Novosti u *current* -u
Post Napisano: 25 Aug 2012, 02:54
Fri Aug 24 20:08:37 UTC 2012
This is Slackware 14.0 release candidate 3, and is hopefully the last stop
on our long road to a stable Slackware release soon. After hearing that
the 3.4.x kernel series will have long term support, I tested 3.4.9 hoping
that it would prove stable enough to use that as the release kernel, but
there are problems with an oops in kernel/time/clocksource.c every few boots.
Given that the 3.2.x series has been very stable, it seems prudent to stick
with that for release, and 3.2.28 is going to be the release kernel. So,
one more round of testing. Let me know if there are any problems. Thanks!
a/aaa_base-14.0-i486-5.txz: Rebuilt.
Added /etc/os-release.
Touched /etc/slackware-version to bring the datestamp closer to release.
a/btrfs-progs-20120821-i486-1.txz: Upgraded.
There haven't been any changes in git since the last pull, but this
package needed a rebuild anyway to get rid of the warnings in the
slack-desc that are no longer applicable.
Thanks to Jens Rottmann.
a/e2fsprogs-1.42.5-i486-1.txz: Upgraded.
a/glibc-solibs-2.15-i486-5.txz: Rebuilt.
a/glibc-zoneinfo-2012e_2012e-noarch-5.txz: Rebuilt.
Upgraded to tzcode2012e and tzdata2012e.
a/kbd-1.15.3-i486-2.txz: Rebuilt.
Added .gz to three patches in the SlackBuild that weren't being applied.
Thanks to guru.
a/kernel-generic-3.2.28-i486-1.txz: Upgraded.
a/kernel-generic-smp-3.2.28_smp-i686-1.txz: Upgraded.
a/kernel-huge-3.2.28-i486-1.txz: Upgraded.
a/kernel-huge-smp-3.2.28_smp-i686-1.txz: Upgraded.
a/kernel-modules-3.2.28-i486-1.txz: Upgraded.
a/kernel-modules-smp-3.2.28_smp-i686-1.txz: Upgraded.
a/lilo-23.2-i486-3.txz: Rebuilt.
Removed upstream liloconfig perl script.
Thanks to dr. s.
a/mkinitrd-1.4.7-i486-5.txz: Rebuilt.
Added a -B option to scan for Btrfs multi-device filesystems.
Thanks to Aaron W. Hsu.
Fixed grep to build load_kernel_modules script correctly.
Thanks to burdi01 on LQ.
a/shadow-4.1.4.3-i486-6.txz: Rebuilt.
Patched adduser to add "lp" (needed for scanning).
Thanks to Niki Kovacs.
a/syslinux-4.05-i486-2.txz: Rebuilt.
Patched a bug in altmbr handling.
Thanks to Ruarí Ødegaard.
a/udev-182-i486-4.txz: Rebuilt.
Commented out the entries in /lib/modprobe.d/isapnp.conf to fix
the error attempting to load rtc_cmos. Thanks to GazL.
ap/cdrtools-3.01a08-i486-1.txz: Upgraded.
Fixes a bug where ISO images do not conform to the ECMA199 standard.
Thanks to Ady Forum.
ap/mc-4.8.1.4-i486-1.txz: Upgraded.
This fixes a bug where data can be lost when trying to move files to a
full partition, as well as some other bugs.
Thanks to Alex Bukhansky.
ap/powertop-2.1-i486-1.txz: Upgraded.
Thanks to bnguyen on LQ.
ap/slackpkg-2.82.0-noarch-7.tgz: Rebuilt.
Updated mirrors list for Slackware 14.0. Thanks to Jordan Clarke.
ap/soma-2.8.5-noarch-1.txz: Upgraded.
Thanks to David Woodfall.
ap/sqlite-3.7.13-i486-1.txz: Upgraded.
d/gdb-7.5-i486-1.txz: Upgraded.
Needed for x32 support.
d/kernel-headers-3.2.28_smp-x86-1.txz: Upgraded.
d/nasm-2.10.04-i486-1.txz: Upgraded.
This resolves bugs when using the AVX instruction set.
Thanks to Konrad Rzepecki.
d/perl-5.16.1-i486-1.txz: Upgraded.
