Novosti u *current* -u
Post Napisano: 18 Jun 2018, 15:57
Slackware 64-bit
Mon Jun 18 06:19:23 UTC 2018
a/aaa_elflibs-15.0-x86_64-1.txz: Upgraded.
       Upgraded to libelf-0.171.so, added libgdbm.so.6.0.0.
a/etc-15.0-x86_64-6.txz: Rebuilt.
       Add $(uname -m) information to /etc/issue.new.
       Don't include /tmp directories - these are handled by aaa_base.
a/kernel-generic-4.14.50-x86_64-1.txz: Upgraded.
a/kernel-huge-4.14.50-x86_64-1.txz: Upgraded.
a/kernel-modules-4.14.50-x86_64-1.txz: Upgraded.
ap/man-db-2.8.3-x86_64-3.txz: Rebuilt.
       Recompiled against gdbm-1.15.
ap/zsh-5.5.1-x86_64-2.txz: Rebuilt.
d/clisp-2.49_20180423_d1310adc5-x86_64-1.txz: Upgraded.
       Compiled against gdbm-1.15.
d/kernel-headers-4.14.50-x86-1.txz: Upgraded.
d/perl-5.26.2-x86_64-5.txz: Rebuilt.
d/python-2.7.15-x86_64-3.txz: Rebuilt.
d/python3-3.6.5-x86_64-4.txz: Rebuilt.
d/ruby-2.5.1-x86_64-4.txz: Rebuilt.
k/kernel-source-4.14.50-noarch-1.txz: Upgraded.
kde/kdelibs-4.14.38-x86_64-3.txz: Rebuilt.
       Patched to build with OpenSSL-1.1.x. Thanks to nobodino.
l/gdbm-1.15-x86_64-1.txz: Upgraded.
n/cyrus-sasl-2.1.27_rc8-x86_64-1.txz: Upgraded.
n/mutt-1.10.0-x86_64-2.txz: Rebuilt.
n/php-7.2.6-x86_64-2.txz: Rebuilt.
n/yptools-2.14-x86_64-11.txz: Rebuilt.
xap/gnuchess-6.2.5-x86_64-3.txz: Rebuilt.
isolinux/initrd.img: Rebuilt.
       Copy libefiboot to the installer (needed by efibootmgr).
       Compress the kernel modules with xz.
       Compress the initrd image with xz.
kernels/*: Upgraded.
Slackware 32-bit
a/aaa_elflibs-15.0-i586-1.txz: Upgraded.
a/etc-15.0-i586-6.txz: Rebuilt.
a/kernel-generic-4.14.50-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.14.50_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.14.50-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.14.50_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.14.50-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.14.50_smp-i686-1.txz: Upgraded.
ap/man-db-2.8.3-i586-3.txz: Rebuilt.
ap/zsh-5.5.1-i586-2.txz: Rebuilt.
d/clisp-2.49_20180423_d1310adc5-i586-1.txz: Upgraded.
d/kernel-headers-4.14.50_smp-x86-1.txz: Upgraded.
d/perl-5.26.2-i586-5.txz: Rebuilt.
d/python-2.7.15-i586-3.txz: Rebuilt.
d/python3-3.6.5-i586-4.txz: Rebuilt.
d/ruby-2.5.1-i586-4.txz: Rebuilt.
k/kernel-source-4.14.50_smp-noarch-1.txz: Upgraded.
kde/kdelibs-4.14.38-i586-3.txz: Rebuilt.
l/gdbm-1.15-i586-1.txz: Upgraded.
n/cyrus-sasl-2.1.27_rc8-i586-1.txz: Upgraded.
n/mutt-1.10.0-i586-2.txz: Rebuilt.
n/php-7.2.6-i586-2.txz: Rebuilt.
n/yptools-2.14-i586-11.txz: Rebuilt.
xap/gnuchess-6.2.5-i586-3.txz: Rebuilt.
extra/linux-4.14.50-nosmp-sdk/*: Upgraded.
