# dmesg
ode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
Initializing HighMem for node 0 (000373fe:000bffb0)
Memory: 3103852k/3145408k available (9560k kernel code, 40008k reserved, 3111k data, 636k init, 2240200k highmem)
virtual kernel memory layout:
fixmap : 0xffd57000 - 0xfffff000 (2720 kB)
pkmap : 0xff400000 - 0xff800000 (4096 kB)
vmalloc : 0xf7bfe000 - 0xff3fe000 ( 120 MB)
lowmem : 0xc0000000 - 0xf73fe000 ( 883 MB)
.init : 0xc1c61000 - 0xc1d00000 ( 636 kB)
.data : 0xc19561c0 - 0xc1c60004 (3111 kB)
.text : 0xc1000000 - 0xc19561c0 (9560 kB)
Checking if this processor honours the WP bit even in supervisor mode...Ok.
SLUB: Genslabs=13, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:1280
spurious 8259A interrupt: IRQ7.
Console: colour dummy device 80x25
console [tty0] enabled
hpet clockevent registered
Fast TSC calibration failed
TSC: PIT calibration matches HPET. 1 loops
Detected 2316.574 MHz processor.
Calibrating delay loop (skipped), value calculated using timer frequency.. 4633.14 BogoMIPS (lpj=2316574)
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
mce: CPU supports 6 MCE banks
using C1E aware idle routine
Performance Events: AMD PMU driver.
... version: 0
... bit width: 48
... generic registers: 4
... value mask: 0000ffffffffffff
... max period: 00007fffffffffff
... fixed-purpose events: 0
... event mask: 000000000000000f
Checking 'hlt' instruction... OK.
ACPI: Core revision 20091214
ftrace: converting mcount calls to 0f 1f 44 00 00
ftrace: allocating 33446 entries in 66 pages
Enabling APIC mode: Flat. Using 1 I/O APICs
..TIMER: vector=0x30 apic1=0 pin1=0 apic2=-1 pin2=-1
..MP-BIOS bug: 8254 timer not connected to IO-APIC
...trying to set up timer (IRQ0) through the 8259A ...
..... (found apic 0 pin 0) ...
....... works.
CPU0: AMD Phenom(tm) 9550 Quad-Core Processor stepping 03
Booting Node 0, Processors #1
Initializing CPU#1
#2
Initializing CPU#2
#3 Ok.
Initializing CPU#3
Brought up 4 CPUs
Total of 4 processors activated (18532.22 BogoMIPS).
devtmpfs: initialized
xor: automatically using best checksumming function: pIII_sse
pIII_sse : 9536.000 MB/sec
xor: using function: pIII_sse (9536.000 MB/sec)
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
PCI: not using MMCONFIG
PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=4
PCI: Using configuration type 1 for base access
PCI: Using configuration type 1 for extended access
bio: create slab <bio-0> at 0
ACPI: EC: Look up EC in DSDT
ACPI: Executed 1 blocks of module-level executable AML code
ACPI: Interpreter enabled
ACPI: (supports S0 S1 S3 S4 S5)
ACPI: Using IOAPIC for interrupt routing
PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
PCI: Using MMCONFIG for extended config space
ACPI Warning: Incorrect checksum in table [OEMB] - 08, should be FB (20091214/tbutils-314)
ACPI: No dock devices found.