Also upgraded to DBI-1.622 and XML-Simple2.20.
k/kernel-source-3.2.28_smp-noarch-1.txz: Upgraded.
l/QScintilla-2.6.1-i486-3.txz: Rebuilt.
Linked shared libraries into /usr/lib${LIBDIRSUFFIX}, fixing some apps
compiled with cmake. Thanks to Dhaby Xiloj.
l/db48-4.8.30-i486-2.txz: Rebuilt.
Removed broken (and unneeded) /usr/include/db4 symlink.
Thanks to Francisco Ambrozio.
l/glibc-2.15-i486-5.txz: Rebuilt.
l/glibc-i18n-2.15-i486-5.txz: Rebuilt.
l/glibc-profile-2.15-i486-5.txz: Rebuilt.
l/qt-4.8.2-i486-3.txz: Rebuilt.
Patched crash bugs in JIT.
Thanks to Heinz Wiesinger.
n/curl-7.27.0-i486-2.txz: Rebuilt.
Fixed syntax error in /usr/bin/curl-config.
Thanks to Dan Church.
n/dhcp-4.2.4_P1-i486-1.txz: Upgraded.
This fixes memory leaks, denial of service vulnerabilities, and
disallows packets with zero length client ids (not valid according to
RFC 2132 section 9.14).
https://kb.isc.org/article/AA-00736" onclick="window.open(this.href);return false;
http://cve.mitre.org/cgi-bin/cvename.cg ... -2011-4539" onclick="window.open(this.href);return false;
http://cve.mitre.org/cgi-bin/cvename.cg ... -2011-4868" onclick="window.open(this.href);return false;
http://cve.mitre.org/cgi-bin/cvename.cg ... -2012-3954" onclick="window.open(this.href);return false;
n/httpd-2.4.3-i486-1.txz: Upgraded.
Fixes many bugs and these security issues:
*) SECURITY: CVE-2012-3502 (cve.mitre.org)
mod_proxy_ajp, mod_proxy_http: Fix an issue in back end
connection closing which could lead to privacy issues due
to a response mixup. PR 53727. [Rainer Jung]
*) SECURITY: CVE-2012-2687 (cve.mitre.org)
mod_negotiation: Escape filenames in variant list to prevent an
possible XSS for a site where untrusted users can upload files to
a location with MultiViews enabled. [Niels Heinen <heinenn google.com>]
http://cve.mitre.org/cgi-bin/cvename.cg ... -2012-2687" onclick="window.open(this.href);return false;
http://cve.mitre.org/cgi-bin/cvename.cg ... -2012-3502" onclick="window.open(this.href);return false;
n/netatalk-2.2.3-i486-1.txz: Upgraded.
This branch of netatalk is required to operate with OS X 10.7 or higher.
I used --enable-ddp to keep AppleTalk services, but is anyone using that?
Thanks to Winston Niles.
n/php-5.4.6-i486-1.txz: Upgraded.
n/samba-3.6.7-i486-1.txz: Upgraded.
n/wireless-tools-29-i486-9.txz: Rebuilt.
Use several tests to see if a device is wireless. Depending on kernel
options or drivers, some of the tests may yield a false negative, but
with a combination of tests the reliability should be good.
Thanks to Tim Thomas for the bug report.
Use sed to convert the MAC address to uppercase.
Thanks to GazL.
Convert `` syntax to $()
x/xorg-server-1.12.3-i486-2.txz: Rebuilt.
Changed Build Operating System to "Slackware 14.0 Slackware Linux Project".
Thanks to lotar on LQ.
x/xorg-server-xephyr-1.12.3-i486-2.txz: Rebuilt.
x/xorg-server-xnest-1.12.3-i486-2.txz: Rebuilt.
x/xorg-server-xvfb-1.12.3-i486-2.txz: Rebuilt.
xap/audacious-3.3.1-i486-2.txz: Rebuilt.
Include the duplicated AUTHORS and COPYING files, as the "About Audacious"
menu choice requires them. Thanks to tomac.pl on LQ.
xap/gnuplot-4.6.0-i486-1.txz: Upgraded.
Seems like a safe enough last-minute request.
Thanks to Greg Tourte.
extra/linux-3.2.28-nosmp-sdk/*: Rebuilt.
isolinux/initrd.img: Rebuilt.
Upgraded to Linux kernel 3.2.28.
kernels/*: Upgraded.
