Modul perl Makefile.PL koji mi je neophodan za jedno 20-tak paketa zavisnosti za jedan program, Shutter.
Našao sam ovo na netu, ali mi ništa ovde nije jasno.
cpan > install HTTP::Response
cpan > install XML::Twig
Našao sam i ovaj site ali mi nije jasno ništa ovde
http://search.cpan.org/dist/ExtUtils-Ma ... pod#___top
Da li sam ga instirao?
bash-4.1# cd ExtUtils-MakeMaker-6.62
bash-4.1# perl Makefile.PL
Using included version of Version::Requirements (0.101020) because it is not already installed.
Using included version of CPAN::Meta::YAML (0.003) because it is not already installed.
Using included version of JSON::PP (2.27104) because it is not already installed.
Using included version of version (0.88) as it is newer than the installed version (0.82).
Using included version of JSON::PP::Compat5006 (1.09) because it is not already installed.
Using included version of ExtUtils::Manifest (1.58) as it is newer than the installed version (1.57).
Using included version of File::Copy::Recursive (0.38) because it is not already installed.
Using included version of CPAN::Meta (2.112150) because it is not already installed.
Using included version of Parse::CPAN::Meta (1.4401) as it is newer than the installed version (1.40).
Checking if your kit is complete...
Looks good
Writing Makefile for ExtUtils::MakeMaker
Writing MYMETA.yml and MYMETA.json
bash-4.1# make
cp inc/ExtUtils/Manifest.pm blib/lib/ExtUtils/Manifest.pm
cp inc/File/Copy/Recursive.pm blib/lib/File/Copy/Recursive.pm
cp lib/ExtUtils/MM_VOS.pm blib/lib/ExtUtils/MM_VOS.pm
cp lib/ExtUtils/Mksymlists.pm blib/lib/ExtUtils/Mksymlists.pm
cp lib/ExtUtils/MM.pm blib/lib/ExtUtils/MM.pm
cp inc/JSON/PP.pm blib/lib/JSON/PP.pm
cp lib/ExtUtils/MM_UWIN.pm blib/lib/ExtUtils/MM_UWIN.pm
cp lib/ExtUtils/testlib.pm blib/lib/ExtUtils/testlib.pm
cp lib/ExtUtils/MM_DOS.pm blib/lib/ExtUtils/MM_DOS.pm
cp lib/ExtUtils/MM_Cygwin.pm blib/lib/ExtUtils/MM_Cygwin.pm
cp inc/version/vpp.pm blib/lib/version/vpp.pm
cp lib/ExtUtils/MM_Win95.pm blib/lib/ExtUtils/MM_Win95.pm
cp lib/ExtUtils/Liblist.pm blib/lib/ExtUtils/Liblist.pm
cp lib/ExtUtils/MM_Darwin.pm blib/lib/ExtUtils/MM_Darwin.pm
cp lib/ExtUtils/MM_AIX.pm blib/lib/ExtUtils/MM_AIX.pm
cp lib/ExtUtils/Liblist/Kid.pm blib/lib/ExtUtils/Liblist/Kid.pm
cp lib/ExtUtils/Mkbootstrap.pm blib/lib/ExtUtils/Mkbootstrap.pm
cp lib/ExtUtils/MakeMaker/FAQ.pod blib/lib/ExtUtils/MakeMaker/FAQ.pod
cp inc/ExtUtils/MANIFEST.SKIP blib/lib/ExtUtils/MANIFEST.SKIP
cp lib/ExtUtils/MM_NW5.pm blib/lib/ExtUtils/MM_NW5.pm
cp lib/ExtUtils/MM_OS2.pm blib/lib/ExtUtils/MM_OS2.pm
cp lib/ExtUtils/MakeMaker.pm blib/lib/ExtUtils/MakeMaker.pm
cp inc/version.pm blib/lib/version.pm
cp inc/CPAN/Meta/Feature.pm blib/lib/CPAN/Meta/Feature.pm
cp inc/version/Internals.pod blib/lib/version/Internals.pod