ACPI: PCI Root Bridge [PCI0] (0000:00)
pci_root PNP0A03:00: ignoring host bridge windows from ACPI; boot with "pci=use_crs" to use them
pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
pci_root PNP0A03:00: host bridge window [mem 0x000d0000-0x000dffff] (ignored)
pci_root PNP0A03:00: host bridge window [mem 0xc0000000-0xff6fffff] (ignored)
pci 0000:00:01.0: reg 10: [io 0x0900-0x09ff]
pci 0000:00:01.1: reg 10: [io 0x0e00-0x0e3f]
pci 0000:00:01.1: reg 20: [io 0x0600-0x063f]
pci 0000:00:01.1: reg 24: [io 0x0700-0x073f]
pci 0000:00:01.1: PME# supported from D3hot D3cold
pci 0000:00:01.1: PME# disabled
pci 0000:00:02.0: reg 10: [mem 0xdfdff000-0xdfdfffff]
pci 0000:00:02.0: supports D1 D2
pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:02.0: PME# disabled
pci 0000:00:02.1: reg 10: [mem 0xdfdfec00-0xdfdfecff]
pci 0000:00:02.1: supports D1 D2
pci 0000:00:02.1: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:02.1: PME# disabled
pci 0000:00:05.0: reg 10: [mem 0xdfdf8000-0xdfdfbfff]
pci 0000:00:05.0: PME# supported from D3hot D3cold
pci 0000:00:05.0: PME# disabled
pci 0000:00:06.0: reg 20: [io 0xffa0-0xffaf]
pci 0000:00:07.0: reg 10: [mem 0xdfdfd000-0xdfdfdfff]
pci 0000:00:07.0: reg 14: [io 0xc480-0xc487]
pci 0000:00:07.0: supports D1 D2
pci 0000:00:07.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:07.0: PME# disabled
pci 0000:00:08.0: reg 10: [io 0xc400-0xc407]
pci 0000:00:08.0: reg 14: [io 0xc080-0xc083]
pci 0000:00:08.0: reg 18: [io 0xc000-0xc007]
pci 0000:00:08.0: reg 1c: [io 0xbc00-0xbc03]
pci 0000:00:08.0: reg 20: [io 0xb880-0xb88f]
pci 0000:00:08.0: reg 24: [mem 0xdfdfc000-0xdfdfcfff]
pci 0000:00:08.1: reg 10: [io 0xb800-0xb807]
pci 0000:00:08.1: reg 14: [io 0xb480-0xb483]
pci 0000:00:08.1: reg 18: [io 0xb400-0xb407]
pci 0000:00:08.1: reg 1c: [io 0xb080-0xb083]
pci 0000:00:08.1: reg 20: [io 0xb000-0xb00f]
pci 0000:00:08.1: reg 24: [mem 0xdfdef000-0xdfdeffff]
pci 0000:00:09.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:09.0: PME# disabled
pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:0b.0: PME# disabled
pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:0c.0: PME# disabled
pci 0000:01:06.0: reg 10: [mem 0xdfef8000-0xdfefffff]
pci 0000:01:07.0: reg 10: [mem 0xdfee0000-0xdfeeffff]
pci 0000:01:07.0: reg 14: [io 0xdc00-0xdc07]
pci 0000:01:07.0: PME# supported from D3hot D3cold
pci 0000:01:07.0: PME# disabled
pci 0000:00:04.0: PCI bridge to [bus 01-01] (subtractive decode)
pci 0000:00:04.0: bridge window [io 0xd000-0xdfff]
pci 0000:00:04.0: bridge window [mem 0xdfe00000-0xdfefffff]
pci 0000:02:00.0: reg 10: [mem 0xc0000000-0xcfffffff 64bit pref]
pci 0000:02:00.0: reg 18: [mem 0xdfff0000-0xdfffffff 64bit]
pci 0000:02:00.0: reg 20: [io 0xe800-0xe8ff]
pci 0000:02:00.0: reg 30: [mem 0xdffc0000-0xdffdffff pref]
pci 0000:02:00.0: supports D1 D2
pci 0000:02:00.1: reg 10: [mem 0xdffec000-0xdffeffff 64bit]
pci 0000:02:00.1: supports D1 D2
pci 0000:00:09.0: PCI bridge to [bus 02-02]
pci 0000:00:09.0: bridge window [io 0xe000-0xefff]
pci 0000:00:09.0: bridge window [mem 0xdff00000-0xdfffffff]
pci 0000:00:09.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
pci 0000:00:0b.0: PCI bridge to [bus 03-03]
pci 0000:00:0c.0: PCI bridge to [bus 04-04]
pci_bus 0000:00: on NUMA node 0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P2._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR11._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.BR12._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 16 17 18 19) *10
ACPI: PCI Interrupt Link [LNKB] (IRQs 16 17 18 19) *5
ACPI: PCI Interrupt Link [LNKC] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNEA] (IRQs 16 17 18 19) *11
ACPI: PCI Interrupt Link [LNEB] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNEC] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNED] (IRQs 16 17 18 19) *11
ACPI: PCI Interrupt Link [LUB0] (IRQs 20 21 22 23) *5
ACPI: PCI Interrupt Link [LUB2] (IRQs 20 21 22 23) *11
ACPI: PCI Interrupt Link [LMAC] (IRQs 20 21 22 23) *5
ACPI: PCI Interrupt Link [LAZA] (IRQs 20 21 22 23) *10
ACPI: PCI Interrupt Link [LACI] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [LMC9] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [LSMB] (IRQs 20 21 22 23) *10
ACPI: PCI Interrupt Link [LPMU] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [LSA0] (IRQs 20 21 22 23) *11
ACPI: PCI Interrupt Link [LSA1] (IRQs 20 21 22 23) *11
ACPI: PCI Interrupt Link [LATA] (IRQs 20 21 22 23) *0, disabled.