Post Napisano: 05 Sep 2012, 10:23
Izmene od utorka 04.09.2012.
Slackware 64bit
a/aaa_elflibs-14.0-x86_64-4.txz: Rebuilt.
a/coreutils-8.19-x86_64-1.txz: Upgraded.
       Upgraded for some important bugfixes, including possible data loss in
       "sort" output.
a/eject-2.1.5-x86_64-3.txz: Rebuilt.
       Fixed "eject -T". Thanks to Darrell Anderson.
a/etc-14.0-x86_64-1.txz: Upgraded.
       Fixed root $path in /etc/csh.login.new.
       Thanks to Goran Lazic.
a/grep-2.14-x86_64-1.txz: Upgraded.
       Upgraded for some important bugfixes. This fixes a matching bug when
       using a multibyte locale, and merges a more refined patch from upstream
       for the false detection of small text files as binary on certain
       filesystems (including Btrfs).
a/mkinitrd-1.4.7-x86_64-6.txz: Rebuilt.
       Fixed sed substitution for README.initrd.
       Thanks to D1ver on LQ.
l/pygobject-2.28.6-x86_64-2.txz: Rebuilt.
       Patched type mismatch.
       Thanks to wadsworth on LQ.
n/gnutls-3.0.23-x86_64-1.txz: Upgraded.
n/netatalk-2.2.3-x86_64-2.txz: Rebuilt.
       Handle atalkd.conf.new and papd.conf.new in doinst.sh.
       Thanks to elyk on LQ.
       Fixed size of a full installation in setup (7.3GB).
       Added comment=x-gvfs-show to /dev/cdrom line in /etc/fstab.
Slackware 32bit
a/aaa_elflibs-14.0-i486-4.txz: Rebuilt.
a/coreutils-8.19-i486-1.txz: Upgraded.
       "sort" output.
a/eject-2.1.5-i486-3.txz: Rebuilt.
a/etc-14.0-i486-1.txz: Upgraded.
a/grep-2.14-i486-1.txz: Upgraded.
a/mkinitrd-1.4.7-i486-6.txz: Rebuilt.
l/pygobject-2.28.6-i486-2.txz: Rebuilt.
n/gnutls-3.0.23-i486-1.txz: Upgraded.
n/netatalk-2.2.3-i486-2.txz: Rebuilt.
Post Napisano: 07 Sep 2012, 23:21
Četvrtak, 06.09.2012.
Slackware 64bitni
Thu Sep 6 21:58:57 UTC 2012
a/dcron-4.5-x86_64-3.txz: Rebuilt.
       Fixed run-parts to only output stderr, so that cron will only send mail
       in the event that a script runs into errors.
       Thanks to Barcoboy on LQ.
a/sysvinit-scripts-2.0-noarch-7.txz: Rebuilt.
       In rc.S, don't run cryptsetup three times in a loop, since it will already
       allow three password attempts by default.
       Thanks to Michael L. Semon.
Slackware 32bitni
a/dcron-4.5-i486-3.txz: Rebuilt.
Post Napisano: 08 Sep 2012, 13:38
07.09.2012. još neke manje izmene
Slackware 64bit
a/dcron-4.5-x86_64-4.txz: Rebuilt.
       After following the discussion about it on LQ, it seems better to not
       direct script output in run-parts to /dev/null, since the default crontab
       does that already. That way if someone wants to get cron job output
       mailed to them it's easy to do by editing the crontab. Thanks to NoStressHQ.
a/sysvinit-scripts-2.0-noarch-8.txz: Rebuilt.
       Updated rescan-scsi-bus and patched around a test that fails.
       Thanks to slacktroll on LQ.
xap/mozilla-firefox-15.0.1-x86_64-1.txz: Upgraded.
       This is a bugfix release.
       Updated /sbin/rescan-scsi-bus.
Slackware 32bit
a/dcron-4.5-i486-4.txz: Rebuilt.
xap/mozilla-firefox-15.0.1-i486-1.txz: Upgraded.
Post Napisano: 09 Sep 2012, 12:43
08.09.2012. neke manje izmene
Slackware 32bit
ap/mc-4.8.4-i486-1.txz: Upgraded.