cp lib/ExtUtils/MM_Unix.pm blib/lib/ExtUtils/MM_Unix.pm
cp inc/JSON/PP/Boolean.pm blib/lib/JSON/PP/Boolean.pm
cp lib/ExtUtils/MM_Win32.pm blib/lib/ExtUtils/MM_Win32.pm
cp inc/CPAN/Meta/Spec.pm blib/lib/CPAN/Meta/Spec.pm
cp inc/CPAN/Meta/History.pm blib/lib/CPAN/Meta/History.pm
cp lib/ExtUtils/MY.pm blib/lib/ExtUtils/MY.pm
cp lib/ExtUtils/MM_MacOS.pm blib/lib/ExtUtils/MM_MacOS.pm
cp lib/ExtUtils/MM_VMS.pm blib/lib/ExtUtils/MM_VMS.pm
cp lib/ExtUtils/MM_BeOS.pm blib/lib/ExtUtils/MM_BeOS.pm
cp lib/ExtUtils/MakeMaker/Tutorial.pod blib/lib/ExtUtils/MakeMaker/Tutorial.pod
cp lib/ExtUtils/MM_QNX.pm blib/lib/ExtUtils/MM_QNX.pm
cp inc/CPAN/Meta/YAML.pm blib/lib/CPAN/Meta/YAML.pm
cp inc/CPAN/Meta/Converter.pm blib/lib/CPAN/Meta/Converter.pm
cp lib/ExtUtils/Command/MM.pm blib/lib/ExtUtils/Command/MM.pm
cp lib/ExtUtils/MakeMaker/Config.pm blib/lib/ExtUtils/MakeMaker/Config.pm
cp inc/JSON/PP/Compat5006.pm blib/lib/JSON/PP/Compat5006.pm
cp inc/CPAN/Meta.pm blib/lib/CPAN/Meta.pm
cp inc/Parse/CPAN/Meta.pm blib/lib/Parse/CPAN/Meta.pm
cp inc/CPAN/Meta/Prereqs.pm blib/lib/CPAN/Meta/Prereqs.pm
cp inc/CPAN/Meta/Validator.pm blib/lib/CPAN/Meta/Validator.pm
cp inc/Version/Requirements.pm blib/lib/Version/Requirements.pm
cp inc/version.pod blib/lib/version.pod
cp lib/ExtUtils/MM_Any.pm blib/lib/ExtUtils/MM_Any.pm
cp bin/instmodsh blib/script/instmodsh
/usr/bin/perl5.12.3 "-Iblib/arch" "-Iblib/lib" -MExtUtils::MY -e 'MY->fixin(shift)' -- blib/script/instmodsh
Manifying blib/man1/instmodsh.1
Manifying blib/man3/ExtUtils::Manifest.3
Manifying blib/man3/File::Copy::Recursive.3
Manifying blib/man3/ExtUtils::MM_VOS.3
Manifying blib/man3/ExtUtils::Mksymlists.3
Manifying blib/man3/ExtUtils::MM.3
Manifying blib/man3/JSON::PP.3
Manifying blib/man3/ExtUtils::MM_UWIN.3
Manifying blib/man3/ExtUtils::testlib.3
Manifying blib/man3/ExtUtils::MM_DOS.3
Manifying blib/man3/ExtUtils::MM_Cygwin.3
Manifying blib/man3/ExtUtils::MM_Win95.3
Manifying blib/man3/ExtUtils::Liblist.3
Manifying blib/man3/ExtUtils::MM_Darwin.3
Manifying blib/man3/ExtUtils::MM_AIX.3
Manifying blib/man3/ExtUtils::Mkbootstrap.3
Manifying blib/man3/ExtUtils::MakeMaker::FAQ.3
Manifying blib/man3/ExtUtils::MM_NW5.3
Manifying blib/man3/ExtUtils::MM_OS2.3
Manifying blib/man3/ExtUtils::MakeMaker.3
Manifying blib/man3/CPAN::Meta::Feature.3
Manifying blib/man3/version::Internals.3
Manifying blib/man3/ExtUtils::MM_Unix.3
Manifying blib/man3/JSON::PP::Boolean.3
Manifying blib/man3/ExtUtils::MM_Win32.3
Manifying blib/man3/CPAN::Meta::Spec.3
Manifying blib/man3/CPAN::Meta::History.3
Manifying blib/man3/ExtUtils::MY.3
Manifying blib/man3/ExtUtils::MM_MacOS.3
Manifying blib/man3/ExtUtils::MM_VMS.3
Manifying blib/man3/ExtUtils::MM_BeOS.3
Manifying blib/man3/ExtUtils::MakeMaker::Tutorial.3