Post Napisano: 19 Jun 2018, 15:58
Slackware 64-bit
Tue Jun 19 05:47:22 UTC 2018
a/btrfs-progs-v4.17-x86_64-1.txz: Upgraded.
a/lvm2-2.02.179-x86_64-1.txz: Upgraded.
l/imagemagick-6.9.10_2-x86_64-1.txz: Upgraded.
n/NetworkManager-1.10.10-x86_64-1.txz: Upgraded.
x/vulkan-sdk-1.1.73.0-x86_64-1.txz: Upgraded.
Mon Jun 18 18:33:23 UTC 2018
       Use -C crc32 when compressing the initrd/modules with xz.
Slackware 32-bit
a/btrfs-progs-v4.17-i586-1.txz: Upgraded.
a/lvm2-2.02.179-i586-1.txz: Upgraded.
l/imagemagick-6.9.10_2-i586-1.txz: Upgraded.
n/NetworkManager-1.10.10-i586-1.txz: Upgraded.
x/vulkan-sdk-1.1.73.0-i586-1.txz: Upgraded.
Post Napisano: 20 Jun 2018, 13:45
Slackware 64-bit
 Jun 19 22:35:25 UTC 2018
a/acl-2.2.53-x86_64-1.txz: Upgraded.
a/attr-2.4.48-x86_64-1.txz: Upgraded.
n/gnupg-1.4.23-x86_64-1.txz: Upgraded.
       Sanitize the diagnostic output of the original file name in verbose mode.
       By using a made up file name in the message it was possible to fake status
       messages. Using this technique it was for example possible to fake the
       verification status of a signed mail.
       https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2018-12020
x/libXaw3d-1.6.3-x86_64-1.txz: Upgraded.
x/libinput-1.11.1-x86_64-1.txz: Upgraded.
x/xf86-input-mouse-1.9.3-x86_64-1.txz: Upgraded.
testing/packages/pkgtools-15.0-noarch-20.txz: Rebuilt.
       This update is a bit scarier than usual, so we're going to test it here
       first and then move it into the main tree in a couple of days if there
       are no serious bug reports. It's well-tested here, and works with the
       slackpkg that's in -current now, but I don't know about slackpkg+ so that's
       another reason to let it cool down here first. The purpose of this update
       is to migrate the package database and directories from /var/log to
       /var/lib/pkgtools. /var/log was never a good place for this data, as it is
       considered by many to be a directory that could be wiped to free up some
       space. Originally the package database was in /var/adm, but the FSSTND
       (later FHS) group decided that directory should be a symlink to /var/log,
       and I went along with that since it was years ago and I was a n00b and didn't
       know any better. /var/lib/pkgtools will be a better and safer location.
       The removed_packages and removed_scripts directories are really just logs
       that aren't actually used for anything - those will remain under /var/log,
       but moved into /var/log/pkgtools. Everything under /var/log will be
       considered potentially non-permanent by the pkgtools - if any directories or
       symlinks disappear from there, the pkgtools will automatically recreate them
       as needed. In fact, the migration process will create symlinks from all the
       old directory locations to the new ones, so anything that expects the old
       locations (including slackpkg, for now) should continue to work. Once this
       moves into the main tree, the plan is to fix other packages to use the new
       installer script directory (/var/lib/pkgtools/setup) and change the installer
       and slackpkg to use the new native locations for everything. When slackpkg
       is changed over to use the new native locations, I'll also make sure to float
       that in testing/ for a few days before moving it to the main tree to avoid
       more unintentional disruption to slackpkg+ users.
       Be aware that the package database migration is a one-way operation, but even
       so if you later downgrade to an older version of the pkgtools it will still
       work through the compatibility symlinks.