vgaarb: device added: PCI:0000:02:00.0,decodes=io+mem,owns=io+mem,locks=none
vgaarb: loaded
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
raid6: int32x1 1074 MB/s
raid6: int32x2 992 MB/s
raid6: int32x4 800 MB/s
raid6: int32x8 527 MB/s
raid6: mmxx1 1906 MB/s
raid6: mmxx2 3554 MB/s
raid6: sse1x1 1632 MB/s
raid6: sse1x2 2753 MB/s
raid6: sse2x1 2996 MB/s
raid6: sse2x2 5027 MB/s
raid6: using algorithm sse2x2 (5027 MB/s)
PCI: Using ACPI for IRQ routing
PCI: pci_cache_line_size set to 64 bytes
HPET: 3 timers in total, 0 timers will be used for per-cpu timer
hpet0: at MMIO 0xfed00000, IRQs 2, 8, 31
hpet0: 3 comparators, 32-bit 25.000000 MHz counter
Switching to clocksource tsc
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp 00:07: disabling [io 0x0900-0x097f] because it overlaps 0000:00:01.0 BAR 0 [io 0x0900-0x09ff]
pnp 00:07: disabling [io 0x0980-0x09ff] because it overlaps 0000:00:01.0 BAR 0 [io 0x0900-0x09ff]
pnp: PnP ACPI: found 15 devices
ACPI: ACPI bus type pnp unregistered
system 00:07: [io 0x0a30-0x0a37] has been reserved
system 00:07: [io 0x04d0-0x04d1] has been reserved
system 00:07: [io 0x0800-0x080f] has been reserved
system 00:07: [io 0x0500-0x057f] has been reserved
system 00:07: [io 0x0580-0x05ff] has been reserved
system 00:07: [io 0x0800-0x087f] could not be reserved
system 00:07: [io 0x0880-0x08ff] has been reserved
system 00:07: [io 0x0d00-0x0d7f] has been reserved
system 00:07: [io 0x0d80-0x0dff] has been reserved
system 00:07: [io 0x2000-0x207f] has been reserved
system 00:07: [io 0x2080-0x20ff] has been reserved
system 00:07: [mem 0xfefe0000-0xfefe01ff] has been reserved
system 00:07: [mem 0xfefe1000-0xfefe1fff] has been reserved
system 00:07: [mem 0xfee01000-0xfeefffff] has been reserved
system 00:07: [mem 0xffb80000-0xffffffff] could not be reserved
system 00:07: [mem 0xff300000-0xff3fffff] has been reserved
system 00:09: [mem 0xfec00000-0xfec00fff] could not be reserved
system 00:09: [mem 0xfee00000-0xfee00fff] has been reserved
system 00:09: [mem 0xfec80000-0xfec8ffff] has been reserved
system 00:0b: [io 0x0230-0x023f] has been reserved
system 00:0b: [io 0x0290-0x029f] has been reserved
system 00:0b: [io 0x0a00-0x0a0f] has been reserved
system 00:0b: [io 0x0a10-0x0a1f] has been reserved
system 00:0d: [mem 0xe0000000-0xefffffff] has been reserved
system 00:0e: [mem 0x00000000-0x0009ffff] could not be reserved
system 00:0e: [mem 0x000c0000-0x000cffff] could not be reserved
system 00:0e: [mem 0x000e0000-0x000fffff] could not be reserved
system 00:0e: [mem 0x00100000-0xbfffffff] could not be reserved
system 00:0e: [mem 0xff700000-0xffffffff] could not be reserved
pci 0000:00:04.0: bridge window [mem pref disabled]
pci 0000:00:0b.0: bridge window [io disabled]
pci 0000:00:0b.0: bridge window [mem disabled]
pci 0000:00:0b.0: bridge window [mem pref disabled]
pci 0000:00:0c.0: bridge window [io disabled]
pci 0000:00:0c.0: bridge window [mem disabled]
pci 0000:00:0c.0: bridge window [mem pref disabled]
pci 0000:00:04.0: setting latency timer to 64