Manifying blib/man3/CPAN::Meta::YAML.3
Manifying blib/man3/ExtUtils::MM_QNX.3
Manifying blib/man3/CPAN::Meta::Converter.3
Manifying blib/man3/ExtUtils::Command::MM.3
Manifying blib/man3/JSON::PP::Compat5006.3
Manifying blib/man3/ExtUtils::MakeMaker::Config.3
Manifying blib/man3/CPAN::Meta.3
Manifying blib/man3/CPAN::Meta::Prereqs.3
Manifying blib/man3/Parse::CPAN::Meta.3
Manifying blib/man3/Version::Requirements.3
Manifying blib/man3/CPAN::Meta::Validator.3
Manifying blib/man3/version.3
Manifying blib/man3/ExtUtils::MM_Any.3
bash-4.1# make test
PERL_DL_NONLAZY=1 /usr/bin/perl5.12.3 "-Iblib/arch" "-Iblib/lib" "-MExtUtils::Command::MM" "-e" "test_harness(0, 'blib/lib', 'blib/arch')" t/*.t
t/00compile.t ............. ok
t/arch_check.t ............ ok
t/backwards.t ............. ok
t/basic.t ................. ok
t/build_man.t ............. ok
t/cd.t .................... ok
t/config.t ................ ok
t/dir_target.t ............ ok
t/FIRST_MAKEFILE.t ........ ok
t/fix_libs.t .............. ok
t/fixin.t ................. ok
t/hints.t ................. ok
t/INST.t .................. ok
t/INST_PREFIX.t ........... ok
t/INSTALL_BASE.t .......... ok
t/installed_file.t ........ ok
t/is_of_type.t ............ ok
t/Liblist.t ............... ok
t/Liblist_Kid.t ........... ok
t/make.t .................. ok
t/MakeMaker_Parameters.t .. ok
t/maketext_filter.t ....... ok
t/meta_convert.t .......... ok
t/metafile_data.t ......... ok
t/metafile_file.t ......... ok
t/min_perl_version.t ...... ok
t/miniperl.t .............. skipped: miniperl test only necessary for the perl core
t/Mkbootstrap.t ........... ok
t/MM_Any.t ................ ok
t/MM_BeOS.t ............... skipped: This is not BeOS
t/MM_Cygwin.t ............. skipped: This is not cygwin
t/MM_NW5.t ................ skipped: This is not NW5
t/MM_OS2.t ................ skipped: This is not OS/2
t/MM_Unix.t ............... ok
t/MM_VMS.t ................ skipped: This is not VMS
t/MM_Win32.t .............. skipped: This is not Win32
t/oneliner.t .............. ok
t/parse_abstract.t ........ ok
t/parse_version.t ......... ok
t/PL_FILES.t .............. ok
t/pm.t .................... ok
t/pm_to_blib.t ............ ok
t/pod2man.t ............... ok
t/postamble.t ............. ok
t/prefixify.t ............. ok
t/prereq.t ................ ok
t/prereq_print.t .......... ok
t/problems.t .............. ok
t/prompt.t ................ ok
t/recurs.t ................ ok
t/revision.t .............. ok
t/several_authors.t ....... ok
t/split_command.t ......... ok
t/test_boilerplate.t ...... ok
t/testlib.t ............... ok
t/VERSION_FROM.t .......... ok
t/WriteEmptyMakefile.t .... ok
t/writemakefile_args.t .... ok
t/xs.t .................... ok
All tests successful.
