Forsiranje xorg-a da koristi odredjenu rezoluciju
Post Napisano: 03 Feb 2014, 15:54
Evo ovako, imam radeon hd 6570 i teram oss radeon drajver, problem je sto mi svuda stavlja 1024x768 a monitoru je nativna 1280x1024. Na nvidiji sam to radio jednostavno sto preko nvidia-settings napravim xorg.conf i to funkcionise.
Izguglao sam negde da je to moguce uraditi pravljenjem fajla
/usr/share/X11/xorg.conf.d/10-monitor.conf
i unosenjem sledeceg
Section "Monitor"
  Identifier "Monitor0"
  <INSERT MODELINE HERE>
EndSection
Section "Screen"
  Identifier "Screen0"
  Device "<INSERT DEVICE HERE>"
  Monitor "Monitor0"
  DefaultDepth 24
  SubSection "Display"
    Depth 24
    Modes "<INSERT MODENAME HERE>"
  EndSubSection
EndSection
Problem je sto ne znam cime treba da zamenim parametre koji nedostaju.
Post Napisano: 03 Feb 2014, 16:50
Pretpostavljam da si probao sa
# xorgsetup
pa da automatski dobiješ podešavanja.
Kod mene je sveže instaliran sistem i u upotrebi os radeon drajver. Nemam xorg.conf a u /etc/X11/xorg.conf.d/ nemam ništa.
Sadržaj mog /etc/X11/xorg.conf-vesa ti možda može pomoći, grafička kod mene je radeon HD6750.
# File generated by xf86config.
# Copyright (c) 1999 by The XFree86 Project, Inc.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE XFREE86 PROJECT BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
# WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
# OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
# Except as contained in this notice, the name of the XFree86 Project shall
# not be used in advertising or otherwise to promote the sale, use or other
# dealings in this Software without prior written authorization from the
# XFree86 Project.
# Refer to the XF86Config(4/5) man page for details about the format of
# this file.
# NOTE:  This is a NEW IMPROVED version of XF86Config-fbdev that uses the vesa
# driver instead of the fbdev driver.  Thanks to Kenneth Fanyo who pointed
# this out to me. :)
# This XF86Config file is designed for use with the VESA framebuffer.
# This generic interface should work with nearly all video cards
# (although not every card will support every resolution).
# With the new driver, it should no longer be required to have frame buffer
# support in the kernel, or to run it on the console.
# Enjoy! :)
# -- volkerdi@slackware.com
# Module section -- this  section  is used to specify
# which dynamically loadable modules to load.
Section "Module"
# This loads the DBE extension module.
    Load        "dbe"  	# Double buffer extension
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
    SubSection  "extmod"
      Option    "omit xfree86-dga"   # don't initialise the DGA extension
    EndSubSection
# This loads the font modules
    Load        "type1"
    Load        "freetype"
    #Load        "speedo"
# This loads the GLX module
    Load       "glx"
EndSection
# Files section.  This allows default font and rgb paths to be set
Section "Files"
# The location of the RGB database.  Note, this is the name of the
# file minus the extension (like ".txt" or ".db").  There is normally
# no need to change the default.
    RgbPath	"/usr/share/X11/rgb"
# Multiple FontPath entries are allowed (which are concatenated together),
# as well as specifying multiple comma-separated entries in one FontPath
# command (or a combination of both methods)
# If you don't have a floating point coprocessor and emacs, Mosaic or other
# programs take long to start up, try moving the Type1 and Speedo directory
# to the end of this list (or comment them out).
    FontPath   "/usr/share/fonts/local/"
    FontPath   "/usr/share/fonts/misc/"
    FontPath   "/usr/share/fonts/OTF/"
    FontPath   "/usr/share/fonts/TTF/"
    FontPath   "/usr/share/fonts/Type1/"
    FontPath   "/usr/share/fonts/CID/"
    FontPath   "/usr/share/fonts/Speedo/"
    FontPath   "/usr/share/fonts/75dpi/:unscaled"
    FontPath   "/usr/share/fonts/100dpi/:unscaled"
    FontPath   "/usr/share/fonts/75dpi/"
    FontPath   "/usr/share/fonts/100dpi/"
    FontPath   "/usr/share/fonts/cyrillic/"
# ModulePath can be used to set a search path for the X server modules.
# The default path is shown here.
#    ModulePath "/usr/lib/xorg/modules"
EndSection
# Server flags section.
Section "ServerFlags"