       The stable verson of mc has several known, annoying bugs. They are fixed in
       this version... hopefully without too many new ones.
xap/xine-lib-1.1.21-i686-1.txz: Upgraded.
       This is a bugfix release, and had flown under the radar here due to previous
       1.2.x releases. I've tested it and it at least works as well as the package
       it replaces. With phonon-xine deprecated, I'm not sure how long Xine will
       be included in Slackware, but this update doesn't seem to hurt so we'll take
       it. Thanks to Willy Sudiarto Raharjo.
xap/xine-ui-0.99.7-i686-1.txz: Upgraded.
       This is a bugfix release. Thanks to Willy Sudiarto Raharjo.
Slackware 64bit
ap/mc-4.8.4-x86_64-1.txz: Upgraded.
xap/xine-lib-1.1.21-x86_64-1.txz: Upgraded.
xap/xine-ui-0.99.7-x86_64-1.txz: Upgraded.
09.09.2012. neke manje izmene manjih izmena od 08.09.2012. :)
Slackware 64bit
xap/xine-ui-0.99.5-x86_64-3.txz: Reverted.
       The file open shortcut appears to be broken in the newer xine-ui. Probably
       safer to just revert it at this point. The new xine-lib seems OK, though.
Slackware 32bit
xap/xine-ui-0.99.5-i686-3.txz: Reverted.
Post Napisano: 11 Sep 2012, 10:28
10.09.2012. čak 2 puta stigao update
Slackware 32bit:
Mon Sep 10 02:55:29 UTC 2012
ap/hplip-3.12.9-i486-1.txz: Upgraded.
       This update fixes some known scanning bugs.
       Thanks to Ken Zalewski.
ap/mc-4.8.4-i486-2.txz: Rebuilt.
       Patched file save problem caused by a missing '/' in the tmp directory path.
       Thanks to guanx on LQ.
n/bluez-4.99-i486-2.txz: Rebuilt.
       Enable the audio socket in audio.conf.
xap/mozilla-thunderbird-15.0.1-i486-1.txz: Upgraded.
xap/xine-ui-0.99.6-i686-1.txz: Upgraded.
       Willy Sudiarto Raharjo claims this one is better than 0.99.5, so I guess we
       will see (quickly). After this, I'm going to be far more resistant to any
       attempts to try to resume the devel cycle. ;-)
Mon Sep 10 22:19:55 UTC 2012
a/sysvinit-scripts-2.0-noarch-9.txz: Rebuilt.
       In rc.M, make sure we are actually returning from runlevel 1 before trying
       to restart udev. Thanks to Cal Peake.
a/udev-182-i486-5.txz: Rebuilt.
       Don't enable autosuspend for some HID devices. With a 3.5+ kernel, this
       might cause these input devices to become non-responsive.
       Thanks to Patrick Verner.
ap/alsa-utils-1.0.26-i486-1.txz: Upgraded.
       Removed alsaconf, which does not work with kmod.
l/alsa-lib-1.0.26-i486-1.txz: Upgraded.
l/gdk-pixbuf2-2.26.1-i486-2.txz: Rebuilt.
       Patched update-gdk-pixbuf-loaders to fix output on multilib systems.
l/seamonkey-solibs-2.12.1-i486-1.txz: Upgraded.
x/scim-1.4.14-i486-2.txz: Rebuilt.
       Compile using --with-gtk-version=2 to fix problems with scim-setup.
       Thanks to Thomas Choi and alienBOB.
xap/seamonkey-2.12.1-i486-1.txz: Upgraded.
Slackware 64bit
ap/hplip-3.12.9-x86_64-1.txz: Upgraded.
ap/mc-4.8.4-x86_64-2.txz: Rebuilt.
n/bluez-4.99-x86_64-2.txz: Rebuilt.
xap/mozilla-thunderbird-15.0.1-x86_64-1.txz: Upgraded.
xap/xine-ui-0.99.6-x86_64-1.txz: Upgraded.
a/udev-182-x86_64-5.txz: Rebuilt.
ap/alsa-utils-1.0.26-x86_64-1.txz: Upgraded.
l/alsa-lib-1.0.26-x86_64-1.txz: Upgraded.
l/gdk-pixbuf2-2.26.1-x86_64-2.txz: Rebuilt.
l/seamonkey-solibs-2.12.1-x86_64-1.txz: Upgraded.
x/scim-1.4.14-x86_64-2.txz: Rebuilt.
xap/seamonkey-2.12.1-x86_64-1.txz: Upgraded.