Files=59, Tests=987, 21 wallclock secs ( 0.22 usr 0.07 sys + 15.67 cusr 1.57 csys = 17.53 CPU)
Result: PASS
bash-4.1# sudo make install
Installing /usr/lib/perl5/5.12.3/version.pod
Installing /usr/lib/perl5/5.12.3/version.pm
Installing /usr/lib/perl5/5.12.3/Parse/CPAN/Meta.pm
Installing /usr/lib/perl5/5.12.3/version/vpp.pm
Installing /usr/lib/perl5/5.12.3/File/Copy/Recursive.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_VMS.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_OS2.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_Win32.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_MacOS.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_Win95.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/Mksymlists.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_Cygwin.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MY.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_Unix.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MANIFEST.SKIP
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_BeOS.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_VOS.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_Darwin.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_QNX.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_AIX.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/Manifest.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/testlib.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_Any.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_DOS.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/Liblist.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/Mkbootstrap.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MakeMaker.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_NW5.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MM_UWIN.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/Liblist/Kid.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MakeMaker/Config.pm
Installing /usr/lib/perl5/5.12.3/ExtUtils/MakeMaker/FAQ.pod
Installing /usr/lib/perl5/5.12.3/ExtUtils/MakeMaker/Tutorial.pod
Installing /usr/lib/perl5/5.12.3/ExtUtils/Command/MM.pm
Installing /usr/lib/perl5/5.12.3/CPAN/Meta.pm
Installing /usr/lib/perl5/5.12.3/CPAN/Meta/Validator.pm
Installing /usr/lib/perl5/5.12.3/CPAN/Meta/History.pm
Installing /usr/lib/perl5/5.12.3/CPAN/Meta/Prereqs.pm
Installing /usr/lib/perl5/5.12.3/CPAN/Meta/YAML.pm
Installing /usr/lib/perl5/5.12.3/CPAN/Meta/Converter.pm
Installing /usr/lib/perl5/5.12.3/CPAN/Meta/Spec.pm
Installing /usr/lib/perl5/5.12.3/CPAN/Meta/Feature.pm
Installing /usr/lib/perl5/5.12.3/Version/Requirements.pm