# Uncomment this to cause a core dump at the spot where a signal is
# received.  This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
#    Option     "NoTrapSignals"
# Uncomment this to disable the <Crtl><Alt><Fn> VT switch sequence
# (where n is 1 through 12).  This allows clients to receive these key
# events.
#    Option     "DontVTSwitch"
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
#    Option     "DontZap"
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
# sequences.  This allows clients to receive these key events.
#    Option     "DontZoom"
# Uncomment this to disable tuning with the xvidtune client. With
# it the client can still run and fetch card and monitor attributes,
# but it will not be allowed to change them. If it tries it will
# receive a protocol error.
#    Option     "DisableVidModeExtension"
# Uncomment this to enable the use of a non-local xvidtune client.
#    Option     "AllowNonLocalXvidtune"
# Uncomment this to disable dynamically modifying the input device
# (mouse and keyboard) settings.
#    Option     "DisableModInDev"
# Uncomment this to enable the use of a non-local client to
# change the keyboard or mouse settings (currently only xset).
#    Option     "AllowNonLocalModInDev"
# Set the basic blanking screen saver timeout.
#    Option      "blank time"    "10"    # 10 minutes
# Set the DPMS timeouts.  These are set here because they are global
# rather than screen-specific.  These settings alone don't enable DPMS.
# It is enabled per-screen (or per-monitor), and even then only when
# the driver supports it.
#    Option      "standby time"  "20"
#    Option      "suspend time"  "30"
#    Option      "off time"      "60"
# On some platform the server needs to estimate the sizes of PCI
# memory and pio ranges. This is done by assuming that PCI ranges
# don't overlap. Some broken BIOSes tend to set ranges of inactive
# devices wrong. Here one can adjust how aggressive the assumptions
# should be. Default is 0.
# Option   "EstimateSizesAggresively" "0"
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
    Identifier	"Keyboard1"
    Driver	"kbd"
# For most OSs the protocol can be omitted (it defaults to "Standard").
# When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
# uncomment the following line.
#    Option     "Protocol"      "Xqueue"
# Set the keyboard auto repeat parameters.  Not all platforms implement
# this.
#    Option     "AutoRepeat"    "500 5"
# Specifiy which keyboard LEDs can be user-controlled (eg, with xset(1)).
#    Option     "Xleds" "1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
#    Option     "XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a European
# keyboard, you will probably want to use one of:
#    Option     "XkbModel"      "pc102"
#    Option     "XkbModel"      "pc105"
# If you have a Microsoft Natural keyboard, you can use:
#    Option     "XkbModel"      "microsoft"
# If you have a US "windows" keyboard you will want:
#    Option     "XkbModel"      "pc104"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#    Option     "XkbLayout"     "de"
# or:
#    Option     "XkbVariant"    "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#    Option     "XkbOptions"    "ctrl:swapcaps"
# These are the default XKB settings for X.Org
#    Option     "XkbRules"      "xorg"
#    Option     "XkbLayout"     "us"
#    Option     "XkbVariant"    ""
#    Option     "XkbOptions"    ""
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
    Identifier	"Mouse1"
    Driver	"mouse"
# On platforms where PnP mouse detection is supported the following
# protocol setting can be used when using a newer PnP mouse:
#    Option     "Protocol"      "Auto"
# The available mouse protocols types that you can set below are:
#    Auto BusMouse GlidePoint GlidePointPS/2 IntelliMouse IMPS/2
#    Logitech Microsoft MMHitTab MMSeries Mouseman MouseManPlusPS/2
#    MouseSystems NetMousePS/2 NetScrollPS/2 OSMouse PS/2 SysMouse
#    ThinkingMouse ThinkingMousePS/2 Xqueue
    Option "Protocol"    "PS/2"
# The mouse device.  The device is normally set to /dev/mouse,
# which is usually a symbolic link to the real device.
    Option "Device"      "/dev/mouse"
#   Option "Device"      "/dev/psaux"
#   Option "Device"      "/dev/ttyS0"
#   Option "Device"      "/dev/ttyS1"
# When using XQUEUE, comment out the above two lines, and uncomment
# the following line.
# Baudrate and SampleRate are only for some Logitech mice. In
# almost every case these lines should be omitted.
#    Option "BaudRate"		"9600"
#    Option "SampleRate"	"150"
# Emulate3Buttons is an option for 2-button Microsoft mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
#    Option "Emulate3Buttons"
#    Option "Emulate3Timeout"    "50"
# ChordMiddle is an option for some 3-button Logitech mice
#    Option "ChordMiddle"
EndSection
# Some examples of extended input devices
# Section "InputDevice"
#    Identifier "spaceball"
#    Driver     "magellan"
#    Option     "Device"        "/dev/cua0"
# EndSection
#    Identifier "spaceball2"
#    Driver     "spaceorb"
# EndSection
#    Identifier "touchscreen0"
#    Driver     "microtouch"
#    Option     "MinX"          "1412"
#    Option     "MaxX"          "15184"
#    Option     "MinY"          "15372"
#    Option     "MaxY"          "1230"
#    Option     "ScreenNumber"  "0"
#    Option     "ReportingMode" "Scaled"
#    Option     "ButtonNumber"  "1"
#    Option     "SendCoreEvents"
# EndSection
#    Identifier "touchscreen1"
#    Driver     "elo2300"
#    Option     "MinX"          "231"
#    Option     "MaxX"          "3868"
#    Option     "MinY"          "3858"
#    Option     "MaxY"          "272"
#    Option     "ButtonThreshold"       "17"
# EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
    Identifier  "My Monitor"
