II) RADEON(0): 950fa940b300023a801871382d40582c
[ 36.339] (II) RADEON(0): 4500dd0c1100001e000000fd00384b1f
[ 36.339] (II) RADEON(0): 5011000a202020202020000000fc0053
[ 36.339] (II) RADEON(0): 4d42323233304e0a20202020000000ff
[ 36.339] (II) RADEON(0): 00483943423131353130300a2020003b
[ 36.339] (II) RADEON(0): Printing probed modes for output VGA-0
[ 36.339] (II) RADEON(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz)
[ 36.339] (II) RADEON(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz)
[ 36.339] (II) RADEON(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz)
[ 36.339] (II) RADEON(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 36.339] (II) RADEON(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 36.339] (II) RADEON(0): Modeline "1440x900"x75.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz)
[ 36.339] (II) RADEON(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz)
[ 36.339] (II) RADEON(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz)
[ 36.339] (II) RADEON(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 +hsync -vsync (49.7 kHz)
[ 36.339] (II) RADEON(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
[ 36.339] (II) RADEON(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz)
[ 36.339] (II) RADEON(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 36.339] (II) RADEON(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 36.339] (II) RADEON(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 36.339] (II) RADEON(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 36.339] (II) RADEON(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 36.339] (II) RADEON(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 36.339] (II) RADEON(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 36.339] (II) RADEON(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz)
[ 36.339] (II) RADEON(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 36.339] (II) RADEON(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 36.339] (II) RADEON(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 36.339] (II) RADEON(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 36.355] (II) RADEON(0): EDID for output DVI-0
[ 36.355] (II) RADEON(0): Output HDMI-0 disconnected
[ 36.355] (II) RADEON(0): Output VGA-0 connected
[ 36.355] (II) RADEON(0): Output DVI-0 disconnected
[ 36.355] (II) RADEON(0): Using exact sizes for initial modes
[ 36.355] (II) RADEON(0): Output VGA-0 using initial mode 1920x1080
[ 36.355] (II) RADEON(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 36.355] (II) RADEON(0): mem size init: gart size :1fdff000 vram size: s:40000000 visible:f7d7000
[ 36.355] (II) RADEON(0): EXA: Driver will allow EXA pixmaps in VRAM
[ 36.355] (==) RADEON(0): DPI set to (96, 96)
[ 36.355] (II) Loading sub module "fb"
[ 36.355] (II) LoadModule: "fb"
[ 36.355] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 36.369] (II) Module fb: vendor="X.Org Foundation"
[ 36.369] compiled for 1.9.5, module version = 1.0.0
[ 36.369] ABI class: X.Org ANSI C Emulation, version 0.4
[ 36.369] (II) Loading sub module "ramdac"
[ 36.369] (II) LoadModule: "ramdac"
[ 36.369] (II) Module "ramdac" already built-in
[ 36.369] (II) UnloadModule: "vesa"
[ 36.369] (II) Unloading /usr/lib64/xorg/modules/drivers/vesa_drv.so
[ 36.369] (--) Depth 24 pixmap format is 32 bpp
[ 36.369] (II) RADEON(0): Front buffer size: 8640K
[ 36.369] (II) RADEON(0): VRAM usage limit set to 220633K
[ 36.377] (==) RADEON(0): Backing store disabled
[ 36.378] (WW) RADEON(0): Direct rendering disabled
[ 36.378] (II) RADEON(0): Acceleration disabled
[ 36.378] (==) RADEON(0): DPMS enabled
[ 36.378] (==) RADEON(0): Silken mouse enabled
[ 36.378] (II) RADEON(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 36.378] (--) RandR disabled
[ 36.378] (II) Initializing built-in extension Generic Event Extension
[ 36.378] (II) Initializing built-in extension SHAPE
[ 36.378] (II) Initializing built-in extension MIT-SHM