Installing /usr/lib/perl5/5.12.3/JSON/PP.pm
Installing /usr/lib/perl5/5.12.3/JSON/PP/Compat5006.pm
Installing /usr/lib/perl5/5.12.3/JSON/PP/Boolean.pm
Installing /usr/share/man/man1/instmodsh.1
Installing /usr/share/man/man3/CPAN::Meta::YAML.3
Installing /usr/share/man/man3/ExtUtils::MM_MacOS.3
Installing /usr/share/man/man3/ExtUtils::Mksymlists.3
Installing /usr/share/man/man3/ExtUtils::MM_Any.3
Installing /usr/share/man/man3/ExtUtils::MM_Cygwin.3
Installing /usr/share/man/man3/ExtUtils::MM_Unix.3
Installing /usr/share/man/man3/ExtUtils::MM_QNX.3
Installing /usr/share/man/man3/CPAN::Meta::Converter.3
Installing /usr/share/man/man3/CPAN::Meta::History.3
Installing /usr/share/man/man3/ExtUtils::MakeMaker::Config.3
Installing /usr/share/man/man3/ExtUtils::Liblist.3
Installing /usr/share/man/man3/JSON::PP::Compat5006.3
Installing /usr/share/man/man3/ExtUtils::Mkbootstrap.3
Installing /usr/share/man/man3/ExtUtils::Command::MM.3
Installing /usr/share/man/man3/CPAN::Meta::Spec.3
Installing /usr/share/man/man3/File::Copy::Recursive.3
Installing /usr/share/man/man3/CPAN::Meta::Feature.3
Installing /usr/share/man/man3/ExtUtils::testlib.3
Installing /usr/share/man/man3/ExtUtils::MY.3
Installing /usr/share/man/man3/ExtUtils::MM_AIX.3
Installing /usr/share/man/man3/version::Internals.3
Installing /usr/share/man/man3/Version::Requirements.3
Installing /usr/share/man/man3/ExtUtils::MM_NW5.3
Installing /usr/share/man/man3/Parse::CPAN::Meta.3
Installing /usr/share/man/man3/ExtUtils::MM_Win95.3
Installing /usr/share/man/man3/ExtUtils::MakeMaker::FAQ.3
Installing /usr/share/man/man3/ExtUtils::MM_Darwin.3
Installing /usr/share/man/man3/ExtUtils::MM_DOS.3
Installing /usr/share/man/man3/ExtUtils::MM_BeOS.3
Installing /usr/share/man/man3/JSON::PP::Boolean.3
Installing /usr/share/man/man3/CPAN::Meta.3
Installing /usr/share/man/man3/ExtUtils::MM_UWIN.3
Installing /usr/share/man/man3/ExtUtils::Manifest.3
Installing /usr/share/man/man3/CPAN::Meta::Validator.3
Installing /usr/share/man/man3/ExtUtils::MakeMaker::Tutorial.3
Installing /usr/share/man/man3/ExtUtils::MakeMaker.3
Installing /usr/share/man/man3/ExtUtils::MM_VMS.3
Installing /usr/share/man/man3/ExtUtils::MM_VOS.3
Installing /usr/share/man/man3/ExtUtils::MM.3
Installing /usr/share/man/man3/CPAN::Meta::Prereqs.3
Installing /usr/share/man/man3/JSON::PP.3
Installing /usr/share/man/man3/version.3
Installing /usr/share/man/man3/ExtUtils::MM_OS2.3
Installing /usr/share/man/man3/ExtUtils::MM_Win32.3
Installing /usr/bin/instmodsh
Appending installation info to /usr/lib/perl5/5.12.3/i486-linux-thread-multi/perllocal.pod
bash-4.1# cd /usr/lib/perl5/5.12.3/