# HorizSync is in kHz unless units are specified.
# HorizSync may be a comma separated list of discrete values, or a
# comma separated list of ranges of values.
# NOTE: THE VALUES HERE ARE EXAMPLES ONLY.  REFER TO YOUR MONITOR'S
# USER MANUAL FOR THE CORRECT NUMBERS.
    HorizSync   31.5 - 50.0
#    HorizSync	30-64         # multisync
#    HorizSync	31.5, 35.2    # multiple fixed sync frequencies
#    HorizSync	15-25, 30-50  # multiple ranges of sync frequencies
# VertRefresh is in Hz unless units are specified.
# VertRefresh may be a comma separated list of discrete values, or a
    VertRefresh 40-90
EndSection
# Graphics device section
# Any number of graphics device sections may be present
Section "Device"
    Identifier  "VESA Framebuffer"
    Driver      "vesa"
    #VideoRam    4096
    # Insert Clocks lines here if appropriate
EndSection
# Screen sections
# Any number of screen sections may be present.  Each describes
# the configuration of a single screen.  A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
Section "Screen"
    Identifier  "Screen 1"
    Device      "VESA Framebuffer"
    Monitor     "My Monitor"
# If your card can handle it, a higher default color depth (like 24 or 32)
# is highly recommended.
#   DefaultDepth 8
#   DefaultDepth 16
   DefaultDepth 24
#   DefaultDepth 32
# "1024x768" is also a conservative usable default resolution.  If you
# have a better monitor, feel free to try resolutions such as
# "1152x864", "1280x1024", "1600x1200", and "1800x1400" (or whatever your
# card/monitor can produce)
    Subsection "Display"
        Depth       8
        Modes "1024x768" "800x600" "640x480"
    EndSubsection
        Depth       16
    EndSubsection
        Depth       24
    EndSubsection
        Depth       32
    EndSubsection
EndSection
# ServerLayout sections.
# Any number of ServerLayout sections may be present.  Each describes
# the way multiple screens are organised.  A specific ServerLayout
# section may be specified from the X server command line with the
# "-layout" option.  In the absence of this, the first section is used.
# When now ServerLayout section is present, the first Screen section
# is used alone.
Section "ServerLayout"
# The Identifier line must be present
    Identifier  "Simple Layout"
# Each Screen line specifies a Screen section name, and optionally
# the relative position of other screens.  The four names after
# primary screen name are the screens to the top, bottom, left and right
# of the primary screen.  In this example, screen 2 is located to the
# right of screen 1.
    Screen "Screen 1"
# Each InputDevice line specifies an InputDevice section name and
# optionally some options to specify the way the device is to be
# used.  Those options include "CorePointer", "CoreKeyboard" and
# "SendCoreEvents".
    InputDevice "Mouse1" "CorePointer"
    InputDevice "Keyboard1" "CoreKeyboard"
EndSection
Post Napisano: 04 Feb 2014, 10:20
Takođe bacni pogled na sledeće linkove:
http://samuelmartin.wordpress.com/2012/ ... ntu-12-04/" onclick="window.open(this.href);return false;
http://www.bingshui.org/tech/defining-d ... ntu-12-04/" onclick="window.open(this.href);return false;
Inače, rezolucija bi trebala da se automatski odredi iz EDIDa, ali će ovo biti ograničeno na rezolucije koje kartica "javlja" da podržava. Recimo, ako je loše prepoznata količina memorije na kartici, i moguća rezolucija će biti manja. Bez obzira na monitor.
U svakom slučaju pre čačkanja vidi šta javlja read-edid (možda ga ima u AURu ili community repoima - pod pretpostavkom da pitaš za Arch :)):
http://www.polypux.org/projects/read-edid/" onclick="window.open(this.href);return false;
Post Napisano: 13 Feb 2014, 23:57
Oprostite sto ne odgovaram, bavio sam se ovih dana sa 2x8600GT pa se sad vratih na ovu kartu. :)
bocke fala na uputstvima, napravio sam 10-monitor.conf
Section "Monitor"
  Modeline "1280x1024_60.00"  108.88  1280 1360 1496 1712  1024 1025 1028 1060  -HSync +Vsync
EndSection
Section "Screen"
  Device "VGA-0"
  Monitor "Monitor0"
  DefaultDepth 24
    Depth 24
    Modes "1280x1024_60.00"
  EndSubSection
EndSection
Koliko mi se cini sve radi samo je meni nesto izgleda izbagovan kde jer od 4.10 nisam brisao .kde :)
Users browsing this forum: No registered users and 22 guests