[ 36.378] (II) Initializing built-in extension XInputExtension
[ 36.378] (II) Initializing built-in extension XTEST
[ 36.378] (II) Initializing built-in extension BIG-REQUESTS
[ 36.378] (II) Initializing built-in extension SYNC
[ 36.378] (II) Initializing built-in extension XKEYBOARD
[ 36.378] (II) Initializing built-in extension XC-MISC
[ 36.378] (II) Initializing built-in extension XINERAMA
[ 36.378] (II) Initializing built-in extension XFIXES
[ 36.378] (II) Initializing built-in extension RENDER
[ 36.378] (II) Initializing built-in extension RANDR
[ 36.378] (II) Initializing built-in extension COMPOSITE
[ 36.378] (II) Initializing built-in extension DAMAGE
[ 36.384] (II) AIGLX: Screen 0 is not DRI2 capable
[ 36.384] (II) AIGLX: Screen 0 is not DRI capable
[ 36.439] (II) AIGLX: Loaded and initialized /usr/lib64/xorg/modules/dri/swrast_dri.so
[ 36.439] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 36.440] (II) RADEON(0): Setting screen physical size to 508 x 285
[ 36.809] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 36.809] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 36.809] (**) Power Button: Applying InputClass "keyboard-all"
[ 36.809] (II) LoadModule: "evdev"
[ 36.810] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[ 36.821] (II) Module evdev: vendor="X.Org Foundation"
[ 36.821] compiled for 1.9.3, module version = 2.6.0
[ 36.821] Module class: X.Org XInput Driver
[ 36.821] ABI class: X.Org XInput driver, version 11.0
[ 36.821] (**) Power Button: always reports core events
[ 36.821] (**) Power Button: Device: "/dev/input/event2"
[ 36.821] (--) Power Button: Found keys
[ 36.821] (II) Power Button: Configuring as keyboard
[ 36.821] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[ 36.821] (**) Option "xkb_rules" "evdev"
[ 36.821] (**) Option "xkb_model" "evdev"
[ 36.821] (**) Option "xkb_layout" "us"
[ 36.821] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 36.849] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 36.849] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 36.849] (**) Power Button: Applying InputClass "keyboard-all"
[ 36.849] (**) Power Button: always reports core events
[ 36.849] (**) Power Button: Device: "/dev/input/event1"
[ 36.849] (--) Power Button: Found keys
[ 36.849] (II) Power Button: Configuring as keyboard
[ 36.849] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
[ 36.849] (**) Option "xkb_rules" "evdev"
[ 36.849] (**) Option "xkb_model" "evdev"
[ 36.849] (**) Option "xkb_layout" "us"
[ 36.849] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 36.851] (II) config/udev: Adding input device USB Speaker (/dev/input/event3)
[ 36.851] (**) USB Speaker: Applying InputClass "evdev keyboard catchall"
[ 36.851] (**) USB Speaker: Applying InputClass "keyboard-all"
[ 36.851] (**) USB Speaker: always reports core events
[ 36.851] (**) USB Speaker: Device: "/dev/input/event3"
[ 36.851] (--) USB Speaker: Found keys
[ 36.851] (II) USB Speaker: Configuring as keyboard
[ 36.851] (II) XINPUT: Adding extended input device "USB Speaker" (type: KEYBOARD)
[ 36.851] (**) Option "xkb_rules" "evdev"
[ 36.851] (**) Option "xkb_model" "evdev"
[ 36.851] (**) Option "xkb_layout" "us"
[ 36.851] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 36.852] (II) config/udev: Adding input device USB Keyboard (/dev/input/event4)
[ 36.852] (**) USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 36.852] (**) USB Keyboard: Applying InputClass "keyboard-all"
[ 36.852] (**) USB Keyboard: always reports core events
[ 36.852] (**) USB Keyboard: Device: "/dev/input/event4"
[ 36.852] (--) USB Keyboard: Found keys
[ 36.852] (II) USB Keyboard: Configuring as keyboard
[ 36.852] (II) XINPUT: Adding extended input device " USB Keyboard" (type: KEYBOARD)
[ 36.852] (**) Option "xkb_rules" "evdev"
[ 36.852] (**) Option "xkb_model" "evdev"
[ 36.852] (**) Option "xkb_layout" "us"
[ 36.852] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 36.852] (II) config/udev: Adding input device USB Keyboard (/dev/input/event5)