pci 0000:00:09.0: setting latency timer to 64
pci 0000:00:0b.0: setting latency timer to 64
pci 0000:00:0c.0: setting latency timer to 64
pci_bus 0000:00: resource 0 [io 0x0000-0xffff]
pci_bus 0000:00: resource 1 [mem 0x00000000-0xffffffff]
pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
pci_bus 0000:01: resource 1 [mem 0xdfe00000-0xdfefffff]
pci_bus 0000:01: resource 3 [io 0x0000-0xffff]
pci_bus 0000:01: resource 4 [mem 0x00000000-0xffffffff]
pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
pci_bus 0000:02: resource 1 [mem 0xdff00000-0xdfffffff]
pci_bus 0000:02: resource 2 [mem 0xc0000000-0xcfffffff 64bit pref]
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
pci 0000:00:00.0: Found enabled HT MSI Mapping
pci 0000:02:00.0: Boot video device
PCI: CLS 64 bytes, default 64
audit: initializing netlink socket (disabled)
type=2000 audit(1280953495.060:1): initialized
highmem bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
DLM (built May 12 2010 22:42:00) installed
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NTFS driver 2.1.29 [Flags: R/W].
ROMFS MTD (C) 2007 Red Hat, Inc.
JFS: nTxBlock = 8192, nTxLock = 65536
SGI XFS with ACLs, security attributes, large block/inode numbers, no debug enabled
SGI XFS Quota Management subsystem
OCFS2 1.5.0
ocfs2: Registered cluster interface o2cb
ocfs2: Registered cluster interface user
OCFS2 Node Manager 1.5.0
OCFS2 DLM 1.5.0
OCFS2 DLMFS 1.5.0
OCFS2 User DLM kernel interface loaded
Btrfs loaded
Slow work thread pool: Starting up
Slow work thread pool: Ready
GFS2 (built May 12 2010 22:42:42) installed
msgmni has been set to 1688
alg: No test for cipher_null (cipher_null-generic)
alg: No test for ecb(cipher_null) (ecb-cipher_null)
alg: No test for digest_null (digest_null-generic)
alg: No test for compress_null (compress_null-generic)
alg: No test for fcrypt (fcrypt-generic)
alg: No test for stdrng (krng)
async_tx: api initialized (async)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
pcieport 0000:00:09.0: setting latency timer to 64
pcieport 0000:00:09.0: irq 24 for MSI/MSI-X
pcieport 0000:00:0b.0: setting latency timer to 64
pcieport 0000:00:0b.0: irq 25 for MSI/MSI-X
pcieport 0000:00:0c.0: setting latency timer to 64
pcieport 0000:00:0c.0: irq 26 for MSI/MSI-X
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
vesafb: framebuffer at 0xc0000000, mapped to 0xf8180000, using 1536k, total 16384k
vesafb: mode is 1024x768x8, linelength=1024, pages=18
vesafb: protected mode interface info at c000:9f88
vesafb: pmi: set display start = c00ca02a, set palette = c00ca0e8
vesafb: scrolling: redraw
vesafb: Pseudocolor: size=8:8:8:8, shift=0:0:0:0
Console: switching to colour frame buffer device 128x48
fb0: VESA VGA frame buffer device
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:0c: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
brd: module loaded
loop: module loaded
Compaq SMART2 Driver (v 2.6.0)
HP CISS Driver (v 3.6.20)
input: Macintosh mouse button emulation as /devices/virtual/input/input0
Loading iSCSI transport class v2.0-870.