bash-4.1# ls -l
total 1956
-r--r--r-- 1 root root 2594 Jan 26 2011 AnyDBM_File.pm
drwxr-xr-x 3 root root 4096 Jan 26 2011 App
drwxr-xr-x 3 root root 4096 Jan 26 2011 Archive
drwxr-xr-x 2 root root 4096 Jan 26 2011 Attribute
-r--r--r-- 1 root root 15003 Jan 26 2011 AutoLoader.pm
-r--r--r-- 1 root root 19637 Jan 26 2011 AutoSplit.pm
drwxr-xr-x 3 root root 4096 Jan 26 2011 B
-r--r--r-- 1 root root 28530 Jan 26 2011 Benchmark.pm
drwxr-xr-x 2 root root 4096 Jan 26 2011 CGI
-r--r--r-- 1 root root 259797 Jan 26 2011 CGI.pm
-r--r--r-- 1 root root 1569 Jan 26 2011 CORE.pod
drwxr-xr-x 8 root root 4096 Feb 5 09:58 CPAN
-r--r--r-- 1 root root 133287 Jan 26 2011 CPAN.pm
drwxr-xr-x 8 root root 4096 Jan 26 2011 CPANPLUS
-r--r--r-- 1 root root 7269 Jan 26 2011 CPANPLUS.pm
drwxr-xr-x 2 root root 4096 Jan 26 2011 Carp
-r--r--r-- 1 root root 16146 Jan 26 2011 Carp.pm
drwxr-xr-x 2 root root 4096 Jan 26 2011 Class
drwxr-xr-x 2 root root 4096 Jan 26 2011 Compress
drwxr-xr-x 2 root root 4096 Jan 26 2011 Config
-r--r--r-- 1 root root 19202 Jan 26 2011 DB.pm
drwxr-xr-x 2 root root 4096 Jan 26 2011 DBM_Filter
-r--r--r-- 1 root root 14407 Jan 26 2011 DBM_Filter.pm
drwxr-xr-x 2 root root 4096 Jan 26 2011 Devel
drwxr-xr-x 2 root root 4096 Jan 26 2011 Digest
-r--r--r-- 1 root root 10354 Jan 26 2011 Digest.pm
-r--r--r-- 1 root root 1937 Jan 26 2011 DirHandle.pm
-r--r--r-- 1 root root 16901 Jan 26 2011 Dumpvalue.pm
drwxr-xr-x 2 root root 4096 Jan 26 2011 Encode
-r--r--r-- 1 root root 4488 Jan 26 2011 English.pm
-r--r--r-- 1 root root 5531 Jan 26 2011 Env.pm
drwxr-xr-x 2 root root 4096 Jan 26 2011 Exporter
-r--r--r-- 1 root root 18494 Jan 26 2011 Exporter.pm
drwxr-xr-x 7 root root 4096 Feb 5 09:58 ExtUtils
-r--r--r-- 1 root root 40966 Jan 26 2011 Fatal.pm
drwxr-xr-x 3 root root 4096 Feb 5 09:58 File
-r--r--r-- 1 root root 5570 Jan 26 2011 FileCache.pm
-r--r--r-- 1 root root 6778 Jan 26 2011 FileHandle.pm
drwxr-xr-x 2 root root 4096 Jan 26 2011 Filter
-r--r--r-- 1 root root 5658 Jan 26 2011 FindBin.pm
drwxr-xr-x 2 root root 4096 Jan 26 2011 Getopt
drwxr-xr-x 3 root root 4096 Jan 26 2011 I18N
drwxr-xr-x 4 root root 4096 Jan 26 2011 IO
drwxr-xr-x 2 root root 4096 Jan 26 2011 IPC
drwxr-xr-x 3 root root 4096 Feb 5 09:58 JSON
drwxr-xr-x 3 root root 4096 Jan 26 2011 Locale
drwxr-xr-x 3 root root 4096 Jan 26 2011 Log
drwxr-xr-x 4 root root 4096 Jan 26 2011 Math
drwxr-xr-x 2 root root 4096 Jan 26 2011 Memoize
-r--r--r-- 1 root root 35295 Jan 26 2011 Memoize.pm
drwxr-xr-x 5 root root 4096 Jan 26 2011 Module
-r--r--r-- 1 root root 18481 Jan 26 2011 NEXT.pm
drwxr-xr-x 3 root root 4096 Jan 26 2011 Net