[ 36.852] (**) USB Keyboard: Device: "/dev/input/event5"
[ 36.853] (II) config/udev: Adding input device C-Media USB Headphone Set (/dev/input/event6)
[ 36.853] (**) C-Media USB Headphone Set : Applying InputClass "evdev keyboard catchall"
[ 36.853] (**) C-Media USB Headphone Set : Applying InputClass "keyboard-all"
[ 36.853] (**) C-Media USB Headphone Set : always reports core events
[ 36.853] (**) C-Media USB Headphone Set : Device: "/dev/input/event6"
[ 36.853] (--) C-Media USB Headphone Set : Found keys
[ 36.853] (II) C-Media USB Headphone Set : Configuring as keyboard
[ 36.854] (II) XINPUT: Adding extended input device "C-Media USB Headphone Set " (type: KEYBOARD)
[ 36.854] (**) Option "xkb_rules" "evdev"
[ 36.854] (**) Option "xkb_model" "evdev"
[ 36.854] (**) Option "xkb_layout" "us"
[ 36.854] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 36.854] (II) config/udev: Adding input device HDA NVidia Headphone (/dev/input/event8)
[ 36.854] (II) No input driver/identifier specified (ignoring)
[ 36.857] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event9)
[ 36.857] (II) No input driver/identifier specified (ignoring)
[ 36.858] (II) config/udev: Adding input device ImPS/2 Generic Wheel Mouse (/dev/input/event7)
[ 36.858] (**) ImPS/2 Generic Wheel Mouse: Applying InputClass "evdev pointer catchall"
[ 36.858] (**) ImPS/2 Generic Wheel Mouse: always reports core events
[ 36.858] (**) ImPS/2 Generic Wheel Mouse: Device: "/dev/input/event7"
[ 36.858] (--) ImPS/2 Generic Wheel Mouse: Found 3 mouse buttons
[ 36.858] (--) ImPS/2 Generic Wheel Mouse: Found scroll wheel(s)
[ 36.858] (--) ImPS/2 Generic Wheel Mouse: Found relative axes
[ 36.858] (--) ImPS/2 Generic Wheel Mouse: Found x and y relative axes
[ 36.858] (II) ImPS/2 Generic Wheel Mouse: Configuring as mouse
[ 36.858] (II) ImPS/2 Generic Wheel Mouse: Adding scrollwheel support
[ 36.858] (**) ImPS/2 Generic Wheel Mouse: YAxisMapping: buttons 4 and 5
[ 36.858] (**) ImPS/2 Generic Wheel Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 36.858] (II) XINPUT: Adding extended input device "ImPS/2 Generic Wheel Mouse" (type: MOUSE)
[ 36.858] (**) ImPS/2 Generic Wheel Mouse: (accel) keeping acceleration scheme 1
[ 36.858] (**) ImPS/2 Generic Wheel Mouse: (accel) acceleration profile 0
[ 36.858] (**) ImPS/2 Generic Wheel Mouse: (accel) acceleration factor: 2.000
[ 36.858] (**) ImPS/2 Generic Wheel Mouse: (accel) acceleration threshold: 4
[ 36.858] (II) ImPS/2 Generic Wheel Mouse: initialized for relative axes.
[ 36.859] (II) config/udev: Adding input device ImPS/2 Generic Wheel Mouse (/dev/input/mouse0)
[ 36.859] (II) No input driver/identifier specified (ignoring)
[ 36.861] (II) config/udev: Adding input device Speakup (/dev/input/event0)
[ 36.861] (**) Speakup: Applying InputClass "evdev keyboard catchall"
[ 36.861] (**) Speakup: Applying InputClass "keyboard-all"
[ 36.861] (**) Speakup: always reports core events
[ 36.861] (**) Speakup: Device: "/dev/input/event0"
[ 36.861] (--) Speakup: Found keys
[ 36.861] (II) Speakup: Configuring as keyboard
[ 36.861] (II) XINPUT: Adding extended input device "Speakup" (type: KEYBOARD)
[ 36.861] (**) Option "xkb_rules" "evdev"
[ 36.861] (**) Option "xkb_model" "evdev"
[ 36.861] (**) Option "xkb_layout" "us"
[ 36.861] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[ 43.891] (II) RADEON(0): EDID vendor "SAM", prod id 1589
[ 43.891] (II) RADEON(0): Using EDID range info for horizontal sync
[ 43.891] (II) RADEON(0): Using EDID range info for vertical refresh
[ 43.891] (II) RADEON(0): Printing DDC gathered Modelines:
[ 43.891] (II) RADEON(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz)
[ 43.891] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 43.891] (II) RADEON(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 43.891] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz)
[ 43.891] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz)