fnic: Cisco FCoE HBA Driver, ver 1.0.0.1121
Adaptec aacraid driver 1.1-5[24702]-ms
aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0.3 loaded
scsi: <fdomain> Detection failed (no card)
sym53c416.c: Version 1.0.0-ac
qlogicfas: no cards were found, please specify I/O address and IRQ using iobase= and irq= options
QLogic Fibre Channel HBA Driver: 8.03.01-k10
iscsi: registered transport (qla4xxx)
QLogic iSCSI HBA Driver
Emulex LightPulse Fibre Channel SCSI driver 8.3.7
Copyright(c) 2004-2009 Emulex. All rights reserved.
Brocade BFA FC/FCOE SCSI driver - version: 2.0.0.0
Failed initialization of WD-7000 SCSI card!
DC390: clustering now enabled by default. If you get problems load
with "disable_clustering=1" and report to maintainers
megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006)
megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
megasas: 00.00.04.12-rc1 Thu Sep. 17 11:41:51 PST 2009
mpt2sas version 03.100.03.00 loaded
GDT-HA: Storage RAID Controller Driver. Version: 3.05
3ware Storage Controller device driver for Linux v1.26.02.002.
3ware 9000 Storage Controller device driver for Linux v2.26.02.013.
LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
ipr: IBM Power RAID SCSI Device Driver version: 2.4.3 (June 10, 2009)
RocketRAID 3xxx/4xxx Controller driver v1.6 (090910)
stex: Promise SuperTrak EX Driver version: 4.6.0000.4
st: Version 20081215, fixed bufsize 32768, s/g segs 256
sata_nv 0000:00:08.0: version 3.5
ACPI: PCI Interrupt Link [LSA0] enabled at IRQ 23
sata_nv 0000:00:08.0: PCI INT A -> Link[LSA0] -> GSI 23 (level, low) -> IRQ 23
sata_nv 0000:00:08.0: setting latency timer to 64
scsi2 : sata_nv
scsi3 : sata_nv
ata1: SATA max UDMA/133 cmd 0xc400 ctl 0xc080 bmdma 0xb880 irq 23
ata2: SATA max UDMA/133 cmd 0xc000 ctl 0xbc00 bmdma 0xb888 irq 23
ACPI: PCI Interrupt Link [LSA1] enabled at IRQ 22
sata_nv 0000:00:08.1: PCI INT B -> Link[LSA1] -> GSI 22 (level, low) -> IRQ 22
sata_nv 0000:00:08.1: setting latency timer to 64
scsi4 : sata_nv
scsi5 : sata_nv
ata3: SATA max UDMA/133 cmd 0xb800 ctl 0xb480 bmdma 0xb000 irq 22
ata4: SATA max UDMA/133 cmd 0xb400 ctl 0xb080 bmdma 0xb008 irq 22
pata_amd 0000:00:06.0: version 0.4.1
pata_amd 0000:00:06.0: setting latency timer to 64
scsi6 : pata_amd
scsi7 : pata_amd
ata5: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
ata6: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
I2O subsystem v1.325
i2o: max drivers = 8
I2O Configuration OSM v1.323
I2O Bus Adapter OSM v1.317
I2O Block Device OSM v1.325
I2O SCSI Peripheral OSM v1.316
I2O ProcFS OSM v1.316
Fusion MPT base driver 3.04.13
Copyright (c) 1999-2008 LSI Corporation
Fusion MPT SPI Host driver 3.04.13
Fusion MPT FC Host driver 3.04.13
Fusion MPT SAS Host driver 3.04.13
Fusion MPT misc device (ioctl) driver 3.04.13
mptctl: Registered with Fusion MPT base driver
mptctl: /dev/mptctl @ (major,minor=10,220)
Fusion MPT LAN driver 3.04.13
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ACPI: PCI Interrupt Link [LUB2] enabled at IRQ 21
ehci_hcd 0000:00:02.1: PCI INT B -> Link[LUB2] -> GSI 21 (level, low) -> IRQ 21
ehci_hcd 0000:00:02.1: setting latency timer to 64
ehci_hcd 0000:00:02.1: EHCI Host Controller
ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:02.1: debug port 1
ehci_hcd 0000:00:02.1: cache line size of 64 is not supported
ehci_hcd 0000:00:02.1: irq 21, io mem 0xdfdfec00
ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: EHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.33.4-smp ehci_hcd
