http://www.slackwiki.com/Broadcom_Wireless" onclick="window.open(this.href);return false;
međutim, prikazani su paketi samo za 13.37
Hoće li ti driveri raditi na 14.0 ili da pričekam slackbuildse da dođu do verzije 14.0?
Hvala i lijep pozdrav!
./broadcom-sta.SlackBuildCode: Select all
make: Entering directory `/usr/src/linux-3.2.29'
Wireless Extension is the only possible API for this kernel version
Using Wireless Extension API
make: Leaving directory `/usr/src/linux-3.2.29'
LD /tmp/SBo/build-broadcom-sta/built-in.o
CC [M] /tmp/SBo/build-broadcom-sta/src/shared/linux_osl.o
CC [M] /tmp/SBo/build-broadcom-sta/src/wl/sys/wl_linux.o
/tmp/SBo/build-broadcom-sta/src/wl/sys/wl_linux.c:388:2: error: unknown field 'ndo_set_multicast_list' specified in initializer
/tmp/SBo/build-broadcom-sta/src/wl/sys/wl_linux.c:388:2: warning: initialization from incompatible pointer type [enabled by default]
/tmp/SBo/build-broadcom-sta/src/wl/sys/wl_linux.c:388:2: warning: (near initialization for 'wl_netdev_ops.ndo_validate_addr') [enabled by default]
make[1]: *** [/tmp/SBo/build-broadcom-sta/src/wl/sys/wl_linux.o] Error 1
make: *** [_module_/tmp/SBo/build-broadcom-sta] Error 2
tar zxvf broadcom-sta.tar.gz Code: Select all
tar xvf $CWD/hybrid-portsrc_${MY_ARCH}-v$(printf $VERSION|tr . _).tar.gzCode: Select all
patch -p0 src/wl/sys/wl_linux.c < $CWD/bc_wl_abiupdate.patch
# installpkg /tmp/ime_paketa.tgzOdlično! Kompajliranje je uspjelo i paket je napravljen i uspješno instaliran. Potrebni moduli su blacklistani, ali nakon reboota i dalje ne mogu widjeti wireless mreže.drummer wrote:Problem koji se ovde javlja je vezan za promene koje su nastale u 3.2 kernelu (koji koristi Slackware 14) a koje nisu bile prisutne u ranijim verzijama kernela (Slackware 13.37 je došao sa 2.6.x verzijom). Isprati ovih nekoliko koraka...
lo no wireless extensions.
eth1 IEEE 802.11bgn ESSID:"" Nickname:"darksta"
Mode:Managed Frequency:2.412 GHz Access Point: Not-Associated
Bit Rate:144 Mb/s Tx-Power:24 dBm
Retry min limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=5/5 Signal level=0 dBm Noise level=-11 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
eth0 no wireless extensions.
iwlist eth1 scanCode: Select all
/etc/rc.d/rc.networkmanager startCode: Select all
# chmod +x /etc/rc.d/rc.networkmanagerCode: Select all
# /etc/rc.d/rc.networkmanagerUsers browsing this forum: No registered users and 19 guests