[ 43.891] (II) RADEON(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz)
[ 43.891] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 43.891] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz)
[ 43.891] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz)
[ 43.891] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz)
[ 43.891] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz)
[ 43.891] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 43.891] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz)
[ 43.891] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz)
[ 43.891] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz)
[ 43.891] (II) RADEON(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz)
[ 43.891] (II) RADEON(0): Modeline "1280x800"x0.0 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz)
[ 43.891] (II) RADEON(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz)
[ 43.891] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz)
[ 43.891] (II) RADEON(0): Modeline "1440x900"x0.0 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz)
[ 43.891] (II) RADEON(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz)
[ 43.891] (II) RADEON(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz)
[ 43.891] (II) RADEON(0): Modeline "1680x1050"x0.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz)
[ 44.683]
Backtrace:
[ 44.683] 0: /usr/bin/X (xorg_backtrace+0x28) [0x4a02d8]
[ 44.683] 1: /usr/bin/X (0x400000+0x60fc9) [0x460fc9]
[ 44.683] 2: /lib64/libc.so.6 (0x7f9e9e8a8000+0x340b0) [0x7f9e9e8dc0b0]
[ 44.683] 3: /lib64/libc.so.6 (0x7f9e9e8a8000+0x8b04b) [0x7f9e9e93304b]
[ 44.683] 4: /usr/lib64/xorg/modules/libfb.so (fbBlt+0xf8) [0x7f9e9c6812b8]
[ 44.683] 5: /usr/lib64/xorg/modules/libfb.so (fbBltStip+0x40) [0x7f9e9c682040]
[ 44.683] 6: /usr/lib64/xorg/modules/libfb.so (fbGetImage+0x206) [0x7f9e9c6877a6]
[ 44.683] 7: /usr/bin/X (0x400000+0x154e48) [0x554e48]
[ 44.683] 8: /usr/lib64/xorg/modules/libshadow.so (0x7f9e9c894000+0x13f9) [0x7f9e9c8953f9]
[ 44.683] 9: /usr/lib64/xorg/modules/extensions/libglx.so (0x7f9e9dbdb000+0x38e4a) [0x7f9e9dc13e4a]
[ 44.683] 10: /usr/lib64/xorg/modules/dri/swrast_dri.so (0x7f9e9b098000+0x28a7b) [0x7f9e9b0c0a7b]
[ 44.683] 11: /usr/lib64/xorg/modules/extensions/libglx.so (0x7f9e9dbdb000+0x38de8) [0x7f9e9dc13de8]
[ 44.683] 12: /usr/lib64/xorg/modules/extensions/libglx.so (0x7f9e9dbdb000+0x35a0e) [0x7f9e9dc10a0e]
[ 44.683] 13: /usr/lib64/xorg/modules/extensions/libglx.so (0x7f9e9dbdb000+0x36852) [0x7f9e9dc11852]
[ 44.683] 14: /usr/lib64/xorg/modules/extensions/libglx.so (0x7f9e9dbdb000+0x38463) [0x7f9e9dc13463]
[ 44.683] 15: /usr/bin/X (0x400000+0x2def1) [0x42def1]
[ 44.683] 16: /usr/bin/X (0x400000+0x21ffe) [0x421ffe]
[ 44.683] 17: /lib64/libc.so.6 (__libc_start_main+0xfd) [0x7f9e9e8c6e5d]
[ 44.683] 18: /usr/bin/X (0x400000+0x21bb9) [0x421bb9]
[ 44.683] Segmentation fault at address (nil)
[ 44.683]
Fatal server error:
[ 44.683] Caught signal 11 (Segmentation fault). Server aborting
[ 44.683]
[ 44.683]
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 44.683] Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 44.683]
[ 44.700] (II) Power Button: Close
[ 44.700] (II) UnloadModule: "evdev"
[ 44.709] (II) Power Button: Close
[ 44.709] (II) UnloadModule: "evdev"
[ 44.718] (II) USB Speaker: Close
[ 44.718] (II) UnloadModule: "evdev"
[ 44.724] (II) USB Keyboard: Close
[ 44.724] (II) UnloadModule: "evdev"
[ 44.729] (II) USB Keyboard: Close
[ 44.729] (II) UnloadModule: "evdev"
[ 44.733] (II) C-Media USB Headphone Set : Close
[ 44.733] (II) UnloadModule: "evdev"
[ 44.758] (II) ImPS/2 Generic Wheel Mouse: Close
[ 44.758] (II) UnloadModule: "evdev"
[ 44.766] (II) Speakup: Close
[ 44.766] (II) UnloadModule: "evdev"
Podigne se Slack ali neće da uđe u X kucanjem komande startx? Šta ti piše na "Welcome to" liniji, koji kernel je u pitanju? Ako ti je lakše u terminalu otkucaj
Koju grafičku karticu koristiš? Imaš li xorg.conf fajl?
# uname -r
Users browsing this forum: No registered users and 37 guests