Post Napisano: 12 Sep 2012, 06:35
12.09.2012.
Slackware64:
a/sysvinit-scripts-2.0-noarch-10.txz: Rebuilt.
       Use start parameter when running /etc/rc.d/rc.atalk.
n/ca-certificates-20120623-noarch-2.txz: Rebuilt.
       Use an installer script to make sure that update-ca-certificates works on
       a fresh installation. Thanks to DarkVision on LQ.
n/netatalk-2.2.3-x86_64-3.txz: Rebuilt.
       Switched to a better rc.atalk that parses the contents of netatalk.conf.
       Thanks to gerasimos_h.
Slackware32:
n/netatalk-2.2.3-i486-3.txz: Rebuilt.
Post Napisano: 12 Sep 2012, 13:19
Nema dugme uredi inače bih dopunio prethodni post.
Još jedan update sleteo jutros.
Slackware 64bit
n/netatalk-2.2.3-x86_64-4.txz: Rebuilt.
       Fix the install script so that it leaves rc.atalk.new when the package is
       upgraded instead of deleting it and leaving nothing but the old rc.atalk.
       Thanks to Sorin Mitrica.
Slackware 32bit
n/netatalk-2.2.3-i486-4.txz: Rebuilt.
Post Napisano: 15 Sep 2012, 16:14
14.09.2012.
Slackware 64bit
Fri Sep 14 20:29:40 UTC 2012
n/dhcp-4.2.4_P2-x86_64-1.txz: Upgraded.
       An issue with the use of lease times was found and fixed. Making certain
       changes to the end time of an IPv6 lease could cause the server to abort.
       Thanks to Glen Eustace of Massey University, New Zealand for finding this
       issue. [ISC-Bugs #30281]
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2012-3955
n/php-5.4.7-x86_64-1.txz: Upgraded.
Fri Sep 14 01:16:31 UTC 2012
a/less-451-x86_64-1.txz: Upgraded.
       This is a bugfix release. (Seems more or less safe ;-)
a/patch-2.7-x86_64-1.txz: Upgraded.
       This version of patch ignores destination filenames that are absolute or
       that contain a component of "..", unless such a filename is provided as
       an argument.
       http://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2010-4651
a/shadow-4.1.4.3-x86_64-7.txz: Rebuilt.
       Fixed adduser and login.defs to add or suggest group "scanner", which
       might still be required by third party scanner drivers.
       Thanks to Alex Baer.
a/sysvinit-scripts-2.0-noarch-11.txz: Rebuilt.
       Edited rc.S to talk about the 3.x kernel in the udev comments.
       Edited rc.M to run rc.udev in all cases again, not just when returning
       from runlevel 1. Even if udev is running already, the additional
       trigger may be required in order to get some devices working. The
       comment that indicated it should only be run when returning from
       runlevel 1 came from a time when the only purpose for rc.udev was to
       start it if it wasn't running. The behavior has changed since then, so
       the comment has been fixed. Guess I should have remembered the words of:
       fortune -m Storer
l/libsoup-2.38.1-x86_64-2.txz: Rebuilt.
       Added the .la files back, as it's not yet safe to eliminate them in this
       package. Thanks to Erik Hanson.
n/bind-9.9.1_P3-x86_64-1.txz: Upgraded.
       This update fixes a security issue where named could crash on a specially
       crafted record. [RT #30416]
Slackware 32bit
n/dhcp-4.2.4_P2-i486-1.txz: Upgraded.
n/php-5.4.7-i486-1.txz: Upgraded.
a/less-451-i486-1.txz: Upgraded.
a/patch-2.7-i486-1.txz: Upgraded.
       an argument.
a/shadow-4.1.4.3-i486-7.txz: Rebuilt.
       fortune -m Storer
l/libsoup-2.38.1-i486-2.txz: Rebuilt.
n/bind-9.9.1_P3-i486-1.txz: Upgraded.
Post Napisano: 20 Sep 2012, 09:49
19.09.2012. Slackware 14 RC5
Da, lepo ste pročitali RC5 :grlj:
Slackware 64bit:
Wed Sep 19 23:52:16 UTC 2012
Here we go one more time with Slackware 14.0 release candidate 5.