drwxr-xr-x 2 root root 4096 Jan 26 2011 Object
drwxr-xr-x 2 root root 4096 Jan 26 2011 Package
drwxr-xr-x 2 root root 4096 Jan 26 2011 Params
drwxr-xr-x 3 root root 4096 Jan 26 2011 Parse
drwxr-xr-x 3 root root 4096 Jan 26 2011 PerlIO
-r--r--r-- 1 root root 11122 Jan 26 2011 PerlIO.pm
drwxr-xr-x 5 root root 4096 Jan 26 2011 Pod
-r--r--r-- 1 root root 24326 Jan 26 2011 Safe.pm
drwxr-xr-x 2 root root 4096 Jan 26 2011 Search
-r--r--r-- 1 root root 1076 Jan 26 2011 SelectSaver.pm
-r--r--r-- 1 root root 17341 Jan 26 2011 SelfLoader.pm
-r--r--r-- 1 root root 8685 Jan 26 2011 Shell.pm
-r--r--r-- 1 root root 28456 Jan 26 2011 Switch.pm
-r--r--r-- 1 root root 4794 Jan 26 2011 Symbol.pm
drwxr-xr-x 4 root root 4096 Jan 26 2011 TAP
drwxr-xr-x 3 root root 4096 Jan 26 2011 Term
drwxr-xr-x 3 root root 4096 Jan 26 2011 Test
-r--r--r-- 1 root root 28800 Jan 26 2011 Test.pm
drwxr-xr-x 2 root root 4096 Jan 26 2011 Text
drwxr-xr-x 2 root root 4096 Jan 26 2011 Thread
-r--r--r-- 1 root root 8285 Jan 26 2011 Thread.pm
drwxr-xr-x 3 root root 4096 Jan 26 2011 Tie
drwxr-xr-x 2 root root 4096 Jan 26 2011 Time
-r--r--r-- 1 root root 6865 Jan 26 2011 UNIVERSAL.pm
drwxr-xr-x 3 root root 4096 Jan 26 2011 Unicode
drwxr-xr-x 2 root root 4096 Jan 26 2011 User
drwxr-xr-x 2 root root 4096 Feb 5 09:58 Version
-r--r--r-- 1 root root 10523 Jan 26 2011 XSLoader.pm
-r--r--r-- 1 root root 925 Jan 26 2011 abbrev.pl
-r--r--r-- 1 root root 1523 Jan 26 2011 assert.pl
drwxr-xr-x 3 root root 4096 Jan 26 2011 autodie
-r--r--r-- 1 root root 11763 Jan 26 2011 autodie.pm
-r--r--r-- 1 root root 4238 Jan 26 2011 autouse.pm
-r--r--r-- 1 root root 6986 Jan 26 2011 base.pm
-r--r--r-- 1 root root 7454 Jan 26 2011 bigfloat.pl
-r--r--r-- 1 root root 9045 Jan 26 2011 bigint.pl
-r--r--r-- 1 root root 17852 Jan 26 2011 bigint.pm
-r--r--r-- 1 root root 18673 Jan 26 2011 bignum.pm
-r--r--r-- 1 root root 4562 Jan 26 2011 bigrat.pl
-r--r--r-- 1 root root 14442 Jan 26 2011 bigrat.pm
-r--r--r-- 1 root root 2106 Jan 26 2011 blib.pm
-r--r--r-- 1 root root 3033 Jan 26 2011 bytes.pm
-r--r--r-- 1 root root 758 Jan 26 2011 bytes_heavy.pl
-r--r--r-- 1 root root 1209 Jan 26 2011 cacheout.pl
-r--r--r-- 1 root root 16702 Jan 26 2011 charnames.pm
-r--r--r-- 1 root root 3277 Jan 26 2011 complete.pl
-r--r--r-- 1 root root 13164 Jan 26 2011 constant.pm
-r--r--r-- 1 root root 2081 Jan 26 2011 ctime.pl
-r--r--r-- 1 root root 2747 Jan 26 2011 deprecate.pm
-r--r--r-- 1 root root 17405 Jan 26 2011 diagnostics.pm
-r--r--r-- 1 root root 2261 Jan 26 2011 dotsh.pl
-r--r--r-- 1 root root 15275 Jan 26 2011 dumpvar.pl
drwxr-xr-x 2 root root 4096 Jan 26 2011 encoding