Slackware 32-bit
Tue Jun 19 22:35:25 UTC 2018
a/acl-2.2.53-i586-1.txz: Upgraded.
a/attr-2.4.48-i586-1.txz: Upgraded.
n/gnupg-1.4.23-i586-1.txz: Upgraded.
x/libXaw3d-1.6.3-i586-1.txz: Upgraded.
x/libinput-1.11.1-i586-1.txz: Upgraded.
x/xf86-input-mouse-1.9.3-i586-1.txz: Upgraded.
Post Napisano: 21 Jun 2018, 16:06
Slackware 64-bit
Thu Jun 21 05:18:41 UTC 2018
a/kernel-generic-4.14.51-x86_64-1.txz: Upgraded.
a/kernel-huge-4.14.51-x86_64-1.txz: Upgraded.
a/kernel-modules-4.14.51-x86_64-1.txz: Upgraded.
d/kernel-headers-4.14.51-x86-1.txz: Upgraded.
d/parallel-20180622-noarch-1.txz: Upgraded.
k/kernel-source-4.14.51-noarch-1.txz: Upgraded.
l/libedit-20180525_3.1-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/kernel-generic-4.14.51-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.14.51_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.14.51-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.14.51_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.14.51-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.14.51_smp-i686-1.txz: Upgraded.
d/kernel-headers-4.14.51_smp-x86-1.txz: Upgraded.
k/kernel-source-4.14.51_smp-noarch-1.txz: Upgraded.
l/libedit-20180525_3.1-i586-1.txz: Upgraded.
extra/linux-4.14.51-nosmp-sdk/*: Upgraded.
Post Napisano: 23 Jun 2018, 12:28
Mala napomena: ako koristite Slackpkg+ a nemate najnoviju verziju, preporučeno je da je instalirate pre instalacije novog pkgtools upgreade-a. U suprotnom ćete morati da isključite slackpkg+ u slackpkgplus.conf, ručno ga ažurirate (instalirate noviju verziju sa upgradepkg) i zatim ga ponovo uključite.
Post Napisano: 24 Jun 2018, 00:02
Slackware 64-bit
 Sat Jun 23 04:57:41 UTC 2018
a/dialog-1.3_20170509-x86_64-2.txz: Rebuilt.
       It seems the latest dialog causes a lot of breakage in the installer and
       other scripts. I looked over the diff since last time and nothing jumped
       out at me. Reverting to the previous version that worked properly.
Sat Jun 23 01:22:07 UTC 2018
a/aaa_elflibs-15.0-x86_64-2.txz: Rebuilt.
       Upgraded libacl.so.1 and libattr.so.1.
       Added libaio.so.1 (needed by future versions of lvm).
a/lvm2-2.02.177-x86_64-1.txz: Upgraded.
       Revert to the previous working version of lvm2. Based on the comments
       in the release notes for version 2.02.178, perhaps it would be prudent
       to sit out the next year and a half of planned instability. I can't
       recall ever _needing_ to upgrade LVM (the version number has been on
       2.02.x for well over a decade)... let's avoid being beta testers as
       upstream refactors everything.
Fri Jun 22 21:54:41 UTC 2018
a/aaa_terminfo-6.1_20180616-x86_64-1.txz: Upgraded.
a/dialog-1.3_20180621-x86_64-1.txz: Upgraded.
d/git-2.18.0-x86_64-1.txz: Upgraded.
d/rust-1.27.0-x86_64-1.txz: Upgraded.
l/ncurses-6.1_20180616-x86_64-1.txz: Upgraded.
l/pulseaudio-12.0-x86_64-2.txz: Rebuilt.
       When installing, recompile the GSettings XML schema files. Thanks to ill323.
l/tango-icon-theme-0.8.90-noarch-3.txz: Rebuilt.
       Don't require locking for doinst.sh.
xap/blackbox-0.73-x86_64-1.txz: Upgraded.
Thu Jun 21 22:58:42 UTC 2018
a/pkgtools-15.0-noarch-20.txz: Rebuilt.
       Move pkgtools database to /var/lib/pkgtools/.
       Move removed logs to /var/log/pkgtools/.
a/sysvinit-2.90-x86_64-1.txz: Upgraded.
ap/cups-filters-1.20.3-x86_64-3.txz: Rebuilt.