Really, this time it is not a drill! Everything is in place and
ready to release at this point, and unless there's some kind of
showstopper found (which doesn't seem too likely after all the
testing that's happened), the release can be expected soon.
After careful consideration and a considerable amount of internal
testing I did relent to give the kernel one more bump to 3.2.29,
so of course 3.2.30 was released a couple of hours ago. ;-)
But that's not a showstopper, and it seems to be time to get off
the never-ending kernel upgrade treadmill until the next cycle
begins. Speaking of kernels, I added sample .configs for all the
3.x kernel branches in /testing. So test away, and if there are
any new problems (or old ones that we missed), let us know soon!
a/glibc-solibs-2.15-x86_64-7.txz: Rebuilt.
a/glibc-zoneinfo-2012f_2012f-noarch-7.txz: Rebuilt.
       Upgraded to tzcode2012f and tzdata2012f.
a/kernel-generic-3.2.29-x86_64-1.txz: Upgraded.
a/kernel-huge-3.2.29-x86_64-1.txz: Upgraded.
a/kernel-modules-3.2.29-x86_64-1.txz: Upgraded.
a/patch-2.7-x86_64-2.txz: Rebuilt.
       Applied two upstream git commits to fix bugs which could cause target
       files to be removed or truncated. Thanks to Qun-Ying.
d/git-1.7.12.1-x86_64-1.txz: Upgraded.
d/kernel-headers-3.2.29-x86-1.txz: Upgraded.
d/slacktrack-2.12-x86_64-1.txz: Upgraded.
       This is a bugfix release. Thanks to Stuart Winter.
d/subversion-1.7.6-x86_64-1.txz: Upgraded.
k/kernel-source-3.2.29-noarch-1.txz: Upgraded.
l/glibc-2.15-x86_64-7.txz: Rebuilt.
l/glibc-i18n-2.15-x86_64-7.txz: Rebuilt.
l/glibc-profile-2.15-x86_64-7.txz: Rebuilt.
n/samba-3.6.8-x86_64-1.txz: Upgraded.
n/vsftpd-3.0.2-x86_64-1.txz: Upgraded.
       This update contains a seccomp sandbox policy fix which stops session
       crashes when listing large directories logged in as a real local user.
       Thanks to Martin.
       Upgraded to Linux kernel 3.2.29.
testing/source/config-testing-3.4.11/*: Added.
       Sample .config files for the 3.4.11 Linux kernel.
testing/source/config-testing-3.5.4/*: Added.
       Sample .config files for the 3.5.4 Linux kernel.
testing/packages/config-testing-3.6-rc4*: Added.
       Sample .config files for the 3.6-rc4 Linux kernel.
Slackware 32bit:
a/glibc-solibs-2.15-i486-7.txz: Rebuilt.
a/kernel-generic-3.2.29-i486-1.txz: Upgraded.
a/kernel-generic-smp-3.2.29_smp-i686-1.txz: Upgraded.
a/kernel-huge-3.2.29-i486-1.txz: Upgraded.
a/kernel-huge-smp-3.2.29_smp-i686-1.txz: Upgraded.
a/kernel-modules-3.2.29-i486-1.txz: Upgraded.
a/kernel-modules-smp-3.2.29_smp-i686-1.txz: Upgraded.
a/patch-2.7-i486-2.txz: Rebuilt.
d/git-1.7.12.1-i486-1.txz: Upgraded.
d/kernel-headers-3.2.29_smp-x86-1.txz: Upgraded.
d/slacktrack-2.12-i486-1.txz: Upgraded.
d/subversion-1.7.6-i486-1.txz: Upgraded.
k/kernel-source-3.2.29_smp-noarch-1.txz: Upgraded.
l/glibc-2.15-i486-7.txz: Rebuilt.
l/glibc-i18n-2.15-i486-7.txz: Rebuilt.
l/glibc-profile-2.15-i486-7.txz: Rebuilt.
n/samba-3.6.8-i486-1.txz: Upgraded.
n/vsftpd-3.0.2-i486-1.txz: Upgraded.
       Thanks to Martin.
extra/linux-3.2.29-nosmp-sdk/*: Rebuilt.
Users browsing this forum: No registered users and 42 guests