usb usb1: SerialNumber: 0000:00:02.1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 10 ports detected
116x: driver isp116x-hcd, 03 Nov 2005
driver isp1362-hcd, 2005-04-04
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ACPI: PCI Interrupt Link [LUB0] enabled at IRQ 20
ohci_hcd 0000:00:02.0: PCI INT A -> Link[LUB0] -> GSI 20 (level, low) -> IRQ 20
ohci_hcd 0000:00:02.0: setting latency timer to 64
ohci_hcd 0000:00:02.0: OHCI Host Controller
ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:02.0: irq 20, io mem 0xdfdff000
usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: OHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.33.4-smp ohci_hcd
usb usb2: SerialNumber: 0000:00:02.0
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 10 ports detected
uhci_hcd: USB Universal Host Controller Interface driver
sl811: driver sl811-hcd, 19 May 2005
r8a66597_hcd: driver r8a66597_hcd, 2009-05-26
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver ums-alauda
usbcore: registered new interface driver ums-cypress
usbcore: registered new interface driver ums-datafab
usbcore: registered new interface driver ums-freecom
usbcore: registered new interface driver ums-isd200
usbcore: registered new interface driver ums-jumpshot
usbcore: registered new interface driver ums-karma
usbcore: registered new interface driver ums-onetouch
usbcore: registered new interface driver ums-sddr09
usbcore: registered new interface driver ums-sddr55
usbcore: registered new interface driver ums-usbat
PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
md: linear personality registered for level -1
md: raid0 personality registered for level 0
md: raid1 personality registered for level 1
md: raid10 personality registered for level 10
md: raid6 personality registered for level 6
md: raid5 personality registered for level 5
md: raid4 personality registered for level 4
md: multipath personality registered for level -4
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.17.0-ioctl (2010-03-05) initialised: dm-devel@redhat.com
cpuidle: using governor ladder
cpuidle: using governor menu
TCP cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 17
Using IPI No-Shortcut mode
ata5.00: ATAPI: Optiarc DVD RW AD-7200A, 1.06, max UDMA/66
ata5: nv_mode_filter: 0x1f39f&0x1f39f->0x1f39f, BIOS=0x1f000 (0xc5000000) ACPI=0x1f01f (30:900:0x11)
ata5.00: configured for UDMA/66
ata3: SATA link down (SStatus 0 SControl 300)
ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata1.00: ATA-8: WDC WD3200AAKS-00G3A0, 40.00A40, max UDMA/133
ata1.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 0/32)
ata1.00: configured for UDMA/133
scsi 2:0:0:0: Direct-Access ATA WDC WD3200AAKS-0 40.0 PQ: 0 ANSI: 5
sd 2:0:0:0: [sda] 625142448 512-byte logical blocks: (320 GB/298 GiB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1 sda2 < sda5 sda6 > sda3 sda4
sd 2:0:0:0: [sda] Attached SCSI disk
usb 2-3: new low speed USB device using ohci_hcd and address 2
ata2: SATA link down (SStatus 0 SControl 300)
usb 2-3: New USB device found, idVendor=04d9, idProduct=1400
usb 2-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
ata4: SATA link down (SStatus 0 SControl 300)
scsi 6:0:0:0: CD-ROM Optiarc DVD RW AD-7200A 1.06 PQ: 0 ANSI: 5
sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
Uniform CD-ROM driver Revision: 3.20
sr 6:0:0:0: Attached scsi CD-ROM sr0
ata6: port disabled. ignoring.