       Recompiled against poppler-0.66.0.
kde/calligra-2.9.11-x86_64-22.txz: Rebuilt.
l/dbus-python-1.2.8-x86_64-1.txz: Upgraded.
l/gc-7.6.6-x86_64-1.txz: Upgraded.
l/harfbuzz-1.8.1-x86_64-1.txz: Upgraded.
l/poppler-0.66.0-x86_64-1.txz: Upgraded.
l/pulseaudio-12.0-x86_64-1.txz: Upgraded.
n/dhcpcd-7.0.6-x86_64-1.txz: Upgraded.
n/php-7.2.7-x86_64-1.txz: Upgraded.
       Added support for libedit.
t/texlive-2017.171108-x86_64-7.txz: Rebuilt.
x/libwacom-0.30-x86_64-1.txz: Upgraded.
xfce/exo-0.12.2-x86_64-1.txz: Upgraded.
xfce/tumbler-0.2.1-x86_64-4.txz: Rebuilt.
xfce/xfce4-settings-4.12.4-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/dialog-1.3_20170509-i586-2.txz: Rebuilt.
a/aaa_elflibs-15.0-i586-2.txz: Rebuilt.
a/lvm2-2.02.177-i586-1.txz: Upgraded.
a/aaa_terminfo-6.1_20180616-i586-1.txz: Upgraded.
a/dialog-1.3_20180621-i586-1.txz: Upgraded.
d/git-2.18.0-i586-1.txz: Upgraded.
d/rust-1.27.0-i686-1.txz: Upgraded.
l/ncurses-6.1_20180616-i586-1.txz: Upgraded.
l/pulseaudio-12.0-i586-2.txz: Rebuilt.
xap/blackbox-0.73-i586-1.txz: Upgraded.
a/sysvinit-2.90-i586-1.txz: Upgraded.
ap/cups-filters-1.20.3-i586-3.txz: Rebuilt.
kde/calligra-2.9.11-i586-22.txz: Rebuilt.
l/dbus-python-1.2.8-i586-1.txz: Upgraded.
l/gc-7.6.6-i586-1.txz: Upgraded.
l/harfbuzz-1.8.1-i586-1.txz: Upgraded.
l/poppler-0.66.0-i586-1.txz: Upgraded.
l/pulseaudio-12.0-i586-1.txz: Upgraded.
n/dhcpcd-7.0.6-i586-1.txz: Upgraded.
n/php-7.2.7-i586-1.txz: Upgraded.
t/texlive-2017.171108-i586-7.txz: Rebuilt.
x/libwacom-0.30-i586-1.txz: Upgraded.
xfce/exo-0.12.2-i586-1.txz: Upgraded.
xfce/tumbler-0.2.1-i586-4.txz: Rebuilt.
xfce/xfce4-settings-4.12.4-i586-1.txz: Upgraded.
Post Napisano: 24 Jun 2018, 08:27
Fala Bocke za info, uštedeo si mi vreme za debug :)
Post Napisano: 24 Jun 2018, 23:56
Slackware 64-bit
Sun Jun 24 20:50:10 UTC 2018
a/aaa_base-14.2-x86_64-5.txz: Rebuilt.
       Don't include /var/log/{packages,scripts,removed_packages,removed_scripts}.
a/procps-ng-3.3.15-x86_64-2.txz: Rebuilt.
       Upgraded to psmisc-23.1. This adds namespace support to killall, and makes
       the default behavior to match against the current PID's namespace, rather
       than all namespaces as it did previously.
ap/qpdf-8.1.0-x86_64-1.txz: Upgraded.
ap/texinfo-6.5-x86_64-4.txz: Rebuilt.
       Recompiled against perl-5.28.0.
ap/vim-8.1.0113-x86_64-1.txz: Upgraded.