-r--r--r-- 1 root root 1819 Jan 26 2011 exceptions.pl
-r--r--r-- 1 root root 1105 Jan 26 2011 fastcwd.pl
-r--r--r-- 1 root root 5863 Jan 26 2011 feature.pm
-r--r--r-- 1 root root 9507 Jan 26 2011 fields.pm
-r--r--r-- 1 root root 4003 Jan 26 2011 filetest.pm
-r--r--r-- 1 root root 1345 Jan 26 2011 find.pl
-r--r--r-- 1 root root 1290 Jan 26 2011 finddepth.pl
-r--r--r-- 1 root root 728 Jan 26 2011 flush.pl
-r--r--r-- 1 root root 1511 Jan 26 2011 getcwd.pl
-r--r--r-- 1 root root 1408 Jan 26 2011 getopt.pl
-r--r--r-- 1 root root 1405 Jan 26 2011 getopts.pl
-r--r--r-- 1 root root 813 Jan 26 2011 hostname.pl
drwxr-xr-x 26 root root 4096 Mar 20 2011 i486-linux-thread-multi
-r--r--r-- 1 root root 1166 Jan 26 2011 if.pm
-r--r--r-- 1 root root 505 Jan 26 2011 importenv.pl
drwxr-xr-x 3 root root 4096 Jan 26 2011 inc
-r--r--r-- 1 root root 3266 Jan 26 2011 integer.pm
-r--r--r-- 1 root root 3204 Jan 26 2011 less.pm
-r--r--r-- 1 root root 820 Jan 26 2011 locale.pm
-r--r--r-- 1 root root 1341 Jan 26 2011 look.pl
-r--r--r-- 1 root root 2300 Jan 26 2011 newgetopt.pl
-r--r--r-- 1 root root 7740 Jan 26 2011 open.pm
-r--r--r-- 1 root root 274 Jan 26 2011 open2.pl
-r--r--r-- 1 root root 274 Jan 26 2011 open3.pl
drwxr-xr-x 2 root root 4096 Jan 26 2011 overload
-r--r--r-- 1 root root 49467 Jan 26 2011 overload.pm
-r--r--r-- 1 root root 1801 Jan 26 2011 overloading.pm
-r--r--r-- 1 root root 3005 Jan 26 2011 parent.pm
-r--r--r-- 1 root root 318272 Jan 26 2011 perl5db.pl
drwxr-xr-x 2 root root 4096 Jan 26 2011 pod
-r--r--r-- 1 root root 1564 Jan 26 2011 pwd.pl
-r--r--r-- 1 root root 368 Jan 26 2011 shellwords.pl
-r--r--r-- 1 root root 7611 Jan 26 2011 sigtrap.pm
-r--r--r-- 1 root root 6093 Jan 26 2011 sort.pm
-r--r--r-- 1 root root 683 Jan 26 2011 stat.pl
-r--r--r-- 1 root root 3716 Jan 26 2011 strict.pm
-r--r--r-- 1 root root 842 Jan 26 2011 subs.pm
-r--r--r-- 1 root root 4806 Jan 26 2011 syslog.pl
-r--r--r-- 1 root root 253 Jan 26 2011 tainted.pl
-r--r--r-- 1 root root 4202 Jan 26 2011 termcap.pl
-r--r--r-- 1 root root 780 Jan 26 2011 timelocal.pl
drwxr-xr-x 6 root root 4096 Jan 26 2011 unicore
-r--r--r-- 1 root root 7785 Jan 26 2011 utf8.pm
-r--r--r-- 1 root root 20125 Jan 26 2011 utf8_heavy.pl
-r--r--r-- 1 root root 3731 Jan 26 2011 validate.pl
-r--r--r-- 1 root root 2358 Jan 26 2011 vars.pm
drwxr-xr-x 2 root root 4096 Feb 5 09:58 version
-r--r--r-- 1 root root 6494 Feb 5 09:56 version.pm
-r--r--r-- 1 root root 9816 Feb 5 09:56 version.pod
-r--r--r-- 1 root root 4328 Jan 26 2011 vmsish.pm
drwxr-xr-x 2 root root 4096 Jan 26 2011 warnings
-r--r--r-- 1 root root 17476 Jan 26 2011 warnings.pm
bash-4.1#