registered taskstats version 1
md: Waiting for all devices to be available before autodetect
md: If you don't use raid, use raid=noautodetect
md: Autodetecting RAID arrays.
md: Scanned 0 and added 0 devices.
md: autorun ...
md: ... autorun DONE.
EXT3-fs (sda3): error: couldn't mount because of unsupported optional features (240)
EXT2-fs (sda3): error: couldn't mount because of unsupported optional features (240)
EXT4-fs (sda3): mounted filesystem with ordered data mode
VFS: Mounted root (ext4 filesystem) readonly on device 8:3.
usb 2-4: new low speed USB device using ohci_hcd and address 3
devtmpfs: mounted
Freeing unused kernel memory: 636k freed
Write protecting the kernel text: 9564k
Write protecting the kernel read-only data: 2448k
usb 2-4: New USB device found, idVendor=09da, idProduct=000a
usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 2-4: Product: PS/2+USB Mouse
usb 2-4: Manufacturer: A4Tech
usb 2-9: new full speed USB device using ohci_hcd and address 4
usb 2-9: New USB device found, idVendor=0a12, idProduct=0001
usb 2-9: New USB device strings: Mfr=0, Product=0, SerialNumber=0
udev: starting version 153
sd 2:0:0:0: Attached scsi generic sg0 type 0
sr 6:0:0:0: Attached scsi generic sg1 type 5
Bluetooth: Core ver 2.15
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
k10temp 0000:00:18.3: unreliable CPU thermal sensor; monitoring disabled
input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
ACPI: Power Button [PWRB]
input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
ACPI: Power Button [PWRF]
i2c i2c-0: nForce2 SMBus adapter at 0x600
i2c i2c-1: nForce2 SMBus adapter at 0x700
rtc_cmos 00:02: RTC can wake from S4
rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
rtc0: alarms up to one year, y3k, 114 bytes nvram, hpet irqs
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64.
ACPI: PCI Interrupt Link [LMAC] enabled at IRQ 23
forcedeth 0000:00:07.0: PCI INT A -> Link[LMAC] -> GSI 23 (level, low) -> IRQ 23
forcedeth 0000:00:07.0: setting latency timer to 64
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: 00
parport_pc 00:06: reported by Plug and Play ACPI
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
(2457000 KHz - 2482000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
(2474000 KHz - 2494000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
(5170000 KHz - 5250000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
cfg80211: Calling CRDA to update world regulatory domain
ppdev: user-space parallel port driver
usbcore: registered new interface driver hiddev
input: HID 04d9:1400 as /devices/pci0000:00/0000:00:02.0/usb2/2-3/2-3:1.0/input/input3
generic-usb 0003:04D9:1400.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 04d9:1400] on usb-0000:00:02.0-3/input0
input: HID 04d9:1400 as /devices/pci0000:00/0000:00:02.0/usb2/2-3/2-3:1.1/input/input4
generic-usb 0003:04D9:1400.0002: input,hidraw1: USB HID v1.10 Mouse [HID 04d9:1400] on usb-0000:00:02.0-3/input1
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
input: A4Tech PS/2+USB Mouse as /devices/pci0000:00/0000:00:02.0/usb2/2-4/2-4:1.0/input/input5
a4tech 0003:09DA:000A.0003: input,hidraw2: USB HID v1.10 Mouse [A4Tech PS/2+USB Mouse] on usb-0000:00:02.0-4/input0
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 19