       Compiled against perl-5.28.0.
d/perl-5.28.0-x86_64-1.txz: Upgraded.
kde/perlkde-4.14.3-x86_64-6.txz: Rebuilt.
kde/perlqt-4.14.3-x86_64-7.txz: Rebuilt.
l/tango-icon-theme-0.8.90-noarch-4.txz: Rebuilt.
       Made a couple of minor corrections to the slack-desc.
n/epic5-2.0.1-x86_64-6.txz: Rebuilt.
n/irssi-1.1.1-x86_64-4.txz: Rebuilt.
n/net-snmp-5.7.3-x86_64-9.txz: Rebuilt.
n/ntp-4.2.8p11-x86_64-4.txz: Rebuilt.
n/stunnel-5.47-x86_64-1.txz: Upgraded.
xap/hexchat-2.14.1-x86_64-4.txz: Rebuilt.
xap/vim-gvim-8.1.0113-x86_64-1.txz: Upgraded.
Slackware 32-bit
a/aaa_base-14.2-i586-5.txz: Rebuilt.
a/procps-ng-3.3.15-i586-2.txz: Rebuilt.
ap/qpdf-8.1.0-i586-1.txz: Upgraded.
ap/texinfo-6.5-i586-4.txz: Rebuilt.
ap/vim-8.1.0113-i586-1.txz: Upgraded.
d/perl-5.28.0-i586-1.txz: Upgraded.
kde/perlkde-4.14.3-i586-6.txz: Rebuilt.
kde/perlqt-4.14.3-i586-7.txz: Rebuilt.
n/epic5-2.0.1-i586-6.txz: Rebuilt.
n/irssi-1.1.1-i586-4.txz: Rebuilt.
n/net-snmp-5.7.3-i586-9.txz: Rebuilt.
n/ntp-4.2.8p11-i586-4.txz: Rebuilt.
n/stunnel-5.47-i586-1.txz: Upgraded.
xap/hexchat-2.14.1-i586-4.txz: Rebuilt.
xap/vim-gvim-8.1.0113-i586-1.txz: Upgraded.
Post Napisano: 26 Jun 2018, 15:08
Slackware 64-bit
 Mon Jun 25 21:22:04 UTC 2018
a/eudev-3.2.5-x86_64-4.txz: Rebuilt.
       Added a couple more modules to watchdog.conf.
l/fribidi-1.0.4-x86_64-1.txz: Upgraded.
l/imagemagick-6.9.10_3-x86_64-1.txz: Upgraded.
xap/mozilla-firefox-60.1.0esr-x86_64-1.txz: Upgraded.
xap/network-manager-applet-1.8.14-x86_64-1.txz: Upgraded.
xap/rxvt-unicode-9.22-x86_64-5.txz: Rebuilt.
xfce/Thunar-1.8.1-x86_64-1.txz: Upgraded.
xfce/xfce4-pulseaudio-plugin-0.4.1-x86_64-1.txz: Upgraded.
xfce/xfce4-screenshooter-1.9.2-x86_64-1.txz: Upgraded.
xfce/xfce4-taskmanager-1.2.1-x86_64-1.txz: Upgraded.
xfce/xfdesktop-4.12.4-x86_64-3.txz: Rebuilt.
       Rebuilt after upgrading to Thunar-1.8.1.
Slackware 32-bit
a/eudev-3.2.5-i586-4.txz: Rebuilt.
l/fribidi-1.0.4-i586-1.txz: Upgraded.
l/imagemagick-6.9.10_3-i586-1.txz: Upgraded.
xap/mozilla-firefox-60.1.0esr-i686-1.txz: Upgraded.
xap/network-manager-applet-1.8.14-i586-1.txz: Upgraded.
xap/rxvt-unicode-9.22-i586-5.txz: Rebuilt.
xfce/Thunar-1.8.1-i586-1.txz: Upgraded.
xfce/xfce4-pulseaudio-plugin-0.4.1-i586-1.txz: Upgraded.
xfce/xfce4-screenshooter-1.9.2-i586-1.txz: Upgraded.
xfce/xfce4-taskmanager-1.2.1-i586-1.txz: Upgraded.
xfce/xfdesktop-4.12.4-i586-3.txz: Rebuilt.
Post Napisano: 27 Jun 2018, 15:14
Slackware 64-bit
Wed Jun 27 04:13:25 UTC 2018
a/kernel-generic-4.14.52-x86_64-1.txz: Upgraded.
a/kernel-huge-4.14.52-x86_64-1.txz: Upgraded.
a/kernel-modules-4.14.52-x86_64-1.txz: Upgraded.
ap/sox-14.4.2-x86_64-6.txz: Rebuilt.
       Rebuilt to drop libssp dependency. We're no longer building that with gcc
       since glibc already includes a built-in SSP implementation.
d/gcc-8.1.1-x86_64-1.txz: Upgraded.
       This is taken from the gcc-8-branch of the svn repo on 20180626, revision
       r262159. All packages have been tested for build failures and all new FTBFS
       issues are fixed - I think we're down to the six possibly obsolete X drivers
       (geode, r128, s3virge, savage, sis, and tseng) and virtuoso-ose.
d/gcc-brig-8.1.1-x86_64-1.txz: Upgraded.
d/gcc-g++-8.1.1-x86_64-1.txz: Upgraded.
d/gcc-gfortran-8.1.1-x86_64-1.txz: Upgraded.
d/gcc-gnat-8.1.1-x86_64-1.txz: Upgraded.
d/gcc-go-8.1.1-x86_64-1.txz: Upgraded.
d/gcc-objc-8.1.1-x86_64-1.txz: Upgraded.
d/kernel-headers-4.14.52-x86-1.txz: Upgraded.
d/libtool-2.4.6-x86_64-8.txz: Rebuilt.
       Recompiled to update embedded GCC version number.
k/kernel-source-4.14.52-noarch-1.txz: Upgraded.
l/db48-4.8.30-x86_64-4.txz: Rebuilt.
       Patched to fix a symbol collision with gcc8.
n/netatalk-3.1.11-x86_64-1.txz: Upgraded.
       Thanks to Matthew Schumacher for updating the build script and providing
       some useful config file examples.
extra/pure-alsa-system/sox-14.4.2-x86_64-6_alsa.txz: Rebuilt.
Slackware 32-bit
a/kernel-generic-4.14.52-i586-1.txz: Upgraded.
a/kernel-generic-smp-4.14.52_smp-i686-1.txz: Upgraded.
a/kernel-huge-4.14.52-i586-1.txz: Upgraded.
a/kernel-huge-smp-4.14.52_smp-i686-1.txz: Upgraded.
a/kernel-modules-4.14.52-i586-1.txz: Upgraded.
a/kernel-modules-smp-4.14.52_smp-i686-1.txz: Upgraded.
ap/sox-14.4.2-i586-6.txz: Rebuilt.
d/gcc-8.1.1-i586-1.txz: Upgraded.
d/gcc-brig-8.1.1-i586-1.txz: Upgraded.
d/gcc-g++-8.1.1-i586-1.txz: Upgraded.
d/gcc-gfortran-8.1.1-i586-1.txz: Upgraded.
d/gcc-gnat-8.1.1-i586-1.txz: Upgraded.
d/gcc-go-8.1.1-i586-1.txz: Upgraded.
d/gcc-objc-8.1.1-i586-1.txz: Upgraded.
d/kernel-headers-4.14.52_smp-x86-1.txz: Upgraded.
d/libtool-2.4.6-i586-8.txz: Rebuilt.
k/kernel-source-4.14.52_smp-noarch-1.txz: Upgraded.
l/db48-4.8.30-i586-4.txz: Rebuilt.
n/netatalk-3.1.11-i586-1.txz: Upgraded.
extra/linux-4.14.52-nosmp-sdk/*: Upgraded.
extra/pure-alsa-system/sox-14.4.2-i586-6_alsa.txz: Rebuilt.