rt61pci 0000:01:06.0: PCI INT A -> Link[LNKA] -> GSI 19 (level, low) -> IRQ 19
forcedeth 0000:00:07.0: ifname eth0, PHY OUI 0x1374 @ 1, addr 00:1f:c6:10:e7:a8
forcedeth 0000:00:07.0: highdma pwrctl mgmt gbit lnktim msi desc-v3
ACPI: PCI Interrupt Link [LAZA] enabled at IRQ 22
HDA Intel 0000:00:05.0: PCI INT B -> Link[LAZA] -> GSI 22 (level, low) -> IRQ 22
hda_intel: Disable MSI for Nvidia chipset
HDA Intel 0000:00:05.0: setting latency timer to 64
phy0: Selected rate control algorithm 'minstrel'
Registered led device: rt61pci-phy0::radio
Registered led device: rt61pci-phy0::assoc
ACPI: PCI Interrupt Link [LNEA] enabled at IRQ 18
HDA Intel 0000:02:00.1: PCI INT B -> Link[LNEA] -> GSI 18 (level, low) -> IRQ 18
HDA Intel 0000:02:00.1: irq 27 for MSI/MSI-X
HDA Intel 0000:02:00.1: setting latency timer to 64
cfg80211: World regulatory domain updated:
(2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
(2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
(2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
(5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Adding 2996112k swap on /dev/sda4. Priority:-1 extents:1 across:2996112k
fuse init (API version 7.13)
lp0: using parport0 (interrupt-driven).
lp0: console ready
Linux agpgart interface v0.103
Intel ISA PCIC probe: not found.
Databook TCIC-2 PCMCIA probe: not found.
forcedeth 0000:00:07.0: irq 28 for MSI/MSI-X
eth0: no link during initialization.
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
ADDRCONF(NETDEV_UP): eth0: link is not ready
rt61pci 0000:01:06.0: firmware: requesting rt2561s.bin
ADDRCONF(NETDEV_UP): wlan0: link is not ready
PPP generic driver version 2.4.2
ip_tables: (C) 2000-2006 Netfilter Core Team
wlan0: direct probe to AP 00:0b:6b:82:e7:d2 (try 1)
wlan0: direct probe to AP 00:0b:6b:82:e7:d2 (try 2)
wlan0: direct probe to AP 00:0b:6b:82:e7:d2 (try 3)
wlan0: direct probe to AP 00:0b:6b:82:e7:d2 timed out
ACPI: PCI Interrupt Link [LNED] enabled at IRQ 17
pci 0000:02:00.0: PCI INT A -> Link[LNED] -> GSI 17 (level, low) -> IRQ 17
[drm] Initialized drm 1.1.0 20060810
[drm] radeon defaulting to userspace modesetting.
pci 0000:02:00.0: setting latency timer to 64
[drm] Initialized radeon 1.32.0 20080528 for 0000:02:00.0 on minor 0
[drm] Setting GART location based on new memory map
[drm] Loading RV730 CP Microcode
platform r600_cp.0: firmware: requesting radeon/RV730_pfp.bin
platform r600_cp.0: firmware: requesting radeon/RV730_me.bin
[drm] Resetting GPU
[drm] writeback test succeeded in 1 usecs
wlan0: direct probe responded
wlan0: authenticate with AP 00:0b:6b:82:e7:d2 (try 1)
wlan0: authenticated
wlan0: associate with AP 00:0b:6b:82:e7:d2 (try 1)
wlan0: RX AssocResp from 00:0b:6b:82:e7:d2 (capab=0x421 status=0 aid=1)
wlan0: associated
ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
PPP BSD Compression module registered
wlan0: no IPv6 routers present
Htedoh da iskoristim priliku samo da priupitam...
Onomad mi je branko pomogao oko konfiguracije wireless-a i takodje me naucio da upisem u rc.local komande za podizanje neta pri startovanju racunara i to je funkcionisalo na 13-ici medjutim na 13.1 to kod mene ne radi da li mozda postoji resenje za to, nije mi tesko da ukucam tri komande za konekciju but?!?!
